Перейти к содержанию
Gowin IDE's rPLL dangling nets warning
Всем добра.
При компиляции проекта с параметризованной rPLL с обвязкой таком виде
module rPLL25MHzTo40MHz66
    input  logic Clk25MHz ,
    output logic PLL40MHz66 ,
    output logic lock
    logic clkoutp  ;
    logic clkoutd  ;
    logic clkoutd3 ;
    rPLL rpll_inst
        .CLKOUT   ( PLL40MHz66 ) ,
        .LOCK     ( lock       ) ,
        .CLKOUTP  ( clkoutp    ) ,
        .CLKOUTD  ( clkoutd    ) ,
        .CLKOUTD3 ( clkoutd3   ) ,
        .RESET    ( '0         ) ,
        .RESET_P  ( '0         ) ,
        .CLKIN    ( Clk25MHz   ) ,
        .CLKFB    ( '0         ) ,
        .FBDSEL   ( '0         ) ,
        .IDSEL    ( '0         ) ,
        .ODSEL    ( '0         ) ,
        .PSDA     ( '0         ) ,
        .DUTYDA   ( '0         ) ,
        .FDLY     ( '0         )
    defparam rpll_inst.FCLKIN           = "25"       ;
    defparam rpll_inst.DYN_IDIV_SEL     = "false"    ;
    defparam rpll_inst.IDIV_SEL         = 7          ;
    defparam rpll_inst.DYN_FBDIV_SEL    = "false"    ;
    defparam rpll_inst.FBDIV_SEL        = 12          ;
    defparam rpll_inst.DYN_ODIV_SEL     = "false"    ;
    defparam rpll_inst.ODIV_SEL         = 16          ;
    defparam rpll_inst.PSDA_SEL         = "0000"     ;
    defparam rpll_inst.DYN_DA_EN        = "true"     ;
    defparam rpll_inst.DUTYDA_SEL       = "1000"     ;
    defparam rpll_inst.CLKOUT_FT_DIR    = 1'b1       ;
    defparam rpll_inst.CLKOUTP_FT_DIR   = 1'b1       ;
    defparam rpll_inst.CLKOUT_DLY_STEP  = 0          ;
    defparam rpll_inst.CLKOUTP_DLY_STEP = 0          ;
    defparam rpll_inst.CLKFB_SEL        = "internal" ;
    defparam rpll_inst.CLKOUT_BYPASS    = "false"    ;
    defparam rpll_inst.CLKOUTP_BYPASS   = "false"    ;
    defparam rpll_inst.CLKOUTD_BYPASS   = "false"    ;
    defparam rpll_inst.DYN_SDIV_SEL     = 2          ;
    defparam rpll_inst.CLKOUTD_SRC      = "CLKOUT"   ;
    defparam rpll_inst.CLKOUTD3_SRC     = "CLKOUT"   ;
    defparam rpll_inst.DEVICE           = "GW2A-18C" ;
endmodule : rPLL25MHzTo40MHz66
и инстанциированного в проект в виде
    rPLL25MHzTo40MHz66 rPLL25MHzTo40MHz66_inst
        .Clk25MHz   ( Clk25MHz   ) ,
        .PLL40MHz66 ( PLL40MHz66 ) ,
        .lock       ( PLL_locked )
возникают предупреждения среды:
WARN  (PA1001) : Dangling net 'PLL_locked'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
WARN  (PA1001) : Dangling net 'clkoutp'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
WARN  (PA1001) : Dangling net 'clkoutd'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
WARN  (PA1001) : Dangling net 'clkoutd3'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
Все эти сигналы, действительно, никак больше не используются.
Вопрос: что с ними можно сделать, кроме как закрыть на них глаза?
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Ещё можно их просто удалить, это же выходные цепи.
Ссылка на сообщение
При удалении указующий перст среды уходит внутрь IP
WARN  (PA1001) : Dangling net 'rpll_inst_2_CLKOUTP'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
WARN  (PA1001) : Dangling net 'rpll_inst_2_CLKOUTD'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
WARN  (PA1001) : Dangling net 'rpll_inst_2_CLKOUTD3'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination
Ссылка на сообщение
Не нашёл ничего лучшего, чем вывести на неиспользуемый вывод
Ссылка на сообщение
7 часов назад, Zversky сказал:
Отменить вывод всех предупреждений для Place & Route.
Ссылка на сообщение
4 часа назад, Ascetic сказал:
Это тоже самое, что закрыть глаза. Не мой путь. Мой я указал выше.
Ссылка на сообщение
В 25.05.2024 в 18:33, Zversky сказал:
Это напрягает софт ненужными аппаратными затратами и ненужной трассировкой, лучше оставлять варнинги.
Ссылка на сообщение
Не все йогурты варнинги одинаково полезны :)
У Вас используется аппаратный блок, с его портами ввода-вывода. Может так оказаться, что не все эти порты требуются в Вашем проекте. Вы их не используете (ну, например, не нужен Вам выход lock). Среда разработки честно предупреждает, что такие-то и сякие входные порты аппаратного блока не имеют драйвера, а выходные - ничем не управляют. Вы анализируете эти предупреждения, и поверяете - или у Вас все так и задумано, или Вы что-то забыли подключить к PLL. Ну и если все так и задумано, то оставляете эти варнинги как есть.
То есть, другими словами: принять предупреждения к сведению - это не то же самое, что игнорировать предупреждения.
Полностью избавляться от варнингов - не самоцель, ИМХО...
Ссылка на сообщение
6 часов назад, StewartLittle сказал:
А принятые к сведению засапрессить, чтобы не загромождали вывод и не маскировали другие сообщения (предупреждения). Когда в выхлопе болтается три сотни предупреждений, которые просмотрены и приняты к сведению, увидеть новое, возможно, важное, может оказаться затруднительно. Хорошо, если инструмент позволяет это делать. Иначе приходится самостоятельно наворачивать постпроцессинг лога.
Ссылка на сообщение
20 часов назад, dxp сказал:
Так китайцы так и сделали - при отключении всех предупреждений, как я показал в посте, все важные, с точки зрения трассировщика, предупреждения будут выводиться вне зависимости от параметра "Show All Warning".
Это легко проверить имитированием предупреждений, к примеру, TA1001, TA1004,...
При этом, все предупреждения, типа "висячих" выходов, пропадут, а "висячие" входы будут с успехом отлавливаться синтезатором.
Ссылка на сообщение
3 часа назад, Ascetic сказал:
Некоторые важные с точки зрения трассировщика могут оказаться не важными на самом деле, и их достаточно будет принять к сведению -- и скрыть. Если инструмент этого не позволяет, придётся это делать руками.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
