hdus 0 May 2, 2024 Posted May 2, 2024 (edited) · Report post library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity lab6 is generic(DATA_WIDTH : natural := 9); port ( side : in std_logic; step : in std_logic_vector(DATA_WIDTH-1 downto 0); vector : in std_logic_vector(DATA_WIDTH-1 downto 0); res_p, res_f : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end entity; architecture rtl of lab6 is procedure inc_d_p( vector : in std_logic_vector; side : in std_logic; step : in std_logic_vector; signal result : out std_logic_vector ) is begin if (side = '0') then result <= std_logic_vector(signed(vector) - signed(step)); else result <= std_logic_vector(signed(vector) + signed(step)); end if; end procedure inc_d_p; function inc_d_f( vector : in std_logic_vector; side : in std_logic; step : in std_logic_vector ) return std_logic_vector is variable result : std_logic_vector(vector' range); begin if (side = '0') then result := std_logic_vector(signed(vector) - signed(step)); else result := std_logic_vector(signed(vector) + signed(step)); end if; return result; end function inc_d_f; begin inc_d_p(vector, side, step, res_p); res_f <= inc_d_f(vector, side, step); end architecture rtl; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity lab6_tb is end entity; architecture rtl of lab6_tb is component lab6 is generic(DATA_WIDTH : natural := 9); port ( side : in std_logic; step : in std_logic_vector(DATA_WIDTH-1 downto 0); vector : in std_logic_vector(DATA_WIDTH-1 downto 0); res_p, res_f : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; signal vector, step : std_logic_vector(9-1 downto 0); signal side : std_logic; signal p, f : std_logic_vector(9-1 downto 0); begin inst1: component lab6 generic map( DATA_WIDTH => 9 ) port map( side => side, step => step, vector => vector, res_p => p, res_f => f ); process is begin vector <= "110110001"; side <= '1'; step <= "000110101"; wait for 100 ps; vector <= "110111101"; side <= '1'; step <= "000110000"; wait for 100 ps; vector <= "101001001"; side <= '0'; step <= "000000110"; wait for 100 ps; vector <= "000001100"; side <= '1'; step <= "000001111"; wait for 100 ps; vector <= "001010101"; side <= '0'; step <= "000100001"; wait for 100 ps; vector <= "001110111"; side <= '1'; step <= "000000011"; wait for 100 ps; end process; end rtl; Первый раз работаю с файлами и не знаю как правильно это реализовать. Нужно при помощи Текстового редактора (Text Editor) инструментальной среды разработки ModelSim-Altera реализовать файловый ввод/вывод. Работа с файлами должна осуществляться в тестирующем модуле (TestBench) Edited May 2, 2024 by hdus ошибка в слове Quote Share this post Link to post Share on other sites More sharing options...
andrew_su 1 May 2, 2024 Posted May 2, 2024 · Report post Пример процесса в тестбенче, считывающего из файла data.txt по два 4-хбитных значения, разделенных пробелом с периодом SCLKP_period/7 В файле данные выглядят так: 1010 0101 1100 0011 и т.д. Считанные данные в виде сигналов S_SDP и S_SDN подаются на входы синтезируемого модуля file file_input : text; -------------------------------------------------------------------------- -- LVDS Input simulation process -------------------------------------------------------------------------- LVDS_process :process variable v_ILINE : line; variable data_p : std_logic_vector(3 downto 0); variable data_n : std_logic_vector(3 downto 0); variable v_SPACE : character; begin wait for 10 us; wait until RISING_EDGE(S_SCLKP); wait for SCLKP_period/7; loop file_open(file_input, "data.txt", read_mode); while not endfile(file_input) loop readline(file_input, v_ILINE); read(v_ILINE, data_p); read(v_ILINE, v_SPACE); -- read in the space character read(v_ILINE, data_n); wait for SCLKP_period/7; S_SDP <= data_p; S_SDN <= data_n; end loop; file_close(file_input); end loop; end process; -------------------------------------------------------------------------- Quote Share this post Link to post Share on other sites More sharing options...
