Vasiliy 0 9 февраля, 2006 Опубликовано 9 февраля, 2006 · Жалоба CST Studio Suite 2006 aplac use valid FlexID ( or MACaddress) add for APLAC 1 Install ( from EFA licensegen) sentinel emulator,reboot,affirm the flexid 7-36c71805 is valid. 2 Save the next lines as license file,and set lm_license_file env to point this license file,done! ********* Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
dream_buyer 0 14 февраля, 2006 Опубликовано 14 февраля, 2006 · Жалоба where is the License file ? can you append it as an attachment ? Thanx in advance ! :a14: CST Studio Suite 2006 aplac use valid FlexID ( or MACaddress) add for APLAC 1 Install ( from EFA licensegen) sentinel emulator,reboot,affirm the flexid 7-36c71805 is valid. 2 Save the next lines as license file,and set lm_license_file env to point this license file,done! ********* Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
navuho 0 3 марта, 2006 Опубликовано 3 марта, 2006 · Жалоба This list provides an overview of some of the most important changes in Service Pack 4 of CST ICROWAVE STUDIO®2006. General / Environment The VBA-command '#uses will be executed correctly now. The history list is now refreshed when switching back to the main view. The tree does no longer loose the focus if a 1D curve is deleted. Shortcuts F7,Ctrl+C and Ctrl+V also work when parameter list edit field is active. Application did not terminate when running the optimizer by command line. Distributed computing Front end did not exit after parameter sweep with distributed computing started via command line. Not all results were merged after distributed solver run. Fixed problem on terminal servers when logging off from Windows while DC calculates a job. Solver messages where not send to front end after reconnect. Reduced memory consumption of Main Controller and Solver Server while sending large files. Solvers did not store results to cache properly when using DC. Import / Export Added improved arc recognition to GERBER import. DXF and GDSII imports can now be executed as macro again. Problem with units for IGES and Step Import/Export repaired. ASCII-Export for surface loss plots enabled. ASCII-Export of surface currents: added column for area. Modeler New error message in command tracefromcurve if resulting solid edges are self-intersecting. Fixed problems during fast history updates in combination with monitors. Repaired problem if a closed current path or a closed wire happened to be outside the mesh due to a symmetry. A mesh is no longer deleted after editing a curve if the bounding box does not change. Plane rotation in mesh view now takes the center of bounding box if selected instead of origin. Suppressed opening of frequency range dialog after clicking on Mesh Control if no solid is defined. Deletion of a user defined view works again. Fixed problem during parameter sweep, in combination with parameterized imports and fast model updates. Problem with incomplete dispersive material settings has been repaired. Meshing / Matrix calculator Problem within the matrix calculator for structures with very small gaps resolved.. The tetrahedral preview mesh was not invalidated when the "add space before mesh generation" in the solver specials changed. Transient solver Improved accuracy of inhomogeneous boundary check for plane wave excitation. Re-normalization was not applied for models with two ports any more if only one port was excited. Frequency domain solver An attempt to free memory for the tetrahedral frequency domain monitor calculation did not succeed. Fixed mismatch between the tetrahedral frequency domain excitation number and the order of discrete ports, if the ports were not sorted by name. Parameter sweep watches, result templates and optimizer results were missing for the resonant frequency domain solver. Resonant frequency domain solver did not start within the optimizer if Calculate modes only is used. Fixed convergence problems for low frequency applications of the hexahedral frequency domain solver. Post processing The adaptive hexahedral mesh refinement did only store the last adaptation pass in the result cache. Clamp to Range option does not produce inconsistencies (color ramp labels vs. info text) anymore. For farfield with tetrahedral mesh the radiation efficiency with more than one defined monitor has been corrected. Fixed field magnitude and radiation efficiency for discrete ports with symmetries. Improved passivity calculation of Network MOR. VBA / Macros Implemented VBA command Pick.ExportFaceTriangles. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
nadie 0 3 марта, 2006 Опубликовано 3 марта, 2006 · Жалоба Залейте, пожалуйста, Service Pack 4 на местный ftp. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Andrew10 0 12 апреля, 2006 Опубликовано 12 апреля, 2006 · Жалоба Привет всем! На сайте _fxp.pcbtech.net появилcя каталог "CST_STUDIO_SUITE_2006 By Crocos" с файлами CST_STUDIO_SUITE_2006.mdf и CST_STUDIO_SUITE_2006.mds Может ли кто-нибудь просветить, что это такое? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Sagitarius 0 12 апреля, 2006 Опубликовано 12 апреля, 2006 · Жалоба Привет всем! На сайте _fxp.pcbtech.net появилcя каталог "CST_STUDIO_SUITE_2006 By Crocos" с файлами CST_STUDIO_SUITE_2006.mdf и CST_STUDIO_SUITE_2006.mds Может ли кто-нибудь просветить, что это такое? Образ диска это. Алкоголь 120% вам поможет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
nadie 0 12 апреля, 2006 Опубликовано 12 апреля, 2006 · Жалоба To Andrew10 Напишите пожалуйста в приват, как логиниться на _fxp.pcbtech.net Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Andrew10 0 12 апреля, 2006 Опубликовано 12 апреля, 2006 · Жалоба Образ диска это. Алкоголь 120% вам поможет. Интересно, что там внутри этого образа, если размер файла *.mdf всего 53.19 Мгб. Проверить смогу завтра, т.к. скаченные файлы на работе. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Sagitarius 0 12 апреля, 2006 Опубликовано 12 апреля, 2006 · Жалоба Образ диска это. Алкоголь 120% вам поможет. Интересно, что там внутри этого образа, если размер файла *.mdf всего 53.19 Мгб. Проверить смогу завтра, т.к. скаченные файлы на работе. Там диск с CST 2006 (1.71Gb), но ключика нет :angry2: Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Andrew10 0 13 апреля, 2006 Опубликовано 13 апреля, 2006 · Жалоба Добрый день всем! А может ли кто-нибудь объяснить ситуацию с лекарством для CST Studio Suite 2006 ? Варианты: 1. Лекарства пока в принципе нет. 2. Лекарство есть, но где взять неизвестно. 3. Лекарство есть и можно взять там-то и там-то. Отвечать можно в ПМ. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Andrew10 0 24 апреля, 2006 Опубликовано 24 апреля, 2006 · Жалоба Привет всем! На сайте _fxp.pcbtech.net появилcя каталог "CST_STUDIO_SUITE_2006 By Crocos" с файлами CST_STUDIO_SUITE_2006.mdf и CST_STUDIO_SUITE_2006.mds Сегодня вдруг отозвался _ftp.laogu.com и обнаружилось, что на этом сайте файл CST_STUDIO_SUITE_2006.mdf имеет размер ~ 450 Мгб а на _ftp.pcbtech.net - 54 Мгб. К чему бы это? У меня доступ на laogu проявляется крайне редко и на очень короткий срок (~10 минут), поэтому сам скачать оттуда ничего не могу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Sagitarius 0 10 мая, 2006 Опубликовано 10 мая, 2006 · Жалоба Доброе время суток! В чем может быть проблема? В CST 5.0 все было нормально, а вот в CST 2006 кнопка "Freqency domain solver" вообще не активна. Удачи. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
smile 0 10 мая, 2006 Опубликовано 10 мая, 2006 · Жалоба Доброе время суток! В чем может быть проблема? В CST 5.0 все было нормально, а вот в CST 2006 кнопка "Freqency domain solver" вообще не активна. Удачи. Уверены, что есть лицензия на "Freqency domain solver" ? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Sagitarius 0 10 мая, 2006 Опубликовано 10 мая, 2006 · Жалоба Доброе время суток! В чем может быть проблема? В CST 5.0 все было нормально, а вот в CST 2006 кнопка "Freqency domain solver" вообще не активна. Удачи. Уверены, что есть лицензия на "Freqency domain solver" ? Нет не уверен :( А как начинается строка в лицензионном файле которая за "Freqency domain solver" отвечает? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
demonis 0 10 мая, 2006 Опубликовано 10 мая, 2006 · Жалоба Тут все больше разговор верется о CST_STUDIO_SUITE. А где можно сегодня взять только CST Microwave Studio 2006 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
