Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба Инициализация: Спойлер LPTIM1->CFGR = 0 // must be modified when LPTIM is disabled | 0 * LPTIM_CFGR_ENC // Encoder mode enable | 0 * LPTIM_CFGR_COUNTMODE // Increment source if CKSEL = 0, 0: internal, 1: LPTIM_IN1 | 0 * LPTIM_CFGR_PRELOAD // ARR and CMP update, 0: after each APB access, 1: at the end of LPTIM period | 0 * LPTIM_CFGR_WAVE // Waveform shape, 0: normal node, 1: set-once mode | 0 * LPTIM_CFGR_TIMOUT // Trigger event when timer is started, 0: ignored, 1: reset and restart timer | 0 * (LPTIM_CFGR_TRIGEN & -LPTIM_CFGR_TRIGEN) // Trigger edge selection, 0: software, 1: rising edge, 2: falling edge, 3: both edges | 0 * (LPTIM_CFGR_TRIGSEL & -LPTIM_CFGR_TRIGSEL) // Trigger selection, // h5xx LPTIM1: 0: LPTIM_ETR, 1: RTC alarm A, 2: RTC alarm B, 3...4: TAMP1..2, 5: GPDMA_CH1, 6: COMP1_OUT, 7: EVENTOUT | 0 * (LPTIM_CFGR_PRESC & -LPTIM_CFGR_PRESC) // Clock prescaler, 0..7: div 2^N | 0 * (LPTIM_CFGR_TRGFLT & -LPTIM_CFGR_TRGFLT) // Trigger filter, 0: off, 1: 2 clk cycles, 2: 4 clk cycles, 3: 8 clk cycles | 0 * (LPTIM_CFGR_CKFLT & -LPTIM_CFGR_CKFLT) // Clock filter, 0: off, 1: 2 int. clk cycles, 2: 4 int. clock cycles, 3: 8 int. clk cycles | 0 * (LPTIM_CFGR_CKPOL & -LPTIM_CFGR_CKPOL) // Clock active edge, 0: rising, 1: falling, 2: both (if CKSEL=0 only), 3: forbidden | 0 * LPTIM_CFGR_CKSEL // Clock selection, 0: internal, 1: LPTIM_IN1 ; // clear flags. Interrupt not asserted if flag set before enabling in DIER LPTIM1->ICR = uint32_t(-1); LPTIM1->DIER = 0 | 0 * LPTIM_DIER_UEIE // Update event DMA request enable | 0 * LPTIM_DIER_CMP2OKIE // CCR2 update complete interrupt enable | 1 * LPTIM_DIER_CC2IE // Capture/Compare 2 interrupt enable | 0 * LPTIM_DIER_REPOKIE // RCR update interrupt enable | 0 * LPTIM_DIER_UEIE // Update event interrupt enable | 0 * LPTIM_DIER_DOWNIE // Direction change to down interrupt enable | 0 * LPTIM_DIER_UPIE // Direction change to up interrupt enable | 0 * LPTIM_DIER_ARROKIE // ARR update complete interrupt enable | 0 * LPTIM_DIER_CMP1OKIE // CCR1 update complete interrupt enable | 0 * LPTIM_DIER_EXTTRIGIE // External trigger valid edge interrupt enable | 0 * LPTIM_DIER_ARRMIE // Autoreload match interrupt enable | 0 * LPTIM_DIER_CC1IE // Capture/Compare 1 interrupt enable ; LPTIM1->CCMR1 = 0 | 0 * (LPTIM_CCMR1_IC2F & -LPTIM_CCMR1_IC2F) // IC2 filter, 0: no filter, 1: 2 cycles, 2: 4 cycles, 3: 8 cycles | 0 * (LPTIM_CCMR1_IC2PSC & -LPTIM_CCMR1_IC2PSC) // IC2 prescaler, 0: disabled, 1: /2, 2: /4, 3: /8 | 1 * (LPTIM_CCMR1_CC2P & -LPTIM_CCMR1_CC2P) // CC2 polarity, compare mode: 0, 2: active high, 1,3: active low // capture mode: 0: rising, 1: falling, 3: both edges | 0 * LPTIM_CCMR1_CC2E // CC2 enable | 0 * LPTIM_CCMR1_CC2SEL // CC2 selection, 0: output PWM, 1: capture | 0 * (LPTIM_CCMR1_IC1F & -LPTIM_CCMR1_IC1F) // IC1 filter, 0: no filter, 1: 2 cycles, 2: 4 cycles, 3: 8 cycles | 0 * (LPTIM_CCMR1_IC1PSC & -LPTIM_CCMR1_IC1PSC) // IC1 prescaler, 0: disabled, 1: /2, 2: /4, 3: /8 | 0 * (LPTIM_CCMR1_CC1P & -LPTIM_CCMR1_CC1P) // CC1 polarity, compare mode: 0, 2: active high, 1,3: active low // capture mode: 0: rising, 1: falling, 3: both edges | 0 * LPTIM_CCMR1_CC1E // CC1 enable | 0 * LPTIM_CCMR1_CC1SEL // CC1 selection, 0: output PWM, 1: capture ; // enable timer LPTIM1->CR = 0 | 0 * LPTIM_CR_RSTARE // Reset after read enable, can be set when LPTIM is enabled | 0 * LPTIM_CR_COUNTRST // Reset counter, can be set when LPTIM is enabled | 0 * LPTIM_CR_CNTSTRT // Start in continuous mode, can be set when LPTIM is enabled | 0 * LPTIM_CR_SNGSTRT // Start in single pulse mode, can be set when LPTIM is enabled | 1 * LPTIM_CR_ENABLE // Enable ; // CCRx must only be modified when LPTIM is enabled LPTIM1->CCR2 = (LPTIM1_CLK + 1000000 - 1) / 1000000; // 1 us minimal driver pulse width // CCRx must only be modified when LPTIM is enabled LPTIM1->ARR = LPTIM1_CLK / 1000; // просто для примера // Enable NVIC interrupt NVIC->ISER[2] = 0 | (1 << (-64 + LPTIM1_IRQn)) // M4_STEP | (1 << (-64 + LPTIM2_IRQn)) // M3_STEP | (1 << (-64 + USB_DRD_FS_IRQn)) | (0 << (-64 + CRS_IRQn)) | (0 << (-64 + GPDMA2_Channel0_IRQn)) | (0 << (-64 + GPDMA2_Channel1_IRQn)) | (0 << (-64 + GPDMA2_Channel2_IRQn)) | (0 << (-64 + GPDMA2_Channel3_IRQn)) | (0 << (-64 + GPDMA2_Channel4_IRQn)) | (0 << (-64 + GPDMA2_Channel5_IRQn)) ; // start timer LPTIM1->CR = 0 | 0 * LPTIM_CR_RSTARE // Reset after read enable, can be set when LPTIM is enabled | 0 * LPTIM_CR_COUNTRST // Reset counter, can be set when LPTIM is enabled | 1 * LPTIM_CR_CNTSTRT // Start in continuous mode, can be set when LPTIM is enabled | 0 * LPTIM_CR_SNGSTRT // Start in single pulse mode, can be set when LPTIM is enabled | 1 * LPTIM_CR_ENABLE // Enable ; Таймер стартует, импульсы на выходе вижу, в регистре LPTIMx->ISR нужные флаги появляются, а в NVIC->ISPR2 соответствующий бит не взводится и обработчик прерывания, соответственно, не вызывается. Что я делаю не так??? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба 50 минут назад, Сергей Борщ сказал: Таймер стартует, импульсы на выходе вижу, в регистре LPTIMx->ISR нужные флаги появляются, а в NVIC->ISPR2 соответствующий бит не взводится и обработчик прерывания, соответственно, не вызывается. Что я делаю не так??? Что в этот момент в PRIMASK и BASEPRI? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jcxz 211 11 июня Опубликовано 11 июня · Жалоба Можно попробовать: При запрещённых всех прочих источниках прерываний сделать полную очистку всех pending (все ICPRx = ~0) (до инита таймера); потом запустить таймер и посмотреть - может где-то запрос появляется в другом регистре/бите? 1 час назад, Arlleex сказал: Что в этот момент в PRIMASK По идее - PRIMASK не должен никак влиять на появление флагов-запросов в NVIC. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба 1 час назад, jcxz сказал: По идее - PRIMASK не должен никак влиять на появление флагов-запросов в NVIC. Ни разу не хочу ставить под сомнение внимательность Сергея, но по себе знаю, что иногда на форум пишу одно, при этом подразумевая чутка другое) Когда замыливается поток мыслей🙂 Вдруг он смотрел вовсе не в NVIC->ISPR, а в регистр рядом? Всякое бывает же. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба 3 часа назад, Arlleex сказал: Что в этот момент в PRIMASK и BASEPRI? Забыл упомянуть, что остальные задействованные прерывания (USB, USART, GPDMA, TIM1, TIM3, COMP, EXTI_10) в это время работают. А с LPTIM не доходит до выставления флагов в NVIC. Причем и с LPTIM1 и с LPTIM2. 1 час назад, jcxz сказал: Можно попробовать: При запрещённых всех прочих источниках прерываний сделать полную очистку всех pending (все ICPRx = ~0) (до инита таймера); потом запустить таймер и посмотреть - может где-то запрос появляется в другом регистре/бите? Интересная мысль. Маловероятно, но сейчас проверю. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба Ради интереса, попробуйте настроить таймер на обычный счет и ловите прерывание по переполнению. Ну или по любым другим прерываниям. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба Тоже пробовал - то же яйцо, только в профиль. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба А всяких режимов Low Power сейчас нет? Т.е. используете как обычный таймер? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба Да, как обычный таймер. Спячки тоже пока нет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jcxz 211 11 июня Опубликовано 11 июня · Жалоба А сами значения в регистрах таймера (после инита) проверили? Сравнили с мануальными? А то кто его знает - не накосячено ли с определениями всех этих множества define-ов, там где вы их взяли? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба 5 часов назад, jcxz сказал: Можно попробовать: При запрещённых всех прочих источниках прерываний сделать полную очистку всех pending (все ICPRx = ~0) (до инита таймера); потом запустить таймер и посмотреть - может где-то запрос появляется в другом регистре/бите? Не взлетело - ни в одном ISPR ни один бит не взводится. 1 час назад, Arlleex сказал: проверить хотя бы заход в прерывание В другие прерывания заходит... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 158 11 июня Опубликовано 11 июня · Жалоба 4 минуты назад, Сергей Борщ сказал: В другие прерывания заходит... Другие - это Вы про UART и т.д. говорили. А я имел в виду возбудить именно этот вектор прерывания через активацию pending в NVIC (регистр ISPR вроде). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 128 11 июня Опубликовано 11 июня · Жалоба 1 час назад, Arlleex сказал: Это условие выполняется. Код в исходном сообщении исправил. 48 минут назад, Arlleex сказал: А я имел в виду возбудить именно этот вектор прерывания через активацию pending в NVIC (регистр ISPR вроде). А смысл делать это вручную? Таймер должен сам взвести именно этот бит, но не взводит. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Plain 184 12 июня Опубликовано 12 июня · Жалоба Про CC2IE есть сноска в таблице. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
