Перейти к содержанию
помогите найти общий язык
Пожалуйста помогите разобраться.
Квартус выдает ошибку
Error (10327): VHDL error at SMC.vhd(68): can't determine definition of operator ""sra"" -- found 0 possible definitions
Error (10411): VHDL Type Conversion error at SMC.vhd(68): can't determine type of object or expression near text or symbol "std_logic_vector"
в проекте стоит галочка использовать VHDL 2008
ошибка возникает в следующем описании:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
entity SMC is
generic ( M : natural := 32 );
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en     : in STD_LOGIC;
Tmax : in STD_LOGIC_VECTOR (31 downto 0); -- maximum timing
Nsegment : in STD_LOGIC_VECTOR (7 downto 0); -- total segment acceleration/deceleration
T0 : in STD_LOGIC_VECTOR (31 downto 0);
--Duty_cycle : in STD_LOGIC_VECTOR (15 downto 0);
--ready_period : out STD_LOGIC;
out_shim : out STD_LOGIC );
end SMC;
architecture Behavioral of SMC is
COMPONENT shim
generic ( N : natural := 3 );
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
--load : in STD_LOGIC;
Period : in STD_LOGIC_VECTOR (N-1 downto 0);
Duty_cycle : in STD_LOGIC_VECTOR (N-1 downto 0);
END COMPONENT;
signal reg_period : STD_LOGIC_VECTOR (M-1 downto 0);
signal reg_duty_cycle : STD_LOGIC_VECTOR (M-1 downto 0);
signal count_period  : STD_LOGIC_VECTOR (M-1 downto 0);
signal reg_number_of_steps : STD_LOGIC_VECTOR (M-1 downto 0);
signal reg_ready_period, reg_segment_ready  : STD_LOGIC;
signal reg_en_shim, reg_load_shim : STD_LOGIC;
signal cnt_segments  : STD_LOGIC_VECTOR (15 downto 0);
signal reg_number_of_segments : STD_LOGIC_VECTOR (M-1 downto 0);
signal cnt : STD_LOGIC_VECTOR (M-1 downto 0);
signal reg_duty_segment : STD_LOGIC_VECTOR (M-1 downto 0);
signal reg_ena_work : STD_LOGIC;
begin
shim_inst : shim
generic map (
    N => M)
port map
        clk => clk,
        rst => rst,
        en => reg_en_shim,
        --load => reg_load_shim,
        Period => reg_period,
        Duty_cycle => reg_duty_cycle,
        ready_period => reg_ready_period,
        out_shim => out_shim
    reg_en_shim <= '1';
    reg_duty_cycle <= std_logic_vector (unsigned(reg_period) sra 1);
process (all)
begin
if rst = '1' then
    count_period <= (others=>'0');
    reg_period <= T0;
    reg_number_of_segments <= std_logic_vector (unsigned(Tmax) sra conv_integer(Nsegment));
    reg_duty_segment <= std_logic_vector (unsigned(Tmax) sra 0);
    reg_segment_ready <= '0';
elsif(rising_edge(clk)) then
if reg_ena_work = '1' then
    if cnt = reg_duty_segment then  -- k
        reg_period <= std_logic_vector (unsigned(reg_period) sra 1);
        reg_segment_ready <= '1';
        reg_duty_segment <= std_logic_vector (unsigned(Tmax) sra conv_integer(cnt_segments+1));
    else
        if reg_ready_period = '1' then
            count_period <= count_period + "0000000000000001";
        end if;
    end if;
end if;
end if;
end process;
process (all)
begin
if rst = '1' then
cnt_segments <= (others=>'0');
cnt <= (others=>'0');
    if reg_segment_ready = '1' then
        cnt_segments <= cnt_segments + "0000000000000001";
    else
        cnt <= cnt + 1;
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
reg_ena_work <= '0';
    if (cnt_segments = Nsegment) then
    elsif en = '1' then
        reg_ena_work <= '1';
    end if;
end if;
end process;
end Behavioral;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use IEEE.NUMERIC_STD.ALL;
entity shim is
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
end shim;
architecture Behavioral of shim is
signal count_shim : STD_LOGIC_VECTOR (N-1 downto 0);
signal reg_Period :  STD_LOGIC_VECTOR (N-1 downto 0);
signal reg_Duty_cycle :  STD_LOGIC_VECTOR (N-1 downto 0);
begin
process (all)
begin
if rst = '1' then
    count_shim <= (others=>'0');
    if en = '1' then
        if count_shim = reg_Period  then
            ready_period <= '1';
        else
            count_shim <= count_shim + std_logic_vector( to_unsigned(1, count_shim'length ));
            ready_period <= '0';
        end if;
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    out_shim <= '0';
    if count_shim < reg_Duty_cycle then
        out_shim <= '1';
    else
        out_shim <= '0';
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    reg_Period <= (others=>'0');
    reg_Duty_cycle <= (others=>'0');
    if ready_period = '1' then
        reg_Period <= Period;
        reg_Duty_cycle <= Duty_cycle;
    end if;
end if;
end process;
end Behavioral;
ошибка ссылается на строку
Моделсим 10.5 ошибок не выдает - моделирует...
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
--use IEEE.STD_LOGIC_UNSIGNED.ALL; - это никогда не использовать.
use ieee.numeric_std.all; - только это и соответственно srl.
-- Note: Function S.11 is not compatible with IEEE Std 1076-1987. Comment
-- out the function (declaration and body) for IEEE StdL 1076-1987 compatibility.
-- Id: S.11
function "srl" (ARG: UNSIGNED; COUNT: INTEGER) return UNSIGNED;
-- Result subtype: UNSIGNED(ARG'LENGTH-1 downto 0)
-- Result: SHIFT_RIGHT(ARG, COUNT)
-- Id: S.2
function SHIFT_RIGHT (ARG: UNSIGNED; COUNT: NATURAL) return UNSIGNED;
-- Result: Performs a shift-right on an UNSIGNED vector COUNT times.
-- The vacated positions are filled with '0'.
-- The COUNT rightmost elements are lost.
https://standards.ieee.org/downloads/1076/1...umeric_std.vhdl
Ссылка на сообщение
Интересно, а если я использую самописные библиотеки, от них тоже нужно отказаться?
Ссылка на сообщение
Однозначно.
Ссылка на сообщение
Однозначно.
Как жалко, имхо. Например fun_pkg очень неплохая библиотека.
Ссылка на сообщение
С чего такой вывод?
Ссылка на сообщение
С чего такой вывод?
Да это не вывод, это вопрос, для себя вывод я сделал давно. Просто хочется знать что думают коллеги.
ссылка
Ведь мои самописные библиотеки никто не стандартизировал.
Ссылка на сообщение
ссылка
Дело не в стандартизированности, обе библиотеки стандартизированы, обе библиотеки определяют знаковые типы и операции с ними, какую из них компилятор должен использовать? Это просто ошибка и бестолковщина, как минимум использовать нужно какую-то одну, лучше последнюю стандартизированную numeric_std, но ни в коем случае не обе одновременно в одном entity.
Ссылка на сообщение
Пугалки какие то. И к чему катастрофическому одновременное использование может привести? Компьютер взорвётся? Вы можете сказать почему за почти 20 лет применения этой троицы я ни разу не видел некорректного поведения? Если в течении этого времени минусов не замечалось а плюсы налицо то вывод очевиден. Это я как хронический практик сужу.
Ссылка на сообщение
исправил так
library IEEE;
entity SMC is
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en     : in STD_LOGIC;
end SMC;
COMPONENT shim
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
END COMPONENT;
signal cnt_segments, cnt_segments1  : STD_LOGIC_VECTOR (15 downto 0);
begin
shim_inst : shim
generic map (
    N => M)
port map
        clk => clk,
        rst => rst,
        en => reg_en_shim,
    reg_en_shim <= '1';
    reg_duty_cycle <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period),  1));
    cnt_segments1 <=   std_logic_vector (unsigned(cnt_segments) + 1);
process (all)
begin
if rst = '1' then
    reg_period <= T0;
    reg_number_of_segments <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(Nsegment))));
    reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), 0));
        reg_period <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period), 1));
        reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(cnt_segments1))));
    else
        end if;
    end if;
end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    else
        cnt <= cnt + 1;
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    elsif en = '1' then
    end if;
end if;
end process;
end Behavioral;
library ieee;
entity shim is
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
end shim;
begin
process (all)
begin
if rst = '1' then
    if en = '1' then
        else
        end if;
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    out_shim <= '0';
        out_shim <= '1';
    else
        out_shim <= '0';
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    end if;
end if;
end process;
end Behavioral;
ошибка
Error (10327): VHDL error at SMC.vhd(90): can't determine definition of operator ""+"" -- found 0 possible definitions
во втором описании тоже тогда надо убирать библиотеку - use ieee.std_logic_unsigned.all;
Ссылка на сообщение
Ну так и правильно, операция + не определена для SLV.
Хотите счетчик на SLV, тогда явно преобразуйте типы, например:
count_period <= std_logic_vector(unsigned(count_period) + 1);
cnt_segments <= std_logic_vector(unsigned(cnt_segments) + 1);
cnt          <= std_logic_vector(unsigned(cnt) + 1);
Или сразу объявляйте счетчики как UNSIGNED, тогда можно обойтись такой записью:
count_period <= count_period + "1";
cnt_segments <= cnt_segments + "1";
cnt          <= cnt + "1";
Изменено пользователем Flip-fl0p
Ссылка на сообщение
в чем разница
у меня сделано так
PS это ошибка для первого описания....
Ссылка на сообщение
в чем разница
у меня сделано так
Так во втором описании так-же присутствует эта ошибка:
Ссылка на сообщение
спасибо... :)
тему можно закрывать...
да, получилось следующим образом:
library IEEE;
entity SMC is
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en     : in STD_LOGIC;
end SMC;
COMPONENT shim
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
END COMPONENT;
begin
shim_inst : shim
generic map (
    N => M)
port map
        clk => clk,
        rst => rst,
        en => reg_en_shim,
    reg_en_shim <= '1';
process (all)
begin
if rst = '1' then
    reg_period <= (others=>'0');
    reg_number_of_segments <= (others=>'0');
    reg_duty_segment <= (others=>'0');
if load = '1' and reg_ena_work = '0' then
    reg_period <= T0;
end if;
if reg_ena_work = '1' and  load = '0' then
        reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(cnt_segments) +1 )));
    else
            count_period <= std_logic_vector (unsigned(count_period) + 1);
        end if;
    end if;
end if;
end if;
end process;
process (all)
begin
if rst = '1' then
        cnt_segments <= std_logic_vector (unsigned(cnt_segments) + 1);
    else
        cnt <= std_logic_vector (unsigned(cnt) + 1);
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    if (unsigned(cnt_segments) = unsigned(Nsegment)) then
    elsif en = '1' then
    end if;
end if;
end process;
end Behavioral;
library ieee;
--use ieee.std_logic_unsigned.all;
entity shim is
Port (
clk : in STD_LOGIC;
rst : in STD_LOGIC;
en : in STD_LOGIC;
end shim;
begin
process (all)
begin
if rst = '1' then
    if en = '1' then
        else
            count_shim <= std_logic_vector (unsigned(count_shim) + 1);
        end if;
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    out_shim <= '0';
        out_shim <= '1';
    else
        out_shim <= '0';
    end if;
end if;
end process;
process (all)
begin
if rst = '1' then
    end if;
end if;
end process;
end Behavioral;
Ссылка на сообщение
Так объявили бы сразу счетчики как UNSIGNED, тога код был бы красивее и, самое главное, гораздо понятнее.
Так-же я не вижу ничего зазорного в объявлении счетчика как INTEGER, если так удобнее для реализации.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
