Не симулируется altdq
Всем добрый день.
Наткнулся на такое: есть проект, компилирую с нуля, запускаю EDA gate level simulation - все ровно, рисует как надо. Добавляю компонент altdq (параметры на рисунках), до этого в проекте такого компонента не было. Запускаю тот же EDA gate level simulation - пишет следующее (вытащил кусок лога):
Loading work.fourier_tbbb
# Loading work.soft_ldpc_st2
# Loading cycloneiii_ver.cycloneiii_pll
# Loading cycloneiii_ver.cycloneiii_m_cntr
# Loading cycloneiii_ver.cycloneiii_n_cntr
# Loading cycloneiii_ver.cycloneiii_scale_cntr
# Loading altera_ver.dffeas
# Loading cycloneiii_ver.cycloneiii_lcell_comb
# Loading cycloneiii_ver.cycloneiii_clkctrl
# Loading cycloneiii_ver.cycloneiii_mux41
# Loading cycloneiii_ver.cycloneiii_ena_reg
# Loading cycloneiii_ver.cycloneiii_io_obuf
# Loading cycloneiii_ver.cycloneiii_io_ibuf
# Loading cycloneiii_ver.cycloneiii_ram_block
# Loading cycloneiii_ver.cycloneiii_ram_register
# Loading cycloneiii_ver.cycloneiii_ram_pulse_generator
# Loading cycloneiii_ver.cycloneiii_ddio_out
# Loading cycloneiii_ver.cycloneiii_latch
# Loading cycloneiii_ver.cycloneiii_mux21
# SDF 6.5b Compiler 2009.10 Oct  1 2009
# Loading instances from test3c40_8_1200mv_85c_v_slow.sdo
# Loading altera_ver.PRIM_GDFF_LOW
# Loading timing data from test3c40_8_1200mv_85c_v_slow.sdo
# ** Warning: (vsim-WLF-5000) WLF file currently in use: vsim.wlf
#           File in use by: Пользователь  Hostname: ALEXPC  ProcessID: 4936
#           Attempting to use alternate WLF file "./wlftnniha9".
# ** Warning: (vsim-WLF-5001) Could not open WLF file: vsim.wlf
#           Using alternate file: ./wlftnniha9
# ** Error: (vsim-SDF-3261) test3c40_8_1200mv_85c_v_slow.sdo(23033): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3262) test3c40_8_1200mv_85c_v_slow.sdo(23037): Failed to find matching specify timing constraint.
# ** Fatal: (vsim-SDF-3444) Failed to annotate from SDF file "test3c40_8_1200mv_85c_v_slow.sdo".
#    Time: 0 ps  Iteration: 0  Instance: /fourier_tbbb File: D:/altera_proj/softldpc_st2/3c40_admtv803/simulation/modelsim/softldpc_tb_st2.v
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./test3c40_run_msim_gate_verilog.do PAUSED at line 12
Убираю поставленный компонент altdq, больше ничего не меняю - и опять все нормально симулируется.
Делаю вывод: не хочет моделсим симулировать altdq. При этом в логе есть такая строчка: "Loading cycloneiii_ver.cycloneiii_ddio_out"
Компиляция в обоих случаях проходит нормально, без каких-то ворнингов и даже намеков в сторону симуляции.
Как его заставить, кто-то сталкивался?
Квартус 9.1 sp2, modelsim altera 6.5b. До сих пор проблем ни с квартусом, ни с моделсимом не было...
Коллеги, хоть напишите, что, мол, делали так, работает... Непонятно то ли софт у меня глючный - переставить, то ли еще что...
Простите - вопрос - а Вы после добавления компонента (altdq) полность проводили компиляцию?? Имею ввиду - до конца, до получения файлов прошивки?? Или только синтез??
Дело в том, что я вижу в приведенных Вами логах только то, что этого самого компонента нет в файлах реальных задержек (.vo или .sdo)........
Можете провести эксперимент - отключите эти самые реальные задержки и посмотрите, симулируется или нет.
Конечно полностью, причем файл test3c40_8_1200mv_85c_v_slow.sdo реально есть, только вот похоже он из модулей внутри состоит, и модуля для altdq нет...
В RTL не симулирует, проект в графике, а ему (моделсиму) как я понимаю, надо HDL.
Именно!!
Перейдите в языковое описание проекта - и усё должно пойти..... (Что - само - не гарантирую....). И ещё - Ква иногда выбрасывает "ненужные" модули.... С Моделсимом хорошо отлаживать написанные проекты - их только синтезируют (или вообще - доверяют Моделсиму и полностью создают/работают в его среде) и лишь потом - в "железо", т.е Ква, и т.д......
Именно!!
Вряд ли в этом (в языке описания) дело. Появилась идея: если кому не лень, проверьте на квартусе выше чем 9.1. Во вложении готовый проект, там настроена сессия симуляции в моделсиме, тестбенч файл, .do файл. Поставил только вход, выход и altdq. Ситуация та же. С altdq - ругается, убираем altdq, соединяем вход с выходом - и все ок, все симулируется.
Кстати, в 9.1 тоже бы проверить не мешало, может у меня квартус или моделсим глючный...
test_altdq.rar
Просимулировал в квартус-симуляторе - все норамально, все задержки появляются, прямоугольники на выходе есть. Сделал экспорт в тестбенч файл vhdl (думал верилог не нравится моделсиму) из вейформэдитора, запустил симуляцию в моделсиме, появилась другая ошибка:
# ** Error: (vsim-SDF-3240) altdqtest_8_1200mv_85c_vhd_slow.sdo(73): Instance '/altdqtest_vhd_vec_tst/i1/\inst|altdq0_dq_plj_component|ddio_outa[0]\/ddioreg_hi' does not have a generic named 'tpd_ena_q_negedge'.
# ** Error: (vsim-SDF-3240) altdqtest_8_1200mv_85c_vhd_slow.sdo(77): Instance '/altdqtest_vhd_vec_tst/i1/\inst|altdq0_dq_plj_component|ddio_outa[0]\/ddioreg_hi' does not have a generic named 'tsetup_d_ena_noedge_negedge'.
Видно что тоже беда с компонентом altdq, но ошибка другая по сравнению с верилоговым тестом.
Ну неужто не было ни у кого такого? Остается только духов вызывать, ну и бубен, костер, все как полагается...
На всякий случай, может кому полезно будет.
Запускаю тот же проект в Q11.1 в связке с Modelsim ASE 10.0C - все отлично симулируется, без ошибок. Похоже перебираться на 11.1 придется...
А в закромах есть лекарство для моделсим альтера эдишн 10.0с (не стартер)? Чего-то не нашел... Если у кого есть, можете на мейл скинуть [email protected]?
