При попытке синтезировать проект с коркой AXI Direct Memory Access вылетает следующее:
ERROR:HDLCompiler:104 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 76: Cannot find <axi_dma> in library <axi_dma_v4_00_a>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
Parsing entity <dma>.
ERROR:HDLCompiler:854 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 78: Unit <dma> ignored due to previous errors.
Parsing architecture <spartan6> of entity <dma>.
ERROR:HDLCompiler:374 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 189: Entity <dma> is not yet compiled.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 193: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 194: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 195: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 196: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 197: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 198: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 199: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 200: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 201: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 202: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 203: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 204: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 205: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 206: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 207: <integer> is not declared.
ERROR:HDLCompiler:69 - " \dma_test\ipcore_dir\dma_synth.vhd" Line 208: <integer> is not declared.
На сайте ксайлинска советуют: http://www.xilinx.com/support/answers/41727.htm
Пытаюсь добавить файлы, но всё равно не получается, ISE пишет, что такие файлы уже включены.
Среда ISE 13.2.
