Перейти к содержанию
Yokogawa VC3300 wireless communication tester
опции: /G GSM /HD1 WDCMA/HSDPA /C1 GPIB
ЦЕНА 45 000 руб.
г.Екатеринбург
тел.8-912-26-32-327
[email protected]
Возможна отправка по РФ
WCDMA (UMTS) part GSM part
General specifications General specifications
Item Specifications Item Specifications
Band UARFCN Band ARFCN
1 9612 to 9888 0 to 124
9262 to 9538 Frequency GSM900/DCS1800
2 955 to 1023
12 to 287 512 to 885
3 8562 to 8913 (BCCH/TCH) 128 to 251
Frequency 8562 to 8763 GSM850/PCS1900
4 512 to 810
(Reception) 1162 to 1362
4123 to 4233
Downlink transmission section
782 to 787
5
807 to 812 Item Specifications
837, 862 Frequency offset -75 to +75kHz (resolution 1kHz) (TXRXmode only)
4162 to 4188 -120.0 to -10.0 dBm (resolution 0.1dBm)
6 Transmission power
812, 837 Accuracy: ±1.0dB (>-110.0 dBm)
Downlink transmission section Uplink reception section
-120.0 to -10.0 dBm (resolution 0.1dBm) Maximum input level +35dBm (CW), +40dBm (GSM single burst)
Transmission power Reception power
Accuracy: ±1.0dB (>-110.0 dBm) Minimum sensitivity -40 dBm
Modulation accuracy 4% or less (when trasmitting DPCH 1ch) Measurement range -40 dBm to +35 dBm
Power measurement
Accuracy ±1.0 dB
Uplink reception section mPheaasseu reermroernt RMeesaisduurael merernotr range pAepapkro 0x..5 1 t.o4 4d5e.g0 (drmegs, vrmalus e0).5 to 20.0 deg
Item Specifications Frequency error Measurement range 0 to ±10 kHz
Reception power measurement Residual error ±0.01 ppm
Minimum sensitivity -70 dBm
Measurement range -70 dBm to +35 dBm
Power measurement
Accuracy ±1.0 dB Measurement function
EVM Residual EVM 3% rms Typical (input level >-30 dBm) Item
Frequency error Measurement range 0 to ±10 kHz Location update
measurement Residual error ±0.01 ppm Call setup/release
Emergency call
Signaling function
Measurement function Frequency handover
System handover
Item Dialing number display
Registration Speech function PN signal transmission and voice loop back
Call setup/release Transmission power
Test loop (RMC 12.2k) Frequency error
Signaling function Emergency call Phase error (rms and peak)
Frequency handover Burst timing
System handover Spectrum (modulation) Offset 100,200,250,400 to 1800 (step 200) kHz
Dialing number display Radio characteristics Spectrum (switching) Offset 400, 600, 1200 to 1800 kHz
measurement
Speech function PN signal transmission and voice loop back RX quality (UE report)
Transmission power RX level (UE report)
Frequency error FER (loopback)
Modulation accuracy BER (loopback)
Open loop power control Actual MS power level
Inner loop power control 1 dB step and 2 dB step
measurement Transmission OFF power Model Suffix code Description
ON/OFF time mask
Occupied bandwidth 733020 VC3300 Main frame
Spectrum emission mask Power cable -D UL and CSA
Adjacent channel leakage power ratio ±5 MHz and 10 MHz -F VDE
Bit error rate -Q BS
-R AS
Base unit general specifications Options -H /G*1 GGBSM test software pre-install
Item Specitications /E*1*2 GSM/GPRS/EDGE test software pre-install
Input/output impedance 50Ω(Typical) /W*1 WCDMA test software pre-install
RF input/output Maximum input power 4W /C1*2 GPIB Interface
connector type N
Input frequency 10 MHz ±3ppm Model Description
External reference
Input impedance 5 kΩ(Typical)
frequency(REF IN)
Connector type BNC
Display 8.4 inch color TFT LCD
Interface 100BASE-TX, RS232, GPIB(option)*
External dimensions 426(W) x 177(H) x 300(D) [mm]
Weight Approx. 10kg
Supply voltage 100 to 120 VAC/200 to 240 VAC
Power supply frequency 50/60Hz
Maximum power 250 VA or less
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Hello,
I am looking to get a copy of the user manual cd for the yokogawa vc3000.  Are you able to provide and how much would it cost.
Thank you.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
