Добрый день помогите с переходом с 20.1.1 на 21.1 ?
версия 20.1.1 работает wsl 1 установлен нормально .
при компиляции Platform Designer возникает ошибка :
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/intelfpga_lite/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: /mnt/c/intelfpga_lite/21.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../hps_AC_ROM.hex -inst_rom ../hps_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0010001110001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0010101110000 -DAC_ROM_MR1=0000000000110 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000011000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0010001101001 -DAC_ROM_MR0_DLL_RESET_MIRR=0010011101000 -DAC_ROM_MR1_MIRR=0000000000110 -DAC_ROM_MR2_MIRR=0000000011000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: UniPHY Sequencer Microcode Compiler
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Copyright (C) 2021 Intel Corporation. All rights reserved.
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Reading sequencer_mc/ac_rom.s ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Reading sequencer_mc/inst_rom.s ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing ../hps_AC_ROM.hex ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing ../hps_inst_ROM.hex ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Info: Writing sequencer/sequencer_auto_ac_init.c ...
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
Error: border: Execution of script generate_hps_sdram.tcl failed
Error: border: 2021.12.11.09:33:50 Info:
Error: border: ********************************************************************************************************************
Error: border:
Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
Error: border:
Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: border:
Error: border: 2021.12.11.09:33:53 Warning: Ignored parameter assignment device=5CSEMA5F31C6
Error: border: 2021.12.11.09:33:53 Warning: Ignored parameter assignment extended_family_support=true
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.seq: This module has no ports or interfaces
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.p0: p0.scc must be exported, or connected to a matching conduit.
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.as: as.afi_init_cal_req must be exported, or connected to a matching conduit.
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.as: as.tracking must be exported, or connected to a matching conduit.
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.c0: c0.status must be exported, or connected to a matching conduit.
Error: border: 2021.12.11.09:33:57 Warning: hps_sdram.p0: p0.avl must be connected to an Avalon-MM master
Error: border: 2021.12.11.09:33:57 Info: hps_sdram: Generating altera_mem_if_hps_emif "hps_sdram" for QUARTUS_SYNTH
Error: border: 2021.12.11.09:33:59 Info: pll: "hps_sdram" instantiated altera_mem_if_hps_pll "pll"
Error: border: 2021.12.11.09:33:59 Info: p0: Generating clock pair generator
Error: border: 2021.12.11.09:34:00 Info: p0: Generating hps_sdram_p0_altdqdqs
Error: border: 2021.12.11.09:34:04 Info: p0:
Error: border: 2021.12.11.09:34:04 Info: p0: *****************************
Error: border: 2021.12.11.09:34:04 Info: p0: Remember to run the hps_sdram_p0_pin_assignments.tcl
Error: border: 2021.12.11.09:34:04 Info: p0: script after running Synthesis and before Fitting.
это же проект при компиляции на 20.1.1 компилируется без ошибок.
Где моя ошибка при установке quartus 21.1 lite
Спасибо
