Patifon_Kakao 0 4 декабря, 2020 Опубликовано 4 декабря, 2020 · Жалоба Всем привет, имеется модель гуммеля-пуна в спайсе, например транзистора BFP843. Как я понимаю у него существует только один источник фликкерного шума в эмиттере с параметрами KF и AF. Хочется добавить второй источник фликкерного шума в базовую цепь, пусть даже пока без корреляции с источником в эмиттере. Может кто-то может посоветовать литературу или как это можно сделать? Скрытый текст ! NOTE: This file was translated from a SPICE file. ! ! SPICE orders the nodes of active devices as Drain Gate Source. ! The AWR convention is Gate Drain Source. The translator has reordered ! the nodes for active device elements (B, J, M and Q). The user should ! verify the node order for subcircuits representing active devices. ! ! Polynomial controlled sources have been decomposed to linear devices ! when possible. The user should verify the use of these devices. ! ! ************************************************************* ! Infineon Technologies AG ! GUMMEL-POON MODEL IN SPICE 2G6 SYNTAX ! VALID UP TO 12 GHZ ! >>> BFP843 <<< ! (C) 2013 Infineon Technologies AG ! Version 1.0 MAR 2013 ! ************************************************************* ! - Please use the global SPICE GP parameter TEMP to specify the ! junction temperature of the device in your application to get ! correct simulation results. This procedure is necessary because ! the GP model does not consider the self heating of the device. ! - TEMP is calculated by TEMP=TA+Pdc*(RthJS+RthSA). The junction ! temperature TEMP is the sum of the ambient temperature TA and ! the increment of temperature caused by the dissipated DC power Pdc. ! - RthJS is the thermal resistance between the junction and the ! soldering point. RthJS for this device is 405 K/W. RthSA is the ! thermal resistance of the PCB, from the soldering point to the ! ambient. For determination of RthSA please refer to Infineon's ! Application Note "Thermal Resistance Calculation" AN077. ! - The model has been verified in the junction temperature range ! -25 C to +125 C. ! - TNOM=25 C is the nominal ambient temperature during measurement ! for the parameter extraction. Please do not change this value. ! ************************************************************** ! .OPTION TNOM=25, GMIN= 1.00e-12 ! BFP843 C B E1 E2 DIM TEMP C FREQ HZ RES OH COND /OH IND H CAP F LNG M TIME SEC ANG DEG VOL V CUR A PWR DBM CKT RES 35 3 ID="RE1" R=0.001 RES 35 4 ID="RE2" R=0.001 CAP 22 33 ID="CBEPAR" C=3.005e-013 CAP 22 11 ID="CBCPAR" C=4.552e-014 CAP 11 33 ID="CCEPAR" C=4.625e-013 CAP 11 66 ID="Cfeed" C=5.2e-012 RES 66 22 ID="Rfeed" R=1032 CAP 66 33 ID="Cfeedpar" C=1.675e-013 IND 22 20 ID="LB" L=7.965e-010 IND 33 30 ID="LE" L=2.56e-010 IND 11 10 ID="LC" L=6.465e-010 CAP 20 30 ID="CBEPCK" C=4e-014 CAP 20 10 ID="CBCPCK" C=1e-015 CAP 10 30 ID="CCEPCK" C=4e-014 IND 20 2 ID="LBX" L=2.5e-010 IND 30 35 ID="LEX" L=9.953e-011 IND 10 1 ID="LCX" L=2.5e-010 RES 55 5 ID="R_CS_npn" R=500 SDIODE 33 25 ID="D1" IS=3e-015 N=1 RS=2.846 CJ0=4e-014 & BV=1e+015 SDIODE 5 25 ID="D2" IS=3e-015 N=1 RS=4700 CJ0=4.5e-014 & BV=1e+015 RES 22 25 ID="R_NBL_fdb" R=3.2 RES 33 5 ID="R_PS" R=0.2 RES 30 5 ID="RSUB" R=0.486 SDIODE 5 15 ID="D3" IS=6.911e-016 N=1.1 RS=1380 CJ0=9.5e-014 & BV=1e+015 SDIODE 23 33 ID="D4" IS=3.5e-015 N=1 RS=0.2 CJ0=3e-014 & BV=1e+015 SDIODE 23 15 ID="D5" IS=3.5e-015 N=1.02 RS=4.7 CJ0=3e-014 & BV=1e+015 RES 15 11 ID="R_NBL_e11g" R=1.8 GBJT 22 11 33 55 ID="Q1" IS=2.226e-016 BF=850.3 NF=0.997 & VAF=375.1 IKF=0.1713 ISE=4.539e-015 NE=1.958 & BR=98.98 NR=0.9941 VAR=1.375 IKR=0.05974 ISC=1.578e-015 & NC=1.8 RB=6.217 IRB=0 RBM=1.774 RE=0.329 RC=7.24 & XTB=-2.276 EG=1.11 XTI=0 CJE=8.091e-014 VJE=0.9141 & MJE=0.06778 TF=1.02369e-012 XTF=1 VTF=0.1832 & ITF=0.5237 PTF=0.5 CJC=3.125e-014 VJC=0.6892 & MJC=0.5349 XCJC=0.8 TR=1e-009 CJS=2.575e-013 & MJS=0.5599 VJS=0.4343 FC=0.5715 KF=3.12e-016 & AF=1.529 ! ************************************************************* DEF4P 2 1 3 4 "BFP8431" Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 49 4 декабря, 2020 Опубликовано 4 декабря, 2020 · Жалоба 4 часа назад, Patifon_Kakao сказал: Как я понимаю у него существует только один источник фликкерного шума в эмиттере с параметрами KF и AF. Как помню, Kf и Af (еще вроде порядок частоты может быть) относятся к току базы. Реальных параметров фликкер-шума в моделях не встречал, скорее для "галочки" проставлены цифры. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
