doom13 0 February 28, 2019 Posted February 28, 2019 · Report post В файле pcw.dtsi эти строки отвечают за конфигурацию контроллера SD? &sdhci0 { clock-frequency = <200000000>; status = "okay"; xlnx,mio_bank = <0x0>; }; Пока пытаюсь поменять их на &sdhci0 { clock-frequency = <200000000>; status = "okay"; xlnx,mio_bank = <0x0>; bus-width = <8>; }; Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 February 28, 2019 Posted February 28, 2019 · Report post Говорю же, тормозните U-Boot на загрузке и поизучайте его DT. В наиболее общем случае, у U-Boot и у ядра могут быть разные DT Vivado (и SDK) какой версии используете? Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 February 28, 2019 Posted February 28, 2019 · Report post Quote root@zynqmp:~# ls -l /sys/firmware/devicetree/base/amba/sdhci* /sys/firmware/devicetree/base/amba/sdhci@ff160000: total 0 -r--r--r-- 1 root root 4 May 30 16:42 #stream-id-cells -r--r--r-- 1 root root 4 May 30 16:42 clock-frequency -r--r--r-- 1 root root 16 May 30 16:42 clock-names -r--r--r-- 1 root root 16 May 30 16:42 clocks -r--r--r-- 1 root root 35 May 30 16:42 compatible -r--r--r-- 1 root root 4 May 30 16:42 interrupt-parent -r--r--r-- 1 root root 12 May 30 16:42 interrupts -r--r--r-- 1 root root 8 May 30 16:42 iommus -r--r--r-- 1 root root 6 May 30 16:42 name -r--r--r-- 1 root root 4 May 30 16:42 power-domains -r--r--r-- 1 root root 16 May 30 16:42 reg -r--r--r-- 1 root root 5 May 30 16:42 status -r--r--r-- 1 root root 0 May 30 16:42 u-boot,dm-pre-reloc -r--r--r-- 1 root root 4 May 30 16:42 xlnx,device_id -r--r--r-- 1 root root 4 May 30 16:42 xlnx,mio_bank Т.е. bus-width оно не увидело? 9 minutes ago, gosha-z said: тормозните U-Boot на загрузке и поизучайте его DT Какой командой? Quote ZynqMP> dm tree Class Probed Driver Name ---------------------------------------- root [ + ] root_drive root_driver simple_bus [ ] generic_si |-- amba_apu@0 simple_bus [ + ] generic_si |-- amba eth [ + ] zynq_gem | |-- ethernet@ff0e0000 gpio [ ] gpio_zynq | |-- gpio@ff0a0000 spi [ + ] zynqmp_qsp | |-- spi@ff0f0000 spi_flash [ ] spi_flash_ | | `-- spi_flash@0:0 mmc [ + ] arasan_sdh | |-- sdhci@ff160000 blk [ ] mmc_blk | | `-- sdhci@ff160000.blk serial [ + ] serial_zyn | |-- serial@ff000000 serial [ ] serial_zyn | `-- serial@ff010000 clk [ + ] fixed_rate |-- pss_ref_clk clk [ + ] fixed_rate |-- video_clk clk [ + ] fixed_rate |-- pss_alt_ref_clk clk [ + ] fixed_rate |-- gt_crx_ref_clk clk [ + ] fixed_rate |-- aux_ref_clk clk [ + ] zynqmp-clk |-- clk clk [ ] fixed_rate |-- dp_aclk simple_bus [ ] generic_si `-- amba_pl@0 ZynqMP> Оно? Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 February 28, 2019 Posted February 28, 2019 · Report post 3 minutes ago, doom13 said: Т.е. bus-width оно не увидело? Нет, не увидел. 3 minutes ago, doom13 said: Какой командой? fdt, если есть. Хотя я могу путать, и это команда просмотра загруженного DT Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 February 28, 2019 Posted February 28, 2019 · Report post Quote ZynqMP> fdt list fdt - flattened device tree utility commands Usage: fdt addr [-c] <addr> [<length>] - Set the [control] fdt location to <addr> fdt move <fdt> <newaddr> <length> - Copy the fdt to <addr> and make it active fdt resize [<extrasize>] - Resize fdt to size + padding to 4k addr + some optional <extrasize> if needed fdt print <path> [<prop>] - Recursive print starting at <path> fdt list <path> [<prop>] - Print one level starting at <path> fdt get value <var> <path> <prop> - Get <property> and store in <var> fdt get name <var> <path> <index> - Get name of node <index> and store in <var> fdt get addr <var> <path> <prop> - Get start address of <property> and store in <var> fdt get size <var> <path> [<prop>] - Get size of [<property>] or num nodes and store in <var> fdt set <path> <prop> [<val>] - Set <property> [to <val>] fdt mknode <path> <node> - Create a new node after <path> fdt rm <path> [<prop>] - Delete the node or <property> fdt header - Display header info fdt bootcpu <id> - Set boot cpuid fdt memory <addr> <size> - Add/Update memory node fdt rsvmem print - Show current mem reserves fdt rsvmem add <addr> <size> - Add a mem reserve fdt rsvmem delete <index> - Delete a mem reserves fdt chosen [<start> <end>] - Add/update the /chosen branch in the tree <start>/<end> - initrd start/end addr NOTE: Dereference aliases by omitting the leading '/', e.g. fdt print ethernet0. ZynqMP> Команда есть, но опции непонятны Quote ZynqMP> help ? - alias for 'help' aes - AES 128 CBC encryption base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootelf - Boot from an ELF image in memory booti - boot arm64 Linux Image image from memory bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol bootvx - Boot vxWorks from an ELF image chpart - change active partition clk - CLK sub-system cmp - memory compare coninfo - print console devices and information cp - memory copy cpu - Multiprocessor CPU boot manipulation and release crc32 - checksum calculation dhcp - boot image via network using DHCP/TFTP protocol dm - Driver model low level access echo - echo args to console editenv - edit environment variable env - environment handling commands exit - exit script ext2load- load binary file from a Ext2 filesystem ext2ls - list files in a directory (default /) ext4load- load binary file from a Ext4 filesystem ext4ls - list files in a directory (default /) ext4size- determine a file's size ext4write- create a file in the root directory false - do nothing, unsuccessfully fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fatsize - determine a file's size fatwrite- write file into a dos filesystem fdt - flattened device tree utility commands fpga - loadable FPGA image support fstype - Look up a filesystem type go - start application at address 'addr' gpt - GUID Partition Table gzwrite - unzip and write memory to block device help - print command description/usage i2c - I2C sub-system iminfo - print header information for application image imxtract- extract a part of a multi-image itest - return true/false on integer compare load - load binary file from a filesystem loadb - load binary file over serial line (kermit mode) loads - load S-Record file over serial line loadx - load binary file over serial line (xmodem mode) loady - load binary file over serial line (ymodem mode) loop - infinite loop on address range ls - list files in a directory (default /) lzmadec - lzma uncompress a memory region md - memory display mdio - MDIO utility commands mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - display MMC info mtdparts- define flash/nand partitions mtest - simple RAM read/write test mw - memory write (fill) nfs - boot image via network using NFS protocol nm - memory modify (constant address) part - disk partition related commands ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables pxe - commands to get and boot from pxe files reset - Perform RESET of the CPU run - run commands in an environment variable save - save file to a filesystem saveenv - save environment variables to persistent storage setenv - set environment variables setexpr - set environment variable as the result of eval expression sf - SPI flash sub-system showvar - print local hushshell variables size - determine a file's size sleep - delay execution for some time source - run script from memory sspi - SPI utility command sysboot - command to get and boot from syslinux files test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol tftpput - TFTP put command, for uploading files to a server time - run commands and summarize execution time timer - access the system timer true - do nothing, successfully ubi - ubi commands ubifsload- load file from an UBIFS filesystem ubifsls - list files in a directory ubifsmount- mount UBIFS volume ubifsumount- unmount UBIFS volume unzip - unzip a memory region version - print monitor, compiler and linker version zynqmp - Verify and load secure images ZynqMP> Всё, что есть в helpe Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 February 28, 2019 Posted February 28, 2019 · Report post Может быть стоит проверить работоспособность eMMC из SDK, на уровне комманд, попробовать попереключать шину? Или тут стопудово u-boot не понимает, что шину в х8 включить надо? Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 February 28, 2019 Posted February 28, 2019 · Report post 1. Я склонен думать, что U-Boot не понимает. 2. Лучше сделайте PMUFW и FSBL в SDK, а не в пиволинуксе Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 March 1, 2019 Posted March 1, 2019 · Report post 14 hours ago, gosha-z said: 2. Лучше сделайте PMUFW и FSBL в SDK, а не в пиволинуксе FSBL у меня свой (шаблонный + немного своего кода), было необходимо конфигурирование системы тактирования. Ещё добавил в него инициализацию eMMC, судя по printf-ам она проходит. Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 March 1, 2019 Posted March 1, 2019 · Report post Не помогло. Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 March 1, 2019 Posted March 1, 2019 · Report post Надо весь комплект - PMUFW, FSBL, U-Boot. "Своя" инициализация eMMC в FSBL погоды не сделает - пока не пересоберете U-Boot с правильным Device Tree, он не будет читать в 8-bit width Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 March 1, 2019 Posted March 1, 2019 · Report post Проверил на всякий случай, что происходит с памятью если пытаться её конфигурировать (использовал SDK BSP). Значение BUS_WIDTH [183] (Extended CSD[183]) при переключении шины меняется с 0 на 2, т.е. как и должно быть для шины х8. Пробую PMUFW выкатить из SDK. Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 March 1, 2019 Posted March 1, 2019 · Report post 13 minutes ago, doom13 said: Проверил на всякий случай, что происходит с памятью если пытаться её конфигурировать (использовал SDK BSP). Значение BUS_WIDTH [183] (Extended CSD[183]) при переключении шины меняется с 0 на 2, т.е. как и должно быть для шины х8. Пробую PMUFW выкатить из SDK. А потом U-Boot на это забивает и работает так, как ему сказано. Предлагаю начать медитировать на тему Device Tree Control - Default Device Tree for DT control Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 March 1, 2019 Posted March 1, 2019 · Report post Quote root@zynqmp:~# ls -l /sys/firmware/devicetree/base/amba/sdhci* /sys/firmware/devicetree/base/amba/sdhci@ff160000: total 0 -r--r--r-- 1 root root 4 May 30 16:41 #stream-id-cells-r--r--r-- 1 root root 4 May 30 16:41 bus-width -r--r--r-- 1 root root 4 May 30 16:41 clock-frequency -r--r--r-- 1 root root 16 May 30 16:41 clock-names -r--r--r-- 1 root root 16 May 30 16:41 clocks -r--r--r-- 1 root root 35 May 30 16:41 compatible -r--r--r-- 1 root root 4 May 30 16:41 interrupt-parent -r--r--r-- 1 root root 12 May 30 16:41 interrupts -r--r--r-- 1 root root 8 May 30 16:41 iommus -r--r--r-- 1 root root 4 May 30 16:41 max-frequency -r--r--r-- 1 root root 6 May 30 16:41 name -r--r--r-- 1 root root 4 May 30 16:41 power-domains -r--r--r-- 1 root root 16 May 30 16:41 reg -r--r--r-- 1 root root 5 May 30 16:41 status -r--r--r-- 1 root root 0 May 30 16:41 u-boot,dm-pre-reloc -r--r--r-- 1 root root 4 May 30 16:41 xlnx,device_id -r--r--r-- 1 root root 4 May 30 16:41 xlnx,mio_bank root@zynqmp:~# root@zynqmp:~# root@zynqmp:~# cat /sys/kernel/debug/mmc0/ios clock: 200000000 Hz actual clock: 200000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on)bus width: 3 (8 bits) timing spec: 9 (mmc HS200) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) root@zynqmp:~# Добавил /<plnx_proj>/components/plnx_workspace/device-tree/device-tree/system-user.dtsi (Вообще советуют делать Customizing Device Trees in Yocto , но у меня так не получилось, ошибки плюёт). Quote /include/ "system-conf.dtsi" / { }; /* SD0 eMMC, 8-bit wide data bus */ /* non-removable; */ /* broken-mmc-highspeed; */ &sdhci0 { max-frequency = <200000000>; bus-width = <8>; }; после старта в Linux разрядность шины поменяло, но u-boot работает, как и раньше в х4 Quote U-BOOT for zynqmp Hit any key to stop autoboot: 1 0 Device: sdhci@ff160000 Manufacturer ID: 13 OEM: 14e Name: Q2J55 Tran Speed: 200000000 Rd Block Len: 512 MMC version 5.0 High Capacity: Yes Capacity: 7.1 GiBBus Width: 4-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 7.1 GiB WRREL Boot Capacity: 16 MiB ENH RPMB Capacity: 4 MiB ENH reading image.ub Quote Share this post Link to post Share on other sites More sharing options...
gosha-z 3 March 1, 2019 Posted March 1, 2019 · Report post В очередной раз повторяю: в наиболее общем случае, у U-Boot и у ядра могут быть разные device tree... Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 March 1, 2019 Posted March 1, 2019 · Report post Откуда он его тянет? Quote Share this post Link to post Share on other sites More sharing options...
