Axel 1 21 июня, 2009 Опубликовано 21 июня, 2009 · Жалоба В конце года Cypress обещает новые PSoCи с Cortex'ом. Параметры и набор периферии выглядят прилично: ----------------------------------------------- Features 32-bit ARM Cortex-M3 CPU Core Flash program memory, up to 256 KB (100,000 write cycles) Up to 64 KB SRAM memory 2 KB EEPROM memory, 1 million cycles, 20 year retention Low voltage, ultra low power Wide operating voltage range: 1.7V to 5.5V High efficiency boost from 0.5V 500 μA at 1 MHz, 2 mA at 6 MHz Four sleep modes including: • 300 nA hibernate mode with RAM retention • 2 μA sleep mode with real time clock, low voltage reset interrupt, and watchdog timeout Versatile IO system 28 to 72 IO (62 GPIO, 8 SIO, 2 USBIO) Any GPIO to any digital or analog peripheral routability 1.2 to 5.5V interface voltages Maskable, independent IRQ on any pin or port Schmitt trigger TTL inputs LCD direct drive up to 46x16 segments All GPIO configurable as open drain high/low, pull up/down, high Z, or strong output Configurable GPIO pin state at power on reset (POR) 25 mA sink on SIO Digital peripherals 16 to 24 programmable PLD-based Universal Digital Blocks (UDB) Full CAN 2.0b 16 RX, 8 TX buffers Full-Speed (FS) USB 2.0 12 Mbps peripheral Up to four 16-bit configurable timer/counter/PWM blocks Library of standard peripherals • 8, 16, 24, and 32-bit timers, counters, and PWMs • SPI, UART, I2C™ • Many others available in catalog Library of advanced peripherals • Cyclic Redundancy Check (CRC) • Pseudo Random Sequence (PRS) generator • LIN Bus 2.0 • Quadrature decoder Custom peripheral creation using Verilog Analog peripherals 0.2% internal voltage reference across -40°C to 85°C Configurable Delta-Sigma ADC with 12 to 20-bit resolution • Sample rates up to 192 ksps • Programmable gain stage: x0.25 to x16 • 12-bit mode, 192 ksps, 70 dB SNR, 1.5 bit INL/DNL • 16-bit mode, 48 ksps, 90 dB SNR, 1 bit INL/DNL Two SAR ADCs, each 12-bit at 1 Msps 80 MHz, 24-bit fixed point digital filter block (DFB) to implement FIR and IIR filters Up to four 8 MHz, 8-bit V/IDACs, configurable up to 12 bits Four comparators with 30 ns response time Four uncommitted opamps with 25 mA drive capability Up to four switch capacitor blocks configurable to: • Analog mixer • Transimpedance amplifier • Programmable gain amplifier x1 to x50 ------------------------------------------------------------------ Даташит есть (preliminary). Выложить не могу :laughing: , но желающим вышлю. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
oll 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Даташит есть (preliminary). Выложить не могу :laughing: , но желающим вышлю. надо - oleg_micromed(собака)datasvit.net Спасибо Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
sensor_ua 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Интересно было бы ознакомиться sensorua[!]gmail.com Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Rst7 5 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Интересно. Если можно - rst7.cbsie[ю]gmail.com Кстати, а какой ценник обещают? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
zltigo 1 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Up to four 16-bit configurable timer/counter/PWM blocks Чистый бред, для 32битников :( Даташит есть (preliminary). Выложить не могу :laughing: , но желающим вышлю. Если не сложно, адрес в личке. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
sergvks 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Чистый бред, для 32битников :( Зря вы так. Это ведь эти блоки можно соединять как угодно в один (например 16+16=32). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
-=Sergei=- 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба надо - oleg_micromed(собака)datasvit.net Спасибо И мне И мне, если не затруднит. shumilin.sergei(злой сабак)ic-design точка ру Спасибо! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
etoja 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба А почему на их сайте ничего нет? Одни 8-битники. ARMов они никогда не делали. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
proba 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба значит будут делать, http://www.msc-ge.com/frame/en/produkte/el...s/3389-www.html как и многие другие , например тошиба. http://www.toshiba-components.com/microcon...ler/Cortex.html (15mw @ 40MHz - реально ли ? ) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
MrYuran 21 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Давно интересует вопрос, насколько качественная аналоговая периферия у сайпресса? Например, что-то навроде AD8551, ads1241 и AD7705 можно соорудить? И почему для Programmable gain amplifier x1 to x50 нужны блоки конденсаторов (Up to four switch capacitor blocks), а не резисторов? И какова точность коэффициента усиления? Или всё равно придется внешние резисторы для ОС ставить? Выглядит заманчиво, если весь усилительно-преобразовательный модуль на одной мелкосхеме забацать, пусть даже с минимальной обвязкой Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
etoja 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба значит будут делать, http://www.msc-ge.com/frame/en/produkte/el...s/3389-www.html На их родном сайте http://www.cypress.com ничего нет. А www.msc-ge.com - это "одна баба сказала ..." Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Axel 1 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Информация достоверная, можно сказать из первых рук... ЕVB с PSoC3 у меня уже есть, плату с PSoC5 обещали через пару месяцев. По ценам - предположительно $7-8 (максимальная конфигурация в больших количествах). Всем пожелавшим разошлю вечером - сейчас со временем туго. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
miv 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Информация достоверная, можно сказать из первых рук... ЕVB с PSoC3 у меня уже есть, плату с PSoC5 обещали через пару месяцев. По ценам - предположительно $7-8 (максимальная конфигурация в больших количествах). Всем пожелавшим разошлю вечером - сейчас со временем туго. и сюда если не сложно ! imakurin[собака].gmail.com Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
sensor_ua 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Нашлась такая инфа https://materials.proxyvote.com/Approved/23...ductor-2009.pdf Взято отсюда http://www.psocdeveloper.com/forums/viewto...=42&p=27431 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
etoja 0 22 июня, 2009 Опубликовано 22 июня, 2009 · Жалоба Так анонс этой микросхемы приведён в годовом отчёте Кипариса (Cypress Annual Report), который делается для привлечения инвесторов и связи с реальной работой не имеет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
