wator 0 10 сентября, 2015 Опубликовано 10 сентября, 2015 · Жалоба Когда-то давно использовалась такая функция: int PLL_Init() { CSL_Status status_pllc1; CSL_PllcHwSetup hwSetup_pllc1; CSL_PllcHwSetup hwSetupRead_pllc1; // Initialize the PLLC CSL module status_pllc1 = CSL_pllcInit(0); if(status_pllc1 != CSL_SOK) return 1; // Clear local data structures memset(&pllc1, 0, sizeof(CSL_PllcObj)); // Open the PLLC CSL module hPll1 = CSL_pllcOpen(&pllc1, CSL_PLLC_1, 0, &status_pllc1); if((hPll1 == 0) || (status_pllc1 != CSL_SOK)) return 2; // Setup PLLC hardware parameters hwSetup_pllc1.divEnable = (CSL_BitMask32) CSL_PLLC_DIVEN_PLLDIV4 | CSL_PLLC_DIVEN_PREDIV | CSL_PLLC_DIVEN_PLLDIV5; hwSetup_pllc1.preDiv = 1; hwSetup_pllc1.pllM = 20; hwSetup_pllc1.pllDiv4 = 2; hwSetup_pllc1.pllDiv5 = (Uint32)0x00000002; hwSetup_pllc1.pllMode = CSL_PLLC_PLLCTL_PLLEN_PLL; status_pllc1 = CSL_pllcHwSetup(hPll1, &hwSetup_pllc1); if(status_pllc1 != CSL_SOK) { status_pllc1 = CSL_pllcClose(hPll1); return 3; } // Read back status_pllc1 = CSL_pllcGetHwSetup(hPll1, &hwSetupRead_pllc1); if(status_pllc1 != CSL_SOK) { status_pllc1 = CSL_pllcClose(hPll1); return 4; } // PLL2 Settings CSL_Status status_pllc2; CSL_PllcHwSetup hwSetup_pllc2; CSL_PllcDivideControl arg1_pllc2; CSL_PllcDivRatio arg2_pllc2; CSL_BitMask32 response_pllc2; CSL_BitMask32 argPllCtrl; // Clear local data structures memset(&pllc2, 0, sizeof(CSL_PllcObj)); // Open the PLLC CSL module hPll2 = CSL_pllcOpen(&pllc2, CSL_PLLC_2, 0, &status_pllc2); // Setup PLLC hardware parameters hwSetup_pllc2.divEnable = 0; hwSetup_pllc2.pllDiv1 = 5; hwSetup_pllc2.pllMode = CSL_PLLC_PLLCTL_PLLEN_PLL; CSL_pllcHwSetup(hPll2, &hwSetup_pllc2); // Command to enable PLLDIV4 arg1_pllc2.divNum = CSL_PLLC_DIVSEL_PLLDIV1; arg1_pllc2.divCtrl = CSL_PLLC_PLLDIV_ENABLE; CSL_pllcHwControl(hPll2, CSL_PLLC_CMD_PLLDIV_CONTROL, &arg1_pllc2); // Command to change PLLDIV1 Divider Ratio arg2_pllc2.divNum = CSL_PLLC_DIVSEL_PLLDIV1; arg2_pllc2.divRatio = 5; CSL_pllcHwControl(hPll2, CSL_PLLC_CMD_SET_PLLRATIO, &arg2_pllc2); // Set GOSET bit to change/set the dividers argPllCtrl = 0x010000; // value to set the GOSET bit CSL_pllcHwControl(hPll2, CSL_PLLC_CMD_PLLCONTROL, &argPllCtrl); // Poll for divide-ratio change and clock alignment to complete do { CSL_pllcGetHwStatus (hPll2, CSL_PLLC_QUERY_STATUS, &response_pllc2); } while (response_pllc2 & CSL_PLLC_STATUS_GO); return 0; } Правильность установки частоты проверялась на ноге GP1/SYSCLK4. Огромное спасибо! Все работает. Выручили. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
