CubeMx settings causes HAL delay to be faster then usual STM32F407 descovery
Hello, I am using CUBEMX to define the clock of the periphery but when i used the HAL delay function  i got the HAL_ delay be 100 times smaller.
In the manual 1000 input is 1 second in HAL delay.
How do i see the effect of the diagram bellow on the HAL DELAY function?
I read about systick maybe affecting it.i am having trouble to link the CUBEMX diagram bellow and systic and delay of HAL_delay.
Can i have a logical link between those elements?
Thanks.
Изменено пользователем sergei94
Thanks.
You should figure out which clock is used for the delay counting. Modifying the clock value in the Cube configuration you may adjust the delay.
By the way using delays in a real-time application is a bad practice.
