Перейти к содержанию
Looking for STM32discovery to communicate on MODBUS
2 hours ago, Jared said:
I understand that ASCII would allow for normal start and stop bits. RTU has 1.5 start bits. Could UART work with ASCII version of MODBUS?
Not bit! Char. It's 7-10 bit.
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
ASCII do not notice any time gap in transmit stream. Its very good. If we using bridge USB-RS485 we periodically get ~ 51 millisecond time burst. Its not bed- nothind is lost , but if use general value of modbus timeouts, we'll get uncomplite some command / It fix if take greather value of timeouts. Just add 60 millisecond to every value and all will work. So dont worry if use modbus rtu + bridge usb-rs485  . Take large timeouts value (++60 millisecond  ).
Ссылка на сообщение
11 bit, always
what is "51 millisecond time burst"? If a bridge USB-RS485 is used as the master, it can transmit 256 bytes without delay between characters (if it has a buffer). But it cannot determine the delay 1.5t and 3.5t when a slave responds.
Ссылка на сообщение
Bridge bring burst to slave responce. It mean: It is not lost bytes, but a ~51 ms pause can separete one part responce (at a random moment) from anothe - so you must use rule >3.5t  as (>3.5t+50...60).
Ссылка на сообщение
I don't undestand. I have several questions.
1. Is the 50ms delay on bus RS485? Or the bridge driver?
2. COM port driver (and virtual) has timeout settings, in milliseconds. Are you used it?
3. Which bridge (chip) is used? CH340, Silabs, FTDI?
Ссылка на сообщение
On bridge. Its not delay - its burst in answer.
COM port timeouts in windows COMMTIMEOUTS structure.
All of them.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
