GenaSPB 11 5 сентября, 2020 Опубликовано 5 сентября, 2020 (изменено) · Жалоба Проверил по-быстрому... Четыре VCP: Spoiler Connection Status Device connected Current Configuration 1 Speed Full (12 Mbit/s) Device Address 1 Number Of Open Pipes 12 Device Descriptor Storch TRX Offset Field Size Value Description 0 bLength 1 12h 1 bDescriptorType 1 01h Device 2 bcdUSB 2 0200h USB Spec 2.0 4 bDeviceClass 1 EFh Miscellaneous 5 bDeviceSubClass 1 02h Common Class 6 bDeviceProtocol 1 01h Interface Association Descriptor 7 bMaxPacketSize0 1 40h 64 bytes 8 idVendor 2 FFFFh 10 idProduct 2 4738h 12 bcdDevice 2 0102h 1.02 14 iManufacturer 1 01h "MicroGenSF" 15 iProduct 1 02h "Storch TRX" 16 iSerialNumber 1 03h "SN:19640302_122880000_2" 17 bNumConfigurations 1 01h Configuration Descriptor 1 Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 02h Configuration 2 wTotalLength 2 0111h 4 bNumInterfaces 1 08h 5 bConfigurationValue 1 01h 6 iConfiguration 1 00h 7 bmAttributes 1 C0h Self Powered 4..0: Reserved ...00000 5: Remote Wakeup ..0..... No 6: Self Powered .1...... Yes 7: Reserved (set to one) (bus-powered for 1.0) 1....... 8 bMaxPower 1 7Dh 250 mA Interface Association Descriptor Abstract Control Model Offset Field Size Value Description 0 bLength 1 08h 1 bDescriptorType 1 0Bh Interface Association 2 bFirstInterface 1 00h 3 bInterfaceCount 1 02h 4 bFunctionClass 1 02h CDC Control 5 bFunctionSubClass 1 02h Abstract Control Model 6 bFunctionProtocol 1 01h AT Commands: V.250 etc 7 iFunction 1 04h "Storch TRX CAT" Interface Descriptor 0/0 CDC Control, 1 Endpoint Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 00h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 01h 5 bInterfaceClass 1 02h CDC Control 6 bInterfaceSubClass 1 02h Abstract Control Model 7 bInterfaceProtocol 1 01h AT Commands: V.250 etc 8 iInterface 1 00h Header Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 00h Header 3 bcdCDC 2 0110h 1.10 Call Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 01h Call Management 3 bmCapabilities 1 00h 7..2: Reserved 000000.. 1: Data Ifc Usage ......0. Call management only over Comm Ifc 0: Call Management .......0 Does not handle call management itself 4 bDataInterface 1 01h Abstract Control Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 04h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 02h Abstract Control Management 3 bmCapabilities 1 02h 7..4: Reserved 0000.... 3: Connection ....0... 2: Send Break .....0.. 1: Line Coding ......1. Line Coding requests and Serial State notification supported 0: Comm Features .......0 Union Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 06h Union 3 bControlInterface 1 00h 4 bSubordinateInterface0 1 01h CDC Data Endpoint Descriptor 85 5 In, Interrupt, 255 ms Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 85h 5 In 3 bmAttributes 1 03h Interrupt 1..0: Transfer Type ......11 Interrupt 7..2: Reserved 000000.. 4 wMaxPacketSize 2 000Ah 10 bytes 6 bInterval 1 FFh 255 ms Interface Descriptor 1/0 CDC Data, 2 Endpoints Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 01h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 02h 5 bInterfaceClass 1 0Ah CDC Data 6 bInterfaceSubClass 1 00h 7 bInterfaceProtocol 1 00h 8 iInterface 1 00h Endpoint Descriptor 01 1 Out, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 01h 1 Out 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Endpoint Descriptor 81 1 In, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 81h 1 In 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Interface Association Descriptor Abstract Control Model Offset Field Size Value Description 0 bLength 1 08h 1 bDescriptorType 1 0Bh Interface Association 2 bFirstInterface 1 02h 3 bInterfaceCount 1 02h 4 bFunctionClass 1 02h CDC Control 5 bFunctionSubClass 1 02h Abstract Control Model 6 bFunctionProtocol 1 01h AT Commands: V.250 etc 7 iFunction 1 05h "Storch TRX CTL" Interface Descriptor 2/0 CDC Control, 1 Endpoint Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 02h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 01h 5 bInterfaceClass 1 02h CDC Control 6 bInterfaceSubClass 1 02h Abstract Control Model 7 bInterfaceProtocol 1 01h AT Commands: V.250 etc 8 iInterface 1 00h Header Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 00h Header 3 bcdCDC 2 0110h 1.10 Call Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 01h Call Management 3 bmCapabilities 1 00h 7..2: Reserved 000000.. 1: Data Ifc Usage ......0. Call management only over Comm Ifc 0: Call Management .......0 Does not handle call management itself 4 bDataInterface 1 03h Abstract Control Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 04h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 02h Abstract Control Management 3 bmCapabilities 1 02h 7..4: Reserved 0000.... 3: Connection ....0... 2: Send Break .....0.. 1: Line Coding ......1. Line Coding requests and Serial State notification supported 0: Comm Features .......0 Union Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 06h Union 3 bControlInterface 1 02h 4 bSubordinateInterface0 1 03h CDC Data Endpoint Descriptor 86 6 In, Interrupt, 255 ms Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 86h 6 In 3 bmAttributes 1 03h Interrupt 1..0: Transfer Type ......11 Interrupt 7..2: Reserved 000000.. 4 wMaxPacketSize 2 000Ah 10 bytes 6 bInterval 1 FFh 255 ms Interface Descriptor 3/0 CDC Data, 2 Endpoints Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 03h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 02h 5 bInterfaceClass 1 0Ah CDC Data 6 bInterfaceSubClass 1 00h 7 bInterfaceProtocol 1 00h 8 iInterface 1 00h Endpoint Descriptor 02 2 Out, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 02h 2 Out 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Endpoint Descriptor 82 2 In, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 82h 2 In 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Interface Association Descriptor Abstract Control Model Offset Field Size Value Description 0 bLength 1 08h 1 bDescriptorType 1 0Bh Interface Association 2 bFirstInterface 1 04h 3 bInterfaceCount 1 02h 4 bFunctionClass 1 02h CDC Control 5 bFunctionSubClass 1 02h Abstract Control Model 6 bFunctionProtocol 1 01h AT Commands: V.250 etc 7 iFunction 1 06h "Storch TRX EXT1" Interface Descriptor 4/0 CDC Control, 1 Endpoint Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 04h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 01h 5 bInterfaceClass 1 02h CDC Control 6 bInterfaceSubClass 1 02h Abstract Control Model 7 bInterfaceProtocol 1 01h AT Commands: V.250 etc 8 iInterface 1 00h Header Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 00h Header 3 bcdCDC 2 0110h 1.10 Call Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 01h Call Management 3 bmCapabilities 1 00h 7..2: Reserved 000000.. 1: Data Ifc Usage ......0. Call management only over Comm Ifc 0: Call Management .......0 Does not handle call management itself 4 bDataInterface 1 05h Abstract Control Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 04h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 02h Abstract Control Management 3 bmCapabilities 1 02h 7..4: Reserved 0000.... 3: Connection ....0... 2: Send Break .....0.. 1: Line Coding ......1. Line Coding requests and Serial State notification supported 0: Comm Features .......0 Union Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 06h Union 3 bControlInterface 1 04h 4 bSubordinateInterface0 1 05h CDC Data Endpoint Descriptor 87 7 In, Interrupt, 255 ms Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 87h 7 In 3 bmAttributes 1 03h Interrupt 1..0: Transfer Type ......11 Interrupt 7..2: Reserved 000000.. 4 wMaxPacketSize 2 000Ah 10 bytes 6 bInterval 1 FFh 255 ms Interface Descriptor 5/0 CDC Data, 2 Endpoints Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 05h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 02h 5 bInterfaceClass 1 0Ah CDC Data 6 bInterfaceSubClass 1 00h 7 bInterfaceProtocol 1 00h 8 iInterface 1 00h Endpoint Descriptor 03 3 Out, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 03h 3 Out 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Endpoint Descriptor 83 3 In, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 83h 3 In 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Interface Association Descriptor Abstract Control Model Offset Field Size Value Description 0 bLength 1 08h 1 bDescriptorType 1 0Bh Interface Association 2 bFirstInterface 1 06h 3 bInterfaceCount 1 02h 4 bFunctionClass 1 02h CDC Control 5 bFunctionSubClass 1 02h Abstract Control Model 6 bFunctionProtocol 1 01h AT Commands: V.250 etc 7 iFunction 1 07h "Storch TRX EXT2" Interface Descriptor 6/0 CDC Control, 1 Endpoint Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 06h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 01h 5 bInterfaceClass 1 02h CDC Control 6 bInterfaceSubClass 1 02h Abstract Control Model 7 bInterfaceProtocol 1 01h AT Commands: V.250 etc 8 iInterface 1 00h Header Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 00h Header 3 bcdCDC 2 0110h 1.10 Call Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 01h Call Management 3 bmCapabilities 1 00h 7..2: Reserved 000000.. 1: Data Ifc Usage ......0. Call management only over Comm Ifc 0: Call Management .......0 Does not handle call management itself 4 bDataInterface 1 07h Abstract Control Management Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 04h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 02h Abstract Control Management 3 bmCapabilities 1 02h 7..4: Reserved 0000.... 3: Connection ....0... 2: Send Break .....0.. 1: Line Coding ......1. Line Coding requests and Serial State notification supported 0: Comm Features .......0 Union Functional Descriptor Offset Field Size Value Description 0 bFunctionLength 1 05h 1 bDescriptorType 1 24h CS Interface 2 bDescriptorSubtype 1 06h Union 3 bControlInterface 1 06h 4 bSubordinateInterface0 1 07h CDC Data Endpoint Descriptor 88 8 In, Interrupt, 255 ms Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 88h 8 In 3 bmAttributes 1 03h Interrupt 1..0: Transfer Type ......11 Interrupt 7..2: Reserved 000000.. 4 wMaxPacketSize 2 000Ah 10 bytes 6 bInterval 1 FFh 255 ms Interface Descriptor 7/0 CDC Data, 2 Endpoints Offset Field Size Value Description 0 bLength 1 09h 1 bDescriptorType 1 04h Interface 2 bInterfaceNumber 1 07h 3 bAlternateSetting 1 00h 4 bNumEndpoints 1 02h 5 bInterfaceClass 1 0Ah CDC Data 6 bInterfaceSubClass 1 00h 7 bInterfaceProtocol 1 00h 8 iInterface 1 00h Endpoint Descriptor 04 4 Out, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 04h 4 Out 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Endpoint Descriptor 84 4 In, Bulk, 64 bytes Offset Field Size Value Description 0 bLength 1 07h 1 bDescriptorType 1 05h Endpoint 2 bEndpointAddress 1 84h 4 In 3 bmAttributes 1 02h Bulk 1..0: Transfer Type ......10 Bulk 7..2: Reserved 000000.. 4 wMaxPacketSize 2 0040h 64 bytes 6 bInterval 1 00h Изменено 5 сентября, 2020 пользователем GenaSPB Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 131 5 сентября, 2020 Опубликовано 5 сентября, 2020 · Жалоба 3 часа назад, GenaSPB сказал: Проверил по-быстрому... Четыре VCP: А МК какой? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 5 сентября, 2020 Опубликовано 5 сентября, 2020 · Жалоба В данном случае это был STM32MP153DAB Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 131 5 сентября, 2020 Опубликовано 5 сентября, 2020 · Жалоба 12 минут назад, GenaSPB сказал: В данном случае это был STM32MP153DAB... Понял. Большое спасибо. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 5 сентября, 2020 Опубликовано 5 сентября, 2020 · Жалоба На STM32H7xx можно три... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 119 12 сентября, 2020 Опубликовано 12 сентября, 2020 · Жалоба Дошли руки побаловаться. Скачал у микрософта свежий образ виртуалки W10, проверил - действительно, ставит драйвера для vcp в композитном устройстве автоматически. 05.09.2020 в 12:14, GenaSPB сказал: Ловите от того, что ранее давал (с двумя компортами). Сравнил со своими дескрипторами - все совпадает кроме 05.09.2020 в 12:14, GenaSPB сказал: 6 bFunctionProtocol 1 01h AT Commands: V.250 etc У меня тут стоит ноль. Раньше я тоже писал сюда единицу, но года два назад линух при втыкании такого устройства стал пытаться с криком "О! Модем подвезли" установить через него связь. Что в общем-то и логично. У ардуинщиков были сложности с этим по этой же причине - у них в дескрипторе этот же протокол указан. У вас упоминание тут AT commands имеет какое-то обоснование или тоже скопировано из примеров в интернете? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 12 сентября, 2020 Опубликовано 12 сентября, 2020 · Жалоба Модем тут остался случайно после безуспешных попыток получить управление dtr (или rts, не помню сейчас) через winapi. Винда просто не формирует управляющего пакета. За инфу про поведение в линуксе спасибо, уберу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 131 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 04.09.2020 в 13:42, Сергей Борщ сказал: Интересно, а можно ли использовать одну и ту же interrupt контрольную точку в нескольких виртуальных портах? Попросил товарища проверить это, в силу отсутствия железа, на котором я это хотел тестировать. Он тестировал на другом МК, но суть от этого не менялась. У меня STM32, у него LPC1768. В дескрипторах обоих виртуальных портов он указал одну и ту же физическую КТ для INTERRUPT. Проверяли на Windows 10 - работает. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 18 октября, 2020 Опубликовано 18 октября, 2020 (изменено) · Жалоба On 9/4/2020 at 7:44 PM, GenaSPB said: Windows 7 при отсутствии или фэйковой interrupt ep работает только в направлении устройства. Десятый виндовс раньше работал. После какого то обновления перестал. Напомню об результатах своих проверок Изменено 18 октября, 2020 пользователем GenaSPB Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 131 6 ноября, 2020 Опубликовано 6 ноября, 2020 · Жалоба 18.10.2020 в 22:39, GenaSPB сказал: Напомню об результатах своих проверок Никак не дает мне покоя мысль, что же такого разного могло быть между Вашей десяткой и моей... Для точного понимания предлагаю несколько определений: отсутствующая КТ - это когда в дескрипторе просто ее не указали - здесь да, не работает; фэйковая КТ - КТ, которая есть в дескрипторе, но ее физически нет в МК (например, задали номер 7, а в МК их всего 5) - не работает тоже; разделяемая КТ - КТ, которая есть в дескрипторах нескольких VCP с одним и тем же номером и которая реально есть в МК. Я полагаю, что Вы тестировали с первыми двумя пунктами? Или в моем понимании "разделяемая" - это по-Вашему тоже "фейковая"? Но, возможно, какие-то версии винды после энумерации просмотрят списки конечных точек на предмет пересечения, и тогда - печаль Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 119 6 ноября, 2020 Опубликовано 6 ноября, 2020 · Жалоба 2 часа назад, Arlleex сказал: Но, возможно, какие-то версии винды после энумерации просмотрят списки конечных точек на предмет пересечения, и тогда - печаль Тут есть некоторое наше общее недопонимание. Если я правильно помню - в посылках этой контрольной точки есть параметр "интерфейс", т.е. к какому из интерфейсов данное сообщение относится, что подразумевает возможность работы одной контрольной точки на несколько интерфейсов. Но с другой стороны, на каждый виртуальный порт вешается свой драйвер и может ли второй драйвер подцепиться к контрольной точке, к которой уже подключен другой драйвер - вопрос. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 6 ноября, 2020 Опубликовано 6 ноября, 2020 (изменено) · Жалоба Плохо работающий компорт был в случае фэйковой. Как и в случае отсутствующей (что Вы подтвердили). Разделяемую не пробовал. Для экономии с отдельными EP в STM32 делал общую память для INTERRUPT EP 20 minutes ago, Сергей Борщ said: Если я правильно помню - в посылках этой контрольной точки есть параметр "интерфейс" Откуда... Нету. Интерфейсы есть только для разбора пакетов по EP0 Изменено 6 ноября, 2020 пользователем GenaSPB Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Сергей Борщ 119 6 ноября, 2020 Опубликовано 6 ноября, 2020 · Жалоба 12 часов назад, GenaSPB сказал: Откуда... Нету. Интерфейсы есть только для разбора пакетов по EP0 Стандарт с вами не согласен: Цитата Universal Serial Bus Class Definitions for Communications Devices Revision 1.2 (Errata 1) November 3, 2010 Communications Class Interface .... Notification elements pass messages via an interrupt or bulk endpoint, using a standardized format. Messages are formatted as a standardized 8-byte header, followed by a variable-length data field. The header identifies the kind of notification, and the interface associated with the notification; it also indicates the length of the variable length portion of the message. И я тоже оговорился. Не "контрольной точки", а "конечной точки", конечно же. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 6 ноября, 2020 Опубликовано 6 ноября, 2020 · Жалоба Осталось чтобы кто-то проверид работу shared ендпоинтов... или хотя бы то, что они не мешают. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Arlleex 131 7 ноября, 2020 Опубликовано 7 ноября, 2020 · Жалоба 7 часов назад, GenaSPB сказал: Осталось чтобы кто-то проверид работу shared ендпоинтов... или хотя бы то, что они не мешают. Относительно недавно я писал о результатах. Проверяли на двух компах с десятками, и на моем домашнем с семеркой - полет нормальный. Но этого мало, нужен больший охват подопытных. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
