Помогите разобраться с case на VHDL
Хочу вместо вложенных условных операторов вида:
if a='1' then
elsif b='1' then
elsif c='1' then
elsid d='1' then
else
написать:
sel(3)<=a;
sel(2)<=b;
sel(1)<=c;
sel(0)<=d;
case sel(3 downto 0) is
when 8 to 15 => .........
when 4 to 7 => .........
when 2 to 3 => .........
when 1 => .........
when others => .........
end case;
какой тип данных при этом должны иметь: a,b,c,d, и sel?
Возьмите за основу код (см. ниже) и подправьте под свои нужды.
library IEEE;
use IEEE.std_logic_1164.all;
entity rdmux16x8 is
port (
EN : in std_logic;
I0 : in std_logic_vector(15 downto 0);
I1 : in std_logic_vector(15 downto 0);
I2 : in std_logic_vector(15 downto 0);
I3 : in std_logic_vector(15 downto 0);
I4 : in std_logic_vector(15 downto 0);
I5 : in std_logic_vector(15 downto 0);
I6 : in std_logic_vector(15 downto 0);
I7 : in std_logic_vector(15 downto 0);
S : in std_logic_vector(2 downto 0);
O : out std_logic_vector(15 downto 0)
end entity;
--}} End of automatically maintained section
library IEEE;
use IEEE.std_logic_unsigned.all;
architecture rdmux16x8_arch of rdmux16x8 is
constant NON_ACTIVE : std_logic_vector(15 downto 0) := (others => '0');
begin
process (S, EN, I0, I1, I2, I3, I4, I5, I6, I7)
begin
if EN = '0' then
O <= NON_ACTIVE;
else
case CONV_INTEGER(S) is
when 0 => O <= I0;
when 1 => O <= I1;
when 2 => O <= I2;
when 3 => O <= I3;
when 4 => O <= I4;
when 5 => O <= I5;
when 6 => O <= I6;
when 7 => O <= I7;
when others => O <= NON_ACTIVE;
end case;
end if;
end process;
end rdmux16x8_arch;
library IEEE;
entity rdmux16x8 is
port (
EN : in std_logic;
end entity;
library IEEE;
begin
begin
if EN = '0' then
O <= NON_ACTIVE;
else
when 0 => O <= I0;
when 1 => O <= I1;
when 2 => O <= I2;
when 3 => O <= I3;
when 4 => O <= I4;
when 5 => O <= I5;
when 6 => O <= I6;
when 7 => O <= I7;
end case;
end if;
end process;
end rdmux16x8_arch;
Ваш код в моем случае не работает.
Есть процесс в котором реализован автомат на if then. В одном из состояний находятся операторы выбра.
if a='1' then
elsif b='1' then
elsif c='1' then
elsif d='1' then
else
Они мне не подходят из-за того, что кушают много логики. Хочу переделать тоже самое с case. Пример моего процесса
process(clk)
if (clk'event and clk='1') then
if state="001" then
end if;
if state="010" then
end if;
if state="011" then
sel(3)<=a;
sel(2)<=b;
sel(1)<=c;
sel(0)<=d;
when 1 => .........
end case;
end if;
Повторю вопрос. Какой тип данных при этом должны иметь: a,b,c,d, и sel?
2 maxics
Как вариант:
signal a : std_logic;
signal b : std_logic;
signal c : std_logic;
signal d : std_logic;
signal sel : std_logic_vector(3 downto 0);
sel <= a & b & c & d;
case sel is
end case;
Но я бы дополнительно ещё проверил что замена if на case не поломает ничего в логике.
2 maxics
Как вариант:
case sel is
end case;
Так выдает ошибку.
Заработало когда перед Sel поставил conv_integer:
sel(3)<=a;
sel(2)<=b;
sel(1)<=c;
sel(0)<=d;
case (conv_integer(sel(3 downto 0))) is
when 1 => .........
end case;
end if;
Так выдает ошибку...
Потому что у вас в case десятичные цифры, впишите туда их как для std_logic_vector и conv_integer можно убирать. Хотя судя по приведённому вами листингу, вам может conv_integer в самый раз..
Вписываю как std_logic_vector . При синтезе ошибка: Choise must be discrete range.
2 maxics
вот пример
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test00 is
   Port ( a : in  STD_LOGIC;
          b : in  STD_LOGIC;
          c : in  STD_LOGIC;
          d : in  STD_LOGIC;
          dout : out  STD_LOGIC);
end test00;
architecture rtl of test00 is
begin
process (sel)
begin
   case sel is
       when "1000" => dout <= '1';
       when "0100" => dout <= '1';
       when "0010" => dout <= '1';
       when "0001" => dout <= '1';
       when others => dout <= '0';
   end case;
end process;
end rtl;
Собирается без вопросов на 1м луте
2 maxics
вот пример
library IEEE;
entity test00 is
          b : in  STD_LOGIC;
          c : in  STD_LOGIC;
          d : in  STD_LOGIC;
end test00;
begin
process (sel)
begin
   case sel is
   end case;
end process;
end rtl;
"a" имеет высший приоритет. Рассмотрим случай a=1 и одновременно c =1. Получаем 1100. И что мы будем делать? others в этом случае не подходит. В моем случае необходимо рассматривать интервалы, т.е. например для первого случая это от 1000 до 11111 (независимо какие b c d делаем определенное действие, т.к. a=1. )
возможно Вам нужен приоритетный шифратор (я по другому не пытался описывать)...
пример:
library IEEE;
entity MY_IF is
port (C,D,E,F: in std_logic;
S: in std_logic_vector(1 downto 0);
POUT: out std_logic);
end MY_IF;
architecture MY_IF_ARCH of MY_IF is
begin
process(S,C,D,E,F)
begin
if S=”00” then POUT<=C;
elsif S=”01” then POUT <=D;
elsif S=”10” then POUT <=E;
else POUT <=F;
end if;
end process;
end MY_IF_ARCH;
пример:
library IEEE;
entity MY_IF is
end MY_IF;
begin
process(S,C,D,E,F)
begin
else POUT <=F;
end if;
end process;
end MY_IF_ARCH;
Как раз от этого пришлось отказаться из-за большого logic level
2maxics:
Я Вам привел пример своего кода, в котором для оеализации необходимого Вам требования приведена функция conv_integer. Это ключевая подсказка. В понедельник переработаю Ваш код, взяв за основу свой пример. Время терпит?
P.S.: "Повторю вопрос. Какой тип данных при этом должны иметь: a,b,c,d, и sel?". объявляете их как std_logic, затем используете conv_integer для дешифрации. Помощь Вам не очевидна?
P.P.S.: Обратное преобразование по моему что-то вроде conv_std_logic_vector (если не ошибаюсь).
если так, Вам никто не запрещает разбить схему на несколько схем, тогда увеличете скоростные характеристики и уменьшите logic level...
Не могли бы пояснить? Желательно на примере. Спасибо!
