Можешь конкретно ошибку привести, в какой именно прорамме пакета она происходит?
Хорошо бы посмотреть сам проект целиком, ну если не можешь тогда хотя б скрин сделай и(или) лог файл приведи.
Вот скрины из моего проекта по шагам.
______.rar
А вот что мне пишет программа в Execution Log:
'gen' release 7.0, version 7.0.9
Copyright © 1994-2001 ISE Integrated Systems Engineering
Loading global tool database 'C:/ISE/tcad/7.0/lib/GENESISelib/tooldb.tcl'
Loading preferences 'C:/ISE/project/pref_win_spm.7.0'
Warning: couldn't load user's preferences: C:/ISE/project/pref_win_spm.7.0 doesn't exist
Loading project 'C:/ISE/project/n-MOP/NEW_90310'...done
'local' submitted jobs:
default: 2 5 6 7 3 8 9 10 4 11 12 13
Mar 11 11:13:03 <NEW_90310> started locally: nodes "all"
local% submit job 2 for local execution
local% submit job 7 for local execution
local% submit job 3 for local execution
local% submit job 10 for local execution
local% submit job 4 for local execution
local% submit job 13 for local execution
local% exec "genjob -nice 19 -job 2 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:03 job 2 <dios> started on host 'spm': "dios -u n2_dio.cmd"
Mar 11 11:13:06 --- job 2 <dios> exited abnormally: exit(44)
local% exec "genjob -nice 19 -job 7 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:09 job 7 <inspect> started on host 'spm': "inspect -f pp7_ins.cmd"
Mar 11 11:13:15 +++ job 7 <inspect> done (6 secs)
local% exec "genjob -nice 19 -job 3 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:18 job 3 <dios> started on host 'spm': "dios -u n3_dio.cmd"
Mar 11 11:13:21 --- job 3 <dios> exited abnormally: exit(44)
local% exec "genjob -nice 19 -job 10 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:24 job 10 <inspect> started on host 'spm': "inspect -f pp10_ins.cmd"
Mar 11 11:13:30 +++ job 10 <inspect> done (6 secs)
local% exec "genjob -nice 19 -job 4 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:33 job 4 <dios> started on host 'spm': "dios -u n4_dio.cmd"
Mar 11 11:13:36 --- job 4 <dios> exited abnormally: exit(44)
local% exec "genjob -nice 19 -job 13 @ISEDB@/n-MOP/NEW_90310"
Mar 11 11:13:40 job 13 <inspect> started on host 'spm': "inspect -f pp13_ins.cmd"
Mar 11 11:13:46 +++ job 13 <inspect> done (6 secs)
Mar 11 11:13:52 <NEW_90310> failed
SCHEDULING REPORT
+++ done : 7 10 13
--- failed : 2 3 4
not started : 5 6 8 9 11 12
gen exits with status 1
что даёт output c
job 4 <dios> exited abnormally: exit(44) ?
В 10м Ткаде view output или с клавиатуры Ctrl+W на выделенной задаче
Изменено пользователем baumanets
Приветствую всех!
Столкнулся с такой проблемой, моделирую технологию стабилитрона, с технологической точки зрения все получается правильно, профили красивые :biggrin: все хорошо.
но как дело доходит до моделирования ВАХ то напряжение пробоя стабильно держится на одной отметке, примерно в 2 раза больше чем планировалось.
Пробовал играться с технологией это ни к чему существенному не привело. Стал копаться в выходных файлах SDEVICE обнаружил что туннелирования через p-n-переход нет(( Подскажите пожалуйста как включить модели туннелирования в SDEVICE ? Читал в мануале про Band2Band туннелирование, там необходимо обозначить регионы или материалы через которые собственно и происходит туннелирование, но как их задать напрямую в SPROCESS так и не понял.
И сразу еще один вопрос спрошу) Как после SPROCESS'а включить NOFFSET3D чтобы на выходе ноффсета была не только сетка но и показывалось легирование структуры? Заранее спасибо.
Приветствую всех!
Какая версия TCADа?
Добрый день. Поставил на WinXP SP2 T-CAD 10.0. C горем пополам добился того, что стал запускаться GENESISe. Однако всплыла другая проблема-при запуске mdraw выдается такая ошибка (в прикрепленном файле). Однако эти файлы лежат в директории %ISEROOT\tcad\10.0\ix86\WinNT\lib\mdraw. Перекинул всю папку в %ISEROOT\tcad\10.0\lib, потом отдельно их туда закинул. Эффекта ноль. Может у кого была уже такая проблема и кто-то знает, куда нужно их кинуть, чтоб запускался mdraw?
Error.rar
Какая версия TCADа?
Sentaurus tcad 10
сейчас пробую после Sprocess'a вставить SDE и в нем определить регионы для туннелирования. но пока не очень успешно
Пиши в личку, на паблик не буду выкладывать.
Sentaurus tcad 10
У меня в синопсисе 10 для снятия вахов в программе DESSIS есть 4 модели для работы
дрейфово-диффузионная, термодинамическая, гидродинамическая, квантовая.
Нечто подобное ИМХО должно быть и тут.
baumanets, у меня пишет, что мне нельзя использовать личные сообщения. Если не сложно, можно на почту отправить: wersun DOG rambler POINT ru
Sorry za translit. Pishu s servera, tut russkoy raskladki net ((
Vobshem modeley dlya tunnelirovaniya tut 5 shtuk. Problema v tom chto pri prostom podhode, toest' prosto propisav ispol'zuemie modeli v komandnike DEVICE tunnelirovanie ne shitaetsya. Neobhodimo oboznachit' v razdele Physics region ili material gde neobhodimo uchitivat eti modeli. Naprimer:
Physics (RegionInterface="JN_Region/JP_Region")
Recombination ( Band2BandTunneling ....
Ya dobilsa razmechenih oblastey s pomoshyu SDE, no tunnelirovanie vse ravno ne shitaetsya((((
Приветствую всех!
может это?
Physics(MaterialInterface="<mat1>/<mat2>") { Recombination(eBarrierTunneling(nonlocal)) }
Math(MaterialInterface="<mat1>/<mat2>") { NonLocal(Length=1e-6) }
может это?
хм а вот в мат часть я ничего не добавлял. попробую, спасибо за совет. только сразу вопрос)
я так понял тут задается туннелирование через два материала например Оксид/Кремний а как быть если материал один, тоесть в кремнии необходимо увидеть
туннелирование между n++ областью стабилитрона и p+ карманом?
вот привожу командник. мож так проще будет понять че не так)
* --- Defining Electrodes
Electrode {
{ Name="Gate" Voltage=0 AreaFactor=250 }
{ Name="Source" Voltage=0 AreaFactor=250 }
{ Name="Drain" Voltage=0 AreaFactor=250 }
{ Name="Substrate" Voltage=0 AreaFactor=250 }
File {
* --- Defining Input Files
Grid = "@tdr@"
Doping = "@tdr@"
* --- Defining Output Files
Plot = "@dat@"
Current = "@plot@"
* --- Defining Physical Models
Physics ( Material="Silicon" ) {
EffectiveIntrinsicDensity (OldSlotboom)
Mobility (DopingDep HighFieldSaturation Enormal)
Recombination (SRH (DopingDep) Auger Avalanche (Eparallel)
eBarrierTunneling(nonlocal) hBarrierTunneling(nonlocal)
eBarrierTunneling(Band2Band TwoBand) hBarrierTunneling(Band2Band TwoBand)
Fermi
* --- Plot Section (Tecplot SV)
Plot {
eDensity hDensity
eCurrent hCurrent
ElectricField
eQuasiFermi hQuasiFermi
Potential Doping SpaceCharge
SRH Auger
eMobility hMobility
DonorConcentration AcceptorConcentration
Doping
eVelocity hVelocity
eEparal hEparal eTemperature
Bandgap Auger
eDirectTunneling
eBarrierTunneling
hBarrierTunneling
eQuantumPotential
qcBandGapShift
Band2BandTunneling
AvalancheGeneration RadiativeRecombination
eAvalanche hAvalanche
ConductBandEnergy ValenceBandEnergy
* --- Math Section
Math ( Material="Silicon" ){
NonLocal(Length=20e-6)
Extrapolate
Derivatives
RelErrControl
Avalderivatives
Digits=5
Notdamped=50
Iterations=30
Directcurrent
ErRef(hole)=1e10
ErRef(electron)=1e10
* --- Solve Section
Solve {
Coupled (Iterations=3000 LineSearchDamping=1e-4)
{ Poisson Electron Hole }
Quasistationary ( InitialStep=0.001 MaxStep=0.005 Minstep=1e-10
Goal { Name="Gate" Voltage=15 } )
{ Coupled { Poisson Electron Hole } }
Все с туннелированием разобрался. Необходимо было просто прописать в Physics строчку Band2Band ... как всегда все гениальное просто, не знаю как я раньше до этого не додумался))
спасибо за советы
