Maverick_ 15 18 декабря, 2023 Опубликовано 18 декабря, 2023 · Жалоба Привет при генерации bitstream в vivado 2019.1 появляется ошибка Quote [DRC NSTD-1] Unspecified I/O Standard: 50 out of 115 logical ports use I/O standard (IOSTANDARD) value 'DEFAULT', instead of a user assigned specific value. This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all I/O standards. This design will fail to generate a bitstream unless all logical ports have a user specified I/O standard value defined. To allow bitstream creation with unspecified I/O standard values (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks NSTD-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: data0_n_out[11:0], data0_p_out[11:0], data1_n_out[11:0], data1_p_out[11:0], clk0_out, and clk1_out. [DRC UCIO-1] Unconstrained Logical Port: 54 out of 115 logical ports have no user assigned specific location constraint (LOC). This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all pin locations. This design will fail to generate a bitstream unless all logical ports have a user specified site LOC constraint defined. To allow bitstream creation with unspecified pin locations (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks UCIO-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: data0_n_out[11:0], data0_p_out[11:0], data1_n_out[11:0], data1_p_out[11:0], clk0_n, clk0_out, clk0_p, clk1_out, clk1_n, and clk1_p. во вложении файли описания и xdc файл помогите пожалуйста понять что не так adc_AD9627.vhd dual_adc_AD9627.vhd const.xdc top_adc_AD9627.vhd Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
makc 210 18 декабря, 2023 Опубликовано 18 декабря, 2023 · Жалоба Как минимум не хватает констрейнтов для цепей data_n_out и data_p_out, а также для o_sclk, o_ss, o_mosi и i_miso. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
MegaVolt 28 18 декабря, 2023 Опубликовано 18 декабря, 2023 · Жалоба Судя по названиям это дифф сигналы. А судя по настройкам это обычные пины. Возможно по этому и ругается. Нужно на них повесить что то типа LVDS25 или LVDS18 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex77 4 18 декабря, 2023 Опубликовано 18 декабря, 2023 · Жалоба а разве для диф пар требуется ОБА констрейна _N и _P ??? На сколь мне помнится требуется указывать токмо для _P и что это дифпара. xilinx в курсе какие выводы составляют "диф.сигнал" Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
andrew_b 15 19 декабря, 2023 Опубликовано 19 декабря, 2023 · Жалоба 10 hours ago, Alex77 said: требуется указывать токмо для _P Не требуется, а допускается. От того, что вы правильно напишете констрены на оба пина, хуже не будет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
