SL555 0 12 октября, 2009 Опубликовано 12 октября, 2009 (изменено) · Жалоба нашел на ebay такой кид: Samsung S3C2440 ARM9 Board + 3.5" TFT LCD Touch Screen CPU - Samsung S3C2440A 400MHz, Max freq. 533Mhz SDRAM - 64MB SDRAM - 32bits Data Bus width - 100MHz Clock Flash - 64MB Nand Flash, - 2MB Nor Flash, BIOS installed LCD - 4 wire resistive touch screen interface - Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels - Up to 64K color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels - In box NEC 256K color 240x320/3.5 inches TFT screen, with touch screen Interface and Resource - 1 10/100M Ethernet RJ-45(DM9000) - 3 Serial Ports(1 RS232 with CTS and RTS) - 1 USB Host - 1 USB Slave Type B - 1 SD Card Interface - 1 Stereo audio out, 1 Micro In - 1 10-Pin JTAG - 4 USER LEDs - 6 USER buttons - 1 PWM Beeper - 1 POT can be used for A/D converter adjust - 1 AT24C08 for I2C test - 1 20-Pin Camera Interface - 1 Battery for RTC - Power In(5V), with switch and lamp Oscillator Freq. - 12MHz RTC - Internal Expand Interface - 1 34-Pin 2.0mm GPIO - 1 40-Pin 2.0mm System Bus Dimension - 100 x 100(mm) OS Support - Linux 2.6.13 - Windows CE.Net 5.0 2. Content List: (1) 1 S3C2440 board (Preload with Linux) (2) 1 Serial cable (3) 1 Net cable (4) 1 USB cable (5) 5V power adapter (6) 1 JTAG board(for H-JTAG) (7) 1 DVD-ROM with product reference (8) 1 NEC LCD: 3.5", 240x320, with touch panel 3. Material list on DVD-ROM (1) H-JTAG Debugger (2) Windows Flash Programmer SJF2440 (3) Linux Nand Flash Programmer Jflash-2440(source code included) (4) Serial tool CRT, dnw (5) Bitmap to C Language transfer tool (6) USB Driver(WindowXP/2000) (7) vivi source code(linux bootloader) (8) LED test program(ADS1.20 project) (9) 2440test program(ADS1.20 project), include : key test, RTC test, ADC test, IIS Audio play(wav), IIS Audio record, touch screen test, I2C test, Samsung 3.5"LCD, 640x480 TFT test (10) WindowsCE BSP and sample project files. (11) Pre-compiled Win CE image for evaluation (12) Linux tool and kernel source codes - arm-linux-gcc-3.3.2 to compile Qtopia - arm-linux-gcc-3.4.1 to compile kernel - arm-linux-gcc-2.95.3 to compile vivi - yaffs file system image maker -mkyaffsimage - linux-2.6.13 for S3C2440 kernel source code(include DM9000, LCD driver, Audio, Touch screen, YAFFS Source code, SD Card, RTC, Expand serial driver, USB Camera,USB Mouse and Keyboard, U-Disk) (13) Pre-compiled Linux image for evaluation (14) Qtopia source codes, web browser source codes (15) Schematics(Protel99SE/PDF) http://cgi.ebay.com/Samsung-S3C2440-ARM9-B...=item27aa521a12 за 88 $, Кто ни будь побывал данный девайс ? Что то слишком дешево они стоят : http://shop.ebay.com/i.html?_trkparms=65%2...br=1&_pgn=1 Изменено 12 октября, 2009 пользователем SL555 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
HARMHARM 0 12 октября, 2009 Опубликовано 12 октября, 2009 · Жалоба Может быть дешево, но не слишком. Я брал какой-то кит на S3C2440 или 2442 у esky-sh. Доставка EMS без проблем за неделю. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Dron_Gus 2 16 октября, 2009 Опубликовано 16 октября, 2009 · Жалоба Я пробовал. Хороший девайс. Все, что написано правда. :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DRUID3 0 16 октября, 2009 Опубликовано 16 октября, 2009 · Жалоба Нифига себе! За ~90$ это просто мечта. Берите и не задумывайтесь! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 140 8 января, 2010 Опубликовано 8 января, 2010 · Жалоба Я пробовал. Хороший девайс. Все, что написано правда. :)Набрел на производителя: http://www.friendlyarm.net/. Но нигде не могу найти информации о потреблении. Интересует в качестве "мозга" для необслуживаемой системы с удаленным доступом, т.е. интересует потребление без дисплея. Dron_Gus, у вас нет такой информации или возможности измерить? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
RobFPGA 34 9 января, 2010 Опубликовано 9 января, 2010 · Жалоба Приветствую! А как такая плата (и аналогичная) могут вести себя в условиях ЭМ помех? Хочется поставить такой модуль для контроля блока питания. Рюшечки менюшечки - красота. Но блок 15 KWt 5KV. Чувствую будут проблемы. Как вообще резистивные тачскрины - чувствительны к наводкам и помехам. Успехов! Rob. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Itch 0 10 января, 2010 Опубликовано 10 января, 2010 · Жалоба Набрел на производителя: http://www.friendlyarm.net/. Но нигде не могу найти информации о потреблении. Интересует в качестве "мозга" для необслуживаемой системы с удаленным доступом, т.е. интересует потребление без дисплея. Dron_Gus, у вас нет такой информации или возможности измерить? Где-то на форуме esky-sh отвечал, что ~300мА А как такая плата (и аналогичная) могут вести себя в условиях ЭМ помех? Плата 4 слойка, так что наверное будет сбоить. Своей пока нету, на днях должны доставить. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Marat_MMX 0 11 февраля, 2010 Опубликовано 11 февраля, 2010 · Жалоба Где-то на форуме esky-sh отвечал, что ~300мА Плата 4 слойка, так что наверное будет сбоить. Своей пока нету, на днях должны доставить. Во сколько вышло вместе с доставкой, если не секрет? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Itch 0 12 февраля, 2010 Опубликовано 12 февраля, 2010 · Жалоба Плата 3.5LCD + камера+WiFi в 139$ с доставкой. Покупал у esky-sh. Шло правда долго, т.к. по непонятной причине посылка месяц лежала в Китае, потом пнул китайца, он пнул почту и через пару недель наконец-то получил ее :) Особо пока не разбирался. Удивило обилие деталей на плате дисплея LCD. По умолчанию прошит линукс + Qtopia, все работает очень быстро. Ток пока не измерял. Вобщем, думаю, очень неплохой стенд для погружения в Embedded. З.Ы. У меня обновленная версия платы уже с 128МБ flash, так что ищите такую же. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Vasily_A 0 13 февраля, 2010 Опубликовано 13 февраля, 2010 · Жалоба а qtopia некитайская под эту плату есть, так чтоб не собирать, а простото готовый имидж скачать? иероглифы напрягают :( плата куплена на ебае за примерно $110 с доставкой, шла больше месяца еще прикол - постоянно используемый нульмодемный шнурок почему то непонравился связке плата-комп, тот что из коробочки - пошел... общие впечатления - приятные, жаль с фпга и дисплеем одновременно за похожие деньги ничего нет... еще вопрос - а ftp сложно на ней поднять? стартуем с SD, и правим ее файловую систему по фтп... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Itch 0 15 февраля, 2010 Опубликовано 15 февраля, 2010 · Жалоба У меня Qtopia как раз английская, а вот образ CE5.0 на диске китайский. ftp работает в линуксе сразу, без дополнительных телодвижений. По поводу токов потребления, стоит WinCE 5.0, напряжение 5 вольт: плата+LCD = 0.4-0.6А, во время простоя в винде 0.46А плата без LCD = 0.2-0.35А, во время простоя примерно 0.25А Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Vasily_A 0 16 февраля, 2010 Опубликовано 16 февраля, 2010 · Жалоба У меня Qtopia как раз английская, а вот образ CE5.0 на диске китайский. скиньте образ английской Qtopia на почту [email protected] заранее спасибо! це5 у меня тоже на плате был китайский, но есть английский триальный (а может и полноценный, я не проверял) под эту плату. могу послать (или ссылку отыскать откуда брал...) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Faris 1 4 мая, 2010 Опубликовано 4 мая, 2010 · Жалоба Хочу узнать, нужен ли дополнительно программатор для этого чудного девайса? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
MAXXXX 0 26 мая, 2010 Опубликовано 26 мая, 2010 · Жалоба Я тоже купил подобный девайс. Установлена Windows 5.0 SE китайская. Диск на 70 процентов на китайском. Не могу понять как к этому киту подступиться. Подскажите где найти инструкцию по переустановке ПО на английском или русском. И вобще интересна любая информация по этому прибору. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
kalipso 0 31 мая, 2010 Опубликовано 31 мая, 2010 · Жалоба Тоже приобрел этот девайс. Покрутил в руках и попробовал установить Qtopia, Android & WinCE 5.0-6.0. Пока остановился на 5-ой винде. Попробовал собрать ядро 5 винды конечно же триал с помощью Платформ Билдера. Все ок. Немного с неточностями собрал, но как факт - получилось. Теперь задача стоит достучаться до портов и встроенных драйверов шины имеющихся на борту проца ну и попутно до всех вкусностей самого процессора. Пока все это пытаюсь сделать таким образом - сама форма приложения для винды пишется на Basic4ppc с подключением dll файла в котором описаны регистры всех вкусностей процессора. В свою очередь dll написана на VB .NET. Понимаю что очень выковыристо, но в линуксе пока не силен (возможно в нем проще). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
