grinux 0 8 декабря, 2023 Опубликовано 8 декабря, 2023 (изменено) · Жалоба Всем привет. Есть плата на Allwinner H5 Cortex-A53 4 ядра. Образ для отладки в SRAM грузится нормально, но выполнения инструкций не происходит, PC не меняется, как будто ни одно ядро не активно. Чтение\запись регистров\памяти, в том числе PC выполняется нормально. Spoiler Thu Dec 07, 2023 16:48:48: Serial number: 941000024 Thu Dec 07, 2023 16:48:48: JTAG speed is initially set to: 1000 kHz Thu Dec 07, 2023 16:48:48: Software reset was performed Thu Dec 07, 2023 16:48:48: Initial reset was performed Thu Dec 07, 2023 16:48:48: TotalIRLen = 4, IRPrint = 0x01 Thu Dec 07, 2023 16:48:48: JTAG chain detection found 1 devices: Thu Dec 07, 2023 16:48:48: #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP Thu Dec 07, 2023 16:48:48: DPv0 detected Thu Dec 07, 2023 16:48:48: Scanning AP map to find all available APs Thu Dec 07, 2023 16:48:48: AP[2]: Stopped AP scan as end of AP map has been reached Thu Dec 07, 2023 16:48:48: AP[0]: AHB-AP (IDR: 0x64770001) Thu Dec 07, 2023 16:48:48: AP[1]: APB-AP (IDR: 0x44770002) Thu Dec 07, 2023 16:48:48: Iterating through AP map to find APB-AP to use Thu Dec 07, 2023 16:48:48: AP[0]: Skipped. Not an APB-AP Thu Dec 07, 2023 16:48:48: AP[1]: APB-AP found Thu Dec 07, 2023 16:48:48: No AP map specified by user. Setting auto-detected AP map. Thu Dec 07, 2023 16:48:48: Scanning ROMTbl @ 0x80000000 Thu Dec 07, 2023 16:48:48: [0]Comp[0] @ 0x81000000: ROM Table Thu Dec 07, 2023 16:48:48: Scanning ROMTbl @ 0x81000000 Thu Dec 07, 2023 16:48:48: [1]Comp[0] @ 0x81010000: Cortex-A53 Thu Dec 07, 2023 16:48:48: [1]Comp[1] @ 0x81020000: CSS600-CTI Thu Dec 07, 2023 16:48:48: Core found. Stopped ROM table scan: https://wiki.segger.com/ROMTableScan Thu Dec 07, 2023 16:48:48: Cortex-A53 @ 0x81010000 (detected) Thu Dec 07, 2023 16:48:48: CoreCTI @ 0x81020000 (detected) Thu Dec 07, 2023 16:48:48: Debug architecture: ARMv8.0 Thu Dec 07, 2023 16:48:48: 6 code breakpoints, 4 data breakpoints Thu Dec 07, 2023 16:48:48: Processor features: Thu Dec 07, 2023 16:48:48: EL0 support: AArch64 + AArch32 Thu Dec 07, 2023 16:48:48: EL1 support: AArch64 + AArch32 Thu Dec 07, 2023 16:48:48: EL2 support: AArch64 + AArch32 Thu Dec 07, 2023 16:48:48: EL3 support: AArch64 + AArch32 Thu Dec 07, 2023 16:48:48: FPU support: Single + Double + Conversion Thu Dec 07, 2023 16:48:48: Add. info (CPU temp. halted) Thu Dec 07, 2023 16:48:48: Current exception level: EL1 Thu Dec 07, 2023 16:48:48: Exception level AArch usage: Thu Dec 07, 2023 16:48:48: EL0: AArch32 Thu Dec 07, 2023 16:48:48: EL1: AArch32 Thu Dec 07, 2023 16:48:48: EL2: AArch32 Thu Dec 07, 2023 16:48:48: EL3: AArch32 Thu Dec 07, 2023 16:48:48: Non-secure status: Non-secure Thu Dec 07, 2023 16:48:48: Cache info: Thu Dec 07, 2023 16:48:48: Inner cache boundary: none Thu Dec 07, 2023 16:48:48: LoU Uniprocessor: 1 Thu Dec 07, 2023 16:48:48: LoC: 2 Thu Dec 07, 2023 16:48:48: LoU Inner Shareable: 1 Thu Dec 07, 2023 16:48:48: I-Cache L1: 32 KB, 256 Sets, 64 Bytes/Line, 2-Way Thu Dec 07, 2023 16:48:48: D-Cache L1: 32 KB, 128 Sets, 64 Bytes/Line, 4-Way Thu Dec 07, 2023 16:48:48: Unified-Cache L2: 512 KB, 512 Sets, 64 Bytes/Line, 16-Way Thu Dec 07, 2023 16:48:48: Found 1 JTAG device, Total IRLen = 4: Thu Dec 07, 2023 16:48:48: #0 Id: 0x5BA00477, IRLen: 4, IRPrint: 0x1 CoreSight JTAG-DP Thu Dec 07, 2023 16:48:48: Loaded debugee: tst64.out Thu Dec 07, 2023 16:48:48: 300 bytes downloaded (97.66 Kbytes/sec) Thu Dec 07, 2023 16:48:48: Download completed. Thu Dec 07, 2023 16:48:48: Software reset was performed Thu Dec 07, 2023 16:48:48: Target reset Thu Dec 07, 2023 16:48:48: Warning: Vector catch is not supported for this CPU core Изменено 8 декабря, 2023 пользователем grinux Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jcxz 210 8 декабря, 2023 Опубликовано 8 декабря, 2023 · Жалоба 6 минут назад, grinux сказал: Всем привет. Есть плата на Allwinner H5 Cortex-A53 4 ядра. Образ для отладки в SRAM грузится нормально, но выполнения инструкций не происходит, PC не меняется, как будто ни одно ядро не активно. Чтение\запись регистров\памяти, в том числе PC выполняется нормально. Может вы к неактивному ядру коннектитесь? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
grinux 0 8 декабря, 2023 Опубликовано 8 декабря, 2023 (изменено) · Жалоба 8 minutes ago, jcxz said: Может вы к неактивному ядру коннектитесь? Может, а как это понять? После подачи питания на плату отрабатывает встроенный бутлоадер. Далее через J-Link commander убедился, что текущий режим выполнения Aarch32. Выбрал в настройках IAR нужное ядро, режим 32bit. Компильнул пустой main, залил средствами Iar. В дизассембере вижу годные инструкции. PC стоит там, где нужно. Возможно нужно какие то дополнительные манипуляции совершить перед\после загрузки образа, чтобы активировать нужное ядро? Изменено 8 декабря, 2023 пользователем grinux Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
