a.graf 0 14 февраля, 2011 Опубликовано 14 февраля, 2011 · Жалоба DATE: 02-11-2011 HOTFIX VERSION: 024 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 858051 ALLEGRO_EDITOR OTHER Allegro's Help>About... System Info... doesn't work on Win7 862703 ALLEGRO_EDITOR DATABASE crash when doing a save_as 866288 ALLEGRO_EDITOR NC Drill customization table won’t let you add characters in lower case 866310 ALLEGRO_EDITOR DRC_CONSTR Testprep doesn't create a DRC for Testpoint > Component 866652 ALLEGRO_EDITOR SCHEM_FTB Allegro Spacing net class not updated with new logic Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
a.graf 0 28 февраля, 2011 Опубликовано 28 февраля, 2011 · Жалоба DATE: 02-26-2011 HOTFIX VERSION: 025 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 746063 CIS OTHER CIS Query Does not display initial search results 779588 ALLEGRO_EDITOR PLACEMENT Symbol outline not rotated with component. 805616 ALLEGRO_EDITOR ARTWORK Allegro produces warning about database extents exceed film size 843145 CONCEPT_HDL CORE Cannot copy grayed out properties in the Attributes form to the buffer 845607 ALLEGRO_EDITOR EDIT_ETCH Sliding with arc gridless enabled leaves extra segments behind and 45 degree segment. 850428 SIG_EXPLORER SIMULATION SigXP failed to simulate the topology with designlink. 853665 SPECCTRA CHECK Scheduling violations reported incorrectly. 855534 CONSTRAINT_MGR OTHER formula result does not update when length changed 855793 CONCEPT_HDL CORE Rename Pin on Block is not working in DE HDL with HF 21 856306 ALLEGRO_EDITOR INTERACTIV Modifying pad instance corrupts db 859437 SIG_INTEGRITY GUI Log Scale setting of EMS2D was cleared by re-open design. 859850 SIG_INTEGRITY GEOMETRY_EXTRACT Allegro freeze during topology extraction with EMS2D. 860366 CAPTURE CONNECTIVITY Netlist is different in V16.3 than in V16.2 860809 F2B BOM Bomhdl failed to create the design view check for existance of the packaged directory 861027 CONSTRAINT_MGR CONCEPT_HDL Unable to synchronize the constraints 862137 SIP_LAYOUT OTHER SPB 16.3 SiP Logic - Derive assignment is unable to resolve connectivity of shapes 862980 ALLEGRO_EDITOR EDIT_ETCH When sliding a via the potential DRC behaviour is inconsistent. 863400 SPIF OTHER SPIF does not translate the oblong pads correctly 864363 APD REPORTS The Wirebond report is failing because there are Non-standard Bond wires present. 864621 ALLEGRO_EDITOR DATABASE Database corrupted after adding layers in Cross Section and trying to save the board file. 865875 ALLEGRO_EDITOR MENTOR mbs2brd translator results in broken/unrouted nets even though the BoardStation design is fully routed 866202 CONSTRAINT_MGR OTHER Worksheet File import fails with error message due to character limit 866726 CONCEPT_HDL CREFER TOC (table of content) not generated in schcref_1 schematic (CREFER flattened output). 867238 CONSTRAINT_MGR INTERACTIV Split Xnet for diff pair crashes PCB editor 867696 SIP_LAYOUT DIE_STACK_EDITOR When doing an Info on this design it will crash. 867742 ALLEGRO_EDITOR DATABASE Thermal Pad view for shapefillet on Negative layer 867842 CAPTURE PROJECT_MANAGER Capture crash with 'Open File Location" 868306 CAPTURE CONNECTIVITY mirror vertically removes junction creates extra nets 869758 CAPTURE GENERATE_PART Generate Part option "Copy schematic to library" does not copy schematic page attributes 869941 ALLEGRO_EDITOR PADS_IN PADS_IN unable to import Power PCB 2005.0 file in 16.3 but works with 16.2 870301 SIP_LAYOUT SHOW_ELEM When selecting Info and then a rectangle shape, the tool will crash. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Ant_m 0 10 марта, 2011 Опубликовано 10 марта, 2011 · Жалоба Кто пробовал 25-й хотфикс? Что нибудь критичное заметили? Сейчас сижу на 22, собираюсь ставить 25... Заметил такую вещь в баглисте 23 хотфикса: 846679 ALLEGRO_EDITOR SHAPE Through Pin can not be voided correctly in dynamic shape. Что это означает? Я у себя ничего такого не замечал... И еще вопрос - а где вообще можно найти информацию про баги у текущего релиза? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 10 марта, 2011 Опубликовано 10 марта, 2011 · Жалоба В списке поправленных багов очередного хотфикса:) Ну или у разработчиков спросить, у них точно баг-лист есть. Только зачем... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 56 13 марта, 2011 Опубликовано 13 марта, 2011 · Жалоба DATE: 03-11-2011 HOTFIX VERSION: 026 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 851882 SCM SCHGEN Multiple issues with the ASA generated schematic in preserve mode while using square bracket 852063 ALLEGRO_EDITOR EDIT_ETCH What is being displayed in the HUD when a percentage is specified as a tolerance? 854502 ALLEGRO_EDITOR DRC_CONSTR DRC not detected until DBDoctor is executed. Status form and sum dwg report are incorrect. 856797 EMI RULE_CHECK Arc segments were detected as warning by bypass_plane_split. 859213 PCB_LIBRARIAN CORE $LOCATION size in PDV and DEHDL differ 860772 ADW PCBCACHE Save Shopping Cart (pcbcache) is crashing component browser 862259 SIG_INTEGRITY FIELD_SOLVERS EMS2D run twice during View Topology. 865158 ALLEGRO_EDITOR SHAPE Shapes are not voided with Dynamic Shape Fill modes with Regions 865295 PCB_LIBRARIAN CORE Part Developer crashs with symbols having Japanese notes 866095 PCB_LIBRARIAN EXPORT_OTHER Export DE HDL part to Capture Part Crashed 866835 SCM UI User arguments not used over project arguments for new tool 867102 CAPTURE LIBRARY Incorrect pin number gets assigned to pin if a PDF is opened before writng the pin number. 868092 CAPTURE GEN_BOM Capture BOM in V16.3 is different than that of V16.2 for attached test case. 868517 ALLEGRO_EDITOR ARTWORK A pinhole was made in the artwork file. 868646 ALLEGRO_EDITOR SCHEM_FTB Change in the PIN_GROUP at the chips level not propagated to the board file does not allow the swap 868844 PCB_LIBRARIAN CORE BUBBLE_GROUP with no value causes problematic symbol 869326 CIS DESIGN_VARIANT View Variant is not showing part as Do Not Stuff 869547 ALLEGRO_EDITOR SCHEM_FTB Error while parsing the alternate symbol 869931 SIG_INTEGRITY OTHER DML Library Management rewrites library longer then 512 characters into multiple lines. 869960 F2B PACKAGERXL PART_NAME property added to Export Packageable schematic parts 870392 APD EDIT_ETCH Route > Slide not performing as expected in 16.3 870704 ALLEGRO_EDITOR PARTITION 2nd import of parttiotion unplace components in master 871177 CAPTURE LIBRARY Keyboard shortcut for closing the Place Part window 871552 PSPICE SIMULATOR Pspice tool crash 871643 ALLEGRO_EDITOR INTERFACES IDF in batch and GUI for dra files fails to calculate extents correctly 871968 ALLEGRO_EDITOR COLOR After using Clear All Nets, Color Dialog box needs to be reopened for adding custom colors. 872352 APD WIREBOND Move Guide paths crashed APD. 872380 CONCEPT_HDL COMP_BROWSER DEHDL crash when editing the ppt_optionset.dat file from Part Manager. 872450 APD WIREBOND Wire to die edge angle remains highlighted in red for wire bond status window in v16.3 872787 APD WIREBOND Some Unused Wire profiles be purged but still existing in Bond Wire Profile of Color Visibility? 873217 ALLEGRO_EDITOR TESTPREP Testpoint generation not working correctly 873500 APD REPORTS Total Plating value is 0 873505 APD MANUFACTURING fillet size changed when recreate Plating Bar 873600 APD OTHER When attempting to Display Pin Names the tool takes a very long time. 874341 ALLEGRO_EDITOR OTHER "Gloss>Convert corner to arc" command made an unnecessary circular arc. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vin 0 14 марта, 2011 Опубликовано 14 марта, 2011 · Жалоба DATE: 03-11-2011 HOTFIX VERSION: 026 куда пропали все свежие апдейты с фтп? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
AlexN 0 14 марта, 2011 Опубликовано 14 марта, 2011 · Жалоба куда пропали все свежие апдейты с фтп? перешли в pub Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vin 0 15 марта, 2011 Опубликовано 15 марта, 2011 · Жалоба перешли в pub 026 в пабе нет. Если бы умеющие, переместили бы все отсюда pub - PCB - _Cadence_ - SPB163 сюда pub - PCB - _Cadence_ - CADENCE.SPB.16.30.000 - Updates, смотрелось бы логичнее. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
vin 0 16 марта, 2011 Опубликовано 16 марта, 2011 · Жалоба Положил Hotfix_SPB16.30.026 в аплоад. Благодарю rloc за файлы. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 56 25 марта, 2011 Опубликовано 25 марта, 2011 · Жалоба DATE: 03-25-2011 HOTFIX VERSION: 027 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 820901 EMI SETUP Request EMC system.conf file that can be read from CDS_SITE. 861999 ALLEGRO_EDITOR DRC_CONSTR DRC hang after padeditdb 862463 CONCEPT_HDL RF_LAYOUT_DRIVEN Rotating and Mirroring RF components in DE-HDL requires RFFLIPMODE property to be correctly updated 867223 ALLEGRO_EDITOR SHAPE Shape fill disappears when Negative shape is converted to Positive in Cross Section 868733 CONCEPT_HDL ARCHIVER ASA Archiver not saving the entire design. 871548 ALLEGRO_EDITOR MENTOR Shapes missing after mbs2brd translation 872003 SIG_EXPLORER SIMULATION TDR simulation results were different between 15.7 and 16.3. 872464 CONCEPT_HDL CORE DEHDL script works in SPB16.2 but not in SPB16.3 873772 SCM CONSTRAINT_MGR Importing a block results in subblocks coming in without properties 874335 SPECCTRA ROUTE Route Custom crashes SPECCTRA after routing for some time during "Running Route Phase". 874989 CAPTURE SCHEMATICS Schematics jumps to another page after a mouse click 875161 CAPTURE NETLISTS Creating Allegro netlist hangs Capture 875411 ALLEGRO_EDITOR NC NC drill produces Error processing extract . Program terminated. 876004 ALLEGRO_EDITOR SHAPE Unused pad suppression problem in Allegro v16.3 since S020~S024 876045 ALLEGRO_EDITOR SHAPE Oval hole drills do not void shape with hole shape drc when the regular pad is smaller than hole 876168 SPECCTRA_MENT_ IMPORT option to have a switch to prevent merging of plane layers during mbs2sp 876210 ALLEGRO_EDITOR SHAPE When updating shapes to Smooth the tool will hang. 876284 ALLEGRO_EDITOR DATABASE Executing SKILL file crashes Allegro 877057 ALLEGRO_EDITOR MENTOR Footprints are shifted when importing from boardstation 877549 SIP_LAYOUT WIREBOND Wirebonds not moving correctly when on an Interposer smaller than the die. 877862 APD WIREBOND APD crashed when add Wirebond without any dump and cannot record script. 878199 CIS DERIVE_NEW_DB_PA Change in Regional Setting causing problem in derive database 878216 APD OTHER stream_in - Stream file scan failed 878400 APD WIREBOND unable to add a wire bonding on few die pad Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 56 10 апреля, 2011 Опубликовано 10 апреля, 2011 · Жалоба DATE: 04-8-2011 HOTFIX VERSION: 028 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 704398 CONCEPT_HDL CORE In Windows mode basic shortcuts do not work when in German language 771137 ADW LRM LRM reports 'Injected Mismatch' for a value based on capitalization of ptf value 872547 CONCEPT_HDL CORE Document schematic - Published PDF is missing Bookmarks 875001 CONSTRAINT_MGR OTHER Click on the Constraint Manager selected net filter icons crash software. 875039 CONSTRAINT_MGR ANALYSIS RPD margin is not calculated in 16.3 876275 CONCEPT_HDL CONSTRAINT_MGR Constraint Manager not retaining target net 877912 APD DRC_CONSTRAINTS Shape to Shape DRC seems to be behaving inconsistenly above 90 um spacing on mcm database. 878022 CONCEPT_HDL CONSTRAINT_MGR NO_XNET_CONNECTION is not working unless defined on last discrete before receiver 878519 SIG_EXPLORER OTHER View Trace Parameter - stripline trace model display incorrect distance to the reference plane 879529 CAPTURE NETLISTS Misleading bus/pin ERROR [NET0081] message from PSpice netlist 881455 ALLEGRO_EDITOR INTERFACES Some Drill Figures missing while Exporting DXF 881711 ALLEGRO_EDITOR SCHEM_FTB Spacing constraints(Net Class) from schematic are not transferring correctly to the layout 882277 ALLEGRO_EDITOR DRC_CONSTR Get Bogus (false) "Thru Pin to shape spacing" DRC for Oval slotted pads. 882408 SCM SCHGEN Export physical fails due to netlisting error with the ASA exported schematic 882796 APD OTHER GDS stream import results in a set of bumps misplaced... possibly rotated 90 degrees Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
a.graf 0 25 апреля, 2011 Опубликовано 25 апреля, 2011 · Жалоба DATE: 04-22-2011 HOTFIX VERSION: 029 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 789198 CAPTURE PROPERTY_EDITOR Newly added user property to a symbol can not be moved on the schematic page. 812501 CAPTURE NETLIST_OTHER Extension of PADS netlist is .NET in V16.3. It should be .ASC. 842161 CIS GEN_BOM CIS standard BOM taking long time 844125 CAPTURE NETLISTS Normal and convert view placed in same design don't get netlisted due to duplicate power pin names. 847688 CAPTURE PROPERTY_EDITOR Property Editor changes selection on Display 851044 CAPTURE GEN_BOM "Export BOM report to Excel" does not appear in the Standard Bill of Material Window. 862785 CAPTURE NETLISTS RINF netlist with net attributes generetaed by capture 16.3 is not getting loaded in CADSTAR tool 868118 CAPTURE NETLIST_ALLEGRO Differential pairs not getting netlisted in hierarchical design. 869630 ALLEGRO_EDITOR DATABASE Request - support additional dielectric layers above the top conductor layer for flex designs. 880219 CIS GEN_BOM Standard CIS BOM does not viewed properly if underscore presents in Part_Number property 881792 ALLEGRO_EDITOR SHAPE Cannot Delete the Islands on the shape. No Error reported. 882128 SPECCTRA HIGHSPEED Difference in length report between Allegro and SPECCTRA 883224 SIG_INTEGRITY SIMULATION crash while reflection simulation from Constraint Manager 883291 SIG_INTEGRITY OTHER Z-axis delay causes incorrect actual values for delay 883971 APD EDIT_ETCH APD crashed when I tried to add cline in (-6674.79 -7506.74) via. 884061 CAPTURE SCHEMATIC_EDITOR multi-line text zoom doesn't work correctly 884181 ADW DBEDITOR Parts get released anyway without any errors flagged. 885019 CAPTURE GEN_BOM Create BOM causes Capture crash with include file 886437 ALLEGRO_EDITOR SHAPE Change of behavior of NET_SHORT between 16.2 and 16.3 887190 ALLEGRO_EDITOR PADS_IN getting parse error during PADS to Allegro Import 887348 ALLEGRO_EDITOR MENTOR mbs2brd translator crashing without any error message in attached testcase -v16.3s027 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 56 25 апреля, 2011 Опубликовано 25 апреля, 2011 · Жалоба DATE: 04-22-2011 HOTFIX VERSION: 029 Если я правильно понимаю, Вы можете поделиться этим Hotfix с любым желающим? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
a.graf 0 25 апреля, 2011 Опубликовано 25 апреля, 2011 · Жалоба Если я правильно понимаю, Вы можете поделиться этим Hotfix с любым желающим? Последние хотфиксы доступны на сайте http://download.cadence.com, но только для зарегистрированных пользователей. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 56 25 апреля, 2011 Опубликовано 25 апреля, 2011 · Жалоба Какой смысл тогда писать об обновлениях, если незарегистрированные пользователи все равно скачать не могут, а зарегистрированные и так все знают? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
