Перейти к содержанию
Вышла FreeRTOS V4.0.5 ... 8.2.3
Changes between V6.0.1 and V6.0.2 released January 9th 2010
+ Changed all GCC ARM 7 ports to use 0 as the SWI instruction parameter.
Previously the parameter was blank and therefore only an implicit 0 but
newer GCC releases do not permit this.
+ Updated IAR SAM7S and SAM7X ports to work with IAR V5.40.
+ Changed the stack alignment requirement for PIC32 from 4 bytes to 8 bytes.
+ Updated prvListTaskWithinSingleList() is it works on processors where the
stack grows up from low memory.
+ Corrected some comments.
+ Updated the startup file for the RVDS LPC21xx demo.
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Очередная мелочевка:
Changes between V6.0.2 and V6.0.3 released February 26 2010
+ SuperH SH7216 (SH2A-FPU) port and demo application added.
+ Slight modification made to the default implementation of
pvPortMallocAligned() and vPortFreeAligned() macros so by default they
just call pvPortMalloc() and vPortFree(). The macros are only needed to
be defined when a memory protection unit (MPU) is being used - and then
only depending on other configuration settings.
Ссылка на сообщение
Changes between V6.0.3 and V6.0.4 released March 14 2010
+ All the contributed files that were located in the Demo/Unsupported_Demos
directory have been removed. These files are instead now available in the
new Community Contributions section of the FreeRTOS website. See
http://www.freertos.org/RTOS-contributed-ports.html
+ The project file located in the Demo/CORTEX_STM32F107_GCC_Rowley directory
has been upgraded to use V2.x of the Rowley Crossworks STM32 support
package.
+ An initial Energy Micro EFM32 demo has been included. This will be
updated over the coming months to make better use of the low power modes
the EFM32 provides.
Ссылка на сообщение
... насчет книжечки: покопайтесь на фтп :)
Спасибо за информацию :) Давно искал "Using the FreeRTOS.... A Practical Guide"
Ссылка на сообщение
Собственно книгу перенес в pub. Пустые-рекламные оглавления - удалил.
Changes between V6.0.4 and V6.0.5 released May 17 2010
+ Added port and demo application for the Cortus APS3 processor.
Ссылка на сообщение
а это вообще где? все обшарил - нигде ненашол, хорошо спрятано.
Ссылка на сообщение
Странно :(. В pub есть раздел операционных систем (по моему логично, что книга по операционной системе находится в нем). В os уже названия операционных систем - в данном случае FreeRTOS (логично, что раздел, так и называется). Все - книга в нем (там сейчас во FreeRTOS ровно 3 файла - запутаться тоже трудно).
Ссылка на сообщение
боюсь показатся тупым, но я pub ненашел ;)
поиск и карта сайта тоже на этот вопрос что такое pub и где он находится не дает....
наверно ложно мое априоное предположение что это какойто url на сервере http://electronix.ru
это вопрос к разному стройству мозга у всех людей. если один специально положил на очевидное место чтоб другому не искать, другой может вообще неонаружить положенный для него предмет :(
Ссылка на сообщение
но я pub ненашел ;).... это какойто url на сервере http://electronix.ru
Издеваетесь? Это FTP сервер. С самого начала так и было написано "насчет книжечки: покопайтесь на фтп"
Ссылка на сообщение
неа, не издеваюсь, честно.
ftp://electronix.ru
логин и пароль с форума
530 ATTENTION!!! ALL CONNECTIONS LOGED
Ссылка на сообщение
Сдается мне, что klen не знаком с ФТП, хотя Свой и постов полно. Это уже бывало в нашей практике с китайцами...
Ссылка на сообщение
Думаю, прочитав это
http://electronix.ru/forum/index.php?showt...st&p=739040
у вас все получится
Ссылка на сообщение
Думаю, прочитав это
у вас все получится
все получилось - оказалось что нада догадатся (а сам бы я не догадался никогда в жизни)прочитать все посты и отрыть ответ - нада зарегестрировать свой пароль! я исходил из априорно неверного предположения что база данных одна для ресурма и логин с паролем однозначно идентифицирует персонаж - оказалось не так.
спасибо, забрал доку по freertos.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
