b-volkov 0 23 ноября, 2017 Опубликовано 23 ноября, 2017 · Жалоба Почему-то Modelsim не хочет находить сгенерированный квартусом SDF-файл. В закладке "SDF" окна "Start Simulation" выбираю файл (от реально там есть) При старте симуляции получаю следующее: vsim -L {D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver} -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb # vsim -L {D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver} -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb # Loading work.tb # Loading work.Main # Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_lcell # Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_asynch_lcell # Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_lcell_register # Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_io # Loading work.FTDIAsincModel # ** INTERNAL ERROR: mtiarOpen(): Unrecognized file path (Keratom3_v.sdo) [b]# ** Error: (vsim-SDF-3894) Keratom3_v.sdo: Compiled SDF file was not found.[/b] # Loading instances from D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo # ** Warning: (vsim-3017) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Too few port connections. Expected 26, found 22. # Region: /tb/s1 # ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPICS'. # ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIClk'. # ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIIn'. # ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIOut'. # Loading timing data from D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo [b]# ** Error: (vsim-7) Failed to open SDF file "Keratom3_v.sdo" in read mode. # No such file or directory. (errno = ENOENT)[/b] # ** Error: (vsim-SDF-3445) Failed to parse SDF file "Keratom3_v.sdo". # Time: 0 ps Iteration: 0 Instance: /tb File: D:/WORK/Altera/Keratom3_main/testbench_FIFO.v # Error loading design # Load canceled Кстати, есть еще одна непонятка: Modelsim не видит альтеровские библиотеки, которые прописаны в окне Library. vsim -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb # vsim -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb # Loading work.tb # Loading work.Main # ** Error: (vsim-3033) D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3.vo(1015): Instantiation of 'maxii_lcell' failed. The design unit was not found. # Region: /tb/s1 # Searched libraries: # D:\WORK\Altera\Keratom3_main\work # ** Error: (vsim-3033) D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3.vo(1055): Instantiation of 'maxii_lcell' failed. The design unit was not found. # Region: /tb/s1 # Searched libraries: # D:\WORK\Altera\Keratom3_main\work ... и так таких сообщений несколько десятков Но если прописать тот же самый путь в закладке Libraries окна "Start Simulation", то эти сообщения исчезают. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
andrew_b 14 23 ноября, 2017 Опубликовано 23 ноября, 2017 · Жалоба Верхний уровень (т. е. тестбенч) -- это / без всяких tb. Соответственно, sdf надо аттачить непосредственно к испытуемому модулю: vsim -sdftyp /s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb причём s1 -- это метка инстанса компонента, а не имя модуля. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
b-volkov 0 23 ноября, 2017 Опубликовано 23 ноября, 2017 · Жалоба Верхний уровень (т. е. тестбенч) -- это / без всяких tb. Соответственно, sdf надо аттачить непосредственно к испытуемому модулю: vsim -sdftyp /s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb причём s1 -- это метка инстанса компонента, а не имя модуля. Попробовал эту строку, только пришлось добавить к ней путь до библиотеки: vsim -L {D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver} -sdftyp /s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo Эффект тот же :( s1 конечно экземпляр модуля. Не знаю, может попробую поставить более новый Modelsim... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
b-volkov 0 24 ноября, 2017 Опубликовано 24 ноября, 2017 · Жалоба Установка версии 10.5 не помогла. Помог перенос SDF-файла из \simulation\modelsim в рабочую паку. Сразу заработало! Возможно, слишком длинная строка пути. Хотя файл *.vo лежит на прежнем месте,в \simulation\modelsim и нормально находится. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Shivers 0 24 ноября, 2017 Опубликовано 24 ноября, 2017 · Жалоба Попробуйте прямо в тело тестбенча вставить команду $sdf_annotate (синтаксис и примеры нагуглите). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
