Ken@t 0 March 29, 2008 Posted March 29, 2008 · Report post В общем, как побочный продукт основной деятельности, удалость создать OAL для Радуги и сделать ебут. -- Потихоньку сделаю БСП Debug channel initialized WCEPreloader Build Mar 29 2008 15:49:13 CPU 199987 KHz PCK 99993 KHz PLLB 95993 KHz Jump EBOOT preess any key Init Debug Serial OK! Press any key to unlock process Process unlocked Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Mar 23 2008 07:25:21 Microsoft Windows CE Ethernet Bootloader 1.0 for AT91RM9200 Rainbow board board (Mar 29 2008 : 15:52:40) Copyright (c) 2001 Microsoft Corporation Portions copyright (c) 2008 Kenat S&H Integration and development Bus Speed 99993 kHz CPU Speed 199987 kHz OEMPlatformInit: press a key to unlock system Performing POST...Successful Default: using Flash SPI Flash SPI selected SPI VirtualAllocCopy Succeeded PIO_SDC_TYPE VirtualAllocCopy Succeeded PIO_A VirtualAllocCopy Succeeded FMD_Init:Configure PIO OK SPI configured for serial data flash FMD_Init:SPI PDC configured! FMD_Init:Switch on DataFlash Card AT45DCB Nand Density = 0x38 Device sdf status=0xFF INFO: settings in flash are bad - storing defaults... WriteFlashSettings CFI_Erase_One_Block:: entering the function . Erase at address: 0x101E0000, bloc k is n°38 .... Press any key to break into configuration menu 65535 ... Press any key to break into configuration menu 65534 ... Main Menu: ---------------------------------------- 1. Network Settings 2. Flash Devices Settings 3. SDCard Settings 4. Boot Mode ESC. Exit (Continue...) Please make a selection: ЗЫ Аденео БСП смотрел и это продвинуло собственные раработки по Радуге. Quote Share this post Link to post Share on other sites More sharing options...
astro 0 April 1, 2008 Posted April 1, 2008 · Report post А где сейчас берут win ce? Интересно попробовать. Quote Share this post Link to post Share on other sites More sharing options...
denim 0 April 1, 2008 Posted April 1, 2008 · Report post А где сейчас берут win ce? Интересно попробовать. +1, а то я хотел на 9260 прикрутить :) Quote Share this post Link to post Share on other sites More sharing options...
Ken@t 0 April 1, 2008 Posted April 1, 2008 · Report post +1, а то я хотел на 9260 прикрутить :) Как и всегда берут здесь https://www.microsoft.com/windows/embedded/eval/trial.mspx Только для прикрутить надо много напочитать и BSP иметь. Quote Share this post Link to post Share on other sites More sharing options...
