Maverick_ 15 11 апреля, 2023 Опубликовано 11 апреля, 2023 · Жалоба Всем привет есть проект - компилируется... когда запускю симуляцию, то появляется ошибка Starting static elaboration ERROR: [VRFC 10-1378] slice direction differs from its index type range [D:/project/xilinx/hdl/correlation_demodulator/source_hdl/shift_srl_delay_bus.vhd:76] ERROR: [VRFC 10-664] expression has 32 elements ; expected 16 [D:/project/xilinx/hdl/correlation_demodulator/source_hdl/shift_srl_delay_bus.vhd:76] ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed. как испраивить не пойму... в проекте используется package library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; package mod_pkg is constant NUM_INSTANCES : integer := 128; constant NUM_PIPELINE : integer := 32; constant PIPELINE_STAGES : integer := 15; constant RESET_ACTIVE_LEVEL : std_logic := '1'; constant AWIDTH : integer := NUM_PIPELINE/2; --:= 16; constant BWIDTH : integer := NUM_PIPELINE/2; --:= 16; type arr_reg_const is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(NUM_PIPELINE-1 downto 0); type arr_comlex_reg_re is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(AWIDTH-1 downto 0); -- (AWIDTH-1 downto 0) type arr_comlex_reg_im is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(BWIDTH-1 downto 0); -- (BWIDTH-1 downto 0) type arr_comlex_result_re is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(AWIDTH+BWIDTH downto 0); type arr_comlex_result_im is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(AWIDTH+BWIDTH downto 0); end modulator_pkg; в топе компонент обявлен: component shift_srl_delay_bus is generic ( NUM_INSTANCES : integer := 128; NUM_PIPELINE : integer := 32; PIPELINE_STAGES : integer := 15; RESET_ACTIVE_LEVEL : std_logic := '1' ); port ( clk : in std_logic; rst : in std_logic; valid : in std_logic; data_in : in std_logic_vector(NUM_PIPELINE-1 downto 0); data_re_out : out arr_comlex_reg_re; data_im_out : out arr_comlex_reg_im ); end component; ----- shift_srl_delay_bus_inst : shift_srl_delay_bus generic map ( NUM_INSTANCES => NUM_INSTANCES, NUM_PIPELINE => NUM_PIPELINE, PIPELINE_STAGES => PIPELINE_STAGES, RESET_ACTIVE_LEVEL => '1' ) port map( clk => clk, rst => rst, valid => valid, data_in => data_in, data_re_out => reg_data_re, data_im_out => reg_data_im ); само описание компонента library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; library work; use work.mod_pkg.all; entity shift_srl_delay_bus is generic ( NUM_INSTANCES : integer := 128; NUM_PIPELINE : integer := 32; PIPELINE_STAGES : integer := 15; RESET_ACTIVE_LEVEL : std_logic := '1' ); port ( clk : in std_logic; rst : in std_logic; valid : in std_logic; data_in : in std_logic_vector(NUM_PIPELINE-1 downto 0); data_re_out : out arr_comlex_reg_re; data_im_out : out arr_comlex_reg_im ); end entity shift_srl_delay_bus; architecture behavioral of shift_srl_delay_bus is type t_const is array (0 to (NUM_INSTANCES-1)) of std_logic_vector(NUM_PIPELINE-1 downto 0); signal reg_data_in : t_const; signal reg_data_out : t_const; --signal reg_data_re : std_logic_vector(AWIDTH-1 downto 0); --signal reg_data_im : std_logic_vector(BWIDTH-1 downto 0); begin gen_pipeline_bus_inst : for i in 0 to NUM_INSTANCES-1 generate pipeline_bus_inst : entity work.pipeline_delay_bus generic map( NUM_INSTANCES => NUM_PIPELINE, PIPELINE_STAGES => PIPELINE_STAGES,--3 RESET_ACTIVE_LEVEL => '1' ) port map( Clock => clk, Reset => rst, valid => valid, Sig_in => reg_data_in(i), Sig_out => reg_data_out(i), ready => open ); end generate gen_pipeline_bus_inst; process(all) begin if rst = '1' then reg_data_in <= (others => (others => '0')); data_re_out <= (others =>(others => '0')); data_im_out <= (others =>(others => '0')); elsif rising_edge(clk) then for i in reg_data_in'high downto reg_data_in'low + 1 loop --for i in 0 to (NUM_INSTANCES-1) loop reg_data_in(i) <= reg_data_out(i - 1); end loop; reg_data_in(reg_data_in'low) <= data_in; --data_out <= reg_data_out(reg_data_out'high); end if; for i in reg_data_in'high downto reg_data_in'low + 1 loop --for i in 0 to (NUM_INSTANCES-1) loop data_re_out(i) <= reg_data_in((NUM_PIPELINE/2)-1 downto 0)(i); --!!!!!!!! data_im_out(i) <= reg_data_in(NUM_PIPELINE-1 downto NUM_PIPELINE/2)(i); --!!!!!!!! end loop; end process; end architecture behavioral; ошибка в строке где в коментариях много !!!! подскажите пожалуйста как подправить Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
xvr 12 11 апреля, 2023 Опубликовано 11 апреля, 2023 · Жалоба data_re_out(i) <= reg_data_in(i)((NUM_PIPELINE/2)-1 downto 0); ? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 11 апреля, 2023 Опубликовано 11 апреля, 2023 · Жалоба 33 minutes ago, xvr said: data_re_out(i) <= reg_data_in(i)((NUM_PIPELINE/2)-1 downto 0); ? Огромное спасибо, помогло.... прямо в цель)))) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
