afe 0 25 января, 2006 Опубликовано 25 января, 2006 · Жалоба На эту (и не только тему) может быть полезнаЖ Procyon AVRlib C-Language Function Library for Atmel AVR Processors http://hubbard.engr.scu.edu/avr/avrlib/ * Byte Buffering (circular) * Bit Buffering (linear) * Printf and other formatted print functions * VT100 Terminal Output * Command Line Interface * FAT16/32 File System (support is read-only for now) * STX/ETX Packet Protocol * Fixed-Point Math Library (basic operations only) * Timers (with PWM, interrupt management) * UART (interrupt driven) * A/D Converter * I2C Master/Slave (interrupt and non-intr) * SPI Interface * External Interrupts External Hardware Device Drivers AVR Software-Emulated Devices * Character LCD Modules (HD44780-based) * I2C EEPROM Memories * SPI EEPROM Memories * MMC/SD Card Interface (SPI mode) * LIS3L02 ST Accelerometer * IDE/ATA Interface (for hard disks and CF cards) * Quadrature Encoders * RC-Servos (up to 8 channels) * STA013 MP3 Decoder Chip * GPS Receivers (via serial port) o NMEA-0813 Protocol o Trimble TSIP Protocol * Graphic LCD Modules o KS0108/HD61202 Controller o T6963 Controller o LCD Fonts and Symbols * I2c Master (Bit-Bang) * UART (software-based, timer interrupt driven) * Pulse Output (timer-based, variable frequency) * Intel-type Memory Bus (Address & Data Buses + nRD,nWR) Network Support * Device Drivers o RTL8019 Ethernet o AX88796 Ethernet o CS8900 Ethernet o Prism2 Wireless LAN * Network Protocols o ARP o ICMP o IP o UDP o DHCP * Network Stack infrastructure Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
