jenya7 0 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 1 hour ago, Alex-lab said: Вы определите, что по вашему значит отбросить. Для меня это заменить нулем. Это сделать нельзя. вот код ребят от ST. сам ПИД. //This is called from TIM3 update interrupt. defined in input.c void updatePid() { uint32_t abs_position_error; int32_t position_delta; int32_t position_delta_delta; static uint8_t prevdir; //getEncoderCount(); this is dangerous to call from interrupt if (!motor_running) { pid_integrated_error=0; return; } position_error = encoder_count - pid_requested_position; position_delta= pid_requested_position - pid_last_requested_position; position_delta_delta = position_delta - pid_last_requested_position_delta; pid_last_requested_position = pid_requested_position; pid_last_requested_position_delta = position_delta; if(abs(position_error)> max_error) max_error = abs(position_error); abs_position_error = abs(position_error); if (abs_position_error > s.max_error) { pwm_motorStop(); ERROR_LED_ON; return; } //P int32_t output = position_error * s.pid_Kp; //I pid_integrated_error += position_error * s.pid_Ki; if (pid_integrated_error > 400000) pid_integrated_error = 400000; if (pid_integrated_error < -400000) pid_integrated_error = -400000; output += pid_integrated_error; //D output += (position_error - pid_prev_position_error) * s.pid_Kd; pid_prev_position_error = position_error; //FF1 output += position_delta * s.pid_FF1; //FF2 output += position_delta_delta * s.pid_FF2; output /= 100; //provide larger dynamic range for pid. (without this, having pid_Ki = 1 was enough for oscillation. //limit output power if (output > MAX_DUTY) output = MAX_DUTY; if (output < -MAX_DUTY) output = -MAX_DUTY; if(output>0) { dir=0; } else { dir=1; } duty = abs(output); } таймер TIM3 настроен на вызов ПИД. void TIM3_IRQHandler(void) { if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) { if(s.inputMethod==inputMethod_stepDir) { updatePid(); TIM_ClearITPendingBit(TIM3, TIM_IT_Update); } else { TIM_ClearITPendingBit(TIM3, TIM_IT_Update); updateCtr++; if(updateCtr>50) { //pwm_motorStop(); //ERROR_LED_ON; } } } не вижу где dt вступает в игру. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex-lab 4 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 1 minute ago, jenya7 said: не вижу где dt вступает в игру. Там где идет инициализация таймера. Задается значение регистра CCR или ARR. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 1 hour ago, Alex-lab said: Там где идет инициализация таймера. Задается значение регистра CCR или ARR. void initPid() { pid_requested_position=encoder_count; pid_integrated_error = 0; pid_prev_position_error =0; //TIM3 used for pid loop timing. RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_TimeBaseStructure.TIM_Prescaler = 72; //1MHz counter TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = 250; //4kHz update interval TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE); TIM_Cmd(TIM3, ENABLE); NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } как? в выходной PWM добавляется dt? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex-lab 4 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба Just now, jenya7 said: TIM_TimeBaseStructure.TIM_Period = 250; //4kHz update interval Вот тут. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 1 hour ago, Alex-lab said: Вот тут. но это же константа. константу всегда можно выбросить, не? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex-lab 4 18 октября, 2020 Опубликовано 18 октября, 2020 · Жалоба 1 minute ago, jenya7 said: константу всегда можно выбросить Лично вам точно можно. Разрешаю. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
