22 -
0 ОбычныйИнформация о vladimirD
- День рождения 03.01.1970
Сайт
1 726 просмотров профиля
Было две основных проблемы: 1) Пересекались регионы памяти в system-user.dtsi 2) Нужно было добавить разделы в system-user.dtsi для второго ядра R5_1 3) Нужно подправить Linux и Standalone applications для второго ядра R5_1 как описано в UG1186 Мой обновленный system-user.dtsi /include/ "system-conf.dtsi" / { fclk0 { status = "okay"; }; reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; rproc_0_reserved: rproc@3ed000000 { no-map; reg = <0x0 0x3ed00000 0x0 0x2090000>; }; }; amba { /* Shared memory */ shm0: shm@0 { compatible = "shm_uio"; reg = <0x0 0x3ed80000 0x0 0x1000000>; }; /* Shared memory */ shm1: shm@1 { compatible = "shm_uio"; reg = <0x0 0x3fd90000 0x0 0x1000000>; }; /* IPI device */ ipi_amp0: ipi@ff340000 { compatible = "ipi_uio"; reg = <0x0 0xff340000 0x0 0x1000>; interrupt-parent = <&gic>; interrupts = <0 29 4>; }; /* IPI device */ ipi_amp1: ipi@ff350000 { compatible = "ipi_uio"; reg = <0x0 0xff350000 0x0 0x1000>; interrupt-parent = <&gic>; interrupts = <0 30 4>; }; /* firmware memory nodes */ r5_0_tcm_a: tcm@ffe00000 { compatible = "mmio-sram"; reg = <0x0 0xFFE00000 0x0 0x10000>; pd-handle = <&pd_tcm_0_a>; }; r5_0_tcm_b: tcm@ffe20000 { compatible = "mmio-sram"; reg = <0x0 0xFFE20000 0x0 0x10000>; pd-handle = <&pd_tcm_0_b>; }; r5_1_tcm_a: tcm@ffe90000 { compatible = "mmio-sram"; reg = <0 0xFFE90000 0x0 0x10000>; pd-handle = <&pd_tcm_1_a>; }; r5_1_tcm_b: tcm@ffe92000 { compatible = "mmio-sram"; reg = <0 0xFFEB0000 0x0 0x10000>; pd-handle = <&pd_tcm_1_b>; }; elf_ddr_0: ddr@3ed00000 { compatible = "mmio-sram"; reg = <0x0 0x3ed00000 0x0 0x40000>; }; elf_ddr_1: ddr@3ed40000 { compatible = "mmio-sram"; reg = <0 0x3ed40000 0x0 0x40000>; }; test_r5_0: zynqmp_r5_rproc@0 { compatible = "xlnx,zynqmp-r5-remoteproc-1.0"; reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "ipi", "rpu_glbl_base"; dma-ranges; core_conf = "split0"; srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0>; pd-handle = <&pd_r5_0>; interrupt-parent = <&gic>; interrupts = <0 29 4>; }; test_r5_1: zynqmp_r5_rproc@1 { compatible = "xlnx,zynqmp-r5-remoteproc-1.0"; reg =<0x0 0xff9a0200 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "ipi", "rpu_glbl_base"; dma-ranges; core_conf = "split1"; srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1>; pd-handle = <&pd_r5_1>; interrupt-parent = <&gic>; interrupts = <0 29 4>; } ; }; power-domains { pd_r5_0: pd_r5_0 { #power-domain-cells = <0x0>; pd-id = <0x7>; }; pd_r5_1: pd_r5_1 { #power-domain-cells = <0x0>; pd-id = <0x8>; }; pd_tcm_0_a: pd_tcm_0_a { #power-domain-cells = <0x0>; pd-id = <0xf>; }; pd_tcm_0_b: pd_tcm_0_b { #power-domain-cells = <0x0>; pd-id = <0x10>; }; pd_tcm_1_a: pd_tcm_1_a { #power-domain-cells = <0x0>; pd-id = <0x11>; }; pd_tcm_1_b: pd_tcm_1_b { #power-domain-cells = <0x0>; pd-id = <0x12>; }; }; }; &ttc0 { compatible = "ttc0"; status = "okay"; }; &ttc1 { compatible = "ttc1"; status = "okay"; }; /* Default ethernet on the AVNET SoM */ &gem3 { status = "okay"; local-mac-address = [00 0a 35 00 02 90]; phy-mode = "rgmii-id"; phy-handle = <&phy0>; phy0: phy@9 { reg = <0x9>; ti,rx-internal-delay = <0x5>; ti,tx-internal-delay = <0x5>; ti,fifo-depth = <0x1>; }; }; &i2c0 { status = "okay"; clock-frequency = <400000>; oled@3c { status = "okay"; compatible = "newhaven,oled-nhd-0420cw"; reg = <0x3c>; enable-vdd-five-volt-reg = <0x00>; /* 0x01 = enable, 0x00 disable and use 2.8v */ }; }; &i2c1 { status = "okay"; clock-frequency = <400000>; i2cswitch@70 { /* U7 on UZ3EG SOM */ compatible = "nxp,pca9542"; #address-cells = <1>; #size-cells = <0>; reg = <0x70>; i2c@0 { /* i2c mw 70 0 1 */ #address-cells = <1>; #size-cells = <0>; reg = <0>; /* IIC_EEPROM */ eeprom@51 { /* U5 on UZ3EG IOCC and U7 on the UZ7EV EVCC*/ compatible = "at,24c08"; reg = <0x51>; }; }; i2c@1 { /* i2c mw 70 0 1 */ #address-cells = <1>; #size-cells = <0>; reg = <1>; /* Temp Sensor - LM75 compatible */ lm75@48 { status = "okay"; compatible = "maxim,mcp980x"; reg = <0x48>; }; }; }; }; &qspi { #address-cells = <1>; #size-cells = <0>; status = "okay"; is-dual = <1>; /* Set for dual-parallel QSPI config */ num-cs = <2>; xlnx,fb-clk = <0x1>; flash0: flash@0 { /* The Flash described below doesn't match our board ("micron,n25qu256a"), but is needed */ /* so the Flash MTD partitions are correctly identified in /proc/mtd */ compatible = "micron,m25p80"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; /* FIXME also DUAL configuration possible */ spi-max-frequency = <108000000>; /* Set to 108000000 Based on DC1 spec */ }; }; /* SD0 eMMC, 8-bit wide data bus */ &sdhci0 { status = "okay"; bus-width = <8>; max-frequency = <50000000>; }; /* ULPI SMSC USB3320 */ &usb0 { status = "okay"; }; &dwc3_0 { status = "okay"; dr_mode = "host"; phy-names = "usb3-phy"; }; system-user.zip
Я спрашивал на их форуме, ответил их модератор. Я как все проверю, выложу сюда детали с комментариями
Мне ответили в Xilinx и предложили хороший пример system-user.dtsi для моего случая. Когда закончу с ними общение, выложу сюда результаты.
Кстати, что у Вас прописано в system-user.dtsi для test_r5_0 ? Я взял пример из libmetal demo и уменя так: reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "rpu_glbl_base"; А в примере для OpenAmp (https://github.com/Xilinx/meta-openamp/blob/rel-v2017.4/recipes-bsp/device-tree/files/zynqmp/openamp-overlay-split.dtsi) так: reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "ipi", "rpu_glbl_base"; Спасибо
Спасибо большое за идею! Я в-основном занимался обычными FPGA, поэтому в embedded Linux еще новичок. Можно попросить Вас набросать в общих деталях, как я могу заменить ядро в Petalinux? Спасибо.
Получил доступ к плате. Я прицепил файл с сообщениями dmesg. Посмотрите, пожалуйста, надеюсь эта информация будет полезна для диагностики. boot.log.txt
Пока не могу выложить, так как плата с другой прошивкой пока тестируется. Но точно были messages по запуску remoteproc0 и точно вообще не было ничего насчет remoteproc1 Выложу, как только получу доступ к плате
Добрый день, подскажите, пожалуйста, если кто сталкивался. Задача: Я пытаюсь запустить libmetal demo из Xilinx UG1186 одновременно в двух процессорах R5_0 и R5_1. Настройки libmetal demo создают один /sys/class/remoteproc/remoteproc0 Соответственно, я могу запустить один экземпляр demo на процессоре R5_0 и не имею возможности запустить второй экземпляр на втором процессоре R5_1. Что я пытался сделать: Обновил Device Tree, добавив элементы для второго ядра R5_1 Пример взял из: https://github.com/Xilinx/meta-openamp/blob/rel-v2017.4/recipes-bsp/device-tree/files/zynqmp/openamp-overlay-split.dtsi Проблема: Petalinux запускает только один remoteproc0. Второй remoteproc1 отсутствует. Что я пропустил? Спасибо. Environment: Zynq UltraScale++, ядра: 4x A53 и 2x R5, Petalinux 2017.4, Vivado/SDK 2018.1, своя плата, детали в system-user.dtsi Мой system-user.dtsi прицеплен к посту. Вот выдержка, относящаяся к libmetal: reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; rproc_0_reserved: rproc@3ed000000 { no-map; reg = <0x0 0x3ed00000 0x0 0x2000000>; }; }; amba { /* Shared memory */ shm0: shm@0 { compatible = "shm_uio"; reg = <0x0 0x3ed80000 0x0 0x1000000>; }; /* IPI device */ ipi_amp: ipi@ff340000 { compatible = "ipi_uio"; reg = <0x0 0xff340000 0x0 0x1000>; interrupt-parent = <&gic>; interrupts = <0 29 4>; }; /* firmware memory nodes */ r5_0_tcm_a: tcm@ffe00000 { compatible = "mmio-sram"; reg = <0x0 0xFFE00000 0x0 0x10000>; pd-handle = <&pd_tcm_0_a>; }; r5_0_tcm_b: tcm@ffe20000 { compatible = "mmio-sram"; reg = <0x0 0xFFE20000 0x0 0x10000>; pd-handle = <&pd_tcm_0_b>; }; r5_1_tcm_a: tcm@ffe90000 { compatible = "mmio-sram"; reg = <0 0xFFE90000 0x0 0x10000>; pd-handle = <&pd_tcm_1_a>; }; r5_1_tcm_b: tcm@ffe92000 { compatible = "mmio-sram"; reg = <0 0xFFEB0000 0x0 0x10000>; pd-handle = <&pd_tcm_1_b>; }; elf_ddr_0: ddr@3ed00000 { compatible = "mmio-sram"; reg = <0x0 0x3ed00000 0x0 0x100000>; }; elf_ddr_1: ddr@3ed40000 { compatible = "mmio-sram"; reg = <0 0x3ed40000 0x0 0x40000>; }; test_r5_0: zynqmp_r5_rproc@0 { compatible = "xlnx,zynqmp-r5-remoteproc-1.0"; reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "ipi", "rpu_glbl_base"; dma-ranges; core_conf = "split0"; srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0>; pd-handle = <&pd_r5_0>; interrupt-parent = <&gic>; interrupts = <0 29 4>; }; test_r5_1: zynqmp_r5_rproc@1 { compatible = "xlnx,zynqmp-r5-remoteproc-1.0"; reg =<0x0 0xff9a0200 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>; reg-names = "rpu_base", "ipi", "rpu_glbl_base"; dma-ranges; core_conf = "split1"; srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1>; pd-handle = <&pd_r5_1>; interrupt-parent = <&gic>; interrupts = <0 29 4>; } ; }; power-domains { pd_r5_0: pd_r5_0 { #power-domain-cells = <0x0>; pd-id = <0x7>; pd_r5_1: pd_r5_1 { #power-domain-cells = <0x0>; pd-id = <0x8>; }; pd_tcm_0_a: pd_tcm_0_a { #power-domain-cells = <0x0>; pd-id = <0xf>; }; pd_tcm_0_b: pd_tcm_0_b { #power-domain-cells = <0x0>; pd-id = <0x10>; }; pd_tcm_1_a: pd_tcm_1_a { #power-domain-cells = <0x0>; pd-id = <0x11>; }; pd_tcm_1_b: pd_tcm_1_b { #power-domain-cells = <0x0>; pd-id = <0x12>; }; }; system-user.dtsi
Такая же проблема бывает, если клок JTAG быстрее клока ILA. Такое бывает, когда мониторим небыстрые процессы и хотим большое время записи.
Все в порядке, успешно скопировали?
Здравствуйте, я перевыложил документ. Set_up_native_Eclipse_to_develop_Modules_for_PetaLinux.pdf
Здравствуйте, я выложил документ снова Set_up_Xilinx_SDK_Eclipse_to_develop_Modules_for_PetaLinux.pdf
