zorgajke 0 30 марта, 2014 Опубликовано 30 марта, 2014 (изменено) · Жалоба Доброе время суток, форумчане! Подскажите пожалуйста, в чем заключается ошибка: в созданной схеме электрической принципиальной, создаю список соединений netlist и пытаюсь подгрузить соединения в утилите PCB. В ответ получаю вот это: * Component VD2 of type VD_HOR loaded with a pattern mismatch between the library (VD_HOR) and netlist file (PATTERN) Warning: line 16 * Component VD3 of type VD_HOR loaded with a pattern mismatch between the library (VD_HOR) and netlist file (PATTERN) Warning: line 24 * Component C3 of type CONDENSATOR_VER loaded with a pattern mismatch between the library (CONDENSATOR_VER) and netlist file (PATTERN) Warning: line 32 * Component C2 of type CONDENSATOR_ELECTR_VER loaded with a pattern mismatch between the library (CONDENSATOR_ELECTR_VER) and netlist file (PATTERN) Warning: line 40 * Component VD1 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN) Warning: line 48 * Component VD6 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN) Warning: line 56 * Component VD4 of type STAB_VER loaded with a pattern mismatch between the library (STAB_VER) and netlist file (PATTERN) Warning: line 64 * Component VD5 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN) Warning: line 72 * Component K1 of type K1_VER loaded with a pattern mismatch between the library (K1_VER) and netlist file (PATTERN) Warning: line 80 * Component VT2 of type PNP_HOR loaded with a pattern mismatch between the library (PNP_HOR) and netlist file (PATTERN) Warning: line 88 * Component VT1 of type NPN_HOR loaded with a pattern mismatch between the library (NPN_HOR) and netlist file (PATTERN) Warning: line 96 * Component U14 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 104 * Component U15 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 112 * Component U16 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 120 * Component U17 of type XP loaded with a pattern mismatch between the library (XP) and netlist file (PATTERN) Warning: line 128 * Component U10 of type RESISTOR_HORIZONTAL loaded with a pattern mismatch between the library (RESISTOR) and netlist file (PATTERN) Warning: line 136 * Component U11 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 144 * Component U12 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 152 * Component U13 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Error: line 154 * Component K1.1 not loaded. No pattern is attached. Error: line 162 * Component K1.2 not loaded. No pattern is attached. Warning: line 176 * Component U18 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 184 * Component U19 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 192 * Component U5 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 200 * Component U4 of type 12 loaded with a pattern mismatch between the library (12) and netlist file (PATTERN) Error: line 202 * Component K2.1 not loaded. No pattern is attached. Warning: line 216 * Component U6 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 224 * Component U1 of type 12 loaded with a pattern mismatch between the library (12) and netlist file (PATTERN) Warning: line 232 ---------------------------------------------------------------------- 30-Mar-14 23:32 Page 1 P-CAD Net List Load Errors ====================================================================== * Component U3 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 240 * Component U2 of type CONDENSATOR_ELECTR_VER loaded with a pattern mismatch between the library (CONDENSATOR_ELECTR_VER) and netlist file (PATTERN) Warning: line 248 * Component U9 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN) Warning: line 256 * Component U8 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN) Warning: line 264 * Component VS1 of type SINIST_VER loaded with a pattern mismatch between the library (SINIST_VER) and netlist file (PATTERN) Warning: Net NET00001 has less than two nodes. Warning: Net NET00003 has less than two nodes. Error: Net NET00004: Pin 3 of VS1-3 not found. Either pin does not exist or TYPE and PATTERN are ambiguous. Warning: Net NET00005 has less than two nodes. Warning: Net NET00008 has less than two nodes. Error: Net NET00007: Pin 0 of K1-0 not found. Either pin does not exist or TYPE and PATTERN are ambiguous. Warning: Net NET00021 has less than two nodes. Net List Errors: 5 Net List Warnings: 35 Lb5.ERR.txt Изменено 30 марта, 2014 пользователем Romashkaa Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
_4afc_ 25 31 марта, 2014 Опубликовано 31 марта, 2014 · Жалоба Подскажите пожалуйста, в чем заключается ошибка: в созданной схеме электрической принципиальной, создаю список соединений netlist и пытаюсь подгрузить соединения в утилите PCB. В ответ получаю вот это: Net List Errors: 5 Net List Warnings: 35 В том что элементы в SCH не соответствуют элементам в PCB. Это возможно в двух случаях: 1. библиотеки подключенные в SCH отличаются от тех что подключены в PCB, например путями. 2. элементы в SCH или PCB взяты не из этих библиотек, а скопированы из других проектов или правились. Самое действенное средство - создать архивную библиотеку из SCH и подключить только её в PCB. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
