gosha
    365
Информация о gosha
  • День рождения 22.05.1972
3 677 просмотров профиля
  1. https://www.newark.com/productimages/standard/en_US/04M5427-40.jpg На фотке м/сх маркировка: PIC16F676-ICD В простой PIC16F676 - не доклали отладчик ?
  2. #include <xc.h> #pragma config FOSC = INTRCCLK // Oscillator Selection bits (INTOSC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN) #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled) #pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled) #pragma config MCLRE = ON // RA3/MCLR pin function select (RA3/MCLR pin function is MCLR) #pragma config BOREN = ON // Brown-out Detect Enable bit (BOD enabled) #pragma config CP = OFF // Code Protection bit (Program Memory code protection is disabled) #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled) /*========================================================*/ void __interrupt() timer_isr(void) { if(TMR0IF==1) { TMR0= 101; TMR0IF=0; } if(TMR1IF==1) { TMR1= 101; TMR1IF=0; } RC2=~RC2; } /*========================================================*/ void main(void) { int i; TRISC2= 0; TRISC3= 0; OPTION_REG = 0x07; // Timer0 with external freq and 32 as prescalar TMR0=100; // Load the time value for 1ms delay TMR0IE=1; //Enable timer interrupt bit in PIE1 register GIE=1; //Enable Global Interrupt PEIE=1; //Enable the Peripheral Interrupt while(1) { for(i=0 ; i < 10000; i++) continue; RC3=0; for(i=0; i < 10000; i++) continue; RC3=1; } } Connecting to MPLAB PICkit 3... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.56.09 Firmware type..............Midrange Target voltage detected Target device PIC16F630 found. Device Revision ID = 4 Device Erased... Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x63 configuration memory Programming/Verify complete The target device is not ready for debugging. Please check your configuration bit settings and program the device before
  3. pic16f628а внутрисхемную отладку не поддерживает ? Ругается: "Programming/Verify complete The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings."
  4. Марку транзистора не подскажете ? Который на фото.
  5. MPLAB-X unresolved identifier TRISA Проект компилируется, и работает. А редактор среды подсвечивает ошибку. Ubunta Как победить ?
  6. В этой статье принимаемый сигнал усиливается, и излучается обратно. Вероятно, в противофазе ? Это более эффективный вариант ? How to Make A Drone Jammer? (Step by Step Instructions) С панельной антенной, спектр получается немного лучше. Спасибо.
  7. Спасибо. Что означает глушить интрмодуляцией ? Что означает глушить блокированием ? Применение блоков 50 Вт (вместо 10Вт которые сейчас) решит проблему подавления малоразмерных БПЛА Mavic и Autel ? Например, таких: UAV jamming module WIFI UAV jammer eviscer 900MHZ 1.2G 1.5G 2.4G 5.8G 30W 50W Transmitter Power БПЛА Mavic 3 (EIRP) 2.4 GHz: ≤33 dBm (FCC); ≤20 dBm (CE/SRRC/MIC) 5.8 GHz: ≤33 dBm (FCC), ≤30 dBm(SRRC), ≤14 dBm(CE) Почему советуете рупорную антенну ? Один из критериев: удобство пользования, компактность. Исходя из этого, панельная антенна намного хуже вариант ? У KPM12-2400/5000 крокса неплохая диаграмма направленности. И мощность до 50 Вт. Измерительная WiFi антенна KPM12-2400/5000 Получится такой конструктив: D4 Handheld Portable Drone Signal Jammer Какую портативную рупороную антенну по-советуете ?
  8. Посоветуйте модули для самодельного ружья против дронов 2.4 ГГц ? Которые модулировали бы несущую шумом в диапазоне частот 2400 - 2483,5 МГц. Купил блоки на алиэкстпрессе. - Не глушат БПЛА. https://aliexpress.ru/item/1005005537625980.html Похоже, они не белым шумом модулируют несущую, а качающейся частотой. м/сх VCO SM1550 установлена. SM1550 - м/сх VCO voltage controlled oscillator 1450-1650MHZ https://aliexpress.ru/item/32846150252.html
  9. Как называется эта клейкая тонкая черная ткань для шлейфов ? Где приобрести ?
  10. https://docs.xilinx.com/r/2021.1-English/ug900-vivado-logic-simulation/Running-the-Vivado-Simulator-in-Batch-Mode https://support.xilinx.com/s/article/63986?language=en_US
  11. https://blog.csdn.net/yihuajack/article/details/120714268 https://support.xilinx.com/s/question/0D52E00006hpSEgSAM/bd-412088?language=en_US
  12. coe-File-converter-for-FPGA-programming-master.zip -прикрепленный файл coe-File-converter-for-FPGA-programming-master.zip
  13. У меня, задание ручками output_delay только ухудшило ситуацию. Из-за тупости, не смог расчитать верные изначения.. Задание только частот всех синхросигналов - оказывалось всегда достаточным, если топология не кривая. Убрать set_output_delay совсем не пробовали ?
  14. Если поможет, проект pcie платы Ethernet c SFP 1G - прикрепленный файл Без DMA. Но, подключенное через SFP, - пингуется. Для платы http://www.alinx.com/en/index.php/default/content/121.html Eth_vnniftri.tar.gz
