Maverick_ 15 20 октября, 2022 Опубликовано 20 октября, 2022 · Жалоба Мне остался по наследству модуль module alg_integrator_smart (clk, reset, start, base, data_in, data_slow, ready_const, clk_const, addr_const, data_const, tdpp, data_out, int_out, int_diff, tau_out); input clk, reset, start; input signed [15:0] data_in; input signed [47:0] data_slow; input signed [23:0] base; input ready_const, clk_const; input [5:0] addr_const; input [15:0] data_const; input signed [15:0] tdpp; output signed [47:0] data_out; output signed [15:0] int_out; output signed [15:0] int_diff; output signed [23:0] tau_out; reg signed [23:0] r_base = 24'sd51200; reg signed [47:0] resalt_r, sample_data; reg signed [63:0] resalt, resalt_i; reg [1:0] front_start; reg signed [23:0] tau_coeff = 24'sd117500;// 917.97 *128 reg signed [23:0] tau_calc = 24'sd117500;// 917.97 *128 reg signed [16:0] k1 = 17'sd0; reg signed [16:0] k2 = 17'sd0; reg tau_calc_en = 1'b0;// default reg signed [39:0] tau_acc; reg signed [16:0] tdpp_delta; //******************************************************* reg signed [23:0] fifo_amp [2:0]; reg signed [47:0] buf2; reg start_prev = 1'b0; reg signed [63:0] int_prev; reg signed [63:0] delta; //******************************************************* // process for update constants always @(posedge clk_const) begin if (ready_const) case (addr_const) 6'd2: tau_coeff[15:0] <= data_const; 6'd3: tau_coeff[23:16] <= data_const[7:0]; 6'd23: tau_calc_en <= data_const[3];// customize[3] -> + 8 6'd25: begin k2[15:0] <= data_const; k2[16] <= 1'b0; end// coefficient (top_discriminator) 6'd26: begin k1[15:0] <= data_const; k1[16] <= 1'b0; end// base temperature (bottom_discriminator) default: begin tau_coeff <= tau_coeff; tau_calc_en <= tau_calc_en; k2 <= k2; k1 <= k1; end endcase end // process tau calculation always@(negedge clk) begin tdpp_delta <= tdpp - k1; if (tau_calc_en == 1'b1) begin if (k1 > 0) // tau_calc <= tau_acc >>> 16; tau_calc <= tau_acc >>> 15; else tau_calc <= tau_coeff; end else tau_calc <= tau_coeff; end always@(posedge clk) begin // tau_acc <= (tau_coeff <<< 16) + k2 * tdpp_delta; tau_acc <= (tau_coeff <<< 15) + k2 * tdpp_delta; end // main process of integrator always@(posedge clk or negedge reset) begin if(reset == 1'b0) begin : resetting resalt <= 64'sd0; resalt_i <= 64'sd0; //resalt_r <= 48'sd0; buf2 <= 48'sd0; end else begin : calculating // input signal buffer fifo_amp[0] <= (data_in <<< 8) - r_base; fifo_amp[1] <= fifo_amp[0]; fifo_amp[2] <= fifo_amp[1]; // buf2 <= fifo_amp[0] * tau_coeff; buf2 <= fifo_amp[0] * tau_calc; if ((start_prev == 1'b1) & (start == 1'b0)) resalt_i <= resalt_i + buf2 - sample_data; else resalt_i <= resalt_i + buf2; resalt <= resalt_i + (fifo_amp[2] <<< 22); end end always@(posedge clk or negedge reset) if(reset == 1'b0) r_base <= r_base; else if ((start_prev == 1'b1) & (start == 1'b0)) r_base <= base; else r_base <= r_base; // process for update slow data always@(posedge clk or negedge reset) if (reset == 1'b0) sample_data <= 48'd0; else sample_data <= data_slow; // process for generate start vector always@(posedge clk) begin //front_start[0] <= start; //front_start[1] <= front_start[0]; start_prev <= start; end // process for calculate delta INT always@(posedge clk) begin delta <= resalt - int_prev; int_prev <= resalt; end // connect outputs assign data_out = resalt; assign int_out = resalt_i >>> 30; assign int_diff = delta >>> 30; assign tau_out = tau_calc; endmodule естественно разработчика я не застал, мои попытки увеличить тактовую хотя бы на 30-40 МГц не принесли результатов проблема в арифметике: buf2 <= fifo_amp[0] * tau_calc; if ((start_prev == 1'b1) & (start == 1'b0)) resalt_i <= resalt_i + buf2 - sample_data; else resalt_i <= resalt_i + buf2; resalt <= resalt_i + (fifo_amp[2] <<< 22); Квартус 18.1 для циклон5 дает 102MHz ... Да описание написано лет десять назад... работало на циклон3 я смог добиться 114МГц module alg_integrator_smart (clk, tau_coeff,k1,k2,tau_calc_en, reset, start, base, data_in, data_slow, ready_const, addr_const, data_const, tdpp, data_out, int_out, int_diff, tau_out); input clk, reset, start; input signed [15:0] data_in; input signed [47:0] data_slow; input signed [23:0] base; input ready_const; input [5:0] addr_const; input [15:0] data_const; input signed [23:0] tau_coeff; // = 24'sd117500;// 917.97 *128 input signed [16:0] k1; // = 17'sd0; input signed [16:0] k2; // = 17'sd0; input tau_calc_en; // = 1'b0;// default input signed [15:0] tdpp; output signed [47:0] data_out; output signed [15:0] int_out; output signed [15:0] int_diff; output signed [23:0] tau_out; reg signed [47:0] reg_data_slow; reg signed [23:0] r_base = 24'sd51200; reg signed [47:0] resalt_r, sample_data; reg signed [63:0] resalt, resalt_i; reg signed [63:0] resalt_a, resalt_b; reg signed [47:0] resalt0; reg [1:0] front_start; //reg signed [23:0] tau_coeff = 24'sd117500;// 917.97 *128 reg signed [23:0] tau_calc = 24'sd117500;// 917.97 *128 //reg signed [16:0] k1 = 17'sd0; //reg signed [16:0] k2 = 17'sd0; //reg tau_calc_en = 1'b0;// default reg signed [39:0] tau_acc; reg signed [31:0] tau_acc0; reg signed [31:0] tau_acc1; reg signed [16:0] tdpp_delta; //******************************************************* reg signed [23:0] fifo_amp [2:0]; reg signed [47:0] buf2; reg start_prev = 1'b0; reg signed [63:0] int_prev; reg signed [63:0] delta; //******************************************************* // process for update constants //always @(posedge clk) //clk_const //begin // if (ready_const) // case (addr_const) // 6'd2: tau_coeff[15:0] <= data_const; // 6'd3: tau_coeff[23:16] <= data_const[7:0]; // 6'd23: tau_calc_en <= data_const[3];// customize[3] -> + 8 // 6'd25: begin k2[15:0] <= data_const; k2[16] <= 1'b0; end// coefficient (top_discriminator) // 6'd26: begin k1[15:0] <= data_const; k1[16] <= 1'b0; end// base temperature (bottom_discriminator) // default: // begin // tau_coeff <= tau_coeff; // tau_calc_en <= tau_calc_en; // k2 <= k2; // k1 <= k1; // end // endcase //end // process tau calculation always@(negedge clk) begin tdpp_delta <= tdpp - k1; if (tau_calc_en == 1'b1) begin if (k1 > 0) // tau_calc <= tau_acc >>> 16; tau_calc <= tau_acc >>> 15; else tau_calc <= tau_coeff; end else tau_calc <= tau_coeff; end always@(posedge clk) begin // tau_acc <= (tau_coeff <<< 16) + k2 * tdpp_delta; //tau_acc <= (tau_coeff <<< 15) + k2 * tdpp_delta; tau_acc <= tau_acc0 + tau_acc1; end always @( posedge clk) begin tau_acc0 <= tau_coeff <<< 15; end always @( posedge clk) begin tau_acc1 <= k2 * tdpp_delta; end // main process of integrator always@(posedge clk or negedge reset) begin if(reset == 1'b0) begin : resetting resalt <= 64'sd0; resalt_i <= 64'sd0; //resalt_r <= 48'sd0; //buf2 <= 48'sd0; end else begin : calculating // input signal buffer fifo_amp[0] <= (data_in <<< 8) - r_base; fifo_amp[1] <= fifo_amp[0]; fifo_amp[2] <= fifo_amp[1]; // buf2 <= fifo_amp[0] * tau_coeff; if ((start_prev == 1'b1) & (start == 1'b0)) //resalt_i <= resalt_i + buf2 - sample_data; resalt_i <= resalt_a; else resalt_i <= resalt_b; resalt <= resalt_i + (fifo_amp[2] <<< 22); end end always @( posedge clk) begin resalt_a <= resalt_a + resalt0; //sample_data; end always @( posedge clk) begin resalt_b <= resalt_b + buf2; //sample_data; end always @( posedge clk) begin //reg_data_slow <= data_slow; resalt0 <= buf2 - data_slow; //sample_data; end always @( posedge clk) begin buf2 = fifo_amp[0] * tau_calc; end always@(posedge clk or negedge reset) if(reset == 1'b0) r_base <= r_base; else if ((start_prev == 1'b1) & (start == 1'b0)) r_base <= base; else r_base <= r_base; //// process for update slow data //always@(posedge clk or negedge reset) // if (reset == 1'b0) // sample_data <= 48'd0; // else // sample_data <= data_slow; // process for generate start vector always@(posedge clk) begin //front_start[0] <= start; //front_start[1] <= front_start[0]; start_prev <= start; end // process for calculate delta INT always@(posedge clk) begin delta <= resalt - int_prev; int_prev <= resalt; end // connect outputs assign data_out = resalt; assign int_out = resalt_i >>> 30; assign int_diff = delta >>> 30; assign tau_out = tau_calc; endmodule и то я изменил немного матемтику она не соответствует первоначальной (это видно в моем описании выше): if ((start_prev == 1'b1) & (start == 1'b0)) resalt_i <= resalt_i + buf2 - sample_data; else resalt_i <= resalt_i + buf2; я сделал вычисления в условиях независимыми, что есть не совсем правильным этот always я уберу - эти регистры будут инициализироваться по авлон ММ шине в одном модуле - в этот модуль будут приходить как входные данные (в моем варианте этот процесс уже закоментирован): // process for update constants always @(posedge clk_const) begin if (ready_const) case (addr_const) 6'd2: tau_coeff[15:0] <= data_const; 6'd3: tau_coeff[23:16] <= data_const[7:0]; 6'd23: tau_calc_en <= data_const[3];// customize[3] -> + 8 6'd25: begin k2[15:0] <= data_const; k2[16] <= 1'b0; end// coefficient (top_discriminator) 6'd26: begin k1[15:0] <= data_const; k1[16] <= 1'b0; end// base temperature (bottom_discriminator) default: begin tau_coeff <= tau_coeff; tau_calc_en <= tau_calc_en; k2 <= k2; k1 <= k1; end endcase end Буду рад конструктивным предложениям/мыслям по увеличению тактовой частоты хотя бы до 130-140МГц ... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
RobFPGA 28 20 октября, 2022 Опубликовано 20 октября, 2022 · Жалоба Лень досконально разбираться в алгоритме в такой простыне кода, но кажется мне что похоже это на обычный gain-control на звене первого порядка. Я бы начал с того что выписать алгоритм вычислений с учетом требований по latency и throughput, а потом смотрел как можно конвеезировать его. P.S. Умножать 24x24 за один такт и ждать высокой частоты? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Самурай 12 20 октября, 2022 Опубликовано 20 октября, 2022 · Жалоба В 21.10.2022 в 00:19, Maverick_ сказал: Буду рад конструктивным предложениям/мыслям по увеличению тактовой частоты хотя бы до 130-140МГц ... Что за хитрый алгоритм разбираться лениво, но работа по двум фронтам на быстродействие сказывается явно не лучшим образом. Это вот тут: В 21.10.2022 в 00:19, Maverick_ сказал: // process tau calculation always@(negedge clk) begin ... tau_calc <= tau_coeff; end И тут: В 21.10.2022 в 00:19, Maverick_ сказал: // main process of integrator always@(posedge clk or negedge reset) begin ... buf2 <= fifo_amp[0] * tau_calc; ... end Лучше все привести к работе по одному фронту. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
des00 25 21 октября, 2022 Опубликовано 21 октября, 2022 · Жалоба 7 hours ago, RobFPGA said: P.S. Умножать 24x24 за один такт и ждать высокой частоты? да даже за 2 такта на сыклоне, с умножителями 19х18 не даст результата) Особо вариантов то нет. Либо вам нужно выделить бюджет на умножение 3-4 такта, как понимаю это должно определяться сигналом подачи входных данных, но в первоначальном коде этого не видно, судя по всему данные идут каждый такт. Либо вводить предварительную обработку с децимацией данных. Т.е. расписать математику и выяснить, можно ли входные данные data_in сложить таким образом, чтобы не сломать работу схемы. Тогда ваш аккумулятор кладется в мультицикловый домен и тактовая уже не представляет проблем) Ну или аппетиты поумерить и вписаться в сыклоновский умножитель 19х18 ничего не делая) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 21 октября, 2022 Опубликовано 21 октября, 2022 · Жалоба Всем спасибо. 7 hours ago, Самурай said: Что за хитрый алгоритм разбираться лениво, но работа по двум фронтам на быстродействие сказывается явно не лучшим образом. Это вот тут: И тут: Лучше все привести к работе по одному фронту. - не увидел, спасибо что обратили внимание. Исправил, тактовая частота повысилась. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
des00 25 21 октября, 2022 Опубликовано 21 октября, 2022 · Жалоба 18 minutes ago, Maverick_ said: Всем спасибо. - не увидел, спасибо что обратили внимание. Исправил, тактовая частота повысилась. только учтите что это могло быть сделано специально, в качестве меры подготовки данных для умножения с накоплением. Т.к. изменив фронт в этом месте, вы добавили задержку сигнала на 1 такт, тогда как там была "попытка" конвейризации, которая на самом деле выглядит как попытка "зафиксировать" выход из логического блока триггером. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 21 октября, 2022 Опубликовано 21 октября, 2022 · Жалоба 9 hours ago, des00 said: только учтите что это могло быть сделано специально, в качестве меры подготовки данных для умножения с накоплением. Т.к. изменив фронт в этом месте, вы добавили задержку сигнала на 1 такт, тогда как там была "попытка" конвейризации, которая на самом деле выглядит как попытка "зафиксировать" выход из логического блока триггером. понял, спасибо за предупреждение и пояснение Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Art55555 0 3 ноября, 2022 Опубликовано 3 ноября, 2022 · Жалоба On 10/21/2022 at 7:00 PM, Maverick_ said: понял, спасибо за предупреждение и пояснение Как показывает практика, конвейерные вычисления, фиксация результата по счётчику (если необходимо), использование DSP-ядер - всё это значительно повышает итоговую частоту работы. Если частот несколько - используем фифо (не защёлкиваем и не ожидает результат по одной частоте, регистрация по другой). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 12 ноября, 2022 Опубликовано 12 ноября, 2022 · Жалоба Добрый! Помогите пожалуйста исправить ошибку в моделсиме, квартус компилирует без проблем Ошибка; Файл во вложении PS уже жаже переписал на английской клавиатуре всю первую строку - думал что кирилица где-то есть Хотя бы мысли, где копать подскажите пожалуйста alg_base_calc_1calc.v Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
RobFPGA 28 12 ноября, 2022 Опубликовано 12 ноября, 2022 · Жалоба 12 minutes ago, Maverick_ said: Хотя бы мысли, где копать подскажите пожалуйста Копать в сторону возможности компилировать верилог код компилятором VHDL ... (vcom vis vlog) 1 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 12 ноября, 2022 Опубликовано 12 ноября, 2022 · Жалоба 2 hours ago, RobFPGA said: Копать в сторону возможности компилировать верилог код компилятором VHDL ... (vcom vis vlog) не увидел, спасибо)) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Джеймс 3 12 ноября, 2022 Опубликовано 12 ноября, 2022 · Жалоба 1 hour ago, Maverick_ said: Добрый! Помогите пожалуйста исправить ошибку в моделсиме, квартус компилирует без проблем Ошибка; Боюсь без остальных (вложенных) файлов проекта сказать что-то будет сложно.. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 12 ноября, 2022 Опубликовано 12 ноября, 2022 · Жалоба 1 hour ago, Джеймс said: Боюсь без остальных (вложенных) файлов проекта сказать что-то будет сложно.. проблема была в том что в do файле я случайно для верилог файла написал команду для vhdl файла было vcom -2008 -work work {./moduls/calc_base/alg_base_calc_1calc.v} надо: vlog -work work {./moduls/calc_base/alg_base_calc_1calc.v} на скрине ошибки это видно))) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
