Добрался до страницы 9 - всё нормально
лог консоли
cd D:/Tmp/23
# reading C:\modeltech_6.5b\win32/../modelsim.ini
do D:/Tmp/23/compile.do
# Copying C:\modeltech_6.5b\win32/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Warning: Copied C:\modeltech_6.5b\win32/../modelsim.ini to modelsim.ini.
#          Updated modelsim.ini.
# -- Compiling module cache
# -- Compiling module memory
# -- Compiling module proc
# Top level modules:
# 	cache
# 	memory
# 	proc
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Compiling package std_logic_util
# -- Compiling package body std_logic_util
# -- Loading package std_logic_util
# -- Compiling entity cache_set
# -- Compiling architecture only of cache_set
# -- Compiling entity top
# -- Compiling architecture only of top
vsim work.top
# vsim work.top
# ** Note: (vsim-3812) Design is being optimized...
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading work.top(only)#1
# Loading work.proc(fast)
# Loading work.cache(fast)
# Loading work.std_logic_util(body)
# Loading work.cache_set(only)#1
# Loading work.memory(fast)
run 100ns
#                   20: Starting Read/Write test
#                   20: Writing data=0000 to addr=00
#                   60: Write miss, picking set 3
run -all
#                  220: Writing data=0001 to addr=01
#                  260: Write miss, picking set 3
#                  420: Writing data=0002 to addr=02
#                  460: Write miss, picking set 3
#                  620: Writing data=0003 to addr=03
#                  660: Write miss, picking set 3
#                  820: Writing data=0004 to addr=04
#                  860: Write miss, picking set 3
#                 1020: Writing data=0005 to addr=05
#                 1060: Write miss, picking set 3
#                 1220: Writing data=0006 to addr=06
#                 1260: Write miss, picking set 3
#                 1420: Writing data=0007 to addr=07
#                 1460: Write miss, picking set 3
#                 1620: Writing data=0008 to addr=08
#                 1660: Write miss, picking set 3
#                 1820: Writing data=0009 to addr=09
#                 1860: Write miss, picking set 3
#                 2020: Reading from addr=00
#                 2060: Read hit to set 3
#                 2100: Reading from addr=01
#                 2140: Read hit to set 3
#                 2180: Reading from addr=02
#                 2220: Read hit to set 3
#                 2260: Reading from addr=03
#                 2300: Read hit to set 3
#                 2340: Reading from addr=04
#                 2380: Read hit to set 3
#                 2420: Reading from addr=05
#                 2460: Read hit to set 3
#                 2500: Reading from addr=06
#                 2540: Read hit to set 3
#                 2580: Reading from addr=07
#                 2620: Read hit to set 3
#                 2660: Reading from addr=08
#                 2700: Read hit to set 3
#                 2740: Reading from addr=09
#                 2780: Read hit to set 3
# Read/Write test done
# ** Note: $stop    : proc.v(75)
#    Time: 2820 ns  Iteration: 0  Instance: /top/p
# Break at proc.v line 75
На своем проекте у меня не ругается, но я хочу именно лабы. Мне непонятно даже, откуда берутся тестовые сигналы (прописаны в тестбенче?), хочу понять вообще основы моделирования, связь с квартусом, как пользоваться тестбенчами...
modelsim6.4a
Кстати, при выполненении do compile.do все проходит нормально, а двойной щелчек на top дает ошибку...
2 torik - вышеприведённые действия делал с файлами с директории "modelsim_data_6.2c.zip/modelsim_lab/modsim_lab1"
Да про них и речь
Версия моделсима какая? Не мог бы кто-нибудь попробовать эти лабы в версии 6.4а? А то споткнулся в самом начале, ошибка непойми о чем, какие действия можно предпринять неясно...
ModelSim SE 6.5b May 21 2009
6.4а снёс месяца 3 назад...
А чё?
Да и в любом случае, какого хрена, что это за ошибка, в чем ее суть? Ну не загрузить, а дальше что...
Это что, из-за того, что не было таблетки от жадности, поддерживает не более одного файла HDL?
Ну допустим, поставлю ModelSim SE 6.5b May 21 2009 - где взять сей инструмент с таблеткой вместе?
А чё?
Дизайны стали очень привязаны к специфике виртексов, а в 11-й версии аси - непринятие А-релизов.
судя по всему у вас МС не можен найти энтити задекларированные в топе.
Двойной щелчёк - это вроде
vsim work.top
таблетку могу намылить, сам МС с сайта качается ;)
У меня сейчас вообще моделсим альтера стартер, может мы говорим совершенно о разных вещах и я зря стараюсь запустить на нем эти лабы?
Да это и так ясно, но что я могу тут сделать, файлы-то есть, чего ему еще надо...
В этом как раз может быть проблема - у меня ж ModelSim SE 6.5b May 21 2009
Может альтеровцы подкрутили что :wassat:
Лог с консоли приведите, может проясниться что
Хочу вернуться к вопросу о моделсиме. Подскажите, где вообще можно что-то попроще почитать о тестбенчах, куда их прикручивать, как писать... А потом уже о моделсиме.
в тему про SV, там линки и книги
Мне бы что-то совсем простое, типа примера простенького тестбенча, как при этом должен выглядеть проект в квартусе, как его передать в моделсим и посмотреть что получается. Для начала что-то вроде счетчика, триггера....
Вот недавно где то выкладывал:
module countbit(
        input clk,             //такт...
        input [7:0] data,      //данные
        input load,            //загрузка данных
        output reg fin,        //флаг, счет закончен
        output reg [4:0] count //результат
    bit [7:0] tempbuff;
    always @ (posedge clk or posedge load) begin
      if(load) begin
        tempbuff <= data;
        fin <= 0;
        count <= 0;
      end
     else begin
        if(tempbuff[0]) begin
          tempbuff <= tempbuff >> 1;
          count++;
        end
      else fin <= 1;
     end
   end
endmodule
module test;
  bit clk;
  bit [7:0] data;
  bit load;
  bit fin;
  bit [4:0] count;
    initial begin
     clk = 0;
     data = 0;
     load = 0;
    #5 data = 8'b11001111;
    #5 load = 1;
    #2 load = 0;
    wait(fin == 1); //Ждать пока счет не закончен
    #5 data = 8'b10101011;
    #5 load =1;
    #2 load = 0;
    #5 $stop;
    end
    always #2 clk = ~clk;
countbit P1 (
   .clk(clk),
   .data(data),
   .load(load),
   .fin(fin),
   .count(count)
endmodule
Собственно программа подсчитыват количество бит прва на лево (с мл. бита) до первого значащего нуля. Не обязательно с самого начала создавать проект в квартусе. Можно сначало
в модель симе создать, писать, симулировать, а потом синтезировать в квартусе. Я сам все это поверхностно изучил, так, что не обессудь. Что не понятно в программе спрашивай, а так
создай проект в модель симе, просимулируй, должно быть все понятно.
следите за форумом, например здесь я выкладывал проект с простым тестбенчем
Iptash, спасибо. Как раз то что надо для понимания связи тестбенча и собственно описания девайса. Вот только моделсим 6.4а у меня тупит, похоже что он просто не работает, качаю 9.1...
А дальше буду вопросы как это в моделсиме запустить.
