Alex_Golubev
Промышленный компьютер тион-про28
LCD у нас 16 бит RGB666 ссылка плюс тачь. Залез в /home/alexey/work/linux/arch/arm/boot/dts/imx28-evk.dts (ни чего не трогал)
Spoiler
// SPDX-License-Identifier: GPL-2.0+
// Copyright 2012 Freescale Semiconductor, Inc.
/dts-v1/;
#include "imx28.dtsi"
	model = "Freescale i.MX28 Evaluation Kit";
	compatible = "fsl,imx28-evk", "fsl,imx28";
	memory@40000000 {
		reg = <0x40000000 0x08000000>;
	reg_3p3v: regulator-3p3v {
		compatible = "regulator-fixed";
		regulator-name = "3P3V";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-always-on;
	reg_vddio_sd0: regulator-vddio-sd0 {
		regulator-name = "vddio-sd0";
		gpio = <&gpio3 28 0>;
	reg_fec_3v3: regulator-fec-3v3 {
		regulator-name = "fec-3v3";
		gpio = <&gpio2 15 0>;
	reg_usb0_vbus: regulator-usb0-vbus {
		regulator-name = "usb0_vbus";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		gpio = <&gpio3 9 0>;
		enable-active-high;
	reg_usb1_vbus: regulator-usb1-vbus {
		regulator-name = "usb1_vbus";
		gpio = <&gpio3 8 0>;
		enable-active-high;
	reg_lcd_3v3: regulator-lcd-3v3 {
		regulator-name = "lcd-3v3";
		gpio = <&gpio3 30 0>;
		enable-active-high;
	reg_can_3v3: regulator-can-3v3 {
		regulator-name = "can-3v3";
		gpio = <&gpio2 13 0>;
		enable-active-high;
	reg_lcd_5v: regulator-lcd-5v {
		regulator-name = "lcd-5v";
	panel {
		compatible = "sii,43wvf1g";
		backlight = <&backlight_display>;
		dvdd-supply = <&reg_lcd_3v3>;
		avdd-supply = <&reg_lcd_5v>;
		port {
			panel_in: endpoint {
				remote-endpoint = <&display_out>;
	apb@80000000 {
		apbh@80000000 {
			gpmi-nand@8000c000 {
				pinctrl-names = "default";
				pinctrl-0 = <&gpmi_pins_a &gpmi_status_cfg
					     &gpmi_pins_evk>;
				status = "okay";
			ssp0: ssp@80010000 {
				compatible = "fsl,imx28-mmc";
				pinctrl-0 = <&mmc0_8bit_pins_a
					&mmc0_cd_cfg &mmc0_sck_cfg>;
				bus-width = <8>;
				//wp-gpios = <&gpio2 12 0>;
				vmmc-supply = <&reg_vddio_sd0>;
				status = "okay";
			ssp1: ssp@80012000 {
				bus-width = <8>;
				wp-gpios = <&gpio0 28 0>;
			ssp2: ssp@80014000 {
				#address-cells = <1>;
				#size-cells = <0>;
				compatible = "fsl,imx28-spi";
				pinctrl-0 = <&spi2_pins_a>;
				status = "okay";
				flash: m25p80@0 {
					#size-cells = <1>;
					compatible = "sst,sst25vf016b", "jedec,spi-nor";
					spi-max-frequency = <40000000>;
					reg = <0>;
			pinctrl@80018000 {
				pinctrl-0 = <&hog_pins_a>;
				hog_pins_a: hog@0 {
					reg = <0>;
					fsl,pinmux-ids = <
						MX28_PAD_SSP1_CMD__GPIO_2_13
						MX28_PAD_SSP1_DATA3__GPIO_2_15
						MX28_PAD_ENET0_RX_CLK__GPIO_4_13
						MX28_PAD_SSP1_SCK__GPIO_2_12
						MX28_PAD_PWM3__GPIO_3_28
						MX28_PAD_LCD_RESET__GPIO_3_30
						MX28_PAD_AUART2_RX__GPIO_3_8
						MX28_PAD_AUART2_TX__GPIO_3_9
					fsl,drive-strength = <MXS_DRIVE_4mA>;
					fsl,voltage = <MXS_VOLTAGE_HIGH>;
					fsl,pull-up = <MXS_PULL_DISABLE>;
				led_pin_gpio3_5: led_gpio3_5@0 {
					reg = <0>;
					fsl,pinmux-ids = <
						MX28_PAD_AUART1_TX__GPIO_3_5
				gpmi_pins_evk: gpmi-nand-evk@0 {
					reg = <0>;
					fsl,pinmux-ids = <
						MX28_PAD_GPMI_CE1N__GPMI_CE1N
						MX28_PAD_GPMI_RDY1__GPMI_READY1
				lcdif_pins_evk: lcdif-evk@0 {
					reg = <0>;
					fsl,pinmux-ids = <
						MX28_PAD_LCD_RD_E__LCD_VSYNC
						MX28_PAD_LCD_WR_RWN__LCD_HSYNC
						MX28_PAD_LCD_RS__LCD_DOTCLK
						MX28_PAD_LCD_CS__LCD_ENABLE
			lcdif@80030000 {
				pinctrl-0 = <&lcdif_24bit_pins_a
					     &lcdif_pins_evk>;
				status = "okay";
				port {
					display_out: endpoint {
						remote-endpoint = <&panel_in>;
			can0: can@80032000 {
				pinctrl-0 = <&can0_pins_a>;
				xceiver-supply = <&reg_can_3v3>;
				status = "okay";
			can1: can@80034000 {
				pinctrl-0 = <&can1_pins_a>;
				status = "okay";
		apbx@80040000 {
			saif0: saif@80042000 {
				pinctrl-0 = <&saif0_pins_a>;
				status = "okay";
			saif1: saif@80046000 {
				pinctrl-0 = <&saif1_pins_a>;
				fsl,saif-master = <&saif0>;
				status = "okay";
			lradc@80050000 {
				status = "okay";
				fsl,lradc-touchscreen-wires = <4>;
				fsl,ave-ctrl = <4>;
				fsl,ave-delay = <2>;
				fsl,settling = <10>;
			i2c0: i2c@80058000 {
				pinctrl-0 = <&i2c0_pins_a>;
				status = "okay";
				sgtl5000: codec@a {
					compatible = "fsl,sgtl5000";
					reg = <0x0a>;
					#sound-dai-cells = <0>;
					VDDA-supply = <&reg_3p3v>;
					VDDIO-supply = <&reg_3p3v>;
					clocks = <&saif0>;
				at24@51 {
					compatible = "atmel,24c32";
					pagesize = <32>;
					reg = <0x51>;
			pwm: pwm@80064000 {
				pinctrl-0 = <&pwm2_pins_a>;
				status = "okay";
			duart: serial@80074000 {
				pinctrl-0 = <&duart_pins_a>;
				status = "okay";
			auart0: serial@8006a000 {
				pinctrl-0 = <&auart0_pins_a>;
				uart-has-rtscts;
				status = "okay";
			auart3: serial@80070000 {
				pinctrl-0 = <&auart3_pins_a>;
				status = "okay";
			usbphy0: usbphy@8007c000 {
				status = "okay";
			usbphy1: usbphy@8007e000 {
				status = "okay";
	ahb@80080000 {
		usb0: usb@80080000 {
			pinctrl-0 = <&usb0_id_pins_a>;
			vbus-supply = <&reg_usb0_vbus>;
			status = "okay";
		usb1: usb@80090000 {
			vbus-supply = <&reg_usb1_vbus>;
			status = "okay";
		mac0: ethernet@800f0000 {
			phy-mode = "rmii";
			pinctrl-0 = <&mac0_pins_a>;
			phy-supply = <&reg_fec_3v3>;
			phy-reset-gpios = <&gpio4 13 GPIO_ACTIVE_LOW>;
			phy-reset-duration = <100>;
			status = "okay";
		mac1: ethernet@800f4000 {
			phy-mode = "rmii";
			pinctrl-0 = <&mac1_pins_a>;
			status = "okay";
	sound {
		compatible = "fsl,imx28-evk-sgtl5000",
			     "fsl,mxs-audio-sgtl5000";
		model = "imx28-evk-sgtl5000";
		saif-controllers = <&saif0 &saif1>;
		audio-codec = <&sgtl5000>;
	leds {
		compatible = "gpio-leds";
		pinctrl-0 = <&led_pin_gpio3_5>;
		user {
			label = "Heartbeat";
			gpios = <&gpio3 5 0>;
			linux,default-trigger = "heartbeat";
	backlight_display: backlight {
		compatible = "pwm-backlight";
		pwms = <&pwm 2 5000000>;
		brightness-levels = <0 4 8 16 32 64 128 255>;
		default-brightness-level = <6>;
и не увидал RGB666 16 бит. И не понял где находятся драйвер для lcd.
Драйвер lcd находится в linux/drivers/gpu/drm/mxsfb.
Но пока советую обратить внимание на этот раздел:
	panel {
В linux/drivers/gpu/drm/panel/panel-simple.c находятся описания LCD-панелей. Найдите совместимую, и замените значение compatible в dts.
19 minutes ago, Alex_Golubev said:
После собрать командой .../buildroot$ make linux-rebuild ? А как быть с тачскрином ?
Да, и убедитесь, что imx28-evk.dtb обновился.
Для тачскрина добавьте в конце dts:
&lradc {
    status = "okay";
Quote
Это как просто изменить, сохранить, после открыть и проверить?
Вот нашел близкий дисплей et057090dhu но у него распиновка не та.
Просто дату/время по ls -l посмотреть, или упоминание во время сборки.
Совпадать должно только разрешение, тайминги и полярности.
Я вот недавно столкнулся с проблемой, просто интересно почему так.
Клонировал ядро линукса
Spoiler
git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git --branch=v4.19 --depth=1
после выполняю команду
Spoiler
make ARCH=arm mxs_defconfig
И получаю ошибку:
Spoiler
alexey@alexey:~/work/linux$ make ARCH=arm mxs_defconfig
Makefile:595: include/config/auto.conf: Нет такого файла или каталога
scripts/kconfig/conf  --syncconfig Kconfig
*** Configuration file ".config" not found!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
scripts/kconfig/Makefile:69: ошибка выполнения рецепта для цели «syncconfig»
make[2]: *** [syncconfig] Ошибка 1
Makefile:539: ошибка выполнения рецепта для цели «syncconfig»
make[1]: *** [syncconfig] Ошибка 2
Makefile:635: ошибка выполнения рецепта для цели «include/config/auto.conf»
make: *** [include/config/auto.conf] Ошибка 2
Говорит нету .config
1 minute ago, Alex_Golubev said:
А что значит [нужное в нем] ?
Точно нужен GUI module, ввод с tslib (как и сам tslib, его искать в Librares->Hardware), а вот нужна ли поддержка TIFF, SVG и т.п. - решайте сами.
Не нашел Qt (obsolete).
Spoiler
    *** Graphic applications ***                                           │ │
  │ │        *** cog needs wpewebkit and a toolchain w/ threads ***                 │ │
  │ │    [ ] fswebcam                                                               │ │
  │ │    [ ] ghostscript                                                            │ │
  │ │        *** glmark2 needs a toolchain w/ C++, gcc >= 4.9 ***                   │ │
  │ │    [ ] gnuplot        │ │
  │ │    [ ] jhead        │ │
  │ │        *** libva-utils needs a toolchain w/ C++, threads, dynamic library *** │ │
  │ │    [ ] netsurf        │ │
  │ │    [ ] pngquant                                                               │ │
  │ │    [ ] rrdtool        │ │
  │ │        *** tesseract-ocr needs a toolchain w/ threads, C++, gcc >= 4.8, dynami│ │
  │ │        *** Graphic libraries ***                                              │ │
  │ │        *** cegui06 needs a toolchain w/ C++, threads, dynamic library ***     │ │
  │ │        *** directfb needs a glibc or uClibc toolchain w/ C++, NPTL, gcc >= 4.5│ │
  │ │        *** efl needs a toolchain w/ C++, dynamic library, gcc >= 4.7, threads,│ │
  │ │    [ ] fbdump (Framebuffer Capture Tool)                                      │ │
  │ │    [ ] fbgrab        │ │
  │ │    [ ] fb-test-app                                                            │ │
  │ │        *** fbterm needs a toolchain w/ C++, wchar, locale ***                 │ │
  │ │    [ ] fbv        │ │
  │ │        *** freerdp needs a toolchain w/ wchar, dynamic library, threads, C++ *│ │
  │ │    [ ] imagemagick                                                            │ │
  │ │    [ ] linux-fusion communication layer for DirectFB multi                    │ │
  │ │        *** mesa3d needs a toolchain w/ C++, NPTL, dynamic library ***         │ │
  │ │        *** ocrad needs a toolchain w/ C++ ***                                 │ │
  │ │    [ ] psplash
 [ ] SDL        │ │
  │ │    [ ] sdl2        │ │
  │ │        *** Other GUIs ***                                                     │ │
  │ │        *** Qt5 needs a toolchain w/ wchar, NPTL, C++, dynamic library ***     │ │
  │ │        *** tekui needs a Lua interpreter and a toolchain w/ threads, dynamic l│ │
  │ │        *** weston needs udev and a toolchain w/ locale, threads, dynamic libra│ │
  │ │    [ ] X.org X Window System  ----                                            │ │
  │ │        *** midori needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host g│ │
  │ │        *** vte needs a toolchain w/ wchar, threads, C++, gcc >= 4.8 ***       │ │
  │ │        *** vte needs an OpenGL or an OpenGL-EGL/wayland backend ***           │ │
  │ │    [ ] xkeyboard-config
Сделал простую программу в qt.
Хочу вывести ее на экран.
