kot-begemot72 0 9 февраля, 2019 Опубликовано 9 февраля, 2019 · Жалоба Yokogawa VC3300 wireless communication tester опции: /G GSM /HD1 WDCMA/HSDPA /C1 GPIB ЦЕНА 45 000 руб. г.Екатеринбург тел.8-912-26-32-327 [email protected] Возможна отправка по РФ WCDMA (UMTS) part GSM part General specifications General specifications Item Specifications Item Specifications Band UARFCN Band ARFCN 1 9612 to 9888 0 to 124 9262 to 9538 Frequency GSM900/DCS1800 2 955 to 1023 12 to 287 512 to 885 3 8562 to 8913 (BCCH/TCH) 128 to 251 Frequency 8562 to 8763 GSM850/PCS1900 4 512 to 810 (Reception) 1162 to 1362 4123 to 4233 Downlink transmission section 782 to 787 5 807 to 812 Item Specifications 837, 862 Frequency offset -75 to +75kHz (resolution 1kHz) (TXRXmode only) 4162 to 4188 -120.0 to -10.0 dBm (resolution 0.1dBm) 6 Transmission power 812, 837 Accuracy: ±1.0dB (>-110.0 dBm) Downlink transmission section Uplink reception section Item Specifications Item Specifications -120.0 to -10.0 dBm (resolution 0.1dBm) Maximum input level +35dBm (CW), +40dBm (GSM single burst) Transmission power Reception power Accuracy: ±1.0dB (>-110.0 dBm) Minimum sensitivity -40 dBm Modulation accuracy 4% or less (when trasmitting DPCH 1ch) Measurement range -40 dBm to +35 dBm Power measurement Accuracy ±1.0 dB Uplink reception section mPheaasseu reermroernt RMeesaisduurael merernotr range pAepapkro 0x..5 1 t.o4 4d5e.g0 (drmegs, vrmalus e0).5 to 20.0 deg Item Specifications Frequency error Measurement range 0 to ±10 kHz Maximum input level +35dBm Reception power measurement Residual error ±0.01 ppm Minimum sensitivity -70 dBm Measurement range -70 dBm to +35 dBm Power measurement Accuracy ±1.0 dB Measurement function EVM Residual EVM 3% rms Typical (input level >-30 dBm) Item Frequency error Measurement range 0 to ±10 kHz Location update measurement Residual error ±0.01 ppm Call setup/release Emergency call Signaling function Measurement function Frequency handover System handover Item Dialing number display Registration Speech function PN signal transmission and voice loop back Call setup/release Transmission power Test loop (RMC 12.2k) Frequency error Signaling function Emergency call Phase error (rms and peak) Frequency handover Burst timing System handover Spectrum (modulation) Offset 100,200,250,400 to 1800 (step 200) kHz Dialing number display Radio characteristics Spectrum (switching) Offset 400, 600, 1200 to 1800 kHz measurement Speech function PN signal transmission and voice loop back RX quality (UE report) Transmission power RX level (UE report) Frequency error FER (loopback) Modulation accuracy BER (loopback) Open loop power control Actual MS power level Inner loop power control 1 dB step and 2 dB step Radio characteristics measurement Transmission OFF power Model Suffix code Description ON/OFF time mask Occupied bandwidth 733020 VC3300 Main frame Spectrum emission mask Power cable -D UL and CSA Adjacent channel leakage power ratio ±5 MHz and 10 MHz -F VDE Bit error rate -Q BS -R AS Base unit general specifications Options -H /G*1 GGBSM test software pre-install Item Specitications /E*1*2 GSM/GPRS/EDGE test software pre-install Input/output impedance 50Ω(Typical) /W*1 WCDMA test software pre-install RF input/output Maximum input power 4W /C1*2 GPIB Interface connector type N Input frequency 10 MHz ±3ppm Model Description External reference Input impedance 5 kΩ(Typical) frequency(REF IN) Connector type BNC Display 8.4 inch color TFT LCD Interface 100BASE-TX, RS232, GPIB(option)* External dimensions 426(W) x 177(H) x 300(D) [mm] Weight Approx. 10kg Supply voltage 100 to 120 VAC/200 to 240 VAC Power supply frequency 50/60Hz Maximum power 250 VA or less Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
kot-begemot72 0 14 марта, 2019 Опубликовано 14 марта, 2019 · Жалоба UP Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Oliver MacDonald 0 14 февраля, 2021 Опубликовано 14 февраля, 2021 · Жалоба Hello, I am looking to get a copy of the user manual cd for the yokogawa vc3000. Are you able to provide and how much would it cost. Thank you. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
