Перейти к содержанию
Spartan3AN - SPI Device not found
Здравствуйте.
Помогите пожалуйста разобраться с программированием внутренней flash микросхемы Spartan3AN.
PROG_B и INIT_B через резистор 4,7 кОм к VCC, SUSPEND = GND, M2:0 = "JTAG"
Вот что пишется после подачи питания при нажатии "Get device ID":
Spoiler
INFO:iMPACT - Current time: 11.02.2023 15:53:25
// *** BATCH CMD : ReadIdcode -p 1
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': IDCODE is '00000010011000010000000010010011'
'1': IDCODE is '02610093' (in hex).
'1': : Manufacturer's ID = Xilinx xc3s50an, Version : 0
Вот что пишется после подачи питания при нажатии "Read device status":
Spoiler
INFO:iMPACT - Current time: 11.02.2023 16:01:11
// *** BATCH CMD : ReadStatusRegister -p 1
PROGRESS_START - Starting Operation.
Validating chain...
'1': Reading status register contents...
CRC error        :         0
IDCODE not validated while writing FDRI                                    :         0
DCM Locked        :         1
status of GTS_CFG_B                                                        :         0
status of GWE                                                              :         0
status of GHIGH                                                            :         0
value of VSEL pin 0                                                        :         1
value of VSEL pin 1                                                        :         1
value of VSEL pin 2                                                        :         1
value of MODE pin M0                                                       :         1
value of MODE pin M1                                                       :         0
value of MODE pin M2                                                       :         1
value of CFG_RDY (INIT_B)                                                  :         1
DONEIN input from Done Pin                                                 :         0
SYNC word not found                                                        :         0
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable ope rations.
INFO:iMPACT - Downloading core file C:/Xilinx/14.7/ISE_DS/ISE/spartan3a/data/xc3s50an_spi.cor.
'1': Downloading core...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 1101 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
Ready/Busy Bit: 1
Result of Main Memory Page to Buffer Compare: 0
Device Density Bits: 0101
Sector Protection enabled: 0
Power of 2 binary page size enabled: 0
INFO:iMPACT - Address 0x00000000 is in sector 0.
INFO:iMPACT - Address 0x0000D587 is not located at the start of a sector boundary. The whole sector will be erased.
INFO:iMPACT - Address 0x0000D587 is in sector 2.
The security register values are:
Sector[0]: NOT SECURED (0)
Sector[1]: NOT SECURED (0)
Sector[2]: NOT SECURED (0)
Sector[3]: NOT SECURED (0)
Sector[4]: NOT SECURED (0)
The lockdown register values are:
Sector[0]: NOT LOCKED DOWN (0)
Sector[1]: NOT LOCKED DOWN (0)
Sector[2]: NOT LOCKED DOWN (0)
Sector[3]: NOT LOCKED DOWN (0)
Sector[4]: NOT LOCKED DOWN (0)
'1': Reading security register...
Factory ID
0F 0B 0F 09 08 06 1F 23 00 01 BB 08 FF FF 5A FF
30 30 50 4B 39 43 38 31 01 6A 30 FF FF FF FF FF
44 44 44 44 FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
done.
One-time User Programmable
done.
PROGRESS_END - End Operation.
Elapsed time =     81 sec.
Если просто прошить ПЛИС, то без проблем она прошивается. Но стоит попытаться прошиться во внутреннюю flash, то вот что пишется:
Spoiler
INFO:iMPACT - Current time: 11.02.2023 16:05:28
// *** BATCH CMD : Program -p 1 -e -v
Validating chain...
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT:2488 - The operation did not complete successfully.
Пишется якобы не найден внутренний SPI. Я пробовал на трёх микросхемах. И везде одинаковый результат. Подскажите, пожалуйста, на что обратить внимание!
Изменено пользователем Valek87
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
3 minutes ago, MegaVolt said:
Нет у неё внутренней флешь.. вот и не находит.. это FPGA а не CPLD.
Как это нет? Есть!
Ссылка на сообщение
6 минут назад, Valek87 сказал:
Как это нет? Есть!
Ух ты какое чудо чудное... я даже не слышал что такое было...
Видели ли вы этот документ?
https://support.xilinx.com/s/article/59572?language=en_US
Ссылка на сообщение
Вообщем помогла статья, которую предложил MegaVolt
Переходим по ссылке https://support.xilinx.com/s/article/59572?language=en_US, делаем всё как в пункте ISE iMPACT Design/Lab Tools Patch for XC3S50AN-TQ(G)144 Devices
P.S. Если кому интересно, что я сделал маленький туториал, как правильно прошить эту ПЛИС. Если нужно, то могу выложить.
Ссылка на сообщение
В 12.02.2023 в 19:29, Valek87 сказал:
Если не сложно 🙂 Чтобы информация оставалась в сети и её можно было найти когда понадобиться.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
