gotcha
Свой-
115 -
0 ОбычныйИнформация о gotcha
1 581 просмотр профиля
Сегодня Xilinx решил зависнуть на другом этапе (обычно зависал на Phase 9.8 Global Placement): В новой ветке проекта этим и занимаюсь. Можете дать ссылку про это почитать?
Starting Clock Frequency Frequency Period Period Slack Type Group --------------------------------------------------------------------------------------------------------------------------------------------------- clk8x|CLKFX_BUF_derived_clock 100.0 MHz 155.8 MHz 10.000 6.417 3.583 derived (from clock_p51) default_clkgroup clock_p51 50.0 MHz NA 20.000 NA DCM/PLL declared default_clkgroup
ISE не дружит с systemverilog, надо много чего переписывать. ... больше света в темную комнату Mapping to part: xc6slx9tqg144-2 Cell usage: DCM_SP 1 use FD 94 uses FDE 2720 uses FDR 245 uses FDRE 3189 uses FDSE 4 uses GND 33 uses MUXCY 12 uses MUXCY_L 233 uses MUXF7 290 uses MUXF8 144 uses VCC 33 uses XORCY 209 uses fifo_w4d16_spartan6 1 use LUT1 109 uses LUT2 202 uses LUT3 934 uses LUT4 991 uses LUT5 527 uses LUT6 1570 uses LUT6_2 5 uses I/O ports: 57 I/O primitives: 53 IBUF 12 uses IBUFG 1 use OBUF 40 uses BUFG 2 uses SRL primitives: SRLC32E 48 uses I/O Register bits: 0 Register bits not including I/Os: 6252 (50%) Global Clock Buffers: 2 of 16 (12%) Total load per clock: clk8x|CLKFX_BUF_derived_clock: 6301 clk8x|CLK0_BUF_derived_clock: 1 clock_p51: 1 Mapping Summary: Total LUTs: 3773 (61%) Distribution of All Consumed LUTs = SRL + LUT1 + LUT2 + LUT3 + LUT4 + LUT5 + LUT6 + LUT6_2- HLUTNM/2 Distribution of All Consumed Luts 3773 = 48 + 109 + 202 + 934 + 991 + 527 + 1570 + 5- 1226/2 Number of unique control sets: 130 Region Summary: Other LUTs: 4338 Other Registers: 6252 Mapper successful! Xilinx пишет Interim Summary --------------- Slice Logic Utilization: Number of Slice Registers: 6,282 out of 11,440 54% Number used as Flip Flops: 6,282 Number used as Latches: 0 Number used as Latch-thrus: 0 Number used as AND/OR logics: 0 Number of Slice LUTs: 3,779 out of 5,720 66% Number used as logic: 3,717 out of 5,720 64% Number using O6 output only: 2,880 Number using O5 output only: 70 Number using O5 and O6: 767 Number used as ROM: 0 Number used as Memory: 48 out of 1,440 3% Number used as Dual Port RAM: 0 Number used as Single Port RAM: 0 Number used as Shift Register: 48 Number using O6 output only: 48 Number using O5 output only: 0 Number using O5 and O6: 0 Number used exclusively as route-thrus: 14 Number with same-slice register load: 0 Number with same-slice carry load: 14 Number with other load: 0 Slice Logic Distribution: Number of MUXCYs used: 320 out of 2,860 11% Number of LUT Flip Flop pairs used: 8,885 Number with an unused Flip Flop: 2,732 out of 8,885 30% Number with an unused LUT: 5,106 out of 8,885 57% Number of fully used LUT-FF pairs: 1,047 out of 8,885 11% Number of unique control sets: 180 Number of slice register sites lost to control set restrictions: 742 out of 11,440 6% A LUT Flip Flop pair for this architecture represents one LUT paired with one Flip Flop within a slice. A control set is a unique combination of clock, reset, set, and enable signals for a registered element. The Slice Logic Distribution report is not meaningful if the design is over-mapped for a non-slice resource or if Placement fails. IO Utilization: Number of bonded IOBs: 53 out of 102 51% Specific Feature Utilization: Number of RAMB16BWERs: 0 out of 32 0% Number of RAMB8BWERs: 1 out of 64 1% Number of BUFIO2/BUFIO2_2CLKs: 1 out of 32 3% Number used as BUFIO2s: 1 Number used as BUFIO2_2CLKs: 0 Number of BUFIO2FB/BUFIO2FB_2CLKs: 1 out of 32 3% Number used as BUFIO2FBs: 1 Number used as BUFIO2FB_2CLKs: 0 Number of BUFG/BUFGMUXs: 2 out of 16 12% Number used as BUFGs: 2 Number used as BUFGMUX: 0 Number of DCM/DCM_CLKGENs: 1 out of 4 25% Number used as DCMs: 1 Number used as DCM_CLKGENs: 0 Number of ILOGIC2/ISERDES2s: 0 out of 200 0% Number of IODELAY2/IODRP2/IODRP2_MCBs: 0 out of 200 0% Number of OLOGIC2/OSERDES2s: 0 out of 200 0% Number of BSCANs: 0 out of 4 0% Number of BUFHs: 0 out of 128 0% Number of BUFPLLs: 0 out of 8 0% Number of BUFPLL_MCBs: 0 out of 4 0% Number of DSP48A1s: 0 out of 16 0% Number of ICAPs: 0 out of 1 0% Number of MCBs: 0 out of 2 0% Number of PCILOGICSEs: 0 out of 2 0% Number of PLL_ADVs: 0 out of 2 0% Number of PMVs: 0 out of 1 0% Number of STARTUPs: 0 out of 1 0% Number of SUSPEND_SYNCs: 0 out of 1 0% огорчает приближение +- полчипа
Ох уж эти новые попугаи. На 3м спартане XC3S500E разводит, но времянка проседает.
Вы, попали в яблочко. Жаль, что синплифай не дает никаких намеков.
Согласен, но были статейки от синопсиса, что синтез поумнел и нонче неотвязан от имплементации.
C чипом XC6SLX150 развелось. Из корок только одна маленькая фифошка.
Чип xilinx spartan6 XC6SLX9 Синтез в synplify h-2013.03 Имплементация ise14.4 Результат синтеза: Register bits not including I/Os: 6252 (50%) Total LUTs: 3773 (61%) Region Summary: Other LUTs: 4338 Other Registers: 6252 Mapper successful! На этапе имплементации долго пыжится phase 9.8 global placement ... И не могет ((( Error:Place:543 - This design does not fit into the number of slices available... Синплифай настолько не знаком со слайсами и возможным роутингом?
Тут два чипа (проекта), у которых есть общие параметры. Не все параметры охота протаскивать до саб-саб...саб модуля. Про инстанцирование - в этом и подстава с пакетами, они не инстанциируются, и parameter ведет себя как localparam и тулами (questasim) незя переопределить.
timing in Vivado
gotcha ответил cerg19 тема в Работаем с ПЛИС, области применения, выбор
Должны быть констрейнты на эти тайминги. -
Если времянка и размеры впритык - не сильно помогут ядра процессора. Если позволяет религия, купить на время внешней мощи и протестировать (наприм. у амазона). Скорее всего надо переходить на другой чип. А так остается инкрементальная компиляция и частичная конфигурация.
Есть Partial Reconfiguration, может там что дельного найдете на уровне скриптов.
Собирать проект кусками пробовали?
)))) Где подводные камни? Как, Вы, храните конфиги, параметры. Как переопределяете?
Есть структура данных, например: typedef struct { logic signed [3:0] channel [5]; } data_t; typedef struct { logic [3:0] atype; data_t data; } packet_t; В модуле создается packet_t и приходится в коде инициализировать: Ключики не помогают: vlog -novopt +initreg+0 +initmem+0 Глюки Questasim 10.2с?
