DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Добрый день! Нужно восстановить полином (для реализации его в FPGA) по следующему алгоритму расчета CRC16 unsigned crc16_table[256] = { 0x0000,0x1189,0x2312,0x329b,0x4624,0x57ad,0x6536,0x74bf, 0x8c48,0x9dc1,0xaf5a,0xbed3,0xca6c,0xdbe5,0xe97e,0xf8f7, 0x1891,0x0918,0x3b83,0x2a0a,0x5eb5,0x4f3c,0x7da7,0x6c2e, 0x94d9,0x8550,0xb7cb,0xa642,0xd2fd,0xc374,0xf1ef,0xe066, 0x3122,0x20ab,0x1230,0x03b9,0x7706,0x668f,0x5414,0x459d, 0xbd6a,0xace3,0x9e78,0x8ff1,0xfb4e,0xeac7,0xd85c,0xc9d5, 0x29b3,0x383a,0x0aa1,0x1b28,0x6f97,0x7e1e,0x4c85,0x5d0c, 0xa5fb,0xb472,0x86e9,0x9760,0xe3df,0xf256,0xc0cd,0xd144, 0x6244,0x73cd,0x4156,0x50df,0x2460,0x35e9,0x0772,0x16fb, 0xee0c,0xff85,0xcd1e,0xdc97,0xa828,0xb9a1,0x8b3a,0x9ab3, 0x7ad5,0x6b5c,0x59c7,0x484e,0x3cf1,0x2d78,0x1fe3,0x0e6a, 0xf69d,0xe714,0xd58f,0xc406,0xb0b9,0xa130,0x93ab,0x8222, 0x5366,0x42ef,0x7074,0x61fd,0x1542,0x04cb,0x3650,0x27d9, 0xdf2e,0xcea7,0xfc3c,0xedb5,0x990a,0x8883,0xba18,0xab91, 0x4bf7,0x5a7e,0x68e5,0x796c,0x0dd3,0x1c5a,0x2ec1,0x3f48, 0xc7bf,0xd636,0xe4ad,0xf524,0x819b,0x9012,0xa289,0xb300, 0xc488,0xd501,0xe79a,0xf613,0x82ac,0x9325,0xa1be,0xb037, 0x48c0,0x5949,0x6bd2,0x7a5b,0x0ee4,0x1f6d,0x2df6,0x3c7f, 0xdc19,0xcd90,0xff0b,0xee82,0x9a3d,0x8bb4,0xb92f,0xa8a6, 0x5051,0x41d8,0x7343,0x62ca,0x1675,0x07fc,0x3567,0x24ee, 0xf5aa,0xe423,0xd6b8,0xc731,0xb38e,0xa207,0x909c,0x8115, 0x79e2,0x686b,0x5af0,0x4b79,0x3fc6,0x2e4f,0x1cd4,0x0d5d, 0xed3b,0xfcb2,0xce29,0xdfa0,0xab1f,0xba96,0x880d,0x9984, 0x6173,0x70fa,0x4261,0x53e8,0x2757,0x36de,0x0445,0x15cc, 0xa6cc,0xb745,0x85de,0x9457,0xe0e8,0xf161,0xc3fa,0xd273, 0x2a84,0x3b0d,0x0996,0x181f,0x6ca0,0x7d29,0x4fb2,0x5e3b, 0xbe5d,0xafd4,0x9d4f,0x8cc6,0xf879,0xe9f0,0xdb6b,0xcae2, 0x3215,0x239c,0x1107,0x008e,0x7431,0x65b8,0x5723,0x46aa, 0x97ee,0x8667,0xb4fc,0xa575,0xd1ca,0xc043,0xf2d8,0xe351, 0x1ba6,0x0a2f,0x38b4,0x293d,0x5d82,0x4c0b,0x7e90,0x6f19, 0x8f7f,0x9ef6,0xac6d,0xbde4,0xc95b,0xd8d2,0xea49,0xfbc0, 0x0337,0x12be,0x2025,0x31ac,0x4513,0x549a,0x6601,0x7788 }; /* compute 16 bit CCITT crc using the table */ unsigned crc16(unsigned crc,unsigned b) { unsigned ret = crc16_table[(b ^ crc) & 0xff] ^ (crc >> 8); return ret; } Хоть в коде и написано что CCITT ( == 1021), но при проверке тестовых значений на онлайн калькуляторах CRC - не совпадает :( Пробовал сравнивать с иными полиномами - тоже безуспешно. Железяка защищает этой CRC данные по HDLC Может кто-нибудь сталкивался и сможет помочь? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
MrYuran 18 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Хоть в коде и написано что CCITT ( == 1021), но при проверке тестовых значений на онлайн калькуляторах CRC - не совпадает :( А задом наперед? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба А задом наперед? Вы про данные? Крутил и так и сяк (q[7:0], q[0:7]) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
MrYuran 18 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Вы про данные? Не, про полином... (полиномы) Сдается мне, первое значение в таблице (не нулевое) и есть искомый полином. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Не, про полином... (полиномы) Сдается мне, первое значение в таблице (не нулевое) и есть искомый полином. Хм, пробовал крутить 1189 на калькуляторе http://zorc.breitbandkatze.de/crc.html В качестве тестового примера взял байт '0'==0x30 Расчет с помощью функции из первого поста дает значение 29B3 с помощью калькулятора (polynom reverse=0,data reverce=0) 1B2B (polynom reverse=0,data reverce=1) CAC6 (polynom reverse=1,data reverce=0) 9956 (polynom reverse=1,data reverce=1) B7DD Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
klop 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Когда то игрался с подобным. Вроде для реверсивного полинома надо в конце накопленные 16 бит инвертировать и байты в них местами поменять. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Когда то игрался с подобным. Вроде для реверсивного полинома надо в конце накопленные 16 бит инвертировать и байты в них местами поменять. Попробовал сделать инверсию, не помогло (или не так делаю ) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
des00 25 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Попробовал сделать инверсию, не помогло (или не так делаю ) может инициализация не правильная ? например надо с 0xFFFF начинать. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба может инициализация не правильная ? например надо с 0xFFFF начинать. Я в тестовом примере пробовал инициализацию с нуля (так именно та плата считает) те unsigned short crc = 0; crc = crc16(crc, 0x30); printf("CRC=0x%X\n"m crc); Соответственно и в калькуляторах начальное значение 0 делал. В принципе, пока из положения вышел (ПЗУ в FPGA + расчет аналогичный как в плате), но ИМХО это не сильно красиво да и свои минусы есть (либо создавать по инстансу ПЗУ для каждого контроллера (а их десятки будут, те затраты Nx256*2), либо продумывать разделение доступа к одному Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
klop 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба было приблизительно так // 0x1021 function [15:0] fn_crc_ccitt; input[15:0] crc_current; input[7:0] data; begin fn_crc_ccitt[0] = data[4] ^ data[0] ^ crc_current[8] ^ crc_current[12]; fn_crc_ccitt[1] = data[5] ^ data[1] ^ crc_current[9] ^ crc_current[13]; fn_crc_ccitt[2] = data[6] ^ data[2] ^ crc_current[10] ^ crc_current[14]; fn_crc_ccitt[3] = data[7] ^ data[3] ^ crc_current[11] ^ crc_current[15]; fn_crc_ccitt[4] = data[4] ^ crc_current[12]; fn_crc_ccitt[5] = data[5] ^ data[4] ^ data[0] ^ crc_current[8] ^ crc_current[12] ^ crc_current[13]; fn_crc_ccitt[6] = data[6] ^ data[5] ^ data[1] ^ crc_current[9] ^ crc_current[13] ^ crc_current[14]; fn_crc_ccitt[7] = data[7] ^ data[6] ^ data[2] ^ crc_current[10] ^ crc_current[14] ^ crc_current[15]; fn_crc_ccitt[8] = data[7] ^ data[3] ^ crc_current[0] ^ crc_current[11] ^ crc_current[15]; fn_crc_ccitt[9] = data[4] ^ crc_current[1] ^ crc_current[12]; fn_crc_ccitt[10] = data[5] ^ crc_current[2] ^ crc_current[13]; fn_crc_ccitt[11] = data[6] ^ crc_current[3] ^ crc_current[14]; fn_crc_ccitt[12] = data[7] ^ data[4] ^ data[0] ^ crc_current[4] ^ crc_current[8] ^ crc_current[12] ^ crc_current[15]; fn_crc_ccitt[13] = data[5] ^ data[1] ^ crc_current[5] ^ crc_current[9] ^ crc_current[13]; fn_crc_ccitt[14] = data[6] ^ data[2] ^ crc_current[6] ^ crc_current[10] ^ crc_current[14]; fn_crc_ccitt[15] = data[7] ^ data[3] ^ crc_current[7] ^ crc_current[11] ^ crc_current[15]; end endfunction // 0x8408 function [7:0] fn_reverse_data; input[7:0] data; integer i; begin for(i=0;i<8;i=i+1) fn_reverse_data[i] = data[7-i]; end endfunction function [15:0] fn_reverse_inverse_crc; input[15:0] crc; integer i; begin for(i=0;i<16;i=i+1) fn_reverse_inverse_crc[i] = ~crc[15-i]; end endfunction always@(negedge ireset or posedge cp2) begin:state_machines_seq if(!ireset)// Reset begin crc_current <= {16{1'b1}}; <<<<<<<<< Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
thermit 1 17 августа, 2011 Опубликовано 17 августа, 2011 (изменено) · Жалоба Dima_G: Хоть в коде и написано что CCITT ( == 1021), но при проверке тестовых значений на онлайн калькуляторах CRC - не совпадает sad.gif Пробовал сравнивать с иными полиномами - тоже безуспешно. Железяка защищает этой CRC данные по HDLC Может кто-нибудь сталкивался и сможет помочь? Полином правильный, табличка с алгоритмом - тоже. Инициализация регистра - 0xFFFF. В качестве CRC берется поразрядная инверсия последнего содержимого регистра. СRC посылается начиная с младшего байта. При проверке байты crc тоже обрабатываются в порядке поступления байт. Если пакет корректный - регистр должен всегда содержать константу 0xF0B8. CRC можно и не обрабатывать, но тогда придется поразрядно инвертировать последнее содержимое регистра, переставлять байты и сравнивать полученное значение с пришедшим CRC. Изменено 17 августа, 2011 пользователем thermit Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Полином правильный, табличка с алгоритмом - тоже. Инициализация регистра - 0xFFFF. В качестве CRC берется поразрядная инверсия последнего содержимого регистра. СRC посылается начиная с младшего байта. При проверке байты crc тоже обрабатываются в порядке поступления байт. Если пакет корректный - регистр должен всегда содержать константу 0xF0B8. CRC можно и не обрабатывать, но тогда придется поразрядно инвертировать последнее содержимое регистра, переставлять байты и сравнивать полученное значение с пришедшим CRC. Что-то у меня не получается.. Загоняю в функцию из первого поста 1 байт данных 0x30; Начальное значение FFFF. crc=0x5EC4 Начальное значение 0000. crc=0x29b3 Если Вам не трудно, покажите на калькуляторе ту же CRC http://zorc.breitbandkatze.de/crc.html (где стоят галки, какие поля чем заполняли) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
thermit 1 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Вот Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
DimaG 0 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Вот что-то у меня не получилось для моих данных (0х30) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
thermit 1 17 августа, 2011 Опубликовано 17 августа, 2011 · Жалоба Все нормально получается. У Вас-то что выходит? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
