_saper_ 0 9 января, 2014 Опубликовано 9 января, 2014 (изменено) · Жалоба Waldelk мне кажется что wvdial именно то что мне нужно. буду надеяться что в ядре планшета уже всё есть)) нашел даже коекакие инструкции 1) I never could get a 100% stable 3G connection 24/7 running. Sometimes they lose the connections (sometimes the provider is responsible for it, sometimes the usb-dongle itself). Newer dongles are better. 2) After testing betavine, and some other tools … I went back to wvdial … easy and 99% stable 3) you need 3 files wvdial & USB_ModeSwitch & USB_ModeSwitch_data. Important: wvdial has to be build for the Arm architecture, I don`t know, if this is done for the Raspberry Pi … if not (maybe larson ??? should contact carl at excito, who has done this for the excito bubba) 4) usb-dongle, there are a lot dongles on the market, but the often are the same. To start I would suggest a dongle which is not brand-new and Important: it should be in the USB_ModeSwitch_data, it saves a lot of time 5) Install wvdial & USB_ModeSwitch & USB_ModeSwitch_data per apt-get install … 6) Edit wvdial.conf with your provider data (this example is for drei.at) ------ /etc/wvdial.conf -------------- Code: Select all [Dialer Defaults] Area Code = Ask Password = 0 Auto DNS = 1 Baud = 460800 Carrier Check = 0 Compuserve = 0 Dial Command = ATD DialMessage1 = DialMessage2 = Force Address = ISDN = 0 Idle Seconds = 3000 Init1 = ATZ Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 Init3 = AT+CGDCONT=1,"IP","drei.at" Modem = /dev/ttyUSB0 Modem Type = Analog Modem New PPPD = yes Password = ; Phone = *99# Stupid Mode = 1 Username = ; Auto Reconnect = On ------ end of /etc/wvdial.conf ------ The best way is *NOT* to use SIM pin codes 6) Edit /etc/network/interfaces and add this lines: auto ppp0 iface ppp0 inet wvdial 7) Test Type * wvdial * and you should get a connection Contrl Z and then type bg restart the Raspberry Pi and you should 8) For setting up a dyndns.org address I use the linux-client: ddclient : http://sourceforge.net/apps/trac/ddclient/ 9) now you could connect to your Raspberry Pi – Drone with your dyndns.org adress и вот ещё ссылка http://www.starterkit.ru/html/index.php?na...=8028&num=3 жду пока приедет планшет, а потом решу что дальше заказывать :smile3046: Изменено 9 января, 2014 пользователем _saper_ Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Waldelk 0 10 января, 2014 Опубликовано 10 января, 2014 · Жалоба Waldelk мне кажется что wvdial именно то что мне нужно. буду надеяться что в ядре планшета уже всё есть)) нашел даже коекакие инструкции 1) I never could get a 100% stable 3G connection 24/7 running. Sometimes they lose the connections (sometimes the provider is responsible for it, sometimes the usb-dongle itself). Newer dongles are better. 2) After testing betavine, and some other tools … I went back to wvdial … easy and 99% stable 3) you need 3 files wvdial & USB_ModeSwitch & USB_ModeSwitch_data. Important: wvdial has to be build for the Arm architecture, I don`t know, if this is done for the Raspberry Pi … if not (maybe larson ??? should contact carl at excito, who has done this for the excito bubba) 4) usb-dongle, there are a lot dongles on the market, but the often are the same. To start I would suggest a dongle which is not brand-new and Important: it should be in the USB_ModeSwitch_data, it saves a lot of time 5) Install wvdial & USB_ModeSwitch & USB_ModeSwitch_data per То что Вы привели это скорей относится к "свисткам" Huawei, которые работают в режиме "виртуального CD-ROM" Если будете SIM900 использовать, то Вам надо UART где-то в планшете взять Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
CADiLO 9 10 января, 2014 Опубликовано 10 января, 2014 · Жалоба >>>> укрчастотнадзор ещё лет сто будет вводить черный список имей. так же как и гаи регистрацию скутеров Если не в курсе, то уже ввели, просто с мобилками разбираться проблемнее. По модулям уже были отключения. >>>> спасибо за наводку Уже теплее, но еще не попали. Маркировка NI - это не зарегестрированые транзитные модули, они в Украину не заходят, а идут сразу к соседям где не нужна регистрация - Молдова, Грузия..... Если бы посмотрели на нашем сайте, то нашли бы что зарегистрированый модуль SIM900R(64) еще дешевле - 105 гривен. >>>но я всеравно хотел купить уже готовую плату на ибее за 27 баксов Ну и купите его с версией 1137B11SIM900M64_ST, а обновления и тем более последнюю расширеную прошивку официально получить не сможете. А если в один прекрасный день отключат, то тоже не очень хорошо получится. ИБЕЮ пофигу, они Вам продали, а дальше сами разбирайтесь что да как... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
_saper_ 0 10 января, 2014 Опубликовано 10 января, 2014 · Жалоба То что Вы привели это скорей относится к "свисткам" Huawei, которые работают в режиме "виртуального CD-ROM" Если будете SIM900 использовать, то Вам надо UART где-то в планшете взять Вот ведь схема подключения GSM модем SIM900--> STM32F3DISCOVERY--->USB(slave)--> USB(OTG)-->планшет STM32F3DISCOVERY будет подключатся как виртуальный com port >>>> укрчастотнадзор ещё лет сто будет вводить черный список имей. так же как и гаи регистрацию скутеров Если не в курсе, то уже ввели, просто с мобилками разбираться проблемнее. По модулям уже были отключения. >>>> спасибо за наводку Уже теплее, но еще не попали. Маркировка NI - это не зарегестрированые транзитные модули, они в Украину не заходят, а идут сразу к соседям где не нужна регистрация - Молдова, Грузия..... Если бы посмотрели на нашем сайте, то нашли бы что зарегистрированый модуль SIM900R(64) еще дешевле - 105 гривен. >>>но я всеравно хотел купить уже готовую плату на ибее за 27 баксов Ну и купите его с версией 1137B11SIM900M64_ST, а обновления и тем более последнюю расширеную прошивку официально получить не сможете. А если в один прекрасный день отключат, то тоже не очень хорошо получится. ИБЕЮ пофигу, они Вам продали, а дальше сами разбирайтесь что да как... на нашем сайте это на ХАГе? просто я пока не спешу покупать что либо. что-бы зря деньги не выкинуть. просто плата с ебея соблазняет тем что всё уже готово :) кстати не вижу разницы между мобильником и модемом для оператора и черного списка. вобщем получу планшет и буду думать что дальше.огромное спасибо за совет Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
CADiLO 9 11 января, 2014 Опубликовано 11 января, 2014 · Жалоба >>>>на нашем сайте это на ХАГе? http://microchip.ua/ или посмотрите дистрибьюторов на http://wm.sim.com/en/marketen.aspx >>>кстати не вижу разницы между мобильником и модемом для оператора и черного списка. разница в ввозе и прохождении таможки >>>вобщем получу планшет и буду думать что дальше.огромное спасибо за совет киньте в личку телефон или перезвоните на любой номер с сайта - отвечу на все вопросы Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Waldelk 0 13 января, 2014 Опубликовано 13 января, 2014 · Жалоба Вот ведь схема подключения GSM модем SIM900--> STM32F3DISCOVERY--->USB(slave)--> USB(OTG)-->планшет STM32F3DISCOVERY будет подключатся как виртуальный com port Удачи Вам в настройке маршрутизации пакетов в таком "бутерброде" Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vassabi 0 13 января, 2014 Опубликовано 13 января, 2014 · Жалоба Удачи Вам в настройке маршрутизации пакетов в таком "бутерброде" Ну чего?... Можно же попробовать линукс на discovery поднять... тогда минут 10 работы. :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
