Перейти к содержанию
вышел хотфикс OrCAD/Allegro 17.2
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 022
Fixed CCRs: SPB 17.2 HF022
06-16-2017
CCRID   Product            ProductLevel2 Title
1755789 ADW                DBEDITOR      Checking in HSS Block returns 'Failed to create archive'
1731459 ADW                FLOW_MGR      Cannot open LRM from Flow Manager
1731460 ADW                FLOW_MGR      Cannot open LRM from Flow Manager
1744081 ADW                FLOW_MGR      Error regarding configuration file when trying to open Workflow Manager
1756727 ADW                LIBIMPORT     EDM Library Import fails with java exceptions when merging classifications
1743763 ADW                SRM           Find filter is grayed out when Allegro PCB Editor is opened from EDM Flow Manager
1748399 ALLEGRO_EDITOR     DATABASE      In release 17.2-2016, end caps not visible for certain clines in PCB Editor
1748522 ALLEGRO_EDITOR     INTERACTIV    A component mirrored using the 'funckey' command jumps to (0,0) position when the 'move' command is used on it
1734983 ALLEGRO_EDITOR     INTERFACES    Secondary step model does not stay mapped after drawing is reopened
1753704 ALLEGRO_EDITOR     REFRESH       Refreshing symbols crashes PCB Editor
1493721 ALLEGRO_EDITOR     SHAPE         Voids on negative planes are not adhering to constraints
1711242 ALLEGRO_EDITOR     SHAPE         Route keep out leads to partly unfilled shapes with gaps
1726865 ALLEGRO_EDITOR     UI_GENERAL    Pop-up Mirror command does not mirror at cursor position
1752987 ALLEGRO_EDITOR     UI_GENERAL    axlUIViewFileCreate zoom to xy location not working while in user created form.
1755638 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, zoom operations using mouse button not working when axlShellPost() is run
1719792 ALLEGRO_PROD_TOOLB CORE          Productivity Toolbox Z-DRC hangs or crashes PCB Editor
1624869 ALTM_TRANSLATOR    CAPTURE       A structure file is required to translate a third-party schematic to OrCAD Capture
1707416 ALTM_TRANSLATOR    CAPTURE       Missing components and pins in the OrCAD Capture schematic translated from a third-party tool
1708825 ALTM_TRANSLATOR    CAPTURE       The third-party translator fails to translate the schematic
1719200 ALTM_TRANSLATOR    CAPTURE       The third-party translator fails to translate all the pages of a schematic
1546070 ALTM_TRANSLATOR    CORE          Third-party to DE-HDL schematic translation fails
1700508 ALTM_TRANSLATOR    CORE          Third-party PCB translator does not work in release 17.2-2016
1699340 ALTM_TRANSLATOR    DE_HDL        Unable to import third-party schematic into DE-HDL using Import menu in PCB Editor
1630379 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator is not importing clines and vias
1708615 ALTM_TRANSLATOR    PCB_EDITOR    All items of third-party PCB not imported in release 17.2-2016
1758296 APD                DXF_IF        DXF OUT: Rounded rectangle pads mirrored incorrectly
1756040 APD                IMPORT_DATA   The 'die text in' command ignores values after the decimal point
1727206 APD                SHAPE         Merging two shapes results in an incorrect shape
1753682 CONCEPT_HDL        CONSTRAINT_MG Constraint Manager stops responding while cross probing DE-HDL
1721334 CONCEPT_HDL        CORE          dsreportgen not able to resolve gated part on schematic
1747559 CONCEPT_HDL        CORE          Copying a logic symbol without a part table entry results in ERROR(SPCODD-53)
1749644 CONCEPT_HDL        CORE          In release 17.2-2016 Hotfix 019, 'align components' is not working on Windows 8 and DE-HDL crashes
1746910 CONCEPT_HDL        GLOBALCHANGE  Global Component Change unable to identify part data when using schematic pick option
1743572 FLOWS              PROJMGR       Project Manager displays incorrect values in Project Setting
1724124 FSP                DESIGN_EXPLOR Provide TCL command to filter design connectivity window
1719105 FSP                GUI           Tabular sorting not working in FPGA System Planner
1755750 PCB_LIBRARIAN      GRAPHICAL_EDI In release 17.2-2016, unable to delete _N pins in PDV Symbol Editor
1722993 PCB_LIBRARIAN      IMPORT_CSV    Part Developer crashes while importing part information stored in a .csv file
1758856 SIP_LAYOUT         3D_VIEWER     Correct the spelling error in the 3D Viewer Design Configuration window
1755179 SIP_LAYOUT         ARTWORK       PCB Editor crashes when creating Gerber files
1743511 SIP_LAYOUT         MANUFACTURING Package Design Integrity shows non-redundant padstacks in the Redundant Padstacks check
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 024
Fixed CCRs: SPB 17.2 HF024
07-28-2017
1762143 ADW                COMPONENT_BRO Part placed using the 'Add' button does not populate 'PART_NAME' property
1765790 ADW                PART_BROWSER  Fail to extract component part number and footprint information
1757719 ADW                TDA           TDO and Windchilll Work Group Manager out of sync at times
1760607 ALLEGRO_EDITOR     DATABASE      Value for number of decimal places changes in Pad Designer in release 17.2-2016
1775160 ALLEGRO_EDITOR     DFA           Loading DFA spreadsheet crashes PCB Editor in release 17.2-2016
1765984 ALLEGRO_EDITOR     OTHER         Cannot view System Info
1729350 ALLEGRO_EDITOR     REPORTS       Net loop is not listed in report
1725242 ALLEGRO_EDITOR     SHAPE         'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape
1754402 ALLEGRO_EDITOR     SHAPE         Illegal arc radius error (SPMHA1-85)
1762888 ALLEGRO_EDITOR     SHAPE         Border line missing for some crosshatch (xhatch) shape voids
1769188 ALLEGRO_EDITOR     SHOW_ELEM     'Show Element' with the 'Groups' option used on certain modules crashes PCB Editor
1767690 ALLEGRO_EDITOR     TESTPREP      PCB Editor crashes when running automatic Testprep
1737337 ALLEGRO_EDITOR     UI_FORMS      Pinned Show Element window closes when opening new design in release 17.2-2016
1736642 ALLEGRO_PROD_TOOLB INTEGRATION   Cannot change accuracy to 4 for 'Change Width' in Productivity Toolbox
1685216 ALTM_TRANSLATOR    CAPTURE       Third-party translator placing symbols off grid
1738679 ALTM_TRANSLATOR    CAPTURE       Connectivity loss in imported schematic
1738705 ALTM_TRANSLATOR    CAPTURE       Connectivity loss in imported schematic
1748583 ALTM_TRANSLATOR    CAPTURE       Crash on importing design using third-party translator
1679310 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator should fix off-centered connections
1686845 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator does not place parts after successful translation
1723141 ALTM_TRANSLATOR    PCB_EDITOR    Placement outlines are rotated in third-party translator
1723164 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator creates board with missing data: vias, traces, and so on
1723190 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator changes design origin
1750496 ALTM_TRANSLATOR    PCB_EDITOR    Third-party board with arc tracks not correctly converted to arc clines
1769624 APD                DATABASE      Attempted symbol delete crashes APD
1707756 ASDA               VARIANT_MANAG Scrolling in Create Variant closes tool
1753699 CM                 RELEASE       installDebugger() does not work in release 17.2-2016 as SKILL kit is not installed
1741534 CONCEPT_HDL        CORE          DE-HDL freezes when selecting a net that contains many connections
1752687 CONCEPT_HDL        CORE          The move command changes the connectivity of the schematic
1763525 CONCEPT_HDL        CORE          Genview crashes when generating split symbols
1766797 CONCEPT_HDL        CORE          Schematic not refreshed after using the clear xnet overrides feature
1770852 F2B                PACKAGERXL    ERROR(SPCOPK-1138): A hard location was found on instances of different physical part types
1754473 FSP                DE-HDL_SCHEMA Provide an option to generate symbols with custom attributes
1748106 FSP                OTHER         Create protocol from existing protocol error message needs clarity
1724201 FSP                SYMBOL_EDITOR Unable to change 'Pin Direction' in symbol editor
1772429 ORBITIO            ALLEGRO_SIP_I Import - OrbitIO: Translator cannot create bundle in PCB Editor
1725759 SIG_INTEGRITY      OTHER         PCB shape/plane capacitance
1760924 SIP_LAYOUT         DIE_STACK_EDI Package height of die .dra file reset to 110um when placed
1764385 SIP_LAYOUT         MODULES       Embedded components are unplaced in created modules (.mdd)
1733679 SIP_LAYOUT         OTHER         'metal density scan' does not use select window
1763707 SIP_LAYOUT         OTHER         SiP Layout exits with error message in release 17.2-2016
1763515 SIP_RF             DIEEXPORT     Virtuoso writes incorrect width for 45 degree path segments in XDA file
1772397 TDA                DEHDL         DE-HDL crashes if license is not available for team design
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 025
Fixed CCRs: SPB 17.2 HF025
1258913 ADW                ADWSERVER     Copy project message: Unable to locate tools.jar
1760866 ADW                ADWSERVER     Metrics dashboard in Allegro EDM Configuration Manager does not show updated SPB 17.2 hotfix
1055946 ADW                ADW_UPREV     Set PTF_SUBTYPE SEARCHABLE to false and default value to exclamation mark
1508163 ADW                COMPONENT_BRO Manufacturers Part tab disappears on clicking anything other than the part number in the left tree
1774164 ADW                COMPONENT_BRO In release 17.2-2016 Hotfix 22, DE-HDL crashes on using Generate View
1345018 ADW                DBEDITOR      Database Editor does not catch empty mandatory properties if no changes are made to the part
1586858 ADW                DBEDITOR      'Access Denied' Error while opening Datasheet Model using Launch Viewer in Database Editor
1754185 ADW                DBEDITOR      Max Height value in DBEditor is different from PCB Editor
1719260 ADW                FLOW_MGR      Configuration error on a fresh install of EDM in release 17.2-2016 Hotfix 014
1743730 ADW                LIBDISTRIBUTI .lis file error in install_model while using MLR.
1757178 ADW                LIBIMPORT     back-end libimport failed, crash and existing flashmodel not found
1648609 ADW                SRM           PCB Editor stops responding when launched with -s option in release 16.6-2015 Hotfix 078
1731152 ADW                TDA           TDO coredumps after a new object has been checked in as minor and deleted.
1766998 ADW                TDA           TDO-ASA: Cannot enable the project for team design until a component is added to the new ASA/SCM design
1695240 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D View of a package symbol not showing the correct mapped STEP file attached to the package symbol
1698148 ALLEGRO_EDITOR     3D_CANVAS     Allegro 3D Viewer crashes on Windows 10
1738655 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D canvas crashes on Windows 10
1750001 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D Canvas crashes on selecting in symbol view
1751796 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas shows component placed at wrong layer for Embedded components
1768775 ALLEGRO_EDITOR     3D_CANVAS     Allegro 3D canvas closes when Update Symbol is done and cannot be re-invoked
1695025 ALLEGRO_EDITOR     ARTWORK       Artwork film show shorts.
1708674 ALLEGRO_EDITOR     COLOR         Dehighlight all should disable the check boxes in the color dialog/nets
1735522 ALLEGRO_EDITOR     COLOR         In release 17.2-2016, PCB Editor crashes when not being able to write the CVSettings.xml file.
1764475 ALLEGRO_EDITOR     COLOR         Allegro PCB Editor hangs when selecting OK on the Color Dialog form
1718438 ALLEGRO_EDITOR     CROSS_SECTION User interface is inconsistent for the Mask Layer Subclass site file editor.
1765387 ALLEGRO_EDITOR     CROSS_SECTION Cross Section Editor does not retain or remove layers added/removed from Setup-->Subclasses
1714910 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes with blank allegro.jrl file when a release 16.6 board is opened in release 17.2-2016 Hotfix 013
1769534 ALLEGRO_EDITOR     DATABASE      DBDoctor unable to delete invalid subclass
1775705 ALLEGRO_EDITOR     DATABASE      Updating stackup in PCB Editor does not change backdrill status to 'Out-of-Date backdrills'
1778608 ALLEGRO_EDITOR     DATABASE      Rigid Flex design: Components with pads defined on the TOP and BOTTOM layers are not placed on the correct layer
1778644 ALLEGRO_EDITOR     DATABASE      Allegro PCB Editor crashes while trying to place dimensions
1698695 ALLEGRO_EDITOR     DRC_CONSTR    Line to Mech-Pin DRC not displayed
1705214 ALLEGRO_EDITOR     DRC_CONSTR    Shape to drill DRCs not getting void and 'cns_show' does not report constraint value
1722841 ALLEGRO_EDITOR     DRC_CONSTR    Inconsistent soldermask to soldermask DRCs on vias as compared to board geometry/soldermask
1736116 ALLEGRO_EDITOR     DRC_CONSTR    Shape Voiding and DRC error on layer with no hole or pad definition
1744248 ALLEGRO_EDITOR     DRC_CONSTR    Release 16.6 to 17.2-2016 DML Independent Flow does not resolve differential pair pin pairs Correctly
1776848 ALLEGRO_EDITOR     DRC_CONSTR    Negative plane island DRC reported in release 17.2-2016 Hotfix 23
1730806 ALLEGRO_EDITOR     EDIT_ETCH     Element 'vias_allowed' is not valid for content model adding high speed via structures
1745332 ALLEGRO_EDITOR     EDIT_ETCH     In release 17.2-2016, PCB Editor crashes when starting Add ZigZag Pattern
1765555 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashes during contour routing
1644401 ALLEGRO_EDITOR     INTERACTIV    PCB Editor crashes on running the z-copy command
1657621 ALLEGRO_EDITOR     INTERACTIV    Copy cline and via cause redundant vias
1688556 ALLEGRO_EDITOR     INTERACTIV    Limitations with editpad boundary
1704901 ALLEGRO_EDITOR     INTERACTIV    Changes cannot be done when 'Design outline' is selected
1710731 ALLEGRO_EDITOR     INTERACTIV    The Edit > Change command does not select or change the text on a block
1714855 ALLEGRO_EDITOR     INTERACTIV    Placing two objects on the Design_Outline subclass causes PCB Editor to crash
1725736 ALLEGRO_EDITOR     INTERACTIV    Edit>Change cannot change silkscreen line to a different class, but works in preselect mode
1728004 ALLEGRO_EDITOR     INTERACTIV    Text cannot be edited if the Design_Outline subclass is in the selection box
1728794 ALLEGRO_EDITOR     INTERACTIV    The Oops command and the Esc key do not work when moving components in the Temp Group mode
1738070 ALLEGRO_EDITOR     INTERACTIV    Copying shape after Shape Operations results in error 'E- (SPMHDB-72): Current active shape must be filled first'
1750696 ALLEGRO_EDITOR     INTERACTIV    Add notch angle option fails to update if changed while add notch command is active.
1755240 ALLEGRO_EDITOR     INTERACTIV    Copy via does not work
1777416 ALLEGRO_EDITOR     INTERACTIV    Running shape operations results in database corruption
1715835 ALLEGRO_EDITOR     INTERFACES    When IDX is imported in PCB Editor, all the shapes are created on package keepout on all subclasses
1744111 ALLEGRO_EDITOR     INTERFACES    Pads rotating 90 degree when exporting DXF file from Allegro PCB Editor
1736045 ALLEGRO_EDITOR     MENTOR        Third-party import crashes PCB Editor with error stating that .SAV file will be created
1751914 ALLEGRO_EDITOR     MULTI_USER    Find Filter options get disabled while creating symbols
1770811 ALLEGRO_EDITOR     MULTI_USER    In release 17.2-2016, axlTriggerSet('exit 'routine) causes a crash while exiting
1736545 ALLEGRO_EDITOR     OTHER         Spelling mistake in description of no_dynamic_zoom variable in user preferences Editor
1761610 ALLEGRO_EDITOR     OTHER         Dynamic shape is not voiding as expected.
1702535 ALLEGRO_EDITOR     PAD_EDITOR    After modifying a padstack in Pad_Editor, the Update to Design function fails to update the dra file
1713461 ALLEGRO_EDITOR     PAD_EDITOR    Padstack editor default geometry not working when cell is preselected
1715702 ALLEGRO_EDITOR     PAD_EDITOR    Donut shape is lost on cutting the pad shape of the donut pad
1720300 ALLEGRO_EDITOR     PAD_EDITOR    Multi-drill staggered pattern: Different hole placement for first and second rows for releases 16.6 and 17.2-2016
1724896 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor shows flash symbol for regular pad on selecting 'Shape Symbol'
1714839 ALLEGRO_EDITOR     PLACEMENT     Selecting an alternate symbol (alt_symbol) in a group, in the Placement Edit mode, removes the symbol from the group
1781502 ALLEGRO_EDITOR     PLACEMENT     Quickplace by room crashes Allegro PCB Editor
1699690 ALLEGRO_EDITOR     SCHEM_FTB     'view_pcb directive' no longer working as expected
1758796 ALLEGRO_EDITOR     SCHEM_FTB     PCB Editor launched from Project Manager does not read the relative paths specified in the view_pcb directive
1761101 ALLEGRO_EDITOR     SCHEM_FTB     On saving a board after import logic in PCB Editor, the file is saved in the cpm location and not in the physical folder
1761394 ALLEGRO_EDITOR     SCHEM_FTB     Working directory for PCB Editor changes after import logic
1714922 ALLEGRO_EDITOR     SCRIPTS       Running script in the non-graphic mode runs the tool graphically
1726550 ALLEGRO_EDITOR     SHAPE         Shape failed to connect to pin
1754945 ALLEGRO_EDITOR     SHAPE         In release 17.2-2016, Delete islands  fails to add DYN_DELETED_ISLAND to voids on Windows 10 systems
1766280 ALLEGRO_EDITOR     SHAPE         SPMHGE-300 Polygon operation failed because of an internal error
1768307 ALLEGRO_EDITOR     TECHFILE      Properties defined in the technology files are not being imported in a new design
1771584 ALLEGRO_EDITOR     TECHFILE      The tech file import command does not update user-defined property immediately
1730104 ALLEGRO_EDITOR     UI_FORMS      Change description  of Title bar option variables in User Preferences
1749272 ALLEGRO_EDITOR     UI_FORMS      etchlen_ignore_pinvia variable needs to be updated
1649254 ALLEGRO_EDITOR     UI_GENERAL    Using wildcard to open padstack file generates error SPMHA1-161 in Padstack Editor in release 17.2-2016
1685985 ALLEGRO_EDITOR     UI_GENERAL    Funckey not working for Display - Measure
1687073 ALLEGRO_EDITOR     UI_GENERAL    Show Measure command shifts focus to Search field in result window after selecting first element
1699272 ALLEGRO_EDITOR     UI_GENERAL    File Viewer not displaying HTML files correctly when 'allegro_html_qt' is enabled
1711321 ALLEGRO_EDITOR     UI_GENERAL    Database settings do not change on changing color settings using the SKILL function axlDBDisplayControl()
1728468 ALLEGRO_EDITOR     UI_GENERAL    The Show Element window takes the focus away from the PCB Editor window
1733690 ALLEGRO_EDITOR     UI_GENERAL    Performance issues in Visibility dialog if called repeatedly in release 17.2-2016, Hotfix 017
1734176 ALLEGRO_EDITOR     UI_GENERAL    Unable to sort padstacks to open in the padstack editor using wildcards
1735733 ALLEGRO_EDITOR     UI_GENERAL    RAVEL checks slower in release 17.2-2016, Hotfix 017
1737545 ALLEGRO_EDITOR     UI_GENERAL    axlVisibleSet is slower in release 17.2-2016
1744655 ALLEGRO_EDITOR     UI_GENERAL    SKILL code with axlVisibleSet slower in release 17.2-2016 compared to 16.6
1759380 ALLEGRO_EDITOR     UI_GENERAL    axlLayerPriority API changes layer visibility and colors
1775071 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, dialog boxes are not displayed in the right order on using SKILL
1708554 APD                GRAPHICS      MCM shape lines are almost short and different with DXF and Gerber files
1678824 APD                SHAPE         Updating dynamic shape fails to void all elements on layer L2.
1742335 ASDA               COMPONENT_BRO Libraries missing from new Component Browser
1779777 ASDA               CONNECTIVITY_ SDA: Net name and physical net name are different
1721919 ASDA               CROSSPROBE    Cross-probing a net from the .brd file highlights the entire bus in the schematic
1714313 ASDA               EDIT_OPERATIO Filter does not work correctly in the Change RefDes form
1730809 ASDA               FORMAT_OBJECT Image transparency slider does not update the number in the combo box correctly
1747397 ASDA               GRAPHICS      Pop-up DRC descriptions are too small and cannot be read
1640061 ASDA               HIERARCHY     Incorrect message received when invalid characters are specified for subdesign suffix
1723535 ASDA               MISCELLANEOUS Clicking in the Command window should place the cursor at the last line to avoid editing previously run commands
1699936 ASDA               PAGE_MANAGEME Page gaps created while moving pages
1737180 ASDA               VARIANT_MANAG Deleted variants are removed from the variant.lst file but displayed in SDA
1763247 ASDA               VARIANT_MANAG Changes in Variant Editor are not reflected on the schematic page.
1733971 CAPTURE            CONNECTIVITY  Auto connect to bus not working in the attached design
1236010 CAPTURE            DATABASE      Capture is very slow in processing designs.
1518560 CAPTURE            DATABASE      Large schematics are slow to respond
1705592 CAPTURE            DATABASE      Capture hangs when switching between schematics that contain nested netgroups
1770687 CAPTURE            GENERAL       In release 17.2-2016 Hotfix 021 and 022, selecting Help - Learning PSpice throws Java Script error
1692435 CAPTURE            HELP          Version Info Window is empty
1767374 CAPTURE            NETLIST_ALLEG Capture crashes on canceling the netlisting process
1719613 CAPTURE            OTHER         Moving a wire in OrCAD Capture CIS or Allegro Design Entry CIS results in design crash
1746663 CAPTURE            OTHER         Capture slows down significantly in release 17.2-2016 Hotfix 017 and 018
1709179 CAPTURE            PROPERTY_EDIT Unable to delete unwanted properties associated with Ground and VCC nets.
1714121 CAPTURE            SCHEMATIC_EDI Mirroring and moving a symbol resets the position of a newly added pin property
1729861 CIS                OTHER         The 'Refresh Part Types' icon is alternated with 'Refresh Symbols From Libs' icon
1333600 CONCEPT_HDL        COMP_BROWSER  Sort the sections numerically in Part Information Manager
1758761 CONCEPT_HDL        COMP_BROWSER  Incorrect Version showing in Component Browser in 17.2
1769591 CONCEPT_HDL        COMP_BROWSER  Modify Component / Project Information Manager (PIM), parts take longer to load in EDM
1479711 CONCEPT_HDL        CORE          Mirroring symbols causes alignment issues
1696208 CONCEPT_HDL        CORE          Display issue with the grid visibility after a save hierarchy
1698802 CONCEPT_HDL        CORE          Pin number overlap with the pin stub when the component is mirrored.
1708917 CONCEPT_HDL        CORE          nconcepthdl crashes on a design with a core dump
1744815 CONCEPT_HDL        CORE          Deleting a page crashes DE-HDL
1751863 CONCEPT_HDL        CORE          'Move' does not move body but only properties of selected part
1763556 CONCEPT_HDL        CORE          Component Alignment and other graphical feature not working in Windows 10
1725121 CONSTRAINT_MGR     CONCEPT_HDL   Audit report of ECSets reflects some gaps in certain columns
1758740 CONSTRAINT_MGR     CONCEPT_HDL   Extracted topology does not populate the gather control used in the ECSet
1759580 CONSTRAINT_MGR     CONCEPT_HDL   Class to Class assignments are incorrectly displayed in the 'CSet Assignment Matrix'
1759590 CONSTRAINT_MGR     CONCEPT_HDL   Unable to create bookmarks in Constraint Manager
1764597 CONSTRAINT_MGR     CONCEPT_HDL   Copying constraints from a SKILL-defined CSet copies the automation flag/attribute ('A' in UI), as well.
1771427 CONSTRAINT_MGR     CONCEPT_HDL   Decimal units specified in the precision settings are not applied correctly
1700402 CONSTRAINT_MGR     DATABASE      Parallelism violation DRC not reported until cline is moved
1700370 CONSTRAINT_MGR     OTHER         Constraint Manager: Expanded nodes collapse on restart
1735636 CONSTRAINT_MGR     OTHER         Inductors are extracted as resistors in the topology
1776917 CONSTRAINT_MGR     OTHER         Creating advanced formula causes the tool to crash
1762979 CONSTRAINT_MGR     TECHFILE      Constraint Manager does not retain values after importing tech file
1699275 CONSTRAINT_MGR     UI_FORMS      Constraint Manager: Dialog boxes opened from the File – Import menu show files and folders in incorrect order
1699312 CONSTRAINT_MGR     UI_FORMS      Typing *.* in the File name field does not display all the files in the Import Constraints dialog box
1742134 CONSTRAINT_MGR     UI_FORMS      Editing a cell from any of the constraint set in Constraint manager is filling other cells that should not be selected
1755576 CONSTRAINT_MGR     UI_FORMS      Constraint Manager: Physical CSet filter not working correctly
1775333 ECW                DASHBOARD     Activity Log is not accessible to ECAD_Integrators if they are not part of the project team
1749220 ECW                OTHER         Remove 'Role' column from Users web parts
1716527 ECW                TDO-SHAREPOIN Allegro Pulse: Mismatch between metrics with components on schematic and components in layout
1724195 FSP                SYMBOL_EDITOR Device pins are not correctly aligned after being moved in Schematic Symbol Editor
1725479 INSTALLATION       DOWNLOAD_MGR  Download Manager error prompts user to close downloadmanager.exe
1738952 PCB_LIBRARIAN      SYMBOL_EDITOR Pin table must allow for Copy/Paste of Rows
1638740 PSPICE             FRONTENDPLUGI Set minimum height for the search field in PSpice Part Search
1699822 PSPICE             FRONTENDPLUGI Set minimum height for the search field in PSpice Part Search
1652265 PSPICE             MODELING_APPS Cannot place PWL source from PSpice Modeling App
1685967 PSPICE             MODELING_APPS Getting error when trying to place PWL source from PSpice Modeling App
1716313 PSPICE             MODELING_APPS PSpice PWL Sources not working correctly in release 17.2-2016 Hotfix 014
1738747 PSPICE             MODELING_APPS Inconsistent file type for PWL part in modeling application and source library
1762202 PSPICE             MODELING_APPS PSpice modelling app Tcl issues
1736605 PSPICE             SIMMODELS     BSIM4.6 model parameters incorrectly handled by simulator
1442623 PSPICE             SIMULATOR     Bias points are nor correct in attached circuit
1618815 PSPICE             SIMULATOR     Bias Point calculation appears incomplete
1723039 PSPICE             SIMULATOR     PSpice crashes when curly braces are specified for the ETABLE parts
1782353 SIG_INTEGRITY      SIGWAVE       SigWave crashes when opening .sww file in release 17.2-2016 Hotfix 023
1745940 SIP_LAYOUT         DATABASE      Cutting a part of a tapered cline does not remove the connectivity on the dangling cline
1780072 SIP_LAYOUT         DIE_ABSTRACT_ Export->Die Abstract File causes a crash
1736396 SIP_LAYOUT         SYMB_EDIT_APP 'No such child' error message when deleting pins in symed
1769728 TDA                CORE          Default policy file needs to be fixed
1735682 XTRACTIM           GUI           XtractIM translation is incorrect: adds anti-pads
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 026
Fixed CCRs: SPB 17.2 HF026
09-15-2017
1765398 ADW                DATAEXCHANGE  Duplicate  MPNs are created when updating MPN classification properties with data exchange
1780147 ADW                DBEDITOR      'Associate Footprint from Tree' does not log the information
1790134 ALLEGRO_EDITOR     DATABASE      Correct spelling  in Layer Function definition
1792345 ALLEGRO_EDITOR     DATABASE      Pastemask is added to bottom layer on backdrilled pins
1792930 ALLEGRO_EDITOR     DATABASE      Uprev required for all libraries and padstacks to use release 16.6 DRA in release 17.2-2016
1781203 ALLEGRO_EDITOR     DFA           DFA Spreadsheet Editor not starting from Windows Start menu
1797422 ALLEGRO_EDITOR     DFA           DFA Spreadsheet Editor not starting from Windows Start menu
1770694 ALLEGRO_EDITOR     INTERFACES    Incremental IDX does not place unplaced components
1776791 ALLEGRO_EDITOR     INTERFACES    STEP file not displayed in PCB Editor for mapping
1783515 ALLEGRO_EDITOR     INTERFACES    PCB Editor reading step model incorrectly
1781485 ALLEGRO_EDITOR     MANUFACT      Setting ipc2581attrpath results in error 'E- ipc2581attrpath: Variable not defined'
1772713 ALLEGRO_EDITOR     MULTI_USER    Allegro Symphony Server rejects group moves
1789853 ALLEGRO_EDITOR     MULTI_USER    Symphony Server rejects updates and hangs frequently
1725591 ALLEGRO_EDITOR     OTHER         File - Export PDF crashes on the design attached
1736324 ALLEGRO_EDITOR     OTHER         Export - PDF fails to export PDF
1794071 ALLEGRO_EDITOR     PLACEMENT     The placement of component is very slow and takes around 3 to 5 minutes per component.
1496199 ALLEGRO_EDITOR     SHAPE         Overlapping route keepouts result in a broken shape.
1760146 ALLEGRO_EDITOR     SHAPE         Void offset in Artwork but not in board for a particular instance only
1770372 ALLEGRO_EDITOR     SHAPE         Overlapping shapes merged in artwork shifts void causing a manufacturing short
1793419 ALLEGRO_EDITOR     SHAPE         Unexpected shape void in artwork in release 16.6
1796666 ALLEGRO_EDITOR     SHAPE         DRCs for out-of-date shape while placing single via
1786386 APD                EXPORT_DATA   Exported dra and pad files do not have right stackup
1765673 APD                SHAPE         Shape in Cu1 and Cu3 cannot void correctly
1782418 APD                SHAPE         Artwork is showing unnecessary horizontal lines
1778366 CONCEPT_HDL        CHECKPLUS     CheckPlus not printing logic design name
1723855 CONCEPT_HDL        CORE          Cannot use Rename Signal for unnamed wire segment if the wire has a branch to the same instance
1755174 CONCEPT_HDL        CORE          Unable to create XNETs on the read-only blocks
1765533 CONCEPT_HDL        CORE          Strokes are slow to respond in release 17.2-2016
1780253 CONCEPT_HDL        CORE          In Windows mode, with copy command still active and symbol on cursor, DE-HDL stops responding on pressing Delete key
1785069 CONCEPT_HDL        CORE          Warning box for SPCOCN-2251 needs to be resized and the text formatted correctly
1786030 CONCEPT_HDL        CORE          Packager fails in release 16.6 but runs successfully in release 17.2-2016
1788077 CONCEPT_HDL        CORE          Creating new window (new tab) in DE-HDL resets view of original window
1788591 CONCEPT_HDL        CORE          Wrong pin number displayed after running packager
1776774 CONCEPT_HDL        CREFER        CRefer crashes without error entry in log file
1328320 CONCEPT_HDL        PDF           Cannot select/search sig_name in published PDF
1787409 CONCEPT_HDL        PDF           Minus character at the end of netname causes unexpected string concatenation during PDF Publish
1758122 CONSTRAINT_MGR     ANALYSIS      Extracted topology for a differential pair is missing a pin-to-pin connection in the top file
1786161 CONSTRAINT_MGR     CONCEPT_HDL   Random crashes in release 17.2-2016 while working on the schematic editor along with Constraint Manager
1788877 CONSTRAINT_MGR     DATABASE      Constraint Manager API cmxlImportFile looks for sub-string during replace mode and not explicit names
1800263 CONSTRAINT_MGR     OTHER         DE-HDL and CM crash when deleting regions
1792000 CONSTRAINT_MGR     UI_FORMS      Data type of constraint not shown in GUI
1744828 FSP                CAPTURE_SCHEM Button appears during 'Generate OrCAD Schematics'
1747568 ORBITIO            OTHER         Import of .oio file in SiP Layout takes a long time
1765229 PSPICE             AA_FLOW       Not able to run PSpice MC after setting Assign Tolerance
1770174 PSPICE             MISC          Issues with DMI Template Code Generator
Ссылка на сообщение
Кто-нибудь знает, что за новая опция появилась в Allegro PCB, возможно после очередного QIR4?
PA3170 - Advanced Technology Option
Изменено пользователем alver
Ссылка на сообщение
нет, и официальные партнеры затрудняются сказать.
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 027
Fixed CCRs: SPB 17.2 HF027
09-29-2017
1795353 ADW                FLOW_MGR      Tool unable to find project in windows_project.txt
1810386 ADW                FLOW_MGR      Error regarding not finding project in 'windows_project.txt'
1743732 ADW                LIBDISTRIBUTI adwserver -install does not give error if it cannot connect to server.
1804378 ALLEGRO_EDITOR     3D_CANVAS     Bend area issues in 3D Viewer
1795312 ALLEGRO_EDITOR     DATABASE      Cannot unlock symbols as status is changed to View on opening design
1803262 ALLEGRO_EDITOR     DATABASE      Donut pad With DYN_THERMAL_CON set to FULL_CONTACT has connectivity issues
1802183 ALLEGRO_EDITOR     DFM           Using mouse wheel to scroll error information in DRC Browser changes font size
1797222 ALLEGRO_EDITOR     DRC_CONSTR    Updating DRC results in error 'SPMHDB-403'
1792163 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashes on moving components
1806640 ALLEGRO_EDITOR     INTERFACES    Step Mapping not working in release 17.2-2016 Hotfix 025
1807278 ALLEGRO_EDITOR     INTERFACES    Running 'step_export_product_asm.exe' displays 'vcruntime140.dll' missing error
1807286 ALLEGRO_EDITOR     INTERFACES    The facet file (.xml) for the STEP model 'modelname.step' cannot be found.
1808006 ALLEGRO_EDITOR     INTERFACES    Facet file for step model cannot be found
1704335 ALLEGRO_EDITOR     MANUFACT      Documentation Editor shows an error about backdrill while no backdrill was used in the design
1800115 ALLEGRO_EDITOR     MANUFACT      IPC2581 Export giving error that backdrill is out of date even though no backdrill is defined in the design
1799444 ALLEGRO_EDITOR     PLACEMENT     Via Array - Boundary placement fails with error
1804129 ALLEGRO_EDITOR     SHAPE         XHatch Shape not voiding properly
1805238 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes while importing netlist
1803542 ALLEGRO_EDITOR     SKILL         Using axlPadstackEdit to change drill size causes via net to change in release 17.2-2016 Hotfix 025
1800774 APD                STREAM_IF     Only one pad in GDSII when running 'stream out' with the Flatten Geometry option
1804196 APD                STREAM_IF     Component is mirrored by X-axis instead of Y-axis on enabling mirror geometry
1803375 ASDA               IMPORT_BLOCK  Import HDL Block fails with message regarding Xnet states and DML independence
1807423 ASDA               NEW_PROJECT   SDA CPM file has erroneous date
1789400 CAPTURE            SCHEMATIC_EDI Capture schematic opens unannotated pages on search
1801573 CONCEPT_HDL        CONSTRAINT_MG Upreving release 16.6 design to 17.2-2016 adds NO_XNET_CONNECTION to some components
1810586 CONCEPT_HDL        CONSTRAINT_MG DE-HDL crashes when transferring XNET properties to similar components in a read-only block
1794169 CONCEPT_HDL        CORE          _automodel command crashes DE-HDL if PACK_IGNORE is set
1798672 CONCEPT_HDL        CORE          Dashes in design name creates an extra design folder in worklib after upreving to release 17.2-2016
1802258 CONCEPT_HDL        CORE          Locking unlocked components results in a warning (SPCOCN-3403)
1803019 CONCEPT_HDL        CORE          DE-HDL crashes on backannotation
1803615 CONCEPT_HDL        CORE          After running 'Mark for Variant', the block cannot be changed to blue
1804029 CONCEPT_HDL        CORE          Visibility issues when using the LOCK functionality
1806352 CONCEPT_HDL        CORE          Group Mirror is causing design corruption.
1806978 CONCEPT_HDL        CORE          Cannot mirror a group of  objects
1810387 CONCEPT_HDL        CORE          Mirroring groups causes erratic display and may corrupt database if project is saved
1812811 CONCEPT_HDL        CORE          Schematic group mirror not working
1810401 CONCEPT_HDL        INFRA         Add Signal Name: Cannot select suggested net name
1800931 CONSTRAINT_MGR     OTHER         Even after removing NO_XNET_CONNECTION on parallel termination, topology extracted has duplicate capacitors
1790106 CONSTRAINT_MGR     SCM           Cannot find the constraints file (0) in the schematic project
1787117 CONSTRAINT_MGR     UI_FORMS      Creating bundle in Constraint Manager crashes PCB Editor
1797384 ECW                METRICS       Pop-up metrics value tool tip is translucent, making values hard/impossible to read
1803226 ECW                METRICS       Pop-up metrics value tool tip is translucent, making values hard/impossible to read
1664059 ORBITIO            ALLEGRO_SIP_I Incorrect connectivity after .brd import
1799338 SIP_LAYOUT         DRC_CONSTRAIN Multi-threaded DRC fails with internal memory error even after setting shape_cache_size
1799499 SIP_LAYOUT         DRC_CONSTRAIN Multi-thread DRC fails
1806585 SIP_LAYOUT         DRC_CONSTRAIN Multi-threaded DRC update aborted: internal memory resource depleted
1809804 SIP_LAYOUT         DRC_CONSTRAIN Error message while updating DRCs in release 17.2-2016 Hotfix 026 regarding shape_cache_size
1788770 XTRACTIM           ENG           Translated bump / ball conductivity is wrong (PowerDC and XtractIM)
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 028
Fixed CCRs: SPB 17.2 HF028
10-14-2017
1773530 ADW                FLOW_MGR      DE-HDL hangs on importing components from another design or copying and pasting components within a design
1790584 ADW                FLOW_MGR      SKILL code for comparing two PCB Editor .brd files does not work in EDM in release 17.2-2016
1794116 ADW                FLOW_MGR      LRM fails to run on project
1811532 ADW                FLOW_MGR      The message for missing tools.jar should not appear in adwcopyproject.log
1812109 ADW                LRM           Library revision manager displays errors while re-importing updated sub-blocks
1771851 ADW                PCBCACHE      Problem in packaging upreved imported block
1814785 ALLEGRO_EDITOR     3D_CANVAS     PCB Editor crashes when a bend is created and then viewed in 3D Viewer
1800131 ALLEGRO_EDITOR     DATABASE      allegro_downrev_library utility fails on Windows 10
1814558 ALLEGRO_EDITOR     DFM           Silkscreen checks do not work if silkscreen is defined as mask in cross section
1814607 ALLEGRO_EDITOR     DFM           DFM check for soldermask does not include Package Geometry/ Soldermask if the soldermask is part of stackup
1813996 ALLEGRO_EDITOR     EDIT_ETCH     Add Connect crashes PCB Editor if clearance view is set to channel
1810832 ALLEGRO_EDITOR     SCHEM_FTB     Error while doing Export Physical from DE-HDL to PCB Editor
1811785 ALLEGRO_EDITOR     SCHEM_FTB     Import > Logic > Import Directory does not resolve the relative path to the packaged folder
1814166 ALLEGRO_EDITOR     SCHEM_FTB     Error message when exporting design to board using an earlier version of database
1817891 ALLEGRO_EDITOR     SCHEM_FTB     Error message when exporting design to board using an earlier version
1818954 ALLEGRO_EDITOR     SCHEM_FTB     Error message when exporting design to board using an earlier version of database
1812808 ALLEGRO_EDITOR     SHAPE         Artwork is different from PCB board
1814836 ALLEGRO_EDITOR     SKILL         Doing zcopy Xhatch pattern crashes PCB Editor in release 17.2-2016
1772218 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor stops responding on Show Element
1778353 ALLEGRO_EDITOR     UI_GENERAL    Intermittent PCB Editor crashes on loading IDX in release 17.2-2016 Hotfix 020
1818077 ALLEGRO_EDITOR     UI_GENERAL    axlViewFileCreate disappears behind window or is blank
1809597 CONCEPT_HDL        CORE          Problem auditing SI model in Allegro Design Entry HDL from Hotfix 025 onward, no problem in Hotfix 024
1810322 CONCEPT_HDL        CORE          Unable to package design if OK_NET_ONE_PIN property is set
1813436 CONCEPT_HDL        CORE          Read-only block import issue in same session: displays error message SPCOCD-553
1813912 CONCEPT_HDL        CORE          The response in DE-HDL is sometimes extremely slow
1812506 CONCEPT_HDL        INTERFACE_DES Error messages during packaging followed by a success message though there are errors in design
1808677 CONSTRAINT_MGR     CONCEPT_HDL   Auto-generation of differential pair finds several instances of the same net
1808898 CONSTRAINT_MGR     CONCEPT_HDL   Unable to resolve the ECSet mapping errors if the topology has pin of PINUSE POWER & GROUND
1810320 CONSTRAINT_MGR     CONCEPT_HDL   DE-HDL - Constraint Manager:  Cannot add group to net class if a net in group is a member of the net class
1812459 CONSTRAINT_MGR     CONCEPT_HDL   Auto-generation of differential pairs has issues
1796234 CONSTRAINT_MGR     OTHER         PCB Editor crashes on query (ALLOW_ON_ETCH_SUBCLASS) without data type defined
1811692 CONSTRAINT_MGR     OTHER         Constraint Manager: Set Topology Constraints - Rel Prop Delay - Pins is empty in release 17.2-2016 Hotfix 026
1816311 CONSTRAINT_MGR     XNET_DIFFPAIR Extracting a differential pair into SigXplorer crashes DE-HDL
1807593 ORBITIO            ALLEGRO_SIP_I Die symbol shifts when importing die from OrbitIO to SiP Layout
1800763 PSPICE             SLPS          Error while running co-simulation in MATLAB for PSpice-SLPS demo designs
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 029
Fixed CCRs: SPB 17.2 HF029
11-3-2017
1814597 ADW                DBEDITOR      Associate part classification is very slow in release 17.2-2016 of Allegro EDM
1733482 ADW                FLOW_MGR      After installing QIR3, Flow Manager prompts with Java Help question
1814789 ADW                PART_BROWSER  PTF shows data in old component browser but not new component browser
1808620 ALLEGRO_EDITOR     DFM           Missing graphics in new drc browser.
1807996 ALLEGRO_EDITOR     EDIT_ETCH     Route Clearance View is not using the correct spacing constraint when nets are partially routed in a region
1747929 ALLEGRO_EDITOR     INTERFACES    Cannot import logo/bmp on a .dra file
1820142 ALLEGRO_EDITOR     INTERFACES    pdf_out command not supporting UNC paths for the output pdf file
1671865 ALLEGRO_EDITOR     MANUFACT      Exceeding 20 characters in Artwork Control Form - General Parameters - Prefix displays 'Illegal Character(s)' error
1710032 ALLEGRO_EDITOR     MANUFACT      Adding Artwork prefix gives error for illegal characters
1714911 ALLEGRO_EDITOR     MANUFACT      ERROR: 'illegal character(s) present in name or value' while adding prefix in Artwork Control Form
1813950 ALLEGRO_EDITOR     MANUFACT      In the drill chart, the titles 'tolerance_drill' and 'tolerance_travel' seem to be reversed
1820970 ALLEGRO_EDITOR     MANUFACT      IDX_EXCLUDE and BOM_IGNORE excluding objects from IDX export
1822045 ALLEGRO_EDITOR     PARTITION     Shape fillet becomes static shape and loses fillet attribute after importing partition
1776181 ALLEGRO_EDITOR     SHAPE         Placing via arrays around a differential pair places vias only for one net
1817283 ALLEGRO_EDITOR     SHAPE         Allegro PCB Editor Show Measure Air Gap shows a very large number
1815595 APD                DRC_CONSTRAIN Differential pair spacing constraint not propagating to physical cset nets
1785116 APD                SHAPE         Big size die performance issue
1811134 APD                STREAM_IF     GDS stream out with 2000 precision has sharp edges along shapes.
1811882 APD                VIA_STRUCTURE High-speed via structure refresh fails
1814878 ASDA               DARK_THEME    Part Manager: Difficult to read black text on black background
1814889 ASDA               DARK_THEME    Change 'updating route in progress' message color: a bright orange bar in dark theme is difficult to read
1817355 ASDA               PAGE_MANAGEME Double-clicking a library in project preferences library does not move the library but changes appearance
1817964 ASDA               SHORTCUTS     User Preferences shortcut misspelled
1820247 CONCEPT_HDL        CORE          DE-HDL crashes while saving a design
1823187 CONCEPT_HDL        CORE          DEHDL allows editing of the locked component's refdes using change text editor
1824052 CONCEPT_HDL        CORE          Trying to edit on a group containing a LOCK component, deletes the packaging data on the schematic
1813987 CONSTRAINT_MGR     OTHER         PCB Editor crashes when Constraint Manager is closed
1821129 CONSTRAINT_MGR     XNET_DIFFPAIR Uprev to release 17.2-2016 adds unwanted NO_XNET_CONNECTION property to discrete symbols
1814725 PSPICE             PROBE         PSpice Measurements crashes PSpice for a digital simulation
1808672 SIP_LAYOUT         INTERACTIVE   create bounding shape command options: 'Min Area' and 'Sync with shape layer'
1817458 SIP_LAYOUT         MANUFACTURING Error in DXF conversion after updating SiP Layout  from Hotfix 066 to 082 in release 16.6
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 030
Fixed CCRs: SPB 17.2 HF030
11-17-2017
1821774 ADW                DBEDITOR      MPN is tagged Pending Purge after deletion and lib_dist
1829549 ALLEGRO_EDITOR     DRC_CONSTR    Dynamic phase DRC marker displayed at the design origin
1690998 ALLEGRO_EDITOR     INTERFACES    Runtime error when running PDF Publisher
1805203 ALLEGRO_EDITOR     INTERFACES    Runtime error when exporting smart PDF on a large board with all film layers selected
1811698 ALLEGRO_EDITOR     INTERFACES    Runtime error while exporting PDF
1823818 ALLEGRO_EDITOR     INTERFACES    Cannot map some step models
1750654 ALLEGRO_EDITOR     MANUFACT      Cut marks cannot be generated on cut outline.
1828293 ALLEGRO_EDITOR     NC            Incorrect status returned for backdrill
1825401 ALLEGRO_EDITOR     PADS_IN       In PADS library translation, pads_lib_in fails to create Placebound_Top as a shape
1825427 ALLEGRO_EDITOR     PADS_IN       Symbol drawing files (.dra) created after PADS Library translation are not getting renamed to their decals
1825460 ALLEGRO_EDITOR     PADS_IN       Pins are moved from their correct locations during PADS Library Translation
1831200 ALLEGRO_EDITOR     PLOTTING      Incorrect PDF output for traces
1321314 ALLEGRO_EDITOR     SHAPE         Force update of dynamic shape generates thermal tie that causes net to short
1647585 ALLEGRO_EDITOR     SHAPE         Void around holes is not circular but of the shape of the bounding box
1830676 ALLEGRO_EDITOR     SHAPE         XHatch Shape not voiding properly
1821286 ALLEGRO_EDITOR     SKILL         Using axlSetParam to set static shape clearance parameter crashes PCB Editor
1804662 ASDA               DARK_THEME    Dark Theme: Change color of selected cells in Rename signals dialog so user can see they are selected
1817486 ASDA               NEW_PROJECT   Need to save a project with a new name, 'copyprojectas' does not seem to work
1826023 ASDA               NEW_PROJECT   SDA requires user to go into project settings window twice to add a library
1830632 ASDA               SCRIPTING     SDA crashes when you type 'find -types' in the Tcl command window
1798864 ASDA               VARIANT_MANAG Retain default part visibility when substituting preferred part for variant
1798865 ASDA               VARIANT_MANAG Value attribute of variant is off while printing though on for default and view
1798866 ASDA               VARIANT_MANAG Variant Printing: Pin numbers printed though set to off on default part
1831836 ASDA               VARIANT_MANAG Cannot delete existing variants in design
1821120 CONCEPT_HDL        CORE          SIGNAL_MODEL attached to a component is not displayed on the canvas in the Attributes form
1824714 CONCEPT_HDL        CORE          Display issue: Page border disappears when running the command _movetogrid
1822587 CONCEPT_HDL        CREFER        CRefer crashes on a hierarchical design using split blocks
1825461 CONSTRAINT_MGR     CONCEPT_HDL   Uprevving to release 17.2-2016 adds NO_XNET_CONNECTIONS on components having custom models
1825968 CONSTRAINT_MGR     DATABASE      cmxlGetObjects returns all the aliased nets and the physical net that goes to the netlist
1819622 CONSTRAINT_MGR     XNET_DIFFPAIR Discrete with NO_XNET_CONNECTION removed from topology when extracted with Routed Interconnect
1829762 ECW                PROJECT_MANAG Pulse log in: Multiple processes triggered, generating many zip file packets and corrupting many of the packets
1810296 F2B                BOM           BOM includes status column,  nothing should ever be forced on a users BOM output
1824593 F2B                PACKAGERXL    PXL crashes and removes the pxl.log file from the Packaged directory
1832005 F2B                PACKAGERXL    Message stating 'PXL has stopped working' when packaging design
1822912 RF_PCB             AUTO_PLACE    rf_autoplace fails for RF component containing variable
1803731 SIP_LAYOUT         DXF_IF        DXF export from 'Component Geometry/Pin_Number' subclass not working in release 17.2-2016
1825478 SIP_LAYOUT         SHAPE         When running the Shape Islands report it is listing all the Fillets as Islands
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 031
Fixed CCRs: SPB 17.2 HF031
12-8-2017
1746108 ADW                DBADMIN       Adding and then saving a custom rule set in rule manager results in corrupt rules.xml
1609983 ADW                DBEDITOR      dbeditor should automatically change mechanical kit names to uppercase
1807139 ADW                DBEDITOR      Cannot add new properties, though the new properties were shown in dbeditor
1807410 ADW                LIB_FLOW      Checked-in parts not available in database
1797408 ADW                TDA           TDO crashes without displaying exception during check-in
1804500 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D canvas fails to show all placebounds of a .dra
1810758 ALLEGRO_EDITOR     3D_CANVAS     3D Viewer represents symbol incorrectly in hotfix 025 but as expected in hotfix 024
1795567 ALLEGRO_EDITOR     EDIT_ETCH     Route menu has same hot key for 'Connect' and 'Convert Fanout'
1796525 ALLEGRO_EDITOR     EDIT_ETCH     AiPT is not pushing dynamic shape to add bumps to resolve dynamic phase DRC
1818170 ALLEGRO_EDITOR     EDIT_ETCH     Fanout with Outward Via direction is shorting few pins
1712658 ALLEGRO_EDITOR     INTERACTIV    Add connect: Pin remains highlighted even after choosing 'Done'
1727193 ALLEGRO_EDITOR     INTERACTIV    Logic - Part List truncates device names to 64 characters though database allows longer names
1775484 ALLEGRO_EDITOR     INTERACTIV    Choosing Next with persistent snap in Show Measure disables persistent snap
1711860 ALLEGRO_EDITOR     MULTI_USER    Multi-user lock cannot be cancelled
1812448 ALLEGRO_EDITOR     NC            Crash when canceling NC Parameters dialog
1792987 ALLEGRO_EDITOR     PAD_EDITOR    Pad Designer does not recognize flash names longer than 31 characters
1810958 ALLEGRO_EDITOR     PAD_EDITOR    Padstacks with offset holes
787024  ALLEGRO_EDITOR     SHAPE         Improve dynamic shape voiding in regions
793232  ALLEGRO_EDITOR     SHAPE         Line to Shape spacing rule outside region affects shape void in region
797245  ALLEGRO_EDITOR     SHAPE         Line to Shape Spacing with Region not followed
865822  ALLEGRO_EDITOR     SHAPE         The autovoid functionality should use the true line-to-shape spacing value
912051  ALLEGRO_EDITOR     SHAPE         Improve dynamic shape voiding in regions
965714  ALLEGRO_EDITOR     SHAPE         Region constraints are not working correctly on dynamic shapes
968342  ALLEGRO_EDITOR     SHAPE         Shape Voiding when crossing constraint region is taking conservative value and not the actual spacing value
974734  ALLEGRO_EDITOR     SHAPE         Shape Voiding when crossing constraint region takes conservative value and not actual spacing value
1073908 ALLEGRO_EDITOR     SHAPE         Allow line to shape spacing in Region
1154787 ALLEGRO_EDITOR     SHAPE         Region constraints not applied correctly to dynamic shapes
1171283 ALLEGRO_EDITOR     SHAPE         Shape Voiding when crossing constraint region takes conservative value and not actual spacing value
1181767 ALLEGRO_EDITOR     SHAPE         Allow override on line to shape spacing in Constraint Region
1183792 ALLEGRO_EDITOR     SHAPE         Allow override on line to shape spacing in Constraint Region
1186210 ALLEGRO_EDITOR     SHAPE         Line to shape spacing constraint does not follow the Constraint Region value
1192312 ALLEGRO_EDITOR     SHAPE         Region constraints are not working correctly.
1387021 ALLEGRO_EDITOR     SHAPE         Improve dynamic shape voiding in Regions
1447891 ALLEGRO_EDITOR     SHAPE         Resolved constraint and actual air gap differ
1465383 ALLEGRO_EDITOR     SHAPE         Line to shape spacing constraint does not follow the Constraint Region
1583144 ALLEGRO_EDITOR     SHAPE         Line to shape spacing inside the constraint region does not follow region rules
1591320 ALLEGRO_EDITOR     SHAPE         Resolve shape to pin constraint in constraint region
1627305 ALLEGRO_EDITOR     SHAPE         Shape Voiding when crossing constraint region takes conservative value and not actual spacing value
1694552 ALLEGRO_EDITOR     SHAPE         Constraint region not working correctly
1764474 ALLEGRO_EDITOR     SHAPE         Line to Shape Spacing for Region should be used inside region instead of conservative value
1775119 ALLEGRO_EDITOR     SHAPE         Shape voiding is not following constraint rules for dynamic shapes in a constraint region
1784916 ALLEGRO_EDITOR     SHAPE         Shapes are not voiding to other shapes against DRC settings, creating random DRCs.
1793179 ALLEGRO_EDITOR     SHAPE         'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape
1803365 ALLEGRO_EDITOR     SHAPE         Region shape to shape constraints take precedence when shapes have multiple constraints
1800530 ALLEGRO_EDITOR     UI_FORMS      3D Anchor menu missing when using new style OrCAD PCB Editor menu
1813604 ALLEGRO_EDITOR     UI_FORMS      3D Anchor View is not available on OrCAD PCB Editor menu.
1784710 ALLEGRO_EDITOR     UI_GENERAL    During Place Replicate and saving file with same name, the warning pop-up window does not show on top
1784728 ALLEGRO_EDITOR     UI_GENERAL    During Place Replicate and saving file with same name, the warning pop-up window does not show on top
1721853 ASDA               CANVAS_EDIT   Movement of components results in shorts and inconsistent routing
1802120 ASDA               CONTEXT_MENUS Ports are selected though filter is set to Components
1803832 ASDA               MISCELLANEOUS Browse and select new libraries without editing cds.lib
1804643 ASDA               TABLE         Exception when pasting table data from third-party tool in SDA
1794004 CAPTURE            LIBRARY       Diode pin numbers different in Capture in release 16.6 and 17.2-2016
1735506 CAPTURE            OTHER         File menu is missing in Capture
1766663 CAPTURE            SCHEMATICS    Capture crashes during part placement
1762181 CAPTURE            SCHEMATIC_EDI Crash on 'Push Occ. Prop into Instance'
1786762 CAPTURE            SCHEMATIC_EDI 'Remove Occurrence Properties' and 'Push Occ. Prop into Instance' corrupt database
1759424 CIS                PART_MANAGER  Unable to save the link database part from part manager
1802670 CONCEPT_HDL        CORE          Variant commands take 6 to 10 hours to run on a block
1816798 CONSTRAINT_MGR     CONCEPT_HDL   CM API ACNS_DESIGN returns the design name in mixed case
1812656 CONSTRAINT_MGR     DATABASE      Constraint Value specified at the DEFAULT PCSet/SCSet is not shown in bold blue
1635766 CONSTRAINT_MGR     UI_FORMS      Worksheet views are not changed as per input
1700505 ECW                PART_LIST_MAN Shopping Cart Quantity is not read or not displayed in Pulse
1797371 ECW                PROJECT_MANAG Clicking on another project sometimes takes you to the default project instead of the project you click on
1843526 INSTALLATION       TRIAL         Trial installer should not check disk space in update licensing mode
1762148 PCB_LIBRARIAN      SETUP         Part Developer: Text not readable in Setup form
1770760 PCB_LIBRARIAN      SYMBOL_EDITOR Symbol Editor does not remember the last size of the window
1773604 PCB_LIBRARIAN      SYMBOL_EDITOR Option to switch between the new and legacy Symbol Editors
1800354 PCB_LIBRARIAN      SYMBOL_EDITOR Resistor has too many lines and looks wrong in new symbol editor
1813346 PCB_LIBRARIAN      SYMBOL_EDITOR Resistor looks different with multiple diagonal lines in new Symbol Editor but looks normal in DE-HDL
1815279 PCB_LIBRARIAN      SYMBOL_EDITOR Unable to change Grid Settings from Lines to Dots
1738603 PSPICE             DIG_SIMULATOR Release 17.2-2016 PSpice digital model: Delay defined by PINDLY is not taken into account
1802905 PSPICE             ENCRYPTION    Incorrect option shown in PSpiceENC syntax in usage detail
1765345 PSPICE             ENVIRONMENT   Custom distributions are not added to the dropdown
1784856 PSPICE             ENVIRONMENT   PSpice ignoring directory changes for Save check point in simulation setup session
1817805 PSPICE             ENVIRONMENT   Incorrect result for PSpice 'Start saving data after'
1784507 PSPICE             FRONTENDPLUGI Spelling of 'Definition' in PSpice Part Search is not correct
1801790 PSPICE             LIBRARIES     SAC model giving errors
1738776 PSPICE             SIMULATOR     PSpice simulation stops before TSTOP
1795950 PSPICE             SIMULATOR     Simulation cannot be completed in release 17.2-2016 but is completed in release 16.6
1803407 PSPICE             SIMULATOR     Getting convergence error on a model
1814759 PSPICE             SLPS          .INC file is not working with SLPS
1715859 SIP_LAYOUT         ETCH_BACK     Etchback mask not overlapping each other; creating floating metal
1729523 SIP_LAYOUT         INTERACTIVE   When creating a bond finger solder mask the results do not match the required settings
1800069 SIP_LAYOUT         INTERACTIVE   Corrupt dra/psm symbol, but the reason is unclear
1756620 SIP_LAYOUT         SHAPE         Performance issue when moving vias.
1782928 SIP_LAYOUT         SHAPE         Shape merging (logical operation) shows error though measuring shows elements are correctly spaced
1816454 SIP_LAYOUT         THIEVING      Thieving: need thieving as a specific data type in CM to better control the filling pattern
1728026 TDA                CORE          Check-in should not require all child objects to be checked in specially if they are not checked-out
1823976 TDA                SHAREPOINT    Connection to server terminates when joining a project
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 032
Fixed CCRs: SPB 17.2 HF032
01-13-2018
1846603 ADW                FLOW_MGR      Copy project GUI not displaying correct design name after changing the project folder name
1831152 ALLEGRO_EDITOR     3D_CANVAS     New 3D viewer canvas is blank
1805870 ALLEGRO_EDITOR     COLOR         Color file with dot (.) in the filename is not recognized for setting color from the Visibility tab
1843126 ALLEGRO_EDITOR     DATABASE      DBDoctor UI is taking very long
1857588 ALLEGRO_EDITOR     DFM           Design for Fabrication - Aspect Ratio is not taking correct drill hole size
1844313 ALLEGRO_EDITOR     INTERFACES    STEP output viewed in third-party tool has parts sunken into the secondary side
1801301 ALLEGRO_EDITOR     MANUFACT      Export IPC 2581 fails if VOLTAGE property is attached to the nets on each side of a RF component
1850078 ALLEGRO_EDITOR     MANUFACT      Choosing 'Manufacture - Artwork' crashes tool
1844049 ALLEGRO_EDITOR     MODULES       Module deletion not removing related component information.
1849665 ALLEGRO_EDITOR     MULTI_USER    Shape rejected by muserver
1782831 ALLEGRO_EDITOR     RAVEL_CHECKS  RAVEL file does not load when it is located on a network with a UNC path specified
1830442 ALLEGRO_EDITOR     SCHEM_FTB     Fail to import technology file with message for failure to read the configuration file
1837391 ALLEGRO_EDITOR     SCHEM_FTB     Capture Property cannot rewrite or update constraints in PCB Editor
1840643 ALLEGRO_EDITOR     SCHEM_FTB     Export physical does not work after modifying PCB cross section
1718165 ALLEGRO_EDITOR     SHAPE         Drill hole cannot be voided by shape
1753245 ALLEGRO_EDITOR     SHAPE         Update Shape retracts more than the shape to shape spacing
1827366 ALLEGRO_EDITOR     SHAPE         out of date shape is not flagged as out of date
1828208 ALLEGRO_EDITOR     SHAPE         Shape remains out of date, but status shows otherwise
1832098 ALLEGRO_EDITOR     SHAPE         Skip via shorts to plane at few places even after the necessary keep-outs are assigned to the via pad-stack.
1834281 ALLEGRO_EDITOR     SHAPE         DBDoctor creates a large number of DRCs
1842121 ALLEGRO_EDITOR     SHAPE         Unable to clear the Drill Hole to Shape Spacing DRC as Pin is not able void to the shape correctly.
1846010 ALLEGRO_EDITOR     SHAPE         Changing MCAD hole to copper spacing in Analysis Modes - Design does not make shapes out-of-date
1839119 ALLEGRO_EDITOR     UI_GENERAL    On some machines, PCB Editor hangs when launched with a script that uses SKILL to open a design
1828794 APD                SHAPE         Setting Shape Fill Xhatch Cells option to HIGH, crashes the application
1840748 CAPTURE            PROJECT_MANAG Capture crashes on opening or creating designs
1785298 CONCEPT_HDL        CORE          Incorrect object access during variant load
1832119 CONCEPT_HDL        CORE          Save Hierarchy shows ERROR(SPCOCN-2010) messages but design packages without error
1833036 CONCEPT_HDL        CORE          nconcepthdl crashes with a core dump when running an external script
1841545 CONCEPT_HDL        CORE          NO_XNET_CONNECTION properties added to two-pin filters after upreving to release 17.2-2016
1842289 CONCEPT_HDL        CORE          Opening a schematic in release 17.2-2016 causes the .dcf file to be overwritten
1841543 CONCEPT_HDL        OTHER         DE-HDL crashes when changing a net name/page name/bit bus after installing release 17.2-2016, Hotfix 029
1843791 CONCEPT_HDL        OTHER         Table of contents listing does not update for some hierarchy blocks at the top level
1850709 CONCEPT_HDL        OTHER         DE-HDL crashes on editing text on canvas in release 17.2-2016, Hotfix 030
1853377 CONCEPT_HDL        OTHER         DE-HDL crashes on trying to edit bus tap value on Windows 10.
1857213 CONCEPT_HDL        OTHER         DE-HDL crashes when changing Power Property
1857214 CONCEPT_HDL        OTHER         In release 17.2-2016, DE-HDL crashes on using 'Change' for a $LOCATION text value on Windows 10
1821982 CONCEPT_HDL        PDF           Pin number shown in PDF published from DE-HDL
1848615 CONCEPT_HDL        PDF           PDF Publisher shows incorrect pin text values for parts
1845996 CONSTRAINT_MGR     CONCEPT_HDL   Confusing error message regarding 'Auto XNets Off Mode' vs 'DML Enabled'
1854190 CONSTRAINT_MGR     CONCEPT_HDL   'Audit - Electrical CSets' hangs Constraint Manager after the design is upreved to release 17.2-2016
1854868 CONSTRAINT_MGR     CONCEPT_HDL   Match Group getting deleted after upreving the design to 17.2 and removing the signal_models
1854872 CONSTRAINT_MGR     CONCEPT_HDL   Additional Pin-Pairs getting created on the DiffPair after upreving to 17.2
1822624 CONSTRAINT_MGR     ECS_APPLY     Cannot copy PCB net schedule from a net to other nets
1854883 CONSTRAINT_MGR     ECS_APPLY     Match group showing 0 length for pin pairs in design upreved from release 16.6 to 17.2-2016
1855893 CONSTRAINT_MGR     OTHER         SigXplorer extraction crashes PCB Editor
1855917 CONSTRAINT_MGR     OTHER         SigXplorer extraction does not extract constraints unless the worksheet is opened once in CM
1855350 CONSTRAINT_MGR     UI_FORMS      Constraint Manager significantly slower in release 17.2-2016, Hotfix 031
1855860 EAGLE_TRANSLATOR   PCB_EDITOR    Cannot invoke a CAD translator in PCB Editor
1857745 EAGLE_TRANSLATOR   PCB_EDITOR    A CAD translator does not invoke in PCB Editor
1859005 EAGLE_TRANSLATOR   PCB_EDITOR    Eagle translator is not invoking at all
1843091 F2B                DESIGNVARI    Variant Editor allows mismatched JEDEC_TYPEs in release 17.2-2016
1719059 FSP                DE-HDL_SCHEMA Termination resistors on buses not being drawn efficiently
1823419 FSP                GUI           Net Name Template not visible in Change Net Name in Windows 10
1480035 ORBITIO            ALLEGRO_SIP_I Die symbols are mirrored when imported back to SiP Layout
1853331 PCB_LIBRARIAN      SETUP         CPM file not updated from PCB Librarian setup
1841308 PCB_LIBRARIAN      SYMBOL_EDITOR Symbol not updated in Library View
1831269 SCM                OTHER         Blank properties of associated components are being filled with NULL
1719057 SCM                SCHGEN        Pins off grid for voltage nets
1719060 SCM                SCHGEN        Pull-ups and pull-downs showing upside down in view
1732687 SCM                SCHGEN        Schematic generation deletes IO ports; says it's placing them on last page, but never places them
1855932 SIG_EXPLORER       OTHER         For non-DML designs, SigXplorer defaulting to mils when PCB Editor design units and CM constraints are in mm
1824035 SIP_LAYOUT         WLP           SiP Layout DRC GUI not reading Tcl blocks in PVS DRC rule deck
Ссылка на сообщение
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 033
Fixed CCRs: SPB 17.2 HF033
01-25-2018
1828672 ADW                ADWSERVER     LDAP connection error while trying to log in to DBeditor
1840699 ADW                DBEDITOR      Unable to release footprint model due to older version being linked to a DE-HDL Block Model
1852402 ALLEGRO_EDITOR     DATABASE      Cutouts are not converted correctly when opening release 16.6 board in release 17.2-2016
1855223 ALLEGRO_EDITOR     DATABASE      Release 16.6. BoardOutline not fully converted to release 17.2-2016 Cutout Layer
1855252 ALLEGRO_EDITOR     DATABASE      Unable to open a previously saved release 17.2-2016 database
1863025 ALLEGRO_EDITOR     DRC_CONSTR    Shape voiding to Via pad with backdrill keepout is oversizing the Dynamic shape void by the backdrill keepout
1854087 ALLEGRO_EDITOR     EDIT_ETCH     Sliding arc crashes PCB Editor
1840667 ALLEGRO_EDITOR     INTERACTIV    Choosing 'Change Text block to' from pop-up displays message 'E- (SPMHGE-150): Text font is not defined'
1849133 ALLEGRO_EDITOR     INTERACTIV    On choosing 'Change Text block to' on text , 'Text font is not defined' message appears
1854695 ALLEGRO_EDITOR     MANUFACT      PCB Editor crashes while performing nc_route
1854634 ALLEGRO_EDITOR     NC            NC Drill file is generated with half the number of Drill Holes on enabling 'Optimize drill head travel'
1856773 ALLEGRO_EDITOR     NC            Issue with Optimize Drill head travel in hotfix 031: Missing drill holes
1860876 ALLEGRO_EDITOR     NC            NC route critical difference between hotfix 031 and 022: No slots found warning
1758671 ALLEGRO_EDITOR     OTHER         Export parameters takes long time to export and some times the process hangs
1040989 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes while editing board outline
1328385 ALLEGRO_EDITOR     SHAPE         Check for missing thermal reliefs when shapes overlap
1366376 ALLEGRO_EDITOR     SHAPE         Thermal created for Xhatch shape overlapping another shape, but not created when solid shapes overlap
1716436 ALLEGRO_EDITOR     SHAPE         Acute angle trim should not violate DRC.
1822377 ALLEGRO_EDITOR     SHAPE         Setting shape parameter Acute angle trim control to Full round produces unwanted shape to keepout DRCs
1826436 ALLEGRO_EDITOR     SHAPE         Same net shape to hole spacing not voiding shape for cline of different net moved close to vias of same net shapes
1834510 ALLEGRO_EDITOR     SHAPE         Same Net Shape to Via Spacing does not always clear correctly
1850716 ALLEGRO_EDITOR     SHAPE         'DiffPair combined void for vias added with Return Path option' does not work with fillet and pad suppression
1852814 ALLEGRO_EDITOR     SHAPE         Thermal reliefs are not created after placing modules.
1853453 ALLEGRO_EDITOR     SHAPE         Route keepout clipping of cross-hatched shapes needs to be corrected
1859391 ALLEGRO_EDITOR     SHAPE         Shapes are not using 'minimum aperture for gap width' for voiding after back drill update.
1859410 ALLEGRO_EDITOR     SHAPE         Shape to Teardrop is not using same net spacing rules
1825397 ALLEGRO_EDITOR     UI_FORMS      Option panel disappears in release 17.2-2016
1854070 ALLEGRO_EDITOR     UI_GENERAL    enable_command_window_history prevents many aliases and commands from working correctly
1855180 ALLEGRO_EDITOR     UI_GENERAL    Comma and dot do not work in funckey if 'enable_command_window_history' is set
1860003 ALLEGRO_EDITOR     UI_GENERAL    Icons and features missing or behaving differently in release 17.2-2016, Hotfix 031
1861278 ALLEGRO_EDITOR     UI_GENERAL    Icons and menus missing in PCB Editor in release 17.2-2016, Hotfix 031
1862292 ALLEGRO_EDITOR     UI_GENERAL    Layout Pins icon missing in toolbar in Symbol Editor since Hotfix 031
1793284 ALLEGRO_PROD_TOOLB CORE          Limit View (V1R, V2R, COM) for OUTLINE layer.
1712701 ALTM_TRANSLATOR    CAPTURE       Third-party translator shows error for missing operand
1802182 ALTM_TRANSLATOR    CAPTURE       Imported schematic has connectivity loss
1802462 ALTM_TRANSLATOR    CAPTURE       Hierarchical ports placed incorrectly for imported third-party design
1823935 ALTM_TRANSLATOR    CAPTURE       Translating third-party schematics with hierarchical pages from Design Entry CIS
1830570 ALTM_TRANSLATOR    CAPTURE       Third-party to Capture translation is translating only one page out of 32
1839627 ALTM_TRANSLATOR    CAPTURE       Third-party translator is not importing complete schematic
1846965 ALTM_TRANSLATOR    CAPTURE       Cannot translate third-party schematic
1816767 ALTM_TRANSLATOR    DE_HDL        Error when translating third-party schematic to DE-HDL
1845601 ALTM_TRANSLATOR    PCB_EDITOR    Cannot operate third-party PCB translation in release 17.2-2016 Allegro Venture PCB Designer license
1841060 APD                DIE_GENERATOR Cannot 'die text out' from SiP Layout or Allegro Package Designer
1793232 APD                SHAPE         When fillet/taper not connected to a pin, voiding process incorrectly applies shape clearance values
1846541 APD                SHAPE         shape degassing does not obey void to shape boundary
1863446 ASDA               CONSTRAINT_MA A space in the name of a spacing or physical constraint results in the incorrect constraint set name
1859678 ASDA               VARIANT_MANAG SDA - When hovering over all three buttons, under Preferred Parts in the Variant info it says (Do not install)
1815839 CONCEPT_HDL        CORE          Allegro Design Entry HDL crashes when entering Location data manually
1841857 CONCEPT_HDL        CORE          Unable to modify Components in non-windows mode
1852096 CONCEPT_HDL        CORE          Creating a block using top-down approach does not generate the CSB file
1857390 CONCEPT_HDL        CORE          DE-HDL crashes on moving symbol
1789070 CONCEPT_HDL        OTHER         Having folder 'allegro' in cpm root directory gives error while launching layout editor from Project Manager
1862484 CONSTRAINT_MGR     CONCEPT_HDL   Extracting an ECSet in SigXP is missing a t-point
1863045 CONSTRAINT_MGR     CONCEPT_HDL   Pin pairs deleted for a few differential pairs after upreving the design to release 17.2-2016
1863054 CONSTRAINT_MGR     CONCEPT_HDL   Differential Pairs are treated as invalid objects on upreved design
1863094 CONSTRAINT_MGR     CONCEPT_HDL   Pin-Pairs are shown duplicated in the topology for the extracted object (Diff Pair)
1831998 CONSTRAINT_MGR     OTHER         'Tools - Options' settings not saved on closing Constraint Manager
1855324 CONSTRAINT_MGR     OTHER         Enable the option 'Expand Hierarchy' in 'Find and Replace' dialog, by default
1860847 CONSTRAINT_MGR     OTHER         'Include Routed interconnect' option once enabled, should remain enabled for that board file
1843359 EAGLE_TRANSLATOR   PCB_EDITOR    While importing third-party PCB, many footprints do not convert, even though the log file says footprint created
1839978 SCM                REPORTS       dsreportgen unable to output reference designator from a lower-level hierarchical block if it has a single component
1850013 SIP_LAYOUT         OTHER         Environment variable 'icp_disable_cte_auto_update' needs grammatical change
1833742 SIP_LAYOUT         PADSTACK_EDIT When creating Die to Die Via using Generate Padstacks, resultant pad stack has wrong Layers
1619098 SIP_LAYOUT         SHAPE         Acute angle of shape in design
1728628 SIP_LAYOUT         SHAPE         Auto-void in dynamic shape does not disappear if object is removed
1854592 SIP_LAYOUT         VIA_STRUCTURE Create via structure returns an error
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 034
Fixed CCRs: SPB 17.2 HF034
02-11-2018
CCRID   Product            ProductLevel2 Title
1863981 ADW                ADW_UPREV     adw_uprev is taking a long time after installing hotfix 031
1868186 ADW                DBEDITOR      Configured LDAP authentication giving error on launching DBeditor after ISR31 installation
1861524 ADW                LIBDISTRIBUTI Library distribution is checking for obsolete classifications every time it is run hence taking more time
1842998 ADW                LIB_FLOW      Footprint model check-in fails with verification checks failed error
1863047 ALLEGRO_EDITOR     DATABASE      The layer added above the TOP layer in SiP Layout cannot be deleted from database.
1864997 ALLEGRO_EDITOR     DATABASE      Opening a downreved design from 17.2 to 16.6 results in Warning(SPMHA1-230): Database has a non-recoverable corruption
1852799 ALLEGRO_EDITOR     DFM           Refresh symbols crashing inside constraint re-enablement code
1865732 ALLEGRO_EDITOR     DFM           The Thru via hole to Pad check in Annular Ring should check only the Finished hole size instead of backdrill diameter
1862977 ALLEGRO_EDITOR     DRC_CONSTR    Differential pair phase tolerance DRCs introduced in release 17.2-2016 DML-independent flow
1864460 ALLEGRO_EDITOR     EXTRACT       Running Extracta from outside using command window writes layer name for top/bottom layers incorrectly for SiP designs
1859208 ALLEGRO_EDITOR     GRAPHICS      Pop-up menu remains on desktop when PCB Editor is minimized
1866422 ALLEGRO_EDITOR     MANUFACT      Backdrill update taking a long time
1867148 ALLEGRO_EDITOR     MANUFACT      Backdrill update taking longer time to process.
1872127 ALLEGRO_EDITOR     MANUFACT      Backdrill performance issues - Additional fixes required for S034
1866577 ALLEGRO_EDITOR     SHAPE         Board becomes unresponsive on Shape Update or Slide Trace
1867590 ALLEGRO_EDITOR     SHAPE         The Shape to Pad clearance on multi drill oblong padstacks is not working correctly
1871902 ALLEGRO_EDITOR     SHAPE         Void issue during rotation of symbol with multi-drill padstack from hotfix S032
1866778 ALLEGRO_EDITOR     UI_GENERAL    Unsupported prototype 'Enable_command_window_history'  is not allowing text edits using arrow keys
1865757 ASDA               DESIGN_CORRUP SDA hangs when trying to save design or copy page or circuitry
1865872 ASDA               DESIGN_CORRUP Corrupt design crashes on editing.
1867039 ASDA               DESIGN_CORRUP Design corruption issues
1831263 CAPTURE            OTHER         Toolbar refresh is very slow on windows 10 after installing latest windows patch
1843595 CAPTURE            OTHER         Icon refresh is very slow on Windows 10 Professional after installing Hotfix 029
1845003 CAPTURE            OTHER         Application slow to respond after running for a long time
1847062 CAPTURE            OTHER         Starting OrCAD Capture redraws the toolbar icons many times.
1850816 CAPTURE            OTHER         Capture redraws toolbar very slowly and repeatedly
1851346 CAPTURE            OTHER         Capture CIS redraws toolbars repeatedly
1851354 CAPTURE            OTHER         Capture slows down in Hotfix 30 as tools icons are repeatedly redrawn very slowly
1851883 CAPTURE            OTHER         Toolbar content refresh is very slow
1852819 CAPTURE            OTHER         Capture refreshes toolbar again and again
1853395 CAPTURE            OTHER         Release 17.2-2016: Capture is refreshing toolbar icons many times at startup with latest hotfix
1853972 CAPTURE            OTHER         Capture starts and redraws toolbar very slowly
1854735 CAPTURE            OTHER         Capture toolbar reloads multiple times
1855850 CAPTURE            OTHER         Toolbar content refresh is very slow
1857523 CAPTURE            OTHER         Toolbar icons refresh multiple times and very slowly in release 17.2-2016
1859219 CAPTURE            OTHER         Toolbar is refreshed multiple times while starting Capture CIS
1859626 CAPTURE            OTHER         OrCAD Capture does not work with the latest Windows 10 update
1863341 CAPTURE            OTHER         Toolbar icon refresh is very slow
1865661 CAPTURE            OTHER         Release 17.2-2016, hotfix 032: Capture extremely slow on Windows 10
1867009 CAPTURE            OTHER         Slow graphics with Design Entry CIS on Windows 10.
1869160 CAPTURE            OTHER         OrCAD Capture poor performance (toolbar related)
1869692 CAPTURE            OTHER         Redrawing of toolbars on Windows 10
1870310 CAPTURE            OTHER         Allegro Design Entry CIS redraw issue
1870367 CAPTURE            OTHER         OrCAD Capture Slow Redraw
1871382 CAPTURE            OTHER         Schematic will not open and toolbars refreshed repeatedly
1872427 CAPTURE            OTHER         OrCAD Capture freeze on Windows 10
1862679 CONCEPT_HDL        COMP_BROWSER  Unable to input property value to search in Part Information Manager
1865039 CONCEPT_HDL        CORE          'Save Hierarchy'  of a release 16.6 design opened in release 17.2-2016 results in unexpected part changes
1866544 CONCEPT_HDL        CORE          XNET_PINS added to migrate Design as DML Independentflow does not get saved in the CSA files
1849363 SIG_INTEGRITY      SIMULATION    Differential impedance calculation shows ZERO when changing dielectric constant
1854195 SIP_LAYOUT         UI_GENERAL    After setting 'enable_command_window_history' in QIR5/Hotfix 031,  Edit - Text no longer functions
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
