a.graf 0 13 сентября, 2010 Опубликовано 13 сентября, 2010 · Жалоба Вышел новый HOTFIX VERSION: SPB16.30.016 DATE: 09-10-2010 HOTFIX VERSION: 016 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 810479 FSP DESIGN_SETTINGS Not able to connect some peripheral signals to FPGA manually 604662 VLS-L VIA When changing Rows/Columns values in Edit Via Properties form, different value are assigned. 747191 PSPICE AA_SENS Pspice crashes when starting Advance Analysis 756103 CONCEPT_HDL ARCHIVER Archiver does not include all the Parts when design blocks are copied from one location to another 758487 APD 3D_VIEWER package substrate (BGA) outline should be on a separate layer, not on bottom conductor layer. 764417 APD EDIT_ETCH Routing with Diagonal entry (45 degree) to Constraint Regions does not work 766409 PSPICE PROBE Copy to Clipboard changes the label text colors 784577 CONCEPT_HDL COMP_BROWSER SingleclickAdd 'true' places does not pick the correct version 784814 SIP_LAYOUT ASSY_RULE_CHECK accuracy of acute angle DRC 792039 CONSTRAINT_MGR OTHER Doing a File->Import->Worksheet Customization from Constraint Manager will change the working directory. 796517 CONCEPT_HDL COMP_BROWSER Component Browser showing wrong symbol 801944 SCM UI SCM dropping terminators and pull-ups when renaming signals (copy - paste special) 804627 PSPICE PROBE Printet text labels have wrong location 810814 CONSTRAINT_MGR OTHER T-point does not create when import DCF file. 811032 ALLEGRO_EDITOR EDIT_ETCH Enable enhanced pad entry to support pads as shapes 812643 SIP_FLOW CONSTRAINT_MGR Physical Constraint values disappear after entering constraint mode 812835 CONSTRAINT_MGR INTERACTIV CM Custom Fomula - "Analyze" on the header of Actual does not analyze pinpairs 813435 SIP_LAYOUT DIE_ABSTRACT_IF Invalid parameter passed to ICP utility API 814060 CONCEPT_HDL CORE Read only library becomes writeable when updated 814347 ALLEGRO_EDITOR ARTWORK It seems like not work ”detailed text checking” on 16.3. 814451 ALLEGRO_EDITOR DATABASE Allegro get crash when run dbdoctor 814496 CAPTURE ANNOTATE Lower level part refdes resets to ? 815150 SIP_RF OTHER sip layout export chips output is not correct 816034 ALLEGRO_EDITOR MANUFACT Backdrill Passes not work from bottom 816065 APD DATABASE Export Libraries with no library dependencies selected creates package symbol without pins. 816426 ALLEGRO_EDITOR SHAPE Dynamic shape not updated when component is unplaced 816616 SCM SYSTEM_OBJECT codesign incorrectly maps primary and secondary codesign object 816686 ALLEGRO_EDITOR TESTPREP Probe Spacing rounds off 3 place decimal to 2 places 816917 SIG_INTEGRITY LIBRARY Issue for loading interconn.iml 816986 ALLEGRO_EDITOR MANUFACT Mfg>NC>Backdrill analysis with passes set at Bottom layer is automatically switching to top, hence failing! 817473 CAPTURE NETLIST_ALLEGRO Backslash (\) is considered as illegal character for netname but it was allow in SPB 16.30.010 817606 SIP_LAYOUT WIREBOND When moving Bondfingers the Via's are sliding too when they should not. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
sergun53 0 15 октября, 2010 Опубликовано 15 октября, 2010 · Жалоба Новый Cadence Hotfix SPB16.30.018 (563Mb) : http://www.megaupload.com/?d=NB51UZUA http://www.megaupload.com/?d=JDRK1YX1 http://www.megaupload.com/?d=6V1925PF http://www.megaupload.com/?d=F7JIHWME http://www.megaupload.com/?d=TQJUXZXH http://www.megaupload.com/?d=FJCZWRR0 http://www.megaupload.com/?d=40F2YKSM взято с Sonsivri Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vkm 0 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Спасибо, sergun53! Это действительно работающая ссылка! До этого скачивал с http://top-varez.info/program/14378-cadenc...e-08112010.html. Так получил, что "Program too big to fit in memory". После скачивания по ссылкам, выложенным sergun53, хотфикс 018 встал нормально. Но не забывайте полечить! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
ramm 0 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Не помню где и когда "откопал" Hotfix_SPB16.30.019_wint_1of1.exe,себе установил,правда почему то пришлось с нуля всё ставить,но всё в порядке,во всяком случае Allegro PCB Editor до 019 "проапгрейдился". :rolleyes: Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Главное не ставить 20-й хотфикс. Они там порядочный баг сделали... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Old1 0 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Главное не ставить 20-й хотфикс. Они там порядочный баг сделали... Что за баг? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vitan 2 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Главное не ставить 20-й хотфикс. Они там порядочный баг сделали... Ну вот... Только скачал... А что будет? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба Что за баг? При генерации карты сверловки все значки отображаются просто точками. Вроде как не смертельно, но нормальный набор файлов для завода сделать не получается. Мы уже сделали реквест(и не мы одни), обещают в след. хотфиксе поправить. Надеюсь на этой неделе новый хотфикс уже появится, предыдущий-то 13 ноября вышел, как бы и пора... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 43 12 декабря, 2010 Опубликовано 12 декабря, 2010 · Жалоба 21-ый уже на саппорте лежит DATE: 12-10-2010 HOTFIX VERSION: 021 =============================================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE =============================================================================== 839749 ALLEGRO_EDITOR MANUFACT Drill entries are repeated in .drl files Не в этом ли проблема была? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба По описанию не похоже, проблема сформулирована как “Drill symbol invisible in artwork”. Посмотрим после установки как оно себя поведет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Old1 0 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба При генерации карты сверловки все значки отображаются просто точками. Вроде как не смертельно, но нормальный набор файлов для завода сделать не получается. ... Странно. У меня вроде бы все нормально... ЗЫ Да, вижу в герберах действительно точки... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба Вот они интересные... Баг поправили, но в перечень не включили:) Ближе к вечеру выложу хотфикс на ФТП. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 43 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба Ближе к вечеру выложу хотфикс на ФТП. Уже там лежит Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба Ок. PS А где лежит? Что-то не вижу. ЗЫ Уже вижу. Админы поработали, в аплоаде практически ничего не осталось, все в пабе:) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
AlexN 0 13 декабря, 2010 Опубликовано 13 декабря, 2010 · Жалоба Ок. PS А где лежит? Что-то не вижу. ЗЫ Уже вижу. Админы поработали, в аплоаде практически ничего не осталось, все в пабе:) в pub по 20 включительно, 21 в upload Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
