Little_boo 0 18 октября, 2006 Опубликовано 18 октября, 2006 (изменено) · Жалоба Я написал замечательный ФИФО, но у него есть один не достаток - он не синтезируется. Описание: library ieee; use ieee.std_logic_1164.all; entity fifo1 is port( reset : in std_logic; data_in_fifo1 : in std_logic_vector(31 downto 0); write_to_fifo1 : in std_logic; fifo1_got : in std_logic; data_TS: inout std_logic_vector(31 downto 0); fifo1_full : out std_logic; EN : in std_logic; fifo1_empty : out std_logic ); constant depth: integer := 32; constant width : integer :=32; end entity; architecture fifo1_arh of fifo1 is type cell is array (depth-1 downto 0) of std_logic_vector(width-1 downto 0); signal empty_internal,full_internal: std_logic; function ring_inc(num : integer; limit : integer) return integer is variable tmp : integer; begin if (num=limit) then tmp:=0; else tmp:=num+1; end if; return tmp; end function; begin main : process(write_to_fifo1,fifo1_got,reset,en) variable data_in : std_logic_vector(31 downto 0); variable f_write,f_read: natural :=0; variable data : cell; begin if rising_edge(write_to_fifo1) then if full_internal='0' then data(f_write):=data_in_fifo1; f_write:=ring_inc(f_write,depth-1); if f_write=f_read then fifo1_full <= '1'; full_internal <= '1'; else fifo1_empty <= '0'; empty_internal <= '0'; end if; end if; end if; if fifo1_got'event and fifo1_got = '1' then if (empty_internal='0') then data_in := data(f_read); f_read:=ring_inc(f_read,depth-1); if f_write = f_read then fifo1_empty <= '1'; empty_internal <= '1'; else fifo1_full <= '0'; full_internal <= '0'; end if; end if; end if; if en = '1' then data_TS <= data_in; else data_TS <= "ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ"; end if; if (reset='1') then for i in 0 to depth-1 loop for j in 0 to width-1 loop data(i)(j):='0'; end loop; end loop; data_TS <= "ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ"; f_read:=0; f_write:=0; fifo1_full<='0'; fifo1_empty<='1'; empty_internal<='1'; full_internal<='0'; end if; end process; end architecture; Видимо это из-за того, что в одном процессе один сигнал зависит он двух сигналов по фронту. Как это обойти не знаю. Разнести в разные процессы нельзя, т.к. сигнал должен управлять одним процессом, иначе возникнет не определенность. Должна быть методика, как это обойти. Поделитесь опытом. Стандартными ФИФО, типа Xilinовсий пользовать не хочется. Хочется своим, компактрным, чтоб можно было если надо что-нибудь поменять. Изменено 18 октября, 2006 пользователем Little_boo Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 18 октября, 2006 Опубликовано 18 октября, 2006 · Жалоба Обсуддалось в конфе НЕОДНОКРАТНО. Не ленитесь искать. ЗЫ И выкиньте код for i in 0 to depth-1 loop for j in 0 to width-1 loop data(i)(j):='0'; end loop; end loop; а то как-то неудобно такое читать. Hint - сброс делается за счет правильных указателей. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
andrew_b 14 18 октября, 2006 Опубликовано 18 октября, 2006 · Жалоба И выкиньте код for i in 0 to depth-1 loop for j in 0 to width-1 loop data(i)(j):='0'; end loop; end loop; а то как-то неудобно такое читать. +1. Вместо этого ужаса надо писать data <= (others => (others => '0')); Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 18 октября, 2006 Опубликовано 18 октября, 2006 · Жалоба +1. Вместо этого ужаса надо писать data <= (others => (others => '0')); Я имел в виду, что для fifo не надо обнулять внутреннюю память, а надо указатель чтения=указатель записи :)и Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Little_boo 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба Обсуддалось в конфе НЕОДНОКРАТНО. Не ленитесь искать. ЗЫ И выкиньте код for i in 0 to depth-1 loop for j in 0 to width-1 loop data(i)(j):='0'; end loop; end loop; а то как-то неудобно такое читать. Hint - сброс делается за счет правильных указателей. Я поискал, на первых двух станицах выданных поисковиком, ничего пожходящего не вычитал. Нащел только обсуждение ФИФО на Верилоге. Ща ещё гляну.. Так обнулять совсем не надо или просто конструкцию надо упростить? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба Читайте статьи про fifo на http://www.sunburst-design.com/papers Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
andrew_b 14 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба Такобнулять совсем не надо или просто конструкцию надо упростить? Тут прав Gate, а я нет. Если обнулять, то вы гарантированно получите(если получите) FIFO на триггерах, понеже у памяти сброса нет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба И еще совет: возьмите генератор памяти (в квартусе genmem.exe, для ксайлинкса не знаю как называется, но есть точно) и сгенерите исходники фифо и посмотрите, как там сделано. Код синтезируемый и rtl. Что касается обнуления - это операция лишняя, т.к. для фифо не бывает случая, когда происходит чтение данных, которые не были бы предварительно записаны. Как только Вы начнете обнулять память (за 1 такт конечно; никто не мешает написать КА, который последовательно пишет нули в память), она немедленно будет синтезироваться в виде набора триггеров, как справедливо указал andrew_b. Вам оно надо? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба По поводу синтезабельности - у Вас несколько клоков, т.е. дизайн асинхронный. Для fpga это зло, д.б. 1 клок. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Little_boo 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба Gate Про обнуление регистров я понял, это похоже и вправду не нужно. Но выходные сигналы "пустой", "полный" надо же обнулить? Иначе до первого обащения к буферу они будут не определены. А внутренние переменные? Потом проблема-то не в ресете. А как раз в 2-х клоках. По 1 пинет, по другому читает. Я и хотел спросить нельзя ли как-нибудь это дело граммотно расписать? Для Xilinxa есть Coregen, он генерит ФИФО. Но он требует несколько клоков инициализации, текста там на 100 страниц, т.е. саому что либо тяжело поправить. Плюс тело зашито в библиотеку Ксайлинковскую, а её не для всякого Софта её удается подцепить. Вот я и хотел найти готовый ФИФО(компактный), это ходовой элемент, я думал их понаписано кучи. Или разрулить свой. Как Вам кажется он вообще может стать рабочим? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
BSV 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба У Xilinx'а кроме Coregen'а имеются еще XAPP's. Там есть реализация ФИФО для Virtex (Spartan 2) с двумя независимыми тактовыми сигналами. Текста, конечно, многовато (но все-таки не сотня страниц), поскольку они почему-то generate не очень активно используют. Но если над этим кодом немного поработать творчески, на выходе получится очень даже ничего себе вещь. При большом желании его можно даже полностью параметризовать (глубина, ширина шин данных, тип памяти(распределенная, блочная), регистр на выходе (есть/нет)) - я это проделал для ФИФО с одним тактовым сигналом - восторг полный один и тот же модуль используется везде, только параметры в generic задать. Кстати, для инициализации адресных счетчиков и флагов (FULL, EMPTY) как раз сброс и нужен. Во время, когда он активен, оба флага стоят в 1, чтобы исключить запись и чтение во время сброса. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gate 0 19 октября, 2006 Опубликовано 19 октября, 2006 · Жалоба Little_boo, с genmem я Вас обманул - он генерит описание для моделирования, там везде барьеры для синтезатора translate_off :( Исходники фифо были на www.opencores.org Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Little_boo 0 20 октября, 2006 Опубликовано 20 октября, 2006 · Жалоба На сколько я Вас понял, код мой гиблый и реанимации не подвержен... :( Решил пока посмотреть, что нам предлагает Coregen, и посмотреть что за XAPP. Рекомендуете здесь искать свое счатье: http://www.opencores.org/cvsweb.shtml/ ? Поикс там видимо нереален... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
BSV 0 20 октября, 2006 Опубликовано 20 октября, 2006 · Жалоба Посмотрите XAPP175, XAPP258, только вместо стандартных элементов лучше использовать синтезируемую память - тогда появится возможность использовать все те вкусности, о которых я говорил выше. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Little_boo 0 25 октября, 2006 Опубликовано 25 октября, 2006 · Жалоба XAPP-ы не посмотрел, пошел по "легкому пути" - взял coregen (fifo_generator_v3.2). Cгенерил асинхронное FIFO 17 бит * 1024 слова с разными клоками на вход и выход, с остальными дефолтовыми опциями. Пока моделировал схему, все было прекрасно... потом синтезировал (ISE 8.2 SP3, Aldec 7.1 SP2, Sinplify 8.5). Сигналы управляющие FIFO: CLK_WR_TO_FIFO, DATA_WR_TO_FIFO, FIFO_WRITE_EN. На диаграмме видно, что последнее слово в каждом пакете данных, записываемое в FIFO 0xXEXF. Однако при выдаче данных FIFO выдает наружу 0xXCXD, а потом выставляет EMPTY. Спустя некоторое время оставшееся слово можно прочитать. Может кто нибудь сталкивался с подобным явлением и может объяснить такое странное поведение корки ?. real.rar Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
