Перейти к содержанию
Modelsim (вывод в окно Transcript)
Добрый день
Подскажите пожалуйста можно ли как то сделать ограничение на вывод в окно Transcript
Для отладки я использую вставки в описании
------ for simulution -------------------------------------------------------------------------------------------
 -- synthesis translate_off
 process (all)
 begin
	IF (CLK'EVENT AND CLK = '1') THEN
		--if reg_same_ready = '1' then
		if (reg_same_ready  = '1') or (reg_same_ready_down  = '1') or (reg_ready  = '1') then
			report "Find data in the table IP_mask" severity note;
			report "index  =: " & to_string(to_integer(unsigned(reg_index))) severity note;
		end if;
	end if;
 end process;
 -- synthesis translate_on
 process (all)
 begin
		if (reg_error = '1') then
			report "Not find data in the table IP_mask" severity note;
		end if;
	end if;
 end process;
у меня  в окно Transcript Modelsim выводятся сообщения
** Note: Start new packet with IP_destination =: 82596CC9
#    Time: 1920 ns  Iteration: 1  Instance: /top_vhd_tst/i1/monitor_ip_header_inst
# ** Note: Find data in the table IP_mask
#    Time: 1960 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index =: 0
#    Time: 1970 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index  =: 15
#    Time: 2010 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index  =: 16
#    Time: 2050 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index  =: 17
#    Time: 2140 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index  =: 14
#    Time: 2180 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/core_binary_search_inst
# ** Note: index  =: 13
# ** Note: Find work channel
#    Time: 2330 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/search_work_channel_inst
# ** Note: for index is work channel =: 16
#    Time: 2430 ns  Iteration: 1  Instance: /top_vhd_tst/i1/binary_search_inst/search_work_channel_inst
# ** Note: for index is work channel =: 14
Можно ли как то запретить вывод
#    Time: * ns  Iteration: 1  *
если да подскажите пожалуйста как это сделать
PS Просто эти строки затрудняют чтение выводимой мною информации
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
В файлике modelsim.ini править надо
у меня такой вывод:
; MessageFormatNote      = "** %S: %R\n   Time: %T  Iteration: %D%I\n"
; MessageFormatWarning   = "** %S: %R\n   Time: %T  Iteration: %D%I\n"
; MessageFormatError     = "** %S: %R\n   Time: %T  Iteration: %D  %K: %i File: %F\n"
; MessageFormatFail      = "** %S: %R\n   Time: %T  Iteration: %D  %K: %i File: %F\n"
; MessageFormatFatal     = "** %S: %R\n   Time: %T  Iteration: %D  %K: %i File: %F\n"
; MessageFormatBreakLine = "** %S: %R\n   Time: %T  Iteration: %D  %K: %i File: %F Line: %L\n"
; MessageFormatBreak     = "** %S: %R\n   Time: %T  Iteration: %D  %K: %i File: %F\n"
; MessageFormat          = "** %S: %R\n   Time: %T  Iteration: %D%I\n"
MessageFormat          =  "------------------------------------------------------------------------------------------------------\n ****** %R \n\t\t\t\t\t | process : %O\n\t\t\t\t\t | Time    : %T\n\t\t\t\t\t | line    : %L\n\t\t\t\t\t | Severity: %S\n------------------------------------------------------------------------------------------------------\n\n"
Ссылка на сообщение
можешь своим modelsim.ini поделиться? пожалуйста
Получается что если я уберу
то не будет выводиться?
Ссылка на сообщение
1 час назад, Maverick_ сказал:
Вроде так.
modelsim.ini
Ссылка на сообщение
On 5/13/2022 at 5:16 PM, Flip-fl0p said:
Подставил указанну строчку в *.ini и ничего не изменилось в выводе, вообще!
Подставил и в локальный и в глобальный *.ini - ничего.
В чем может быть проблема?
Ссылка на сообщение
6 часов назад, slkhome сказал:
Потому-что надо не подставлять строчку, а редактировать этот файл.
Ссылка на сообщение
slkhome в моем случае у меня вообще все закоментировано
я еще не правил...
Ссылка на сообщение
On 5/20/2022 at 6:01 PM, Maverick_ said:
Разобрался. Оказывается у меня в фоне был еще один Моделсим запущен. Поэтому даже если я правил файл, не подхватывались изменения.
Когда все закрыл и запустил все заново - все заработало и подхватилось.
Спасибо!
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
