Maverick_ 15 21 июля, 2013 Опубликовано 21 июля, 2013 · Жалоба Просто решил поделиться... :) LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY DIVISION IS GENERIC(SIZE: INTEGER := 64); PORT(RESET: IN STD_LOGIC; EN: IN STD_LOGIC; CLK: IN STD_LOGIC; NUM: IN STD_LOGIC_VECTOR((SIZE - 1) DOWNTO 0); DEN: IN STD_LOGIC_VECTOR((SIZE - 1) DOWNTO 0); RES: OUT STD_LOGIC_VECTOR((SIZE - 1) DOWNTO 0); RM: OUT STD_LOGIC_VECTOR((SIZE - 1) DOWNTO 0) ); END DIVISION; ARCHITECTURE BEHAV OF DIVISION IS SIGNAL BUF: STD_LOGIC_VECTOR((2 * SIZE - 1) DOWNTO 0); SIGNAL DBUF: STD_LOGIC_VECTOR((SIZE - 1) DOWNTO 0); SIGNAL SM: INTEGER RANGE 0 TO SIZE; ALIAS BUF1 IS BUF((2 * SIZE - 1) DOWNTO SIZE); ALIAS BUF2 IS BUF((SIZE - 1) DOWNTO 0); BEGIN PROCESS(RESET, EN, CLK) BEGIN IF RESET = '1' THEN RES <= (OTHERS => '0'); RM <= (OTHERS => '0'); SM <= 0; ELSIF RISING_EDGE(CLK) THEN IF EN = '1' THEN CASE SM IS WHEN 0 => BUF1 <= (OTHERS => '0'); BUF2 <= NUM; DBUF <= DEN; RES <= BUF2; RM <= BUF1; SM <= SM + 1; WHEN OTHERS=> IF BUF((2 * SIZE - 2) DOWNTO (SIZE - 1)) >= DBUF THEN BUF1 <= '0' & (BUF((2 * SIZE - 3) DOWNTO (SIZE - 1)) - DBUF((SIZE - 2) DOWNTO 0)); BUF2 <= BUF2((SIZE - 2) DOWNTO 0) & '1'; ELSE BUF <= BUF((2 * SIZE - 2) DOWNTO 0) & '0'; END IF; IF SM /= SIZE THEN SM <= SM + 1; ELSE SM <= 0; END IF; END CASE; END IF; END IF; END PROCESS; END BEHAV; простой тестбенч для проверки LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY test_div IS END test_div; ARCHITECTURE behavior OF test_div IS COMPONENT DIVISION PORT( RESET : IN std_logic; EN : IN std_logic; CLK : IN std_logic; NUM : IN std_logic_vector(63 downto 0); DEN : IN std_logic_vector(63 downto 0); RES : OUT std_logic_vector(63 downto 0); RM : OUT std_logic_vector(63 downto 0) ); END COMPONENT; signal RESET : std_logic := '0'; signal EN : std_logic := '0'; signal CLK : std_logic := '0'; signal NUM : std_logic_vector(63 downto 0) := (others => '0'); signal DEN : std_logic_vector(63 downto 0) := (others => '0'); signal RES : std_logic_vector(63 downto 0); signal RM : std_logic_vector(63 downto 0); -- Clock period definitions constant CLK_period : time := 10 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: DIVISION PORT MAP ( RESET => RESET, EN => EN, CLK => CLK, NUM => NUM, DEN => DEN, RES => RES, RM => RM ); -- Clock process definitions CLK_process :process begin CLK <= '0'; wait for CLK_period/2; CLK <= '1'; wait for CLK_period/2; end process; -- Stimulus process start_gen: process begin en <= '0'; wait for 120 ns; en <= '1'; wait; end process; reset_gen: process begin RESET <= '1'; wait for 20 ns; RESET <= '0'; wait; end process; data_gen: process begin NUM <= "0000000000000000000000000000000001000100000000000000000000000000"; DEN <= "0000000000000000000000000000000000000000101010100000000000000000"; wait; end process; END; PS Может кому-то пригодиться... ;) PS PS Будут идеи/алгоритмы как реализовать лучше, быстрее и оптимальней - пишите... PS PS PS Найдете баги - тоже пишите... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 22 июля, 2013 Опубликовано 22 июля, 2013 · Жалоба а может кто-то поделиться параметризируемым делением с фиксированной запятой? :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DASM 0 22 июля, 2013 Опубликовано 22 июля, 2013 · Жалоба PS PS Будут идеи/алгоритмы как реализовать лучше, быстрее и оптимальней - пишите... Хорошо бы еще словами объяснять в чем именно идея и в чем отличие от.. Мне VHDL честно скажу непонятен - если после С-С++ довольно спокойно стал работать с Verilog, без проблем с m-скриптами Матлаба (жаль что индексы с 1 а не с нуля), Phyton тоже нормуль, то вот в VHDL въехать не могу никак глядя на исходники (да и не очень понимаю зачем, когда баловство пройдет и нужен будет ASIC - понадобятся Verilog сурцы. Кстати скоспилировал тут конвертор VHDL2Verilog - ничего вроде так.. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 22 июля, 2013 Опубликовано 22 июля, 2013 · Жалоба Мне VHDL честно скажу непонятен - если после С-С++ довольно спокойно стал работать с Verilog, без проблем с m-скриптами Матлаба (жаль что индексы с 1 а не с нуля), Phyton тоже нормуль, то вот в VHDL въехать не могу никак глядя на исходники (да и не очень понимаю зачем, когда баловство пройдет и нужен будет ASIC - понадобятся Verilog сурцы. Кстати скоспилировал тут конвертор VHDL2Verilog - ничего вроде так.. не для холивара... я пишу на VHDL, Verilog читаю (но мне он не нравится, есть на то свои причины, но если очень нужно будет буду писать и на Verilog) :) Как говориться на вкус и цвет товарищей нет... ;) Есть довольно неплохая книга у Полякова "языки VHDL, Verilog в проектировании цифровой аппаратуры". Там приводятся все базовые конструкции для этих двух языков... Посмотрите возможно хотя бы будете читать описания на VHDL. Кстати я по этой книге Verilog научился читать... Хорошо бы еще словами объяснять в чем именно идея и в чем отличие от.. у меня здесь в принципе ничего нового, это просто по другому переписанный стандартный RestoreDiv. Количество тактов деления равна разрядности делимого/делителя, в данном алгоритме они равны... Может у Вас реализация которая быстрее выполняется (в тактах) или есть реализация, которая еще меньше кушает логики... или имеются таковые алгоритмы... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
smoke_111 0 25 июля, 2013 Опубликовано 25 июля, 2013 (изменено) · Жалоба Есть целочисленная делилка, выдающая два бита за такт. По поводу деления, посмотрите патенты компании Intel, там предложены несколько очень интересных методов. Еще попадалось что-то интересное в патентах компании Mitsubishi, если сейчас правильно помню, просто этим вопросом задавался довольно давно. Изменено 25 июля, 2013 пользователем smoke_111 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 25 июля, 2013 Опубликовано 25 июля, 2013 · Жалоба Есть целочисленная делилка, выдающая два бита за такт. По поводу деления, посмотрите патенты компании Intel, там предложены несколько очень интересных методов. Еще попадалось что-то интересное в патентах компании Mitsubishi, если сейчас правильно помню, просто этим вопросом задавался довольно давно. А Вы можете поделиться? Пожалуйста, постарайтесь вспомнить :) Очень интересно посмотреть.... upd вот ссылка на документ от интела - вроде то, о чем писал smoke_111 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
yes 8 25 июля, 2013 Опубликовано 25 июля, 2013 · Жалоба погуглить можно по словам SRT division Radix 4 division и т.п. вроде то же самое, только несколько бит за такт - сколько бит зависит от размера таблицы (look-up-table) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Serhiy_UA 1 26 июля, 2013 Опубликовано 26 июля, 2013 · Жалоба а может кто-то поделиться параметризируемым делением с фиксированной запятой? :) А какие в итоге требование к разрядности, быстродейтсвию, аппаратурным затратам, ну и семейству ПЛИС? Это для проекта или чисто теория? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 26 июля, 2013 Опубликовано 26 июля, 2013 · Жалоба А какие в итоге требование к разрядности, быстродейтсвию, аппаратурным затратам, ну и семейству ПЛИС? Это для проекта или чисто теория? целая часть - 32 разряда (но хотелось бы чтобы была возможность увеличения до 64 бит - возможно оно и никогда не понадобиться) дробная часть - 16 разряда (но хотелось бы чтобы была возможность увеличения до 32 бит - возможно оно и никогда не понадобиться) есть планы вставить в проект - для увеличения точности расчетов... ПЛИС spartan6. Сейчас используется ПЛИС 6slx16csg324-3 Быстродействие хотелось бы иметь выше 150 МГц (для модуля с целой части 32 разряда и 16 разрядов дробной части). Затраты чем меньше, тем лучше... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
smoke_111 0 6 августа, 2013 Опубликовано 6 августа, 2013 · Жалоба Прошу прощения, однако тот компонент оказался для нормализованных чисел с плавающей точкой, я посмотрел коды. Коды я выложить не могу, но принцип мне рассказать никто не мешает, для целочисленного деления он будет тем же. Если интересно, то напишу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Kuzmi4 0 6 августа, 2013 Опубликовано 6 августа, 2013 · Жалоба 2 smoke_111 пишите конечно B) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
smoke_111 0 11 октября, 2013 Опубликовано 11 октября, 2013 (изменено) · Жалоба 2 smoke_111 пишите конечно B) Долго я собирался с духом. В целом, концепция деления в столбик это алгоритм двоичного поиска, возможно это очевидно, но на всякий случай подчеркну, каждый раз вычитая мы проверяем принадлежность результата деления к той или иной стороне. Что отсюда следует, можно организовать поиск, деля область не на две части, а на 4, 8 , ну или на сколько вам позволит ваша совесть, требования к ресурсоемкости и скорости (это даст вам соответсвенно 2, 3 и т.д. разрядов за одну операцию ). Как это сделать? Приведу пример для разбиения на 4 части, для положительных чисел : Пусть N(15:0) - делимое, D(15:0) - делитель, R_i(15:0) - остаток i -й итерации Берем старшие два бита N(15:14) в параллель вычисляем следующие выражения (1)"расширяем нулями"&N(15:14) - 3*D(15:0); (2)"расширяем нулями"&N(15:14) - 2*D(15:0);(3)"расширяем нулями"&N(15:14) - D(15:0) Если (1) больше или равно нулю, то первые два бита результат деления равны "11"; если (1) меньше нуля, но (2) >=0 то первые два бита результата деления соответсвенно равны 10; Если (1) <0; (2)<0 (3)>=0, то первый два бита равны 01, если все три меньше нуля, то значит первые два бита равны нулю, Выбираем соответсвующий остаток прилепляем к нему сбоку следующие два бита делимого N(13:12) повторять описанные выше действия, до полного удовлетворения :-) Изменено 11 октября, 2013 пользователем smoke_111 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
