Перейти к содержанию
Может уже обсуждалось. Как побороть ошибку билда кикада под 7-й виндой (с помощью KiCadWinbuilder):
-- Checking for GLEW
-- Downloading
You have not informed bzr of your Launchpad ID, and you must do this to
write to Launchpad or access private data.  See "bzr help launchpad-login".
bzr: ERROR: exceptions.UnicodeEncodeError: 'ascii' codec can't encode characters in position 34-43: ordinal not in range(128)
Traceback (most recent call last):
  File "bzrlib\commands.pyo", line 930, in exception_to_return_code
  File "bzrlib\commands.pyo", line 1141, in run_bzr
  File "bzrlib\commands.pyo", line 673, in run_argv_aliases
  File "bzrlib\commands.pyo", line 697, in run
  File "bzrlib\cleanup.pyo", line 136, in run_simple
  File "bzrlib\cleanup.pyo", line 166, in _do_with_cleanups
  File "bzrlib\builtins.pyo", line 1649, in run
  File "bzrlib\branch.pyo", line 1463, in create_checkout
  File "bzrlib\bzrdir.pyo", line 906, in create_workingtree
  File "bzrlib\workingtree_4.pyo", line 1565, in initialize
  File "bzrlib\transform.pyo", line 2535, in build_tree
  File "bzrlib\transform.pyo", line 2590, in _build_tree
  File "bzrlib\progress.pyo", line 116, in update
  File "bzrlib\ui\text.pyo", line 374, in _progress_updated
  File "bzrlib\ui\text.pyo", line 554, in show_progress
  File "bzrlib\ui\text.pyo", line 536, in _repaint
  File "bzrlib\ui\text.pyo", line 440, in _show_line
bzr 2.6b1 on python 2.6.6 (Windows-7-6.1.7601-SP1)
arguments: ['bzr', 'co', '--lightweight', 'lp:glew-cmake', 'glew-cmake']
plugins: bzrtools[2.5.0], changelog_merge[2.6b1], colo[0.4.0],
    explorer[1.3.0dev], fastimport[0.14.0dev], git[0.6.8dev],
    launchpad[2.6b1], loom[2.3.0dev], netrc_credential_store[2.6b1],
    news_merge[2.6b1], pipeline[1.4.0], qbzr[0.23.0dev], rewrite[0.6.4dev],
    svn[1.2.2dev], upload[1.2.0dev], xmloutput[0.8.8]
encoding: 'cp1251', fsenc: 'mbcs', lang: None
*** Bazaar has encountered an internal error.  This probably indicates a
    bug in Bazaar.  You can help us fix it by filing a bug report at
        https://bugs.launchpad.net/bzr/+filebug
    including this traceback and a description of the problem.
ERROR Checking out source code!
ERROR Bazaar said:
Для продолжения нажмите любую клавишу . . .
Изменено пользователем ArtDenis
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Потрудитесь прочитать предыдущую страницу.
Ссылка на сообщение
Отписываюсь по результату. Забегая наперед, скажу, ничего не получилось.
В общем поставил на виртуальную машину WinXP SP3. Скачал kicadwinbuilder 3.4, попробовал, результат тот же, что и в Win7. Решил потом попробовать с kicadwinbuilder 3.3, результат тот же, не собирается kicad, но что заметил, в командной строке проходит проверка на компилятор MinGW. Отдельно я его не ставил, может в этом проблема? Если да, то посоветуйте, пожалуйста, что конкретно нужно поставить. Еще есть предположение на то, что быть может на компьютер нужно установить какой-то SDK, ведь не может быть, что на одном компьютере kicad собирается, а на другом нет, явно, что чего-то не хватает.
Ссылка на сообщение
Нет, отдельно его ставить не нужно - он идет в комплекте с kicadwinbuilder.
kicadwinbuilder и есть такой SDK.
Ссылка на сообщение
Тогда даже не знаю, в чем может быть такое дикое нежелание kicadwinbuilderа собрать сборку на моих двух компьютерах. Единственное, что я не делал, так это то, что не давал своих Launcpad ID, но, думаю, что это не так важно.
Ссылка на сообщение
Может стоит попробовать собрать из корня диска С: ?)) Знаю, звучит глупо, но мало ли...
P.S. Я имею в виду c:\kicad-winbuilder\... вместо d:\...
Изменено пользователем Барановский Константин
Ссылка на сообщение
Пробовал, даже сократил еще больше имя, пробовал из директории c:\kicad\... и никак. У меня такое чувство, что чего-то не хватает установленного из программ того, что стоит у вас.
Ссылка на сообщение
Так а на чем у вас сейчас процесс заканчивается? По какой ошибке вываливается? Там есть папочка с логами, прикрепите сюда архив с ее содержимым.
Ссылка на сообщение
Заканчивается на том же самом месте, что и на Win 7. Ну в общем, выкладываю логи, посмотрите, пожалуйста, может что-то увидите
logs.zip
Ссылка на сообщение
Все указывает на то, что у Вас проблемы с bzr.exe. На сколько помню Вам уже писали, что bzr.exe кривой в сборке KiCad Winbuilder.
У меня были подобные чудеса. Из-за того, что bzr.exe падал на каком-то этапе при клонировании каждого из хранилищ, то ошибки потом при сборке с помощью cmake появлялись в различных местах.
Мне помогло следующее: удалял из KiCad Winbuilder полностью содержимое директории, в которой находится программа bzr. Далее внутрь этой директории копировал содержимое директории C:/Program files/bzr (bzr ставил под винду штатным способом с помощью инсталлятора bzr, скачанного с официального сайта bzr). Точные наименования директорий не укажу сейчас, поскольку нет под рукой той машины с виндой.
После этого нужно обязательно удалить все директории с закаченными клонами хранилищ (если не ошибаюсь, хранилища закачиваются в директорию src). Иначе KiCad Winbuilder больше не будет пытаться склонировать хранилища, которые он пытался дать команду склонировать, а они недоклонировались и находятся теперь в разрушенном состоянии.
Ссылка на сообщение
Это всё хорошо, но я не понял про ГОСТовские дополнения. Как их туда вклячить?
AHTOXA
Сборку 4289 можно советовать только врагу. Куча глюков, и откатиться нельзя - старые версии не понимают формат его PCB файла, а в этой версии больше нет возможности сохранения в старом формате.
Ссылка на сообщение
AHTOXA
Пардон. Я не советовал какую-то конкретную сборку, я просто подсказал, где можно взять готовые.
А какая версия сейчас правильная?
Ссылка на сообщение
Если есть интерес к возможности ГОСТ сборки под винду, давайте создам ветку на базе lp:kicad-winbuilder, туда внесу все изменения, которые для этого делал.
Ссылка на сообщение
Ребят, доброго времени суток! Вроде бы пошло, коллективный разум победил, спасибо всем за советы, завтра отпишу, что и как делал, если все пройдет до конца гладко.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
