srm 0 26 мая, 2010 Опубликовано 26 мая, 2010 (изменено) · Жалоба aaarrr, ок. спасибо за желание помочь. template <uint_t i_timer> class CTimerImpl { private: static const AT91PS_TC m_timer; static const uint_t m_timer_id = i_timer == 0 ? AT91C_ID_TC0 : i_timer == 1 ? AT91C_ID_TC1 : i_timer == 2 ? AT91C_ID_TC2 : 0; private: static const uint32_t m_max_ticks = 0x10000; static const uint32_t m_interrupt_priority = 1; public: static CTimerImpl<i_timer>* m_instance; private: float m_max_time_ms; float m_ticks_per_ms; private: static void interrupt_handler() { uint32_t mask = m_timer->TC_SR; uint32_t x = 0; x = mask; // m_instance->on_interrupt(mask); } inline bool on_interrupt(uint32_t mask) { if (mask & AT91C_TC_CPAS) on_event_a(); if (mask & AT91C_TC_CPBS) on_event_b(); if (mask & AT91C_TC_CPCS) on_overflow(); return (mask & (AT91C_TC_CPAS | AT91C_TC_CPCS | AT91C_TC_CPBS)) != 0; } uint32_t calculate_optimal_divider(float max_period_ms) { const float cycles_per_ms = CSystem::get_instance()->get_frequency() / 1000.0f; const float max_time_ms = m_max_ticks / cycles_per_ms; m_max_time_ms = max_time_ms * 2.0f; m_ticks_per_ms = cycles_per_ms / 2.0f; if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV1_CLOCK; m_max_time_ms = max_time_ms * 8.0f; m_ticks_per_ms = cycles_per_ms / 8.0f; if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV2_CLOCK; m_max_time_ms = max_time_ms * 32.0f; m_ticks_per_ms = cycles_per_ms / 32.0f; if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV3_CLOCK; m_max_time_ms = max_time_ms * 128.0f; m_ticks_per_ms = cycles_per_ms / 128.0f; if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV4_CLOCK; m_max_time_ms = max_time_ms * 1024.0f; m_ticks_per_ms = cycles_per_ms / 1024.0f; if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV5_CLOCK; __STL_THROW(invalid_argument("vary big period")); return AT91C_TC_CLKS_TIMER_DIV5_CLOCK; } protected: virtual void on_event_a() = 0; virtual void on_event_b() = 0; virtual void on_overflow() = 0; void initialize(float max_time_ms) { m_instance = this; AT91F_AIC_CfgPMC(); AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id); // Disable TC clock m_timer->TC_CCR = AT91C_TC_CLKDIS; AT91F_TC_InterruptDisable(m_timer, 0xFFFFFFFF); // Clear status register uint32_t mask = m_timer->TC_SR; mask = ~mask; // Set mode m_timer->TC_CMR = calculate_optimal_divider(max_time_ms) | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0; // enable interrupts AT91F_TC_InterruptEnable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS); // configure interrupt handler AT91F_AIC_ConfigureIt( AT91C_BASE_AIC, m_timer_id, m_interrupt_priority, AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL, (void(*)())interrupt_handler ); // enable interrupt AT91F_AIC_EnableIt(AT91C_BASE_AIC, m_timer_id); } void deinitialize() { stop(); // disable interrupts AT91F_TC_InterruptDisable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS); // mode m_timer->TC_CMR = 0; // perepheral clock AT91F_PMC_DisablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id); } void set_time_a(float time_a_ms) { m_timer->TC_RA = (uint32_t)(std_math::min(time_a_ms, m_max_time_ms) * m_ticks_per_ms); } void set_time_b(float time_b_ms) { m_timer->TC_RB = (uint32_t)(std_math::min(time_b_ms, m_max_time_ms) * m_ticks_per_ms); } void set_time_reset(float period_ms) { m_timer->TC_RC = (uint32_t)(std_math::min(period_ms, m_max_time_ms) * m_ticks_per_ms); } inline void start() { m_timer->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG; } inline void stop() { m_timer->TC_CCR = AT91C_TC_CLKDIS; } }; template <> const AT91PS_TC CTimerImpl<0>::m_timer = AT91C_BASE_TC0; template <> const AT91PS_TC CTimerImpl<1>::m_timer = AT91C_BASE_TC1; template <> const AT91PS_TC CTimerImpl<2>::m_timer = AT91C_BASE_TC2; template <uint_t i_timer> CTimerImpl<i_timer>* CTimerImpl<i_timer>::m_instance; вызываю так: CTimer<0> timer(10.0f); timer.set_time_a(2.0f); timer.set_time_b(6.0f); timer.set_time_reset(8.0f); timer.start(); while(1); Изменено 26 мая, 2010 пользователем aaarrr Оформление цитаты исходника Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
srm 0 26 мая, 2010 Опубликовано 26 мая, 2010 (изменено) · Жалоба в симуляторе Keil всё пучком :07: максимально упростил код. кому не лень, пожалуйста, скомпилируйте у себя и посмотрите чему равен mask. может у меня контроллер косячный... void timer_handler() { unsigned int mask = AT91C_BASE_TC0->TC_SR; mask ++; } int main() { // enable PMC AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_FIQ; AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_TC0; // set mode AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKDIS; AT91C_BASE_TC0->TC_IDR = 0xFFFFFFFF; AT91C_BASE_TC0->TC_SR; AT91C_BASE_TC0->TC_CMR = AT91C_TC_CLKS_TIMER_DIV5_CLOCK | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0; // enable interrupts on compare A, B, C AT91C_BASE_TC0->TC_IER = AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS; AT91C_BASE_TC0->TC_RA = 100; AT91C_BASE_TC0->TC_RB = 200; AT91C_BASE_TC0->TC_RC = 400; // start AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG; // set irq handler AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_TC0; AT91C_BASE_AIC->AIC_SMR[AT91C_ID_TC0] = 0; AT91C_BASE_AIC->AIC_SVR[AT91C_ID_TC0] = (unsigned int)timer_handler; AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_TC0; // enable interrupts from timer AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_TC0; while (1); } Изменено 26 мая, 2010 пользователем srm Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
srm 0 27 мая, 2010 Опубликовано 27 мая, 2010 · Жалоба Вроде, немного разобрался. Если поставить значение делителя 1024 и значения регистров A ~ 10000, B ~ 40000, C ~ 60000, то ошибка перестаёт повторяться. Я несколько изменил тестовый пример. в обработчике делаю так: volatile static int ss; void timer_handler() { unsigned int mask = AT91C_BASE_TC0->TC_SR; ss = (mask & (AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS)) == (AT91C_TC_CPAS | AT91C_TC_CPBS); } А в программе постоянно вывожу значение ss: while (1) { printf("%d", ss); } Если делитель = 32, A = 0x7331, B = 0xA681, С = 0xD335. Т.о. Время между двумя сравнениями 13136*32/48000 = 8,75 мс. печатается: 00000100001000001000000100000100000100000010000010000010000010000010000001000001 0000010000010000001000001000001 ну не может прерывание обрабатываться 8 миллисекунд! тем более, что при уменьшении времени (вплодь до десятых долей мс) выводится примерно то же самое. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
srm 0 1 июня, 2010 Опубликовано 1 июня, 2010 (изменено) · Жалоба В реалтайме, вроде, всё норм. У меня 12 сервомеханизмов, шимы под них генерирует таймер at91sam7s256. Всё замечательно, сервы крутятся именно так, как мне нужно. Но, опять всплыл подводный камень и опять с real time timer'ом. если я в цикле изменяю позицию серв: while (true) { for (uint32_t x = 0; x < 20000; x ++) { servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); servo2.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); // ... servo11.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); } for (uint32_t x = 0; x < 20000; x ++) { servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); servo2.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); // ... servo11.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); } } , то всё прекрасно. Если я синхронизирую позицию по таймеру, то сервы время от времени начинают уезжать. т.е. двигается медленно, с постоянной скоростью в одну сторону, потом раз - и резко ушла в другую, потом снова медленно двигается вперёд. повторяется, примерно, один раз за 4 прохода цикла (20 сек): while (true) { start_time = watch->get_time_us(); while (true) { uint64_t current_time = watch->get_time_us(); if (current_time - start_time > 5000000) break; float x = (current_time - start_time) / 5000000.0f; servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position)); } start_time = watch->get_time_us(); while (true) { uint64_t current_time = watch->get_time_us(); if (current_time - start_time > 5000000) break; float x = (current_time - start_time) / 5000000.0f; servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position)); } } Изменено 1 июня, 2010 пользователем srm Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 1 июня, 2010 Опубликовано 1 июня, 2010 · Жалоба Ну а get_time_us() что собой представляет? Желание использовать RTT как источник информации о времени представляется, мягко говоря, несколько странным: таймер работает от RC-генератора, частота которого по определению может бултыхаться в широких пределах. Единственное разумное его применение - это поднимать процессор из idle по будильнику. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
srm 0 1 июня, 2010 Опубликовано 1 июня, 2010 (изменено) · Жалоба aaarrr, я, вроде, по применению и использую. насколько я понял из даташита, real time timer служит как раз для получения информации о текущем времени. Тем более, что большая точность мне не нужна. Время мне нужно для того, чтобы движения робота были синхронны. Ну и плюс для работы ПИД регуляторов. get_time_us всего лишь запрашивает показание счётчика и переводит тики в микросекунды. По ходу дела, все эти глюки происходят из-за jtag'a. если запускать программу на выполнение без отладки, при отключенном Jtag'е, то глюки, вроде, не повторяются.. В общем, magic! Изменено 1 июня, 2010 пользователем srm Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 1 июня, 2010 Опубликовано 1 июня, 2010 · Жалоба aaarrr, я, вроде, по применению и использую. насколько я понял из даташита, real time timer служит как раз для получения информации о текущем времени. get_time_us всего лишь запрашивает показание счётчика и переводит тики в микросекунды. RC Oscillator Frequency: Min. 22 Typ. 32 Max. 42 kHz Т.е. плюс-минус лапоть. Устраивает такое время? Для формирования точных интервалов существует Periodic Interval Timer. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
srm 0 1 июня, 2010 Опубликовано 1 июня, 2010 · Жалоба мдя... робот будет ходить либо вдвое быстрее, либо вдвое медленнее :)))))) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 1 июня, 2010 Опубликовано 1 июня, 2010 · Жалоба мдя... робот будет ходить либо вдвое быстрее, либо вдвое медленнее :)))))) Вот именно. Тут не 5%, а совсем неприлично. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Nikitoc 0 25 июня, 2010 Опубликовано 25 июня, 2010 (изменено) · Жалоба Добрый день. Дабы не плодить похожих тем решил спросить здесь. Пытаюсь вызвать прерывание от RTTC. Работаю в Keil. Инициализирую так: AT91S_AIC *pAIC = AT91C_BASE_AIC; void INIT_RTTC (int Alarm_Value_seconds) { /* Initialize Real Time Timer */ pRTTC->RTTC_RTAR = (Alarm_Value_seconds - 1); pAIC->AIC_IECR = AT91C_ID_SYS; pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST | AT91C_AIC_SRCTYPE_POSITIVE_EDGE; pRTTC->RTTC_RTMR = (AT91C_RTTC_RTPRES & 0x8000) | AT91C_RTTC_ALMIEN | AT91C_RTTC_RTTRST; } Обработчик объявляю так: __irq void RTTC_Interrupt_Handler (void) { if ((pRTTC->RTTC_RTSR & AT91C_RTTC_ALMS) != 0) { LED_ON; } else { LED_OFF; } } В стартапе этот кусок поменял так: Reset_Addr DCD Reset_Handler Undef_Addr DCD Undef_Handler SWI_Addr DCD SWI_Handler PAbt_Addr DCD PAbt_Handler DAbt_Addr DCD DAbt_Handler DCD 0 ; Reserved Address IRQ_Addr DCD IRQ_Handler FIQ_Addr DCD FIQ_Handler Undef_Handler B Undef_Handler SWI_Handler B SWI_Handler PAbt_Handler B PAbt_Handler DAbt_Handler B DAbt_Handler PRESERVE8 IMPORT RTTC_Interrupt_Handler IRQ_Handler B RTTC_Interrupt_Handler FIQ_Handler B FIQ_Handler В общем, прерывание не происходит. В чем ошибка, подскажите, пожалуйста. P.S. Отладчиком смотрю содержимое регистра RTT_SR - флаги ALMS и RTCINC -поднимаются и SYSIRQ - находится в состоянии pending. Однако, перехода по вектору не происходит... Изменено 25 июня, 2010 пользователем Nikitoc Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 25 июня, 2010 Опубликовано 25 июня, 2010 · Жалоба AT91C_AIC_SRCTYPE_POSITIVE_EDGE Ну почему, почему все упорно пытаются работать по фронту, а? Для внутренних источников это в 99.9% случаев не нужно, для внешних - в 90%. В остальных 0.1% и 10% нужно проявлять предельную внимательность при обслуживании такого прерывания. В вашем случае отсутствует сброс источника в AIC, и запись в EOICR (хотя если принять во внимание переделку в стартапе, последнее уже несущественно). А уж прерывания RTT - это просто одно большое недоразумение. Для их использования нужно иметь ну очень веские основания. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Nikitoc 0 25 июня, 2010 Опубликовано 25 июня, 2010 (изменено) · Жалоба Ну почему, почему все упорно пытаются работать по фронту, а? Для внутренних источников это в 99.9% случаев не нужно, для внешних - в 90%. В остальных 0.1% и 10% нужно проявлять предельную внимательность при обслуживании такого прерывания. В вашем случае отсутствует сброс источника в AIC, и запись в EOICR (хотя если принять во внимание переделку в стартапе, последнее уже несущественно). А уж прерывания RTT - это просто одно большое недоразумение. Для их использования нужно иметь ну очень веские основания. Изменил инициализацию таким образом: void INIT_RTTC (int Alarm_Value_seconds) { /* Initialize Real Time Timer */ pRTTC->RTTC_RTAR = (Alarm_Value_seconds - 1); pAIC->AIC_IECR = AT91C_ID_SYS; pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST; pAIC->AIC_ICCR = AT91C_ID_SYS; pRTTC->RTTC_RTMR = (AT91C_RTTC_RTPRES & 0x8000) | AT91C_RTTC_ALMIEN | AT91C_RTTC_RTTRST; А обработчик так: __irq void RTTC_Interrupt_Handler (void) { if ((pRTTC->RTTC_RTSR & AT91C_RTTC_ALMS) != 0) { LED_ON; } else { LED_OFF; } pAIC->AIC_EOICR = 0; // Reset AIC logic } Все равно не заходит! :crying: Изменено 25 июня, 2010 пользователем Nikitoc Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 25 июня, 2010 Опубликовано 25 июня, 2010 · Жалоба Изменил инициализацию таким образом: ICCR работает только для прерываний по фронту, писать его здесь бессмысленно. А обработчик так: EOICR нужно писать в любом случае, если уж оказались в прерывании, а не по каким-либо еще условиям. Глобально прерывания разрешены? Отладчик малину не портит, часом? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Nikitoc 0 25 июня, 2010 Опубликовано 25 июня, 2010 (изменено) · Жалоба Глобально прерывания разрешены? Ээээмммм.... А где они разрешаются? Изменено 25 июня, 2010 пользователем Nikitoc Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 69 25 июня, 2010 Опубликовано 25 июня, 2010 · Жалоба Разрешаются сбросом бита I регистра CPSR процессора. Из-под 'C' обычно предусматривается доступ в виде intrinsic-функций типа __enable_inerttupts(), или чего-то подобного - смотрите хелп своего компилятора. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
