LexaryStyle
290 -
1 ОбычныйИнформация о LexaryStyle
3 892 просмотра профиля
LexaryStyle подписался на Gowin: использование IODELAY + IEM + IDES и Китайские ПЛИС
Нашел софткит с примерами: https://github.com/nxp-mcuxpresso/mcux-sdk-examples/tree/main/evkmimxrt685 Кстати получилось собрать новую среду разработки тут(ВПН): https://mcuxpresso.nxp.com/en/builder?hw=EVK-MIMXRT685 Платы Mimxrt685-EVK есть на авито!)
GW5A Доступны к покупке?
Mimxrt685-EVK Cadence Xtensa HiFi4 DSP опыт работы
LexaryStyle опубликовал тема в NXP
Приветствую. Не могу получить софт у поставщика, кто имел опыт работы с этим камнем? Хочу попробовать в качестве audio DSP The i.MX RT600 is a crossover MCU family optimized for 32-bit immersive audio playback and voice user interface applications combining a high-performance Cadence Tensilica HiFi 4 audio DSP core with a next-generation Cortex-M33 core. The i.MX RT600 family of crossover MCUs is designed to unlock the potential of voice-assisted end nodes with a secure, power-optimized embedded processor. The i.MX RT600 family provides up to 4.5MB of on-chip SRAM and several high-bandwidth interfaces to access off-chip flash, including an Octal/Quad SPI interface with an on-the-fly decryption engine. MIMXRT685SFVKB Cortex-M33 (300 MHz, 128 KB TCM) core processor with Cadence Xtensa HiFi4 DSP Onboard, high-speed USB, Link2 debug probe with CMSIS-DAP protocol (supporting Cortex M33 debug only) High speed USB port with micro A/B connector for the host or device functionality UART, I2C and SPI port bridging from i.MX RT685 target to USB via the on-board debug probe 512 MB Macronix Octal SPI Flash operating at 1.8 V 4.5 MB Apmemory PSRAM Full size SD card slot (SDIO) NXP PCA9420UK PMIC User LEDs Reset and User buttons Arduino and PMod/Host expansion connectors NXP FXOS8700CQ accelerometer Stereo audio codec with line in/out and electret microphone Stereo NXP TFA9894 digital amplifiers, with option for external +5V power for higher performance speakers Support for up to eight off-board digital microphones via 12-pin header Two on-board DMICS -
http://gowin_can_refdesign.zip/ МОжет ктото скачать?
Я ошибочно предположил что для источника тока скорость нарастания сигнала при разной Z0 дает разный звон. смоделировал для согласованной нагрузки токовый выход: выход по напряжению: у токового варианта звона нет и для не согласованной, но нагруженная резистором линия является делителем, значит для 24мА выхода придется делать больше >150 ом нагрузочного и не париться с волновым. Вопрос видимо закрыт, если сделать выход по напряжению не возможно в GW2A, да и не нужно судя по моделям. TransmissionLineInverter.asc
Я так и делал обычно (только резистор ставил на выходной каскад перед линией а не после), а сейчас решил все перерасчетать и чтото не сходится. Но получается что в случае выхода по току, уменьшаются ЭМИ и потребление. звон управляется параметром Slew rate option. Но рекомендаций по волновому сопротивлению относительно скорости нарастания я не нашел.
Благодарю! Озадачился согласованием и расчетом волнового сопротивления линий для минимизации отражений и звона. Имею 100 Ом по входу (волновое тоже 100), на который подаю сигнал с ПЛИС, если я буду питать током то у меня будет маленькая амплитуда... Нашел режим PCI33, у него судя по описанию нет токового выхода, вроде как мой вариант. Скорость нарастания для тока мне считать за 0ps? параллельная тема про SLEW RATE
Подскажите где указаны частотные характеристики пина GW2A, Rise Fall параметры ищу, несколько раз смотрел ДШ не нашел.
Благодарю. А вы использовали режим загрузки битстрима через SPI внешней флешки с контроллера?
Спрашиваю потому что работал только из под винды, есть оригинальный тулз для программирования из под linux? это https://wiki.sipeed.com/hardware/en/tang/Tang-Nano-Doc/flash-in-linux.html ?
Хочу заложить JTAG прогер на плату чтобы заливать обновления в GW2A без связки программатор + EDA. Каким софтом через BL702 я могу с линуха прошить через CLI, какие варианты?
жаль только их базовый вариант ни к чему не привязан и висит особняком, а Sipeed именно на нем платы делает. По частотным характеристикам низовой продукт, будем надеется это компенсирует их цена.
я думаю это был ключевой момент позволивший группе инженеров заявить о себе как о самостоятельной компании. Беда в том что цены на их продукцию растут и стремятся выровняться с XIL/INT, это расстраивает но это больше перекупы думаю.
она есть в репозитарии?
вообще не может прошить embFlash ПЛИС. Буду пробовать через openFPGALoader, изучаю доку проблемы решил заменой папки программера на программер с сайта sipeed. И СРАМ и ФЛЕШ шьются
