VladislavS 29 4 сентября, 2019 Опубликовано 4 сентября, 2019 · Жалоба Да ладно. Вот лог. Тут я пару раз вставил вытащил кабель. А в конце отключил в диспетчере устройств с воткнутым кабелем. Спойлер Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 27 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 28 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 29 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 30 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
retro55 0 5 сентября, 2019 Опубликовано 5 сентября, 2019 (изменено) · Жалоба 13 hours ago, VladislavS said: Да ладно. Вот лог. Тут я пару раз вставил вытащил кабель. А в конце отключил в диспетчере устройств с воткнутым кабелем. Reveal hidden contents Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 27 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 28 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 29 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND Int_WKUP Int_USBRST GET_Device_Descriptor 64 bytes Int_USBRST SET_ADDRESS 30 GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 255 bytes GET_String_Serial 255 bytes GET_String_LangID 255 bytes GET_String_Product 255 bytes GET_Device_qualifier_Descriptor 10 bytes GET_Device_Descriptor 18 bytes GET_Configuration_Descriptor 9 bytes GET_Configuration_Descriptor 67 bytes GET_Configuration_Descriptor 265 bytes SET_CONFIGURATION 1 GET_LINE_CODING SET_CONTROL_LINE_STATE SET_LINE_CODING SET_LINE_CODING DATA GET_LINE_CODING Int_SUSPEND И где там resume? может WKUP ? void HAL_PCD_ResumeCallback(PCD_HandleTypeDef *hpcd) { /* USER CODE BEGIN 3 */ /* USER CODE END 3 */ USBD_LL_Resume((USBD_HandleTypeDef*)hpcd->pData); } Ставлю в этой функции точку прерыванию и она здесь не останавливается при подключении отключении USB. Зато в этой функции void HAL_PCD_SuspendCallback(PCD_HandleTypeDef *hpcd) { /* Inform USB library that core enters in suspend Mode */ USBD_LL_Suspend((USBD_HandleTypeDef*)hpcd->pData); __HAL_PCD_GATE_PHYCLOCK(hpcd); /*Enter in STOP mode */ /* USER CODE BEGIN 2 */ usb_connect = 0 ; // if (hpcd->Init.low_power_enable) { /* Set SLEEPDEEP bit and SleepOnExit of Cortex System Control Register */ SCB->SCR |= (uint32_t)((uint32_t)(SCB_SCR_SLEEPDEEP_Msk | SCB_SCR_SLEEPONEXIT_Msk)); } /* USER CODE END 2 */ } останавливается два раза как при подключении так и при отключении. А определить подключение это или отключение невозможно. Изменено 5 сентября, 2019 пользователем retro55 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
VladislavS 29 5 сентября, 2019 Опубликовано 5 сентября, 2019 · Жалоба 5 часов назад, retro55 сказал: определить подключение это или отключение невозможно. Подключение проще всего по Reset определять. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
