Zversky 19 25 мая Опубликовано 25 мая · Жалоба Всем добра. При компиляции проекта с параметризованной rPLL с обвязкой таком виде module rPLL25MHzTo40MHz66 ( input logic Clk25MHz , output logic PLL40MHz66 , output logic lock ) ; logic clkoutp ; logic clkoutd ; logic clkoutd3 ; rPLL rpll_inst ( .CLKOUT ( PLL40MHz66 ) , .LOCK ( lock ) , .CLKOUTP ( clkoutp ) , .CLKOUTD ( clkoutd ) , .CLKOUTD3 ( clkoutd3 ) , .RESET ( '0 ) , .RESET_P ( '0 ) , .CLKIN ( Clk25MHz ) , .CLKFB ( '0 ) , .FBDSEL ( '0 ) , .IDSEL ( '0 ) , .ODSEL ( '0 ) , .PSDA ( '0 ) , .DUTYDA ( '0 ) , .FDLY ( '0 ) ) ; defparam rpll_inst.FCLKIN = "25" ; defparam rpll_inst.DYN_IDIV_SEL = "false" ; defparam rpll_inst.IDIV_SEL = 7 ; defparam rpll_inst.DYN_FBDIV_SEL = "false" ; defparam rpll_inst.FBDIV_SEL = 12 ; defparam rpll_inst.DYN_ODIV_SEL = "false" ; defparam rpll_inst.ODIV_SEL = 16 ; defparam rpll_inst.PSDA_SEL = "0000" ; defparam rpll_inst.DYN_DA_EN = "true" ; defparam rpll_inst.DUTYDA_SEL = "1000" ; defparam rpll_inst.CLKOUT_FT_DIR = 1'b1 ; defparam rpll_inst.CLKOUTP_FT_DIR = 1'b1 ; defparam rpll_inst.CLKOUT_DLY_STEP = 0 ; defparam rpll_inst.CLKOUTP_DLY_STEP = 0 ; defparam rpll_inst.CLKFB_SEL = "internal" ; defparam rpll_inst.CLKOUT_BYPASS = "false" ; defparam rpll_inst.CLKOUTP_BYPASS = "false" ; defparam rpll_inst.CLKOUTD_BYPASS = "false" ; defparam rpll_inst.DYN_SDIV_SEL = 2 ; defparam rpll_inst.CLKOUTD_SRC = "CLKOUT" ; defparam rpll_inst.CLKOUTD3_SRC = "CLKOUT" ; defparam rpll_inst.DEVICE = "GW2A-18C" ; endmodule : rPLL25MHzTo40MHz66 и инстанциированного в проект в виде rPLL25MHzTo40MHz66 rPLL25MHzTo40MHz66_inst ( .Clk25MHz ( Clk25MHz ) , .PLL40MHz66 ( PLL40MHz66 ) , .lock ( PLL_locked ) ) ; возникают предупреждения среды: WARN (PA1001) : Dangling net 'PLL_locked'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination WARN (PA1001) : Dangling net 'clkoutp'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination WARN (PA1001) : Dangling net 'clkoutd'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination WARN (PA1001) : Dangling net 'clkoutd3'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination Все эти сигналы, действительно, никак больше не используются. Вопрос: что с ними можно сделать, кроме как закрыть на них глаза? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
makc 225 25 мая Опубликовано 25 мая · Жалоба Ещё можно их просто удалить, это же выходные цепи. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Zversky 19 25 мая Опубликовано 25 мая · Жалоба При удалении указующий перст среды уходит внутрь IP WARN (PA1001) : Dangling net 'rpll_inst_2_CLKOUTP'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination WARN (PA1001) : Dangling net 'rpll_inst_2_CLKOUTD'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination WARN (PA1001) : Dangling net 'rpll_inst_2_CLKOUTD3'(source:'rpll_inst') in module 'rPLL25MHzTo40MHz66' has no destination Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Zversky 19 25 мая Опубликовано 25 мая · Жалоба Не нашёл ничего лучшего, чем вывести на неиспользуемый вывод Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Ascetic 0 25 мая Опубликовано 25 мая · Жалоба 7 часов назад, Zversky сказал: Вопрос: что с ними можно сделать, кроме как закрыть на них глаза? Отменить вывод всех предупреждений для Place & Route. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Zversky 19 25 мая Опубликовано 25 мая · Жалоба 4 часа назад, Ascetic сказал: Отменить вывод всех предупреждений для Place & Route. Это тоже самое, что закрыть глаза. Не мой путь. Мой я указал выше. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vladec 12 27 мая Опубликовано 27 мая · Жалоба В 25.05.2024 в 18:33, Zversky сказал: Не нашёл ничего лучшего, чем вывести на неиспользуемый вывод Это напрягает софт ненужными аппаратными затратами и ненужной трассировкой, лучше оставлять варнинги. 1 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
StewartLittle 45 27 мая Опубликовано 27 мая · Жалоба В 25.05.2024 в 18:33, Zversky сказал: Не нашёл ничего лучшего, чем вывести на неиспользуемый вывод Не все йогурты варнинги одинаково полезны :) У Вас используется аппаратный блок, с его портами ввода-вывода. Может так оказаться, что не все эти порты требуются в Вашем проекте. Вы их не используете (ну, например, не нужен Вам выход lock). Среда разработки честно предупреждает, что такие-то и сякие входные порты аппаратного блока не имеют драйвера, а выходные - ничем не управляют. Вы анализируете эти предупреждения, и поверяете - или у Вас все так и задумано, или Вы что-то забыли подключить к PLL. Ну и если все так и задумано, то оставляете эти варнинги как есть. То есть, другими словами: принять предупреждения к сведению - это не то же самое, что игнорировать предупреждения. Полностью избавляться от варнингов - не самоцель, ИМХО... 1 1 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Zversky 19 27 мая Опубликовано 27 мая · Жалоба Всем спасибо, принял к сведению. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
dxp 65 27 мая Опубликовано 27 мая · Жалоба 6 часов назад, StewartLittle сказал: То есть, другими словами: принять предупреждения к сведению - это не то же самое, что игнорировать предупреждения. А принятые к сведению засапрессить, чтобы не загромождали вывод и не маскировали другие сообщения (предупреждения). Когда в выхлопе болтается три сотни предупреждений, которые просмотрены и приняты к сведению, увидеть новое, возможно, важное, может оказаться затруднительно. Хорошо, если инструмент позволяет это делать. Иначе приходится самостоятельно наворачивать постпроцессинг лога. 1 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Ascetic 0 28 мая Опубликовано 28 мая · Жалоба 20 часов назад, dxp сказал: увидеть новое, возможно, важное, может оказаться затруднительно Так китайцы так и сделали - при отключении всех предупреждений, как я показал в посте, все важные, с точки зрения трассировщика, предупреждения будут выводиться вне зависимости от параметра "Show All Warning". Это легко проверить имитированием предупреждений, к примеру, TA1001, TA1004,... При этом, все предупреждения, типа "висячих" выходов, пропадут, а "висячие" входы будут с успехом отлавливаться синтезатором. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
dxp 65 28 мая Опубликовано 28 мая · Жалоба 3 часа назад, Ascetic сказал: Так китайцы так и сделали - при отключении всех предупреждений, как я показал в посте, все важные, с точки зрения трассировщика, предупреждения будут выводиться вне зависимости от параметра "Show All Warning". Некоторые важные с точки зрения трассировщика могут оказаться не важными на самом деле, и их достаточно будет принять к сведению -- и скрыть. Если инструмент этого не позволяет, придётся это делать руками. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
