Всем привет, нужна помощь, я вывел на лед панель 8x8 инициалы, нужно реализовать моргание этой панели. Если конкретно: должны высветиться инициалы на секунду, потом потухнуть, потом опять высветиться и больше не мигать
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity ledc8x8 is
port (
RESET: in std_logic;
SMCLK: in std_logic;
ROW: out std_logic_vector(7 downto 0);
LED: out std_logic_vector(7 downto 0)
end ledc8x8;
architecture main of ledc8x8 is
signal active_row: std_logic_vector(7 downto 0);
signal counter_enable: std_logic;
signal counter_value: std_logic_vector (7 downto 0);
begin
-- Sem doplnte popis obvodu. Doporuceni: pouzivejte zakladni obvodove prvky
-- (multiplexory, registry, dekodery,...), jejich funkce popisujte pomoci
-- procesu VHDL a propojeni techto prvku, tj. komunikaci mezi procesy,
-- realizujte pomoci vnitrnich signalu deklarovanych vyse.
-- DODRZUJTE ZASADY PSANI SYNTETIZOVATELNEHO VHDL KODU OBVODOVYCH PRVKU,
-- JEZ JSOU PROBIRANY ZEJMENA NA UVODNICH CVICENI INP A SHRNUTY NA WEBU:
-- http://merlin.fit.vutbr.cz/FITkit/docs/navody/synth_templates.html.
-- Nezapomente take doplnit mapovani signalu rozhrani na piny FPGA
-- v souboru ledc8x8.ucf.
counter: process(RESET, SMCLK)
begin
if RESET = '1' then
counter_value <= "00000000";
elsif rising_edge(SMCLK) then
if counter_value = "11111111" then
counter_enable <= '1';
else
counter_enable <= '0';
counter_value <= counter_value + 1;
end if;
end if;
end process counter;
rotation: process(RESET, SMCLK, counter_enable)
begin
if RESET = '1' then
active_row <= "10000000";
elsif rising_edge(SMCLK) and counter_enable = '1' then
case active_row is
when "10000000" => active_row <= "01000000";
when "01000000" => active_row <= "00100000";
when "00100000" => active_row <= "00010000";
when "00010000" => active_row <= "00001000";
when "00001000" => active_row <= "00000100";
when "00000100" => active_row <= "00000010";
when "00000010" => active_row <= "00000001";
when "00000001" => active_row <= "10000000";
when others => null;
end case;
end if;
ROW <= active_row;
end process rotation;
decoder: process(active_row)
begin
case active_row is
when "00000001" => LED <= "00010111";
when "00000010" => LED <= "11010111";
when "00000100" => LED <= "11010111";
when "00001000" => LED <= "00010111";
when "00010000" => LED <= "11010111";
when "00100000" => LED <= "11010111";
when "01000000" => LED <= "11010110";
when "10000000" => LED <= "11011001";
when others => LED <= "00000000";
end case;
end process decoder;
end main;
в vhdl совсем новичок, так что прошу дополнить код, заранее благодорю
